VW Transporter t5 ABS control module coding
Michaelhare
C?ID=259134
Hi all I'm trying to code in a new abs control module but I have tried going into the abs module but its says no communication.
I have run a full scan which I have added.
any help would be great
many thanks
          57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ7H140551   Mileage: 238030km-147904miles
   Part No SW: 038 906 016 AJ    HW: 038 906 016 AJ
   Component: R4 1,9L EDC  000SG  9713
   Revision: --H05---    Serial number: VWZ7Z0G5298551
   Coding: 0000031
   Shop #: WSC 02736 790 00000
   VCID: 5CB033E29C467CAFA5-5178
005705 - Powertrain Data Bus
               P1649 - 000 - Missing Message from ABS Controller
                    Fault Frequency: 14
                    Mileage: 238039 km
                    Speed: 4.0 km/h
                    Voltage: 11.55 V
                    Bin. Bits: 11000100
                    Torque: 0.0 Nm
                    Bin. Bits: 00000000
005661 - Glowplug for Cylinder 4 (Q13)
               P161D - 000 - Open Circuit
                    Fault Status: 01110000
                    Mileage: 238039 km
                    Speed: 4.0 km/h
                    Voltage: 11.48 V
                    Bin. Bits: 11000100
                    Temperature: 17.1°C
                    Bin. Bits: 00110000
012295 - Camshaft Position Sensor (G40)
               P3007 - 000 - No Signal - Intermittent
                    Fault Status: 00110000
                    Mileage: 238039 km
                    RPM: 168 /min
                    Speed: 4.0 km/h
                    Load: 40.0 %
                    Voltage: 11.02 V
                    Bin. Bits: 11000000
                    Idle Stabilization: 0.0°KW
                    (no units): 32.0
Readiness: 1 2 0 0 0
Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
   Part No: 7H0 937 049 R
   Component: BORDNETZ SGVER 1.0  1101
   Coding: 0000004
   VCID: 418EE2961BE43147D6-515A
00925 - Fuse (30) for Interior Lamps (S261)
            014 - Defective
            013 - Check DTC Memory
   Part No: 1C0 909 605 A
   Component: 3B AIRBAG VW51      0010
   Coding: 13122
   Shop #: WSC 02736
   VCID: 224C4D1AAEA20A5FAF-515A
Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
   Part No: 7H0 920 951 T
   Coding: 00413
   Shop #: WSC 00082
   VCID: 3D769E66371C55A7B2-515A
   WV1ZZZ7HZ7H140551     VWZ7Z0G5298551
            49-00 - No Communications
01304 - Radio
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 02736
   VCID: 70E8775230CEE8CF69-515A
01304 - Radio
Address 46: Central Conv.        Labels: 7H0-959-433.lbl
   Part No: 7H0 959 433 B
   Component: CXL Komfortgerát     0004
   Coding: 00021
   Shop #: WSC 02736
   VCID: 326CBD5AFE429ADF5F-4B32
            52-10 - Supply Voltage Too High - Intermittent
01312 - Powertrain Data Bus
            79-00 - Please Check Fault Codes
End-------------------------(Elapsed Time: 06:30)--------------------------
Your ECU also thinks the ABS module is off-line. Check fuses, and power/ground at ABS module.
I agree, per the scans via e-mail 03 wasn't online either so checking power/grounds to the ABS is the best place to start.
Although unlikely, you might want to make sure the lack of a factory 56-Radio in the scan isn't related to communication issues in any way.
P.S. This should be a ESP MK25E1 system so post the scan with 03 communicating when you get to that point. We should be able to build that coding for you.
Michaelhare
C?ID=259134
thank you for your replies I will have a look and report back
