Audi A5 2011 Gearbox Malfunktion!
Samson
Sweden
C?ID=229490
Hello All!
I have a Audi A5 with multiple error codes from gearbox, and message on dashboard regarding "Gearbox Malfunction"
Gearbox goes into fail safe mode from time to time and the customer can restart it after 5 minutes or so and then drive it for a while.
I have tried to find solution on some forums but just become confused about repair methode, so I try this way.
Kind regard and thanks in advance
Monday,23,September,2019,13:04:40:01232
VCDS Version: 19.6.1.0 (x64)
VIN: WAUZZZ8T4CA011899   License Plate: MSA673
Mileage: 143420km-89117mi   Repair Order:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 62 69 72
          77
VIN: WAUZZZ8T4CA011899   Mileage: 143420km-89117miles
Address 01: Engine (------CDNC)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115     HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0008
   Revision: ECH09---
   Coding: 1A250013243601022000
   Shop #: WSC 10017 002 1048576
   ASAM Dataset: EV_ECM20TFS0118K5907115 001010
   ROD: EV_ECM20TFS0118K5907115.rod
   VCID: 6FD59001B699DC3770-803A
8172 - Selector Lever
          P0919 00 [032] - Malfunction
                    Mileage: 143400 km
                    Date: 2018.09.20
                    Time: 14:55:28
                    Engine speed: 836.00 /min
                    Normed load value: 9.8 %
                    Vehicle speed: 18 km/h
                    Coolant temperature: 96 °C
                    Intake air temperature: 32 °C
                    Voltage terminal 30: 14.512 V
   Part No SW: 8K1 927 156 P    HW: 0B5 927 156 F
   Component: 0B5 20TFSIRdW H10 0008
   Revision: --H10---    Serial number: 0000000228
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501 A02196
   ROD: EV_TCMDL501.rod
   VCID: 42B309B5D58B015FCF-8016
17598 - Selector Lever Sensor
          P179E 00 [032] - Electrical Malfunction
                    Reset counter: 39
                    Mileage: 143398 km
                    Date: 2018.09.20
                    Time: 14:53:08
                    Engine speed: 1565 /min
                    Transmission input speed: 1565 /min
                    Transmission output speed: 606 /min
                    Engine torque: 20 Nm
                    Transmission fluid temperature: 49 °C
                    Accelerator position: 10.4 %
                    Clutch status: Kupplung 2 kann Moment übertragen
                    Voltage terminal 30: 15.100 V
                    Supply voltages of sensors: status-Sensor Supply SV1: sensor supply correct
                    Supply voltages of sensors: status-Sensor Supply SV2: sensor supply correct
                    Supply voltages of sensors: status-Sensor Supply SV3: sensor supply correct
                    Sensors for driving mode: error status-FID 149: passive or deactive
                    Sensors for driving mode: error status-FID 161: passive or deactive
                    Sensors for driving mode: error status-FID 162: passive or deactive
                    Sensors for driving mode: error status-FID 163: passive or deactive
                    Sensors for driving mode: error status-FID 164: passive or deactive
                    Sensors for driving mode: error status-FID 165: passive or deactive
                    Sensors for driving mode: error status-FID 166: passive or deactive
                    Sensors for driving mode: error status-FID 167: passive or deactive
                    Sensors for driving mode: error status-FID 168: passive or deactive
                    Sensors for driving mode: error status-FID 169: passive or deactive
                    Sensors for driving mode: lock of diagnostics-FID 149: not locked
                    Sensors for driving mode: lock of diagnostics-FID 161: not locked
                    Sensors for driving mode: lock of diagnostics-FID 162: not locked
                    Sensors for driving mode: lock of diagnostics-FID 163: not locked
                    Sensors for driving mode: lock of diagnostics-FID 164: not locked
                    Sensors for driving mode: lock of diagnostics-FID 165: not locked
                    Sensors for driving mode: lock of diagnostics-FID 166: not locked
                    Sensors for driving mode: lock of diagnostics-FID 167: not locked
                    Sensors for driving mode: lock of diagnostics-FID 168: not locked
                    Sensors for driving mode: lock of diagnostics-FID 169: not locked
                    W006_Vwh_PrzWh_Whs1-Data: 38.70 %
                    W007_Vwh_PrzWh_Whs2-Data: 95.85 %
17601 - Selector Lever Sensor
          P179F 00 [032] - Malfunction
                    Reset counter: 39
                    Mileage: 143398 km
                    Date: 2018.09.20
                    Time: 14:53:02
                    Engine speed: 1600 /min
                    Transmission input speed: 1600 /min
                    Transmission output speed: 621 /min
                    Engine torque: 108 Nm
                    Accelerator position: 22.0 %
                    Sensors for driving mode: lock of diagnostics-FID 169: currently locked
                    W007_Vwh_PrzWh_Whs2-Data: 40.90 %
   Part No SW: 8K0 907 379 BS    HW: 8K0 907 379 BS
   Component: ESP8 quattro  H09 0090
   Coding: 09DD4C
   VCID: 0B2DE491AA418017FC-805E
                    Fault Status: 00101101
                    Reset counter: 41
                    Mileage: 143400 km
                    Date: 2018.09.20
                    Time: 14:55:28
                    Hex Value: 0x1340
                    Hex Value: 0x4006
                    Hex Value: 0x121A
                    Hex Value: 0x02B8
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 EE    HW: 8K0 907 064 EE
   Component: BCM2 2.0      H10 0530
   Coding: 01A40000000000000000
   VCID: 77C5A861C6C994F7A8-8022
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H60 0072
   Serial number: 0511000061596008
   Component: J764 ELV MLB  H39 0046
   Serial number: 2311000234718004
                    Reset counter: 41
                    Mileage: 143400 km
                    Date: 2018.09.20
                    Time: 14:55:33
   Part No SW: 8K1 820 043 L    HW: 8K1 820 043 L
   Component: KLIMA 1 ZONE  H02 0033
   Revision: A1000000    Serial number: 01251020110903
   Coding: 642002C000
   VCID: 31515679682D8AC726-8064
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 AH
   Component: BCM1 1.0      H14 0103
   Revision: 08014001    Serial number: 00000326047802
   Coding: 2600C0108034AFC00081400300001D0D0F1C630826090201000004000400030100000024000000
   Shop #: WSC 40480 222 82201
   VCID: 78C7AB5DCBD79B8FA1-802C
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 201011  H15 0070
   Serial number: SWF11100200218
   Coding: 00FD11
   Component: G397_RLFS  H06 0001
   Serial number: 10026070
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001310111404
   Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H02 0002
   Serial number: FC2803D5000000000001
                    Reset counter: 41
                    Mileage: 143400 km
                    Date: 2018.09.20
                    Time: 14:55:33
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H44 0610
   Serial number: 003KFD805B6
   Coding: 30523938363030303030554A304C38543053
   VCID: 48A71B9DF3B72B0F11-801C
   Serial number: 6334MSME6422792DI
   Serial number: 6344MSME6433313B8
   Serial number: 6352QSME62673468J
   Serial number: 6362QSME62672648J
   Serial number: 63732SME16612C66$
   Serial number: 63832SME5967205E5
Address 16: Steering wheel        Labels: None
   VCID: 5599C2E9BC0586E79A-8000
   Part No SW: 8T0 920 930 B    HW: 8T0 920 930 B
   Component: KOMBIINSTR.   H23 0639
   Revision: 00000000    Serial number: JS1361EAC
   Coding: 1307310003010008010000
   VCID: 355962699C45A6E77A-8060
Address 19: CAN Gateway
DrPeter
16.4905° S, 151.7375° W
Thank you for posting your question and the Auto-Scan. The fault codes below can set when there is a concern with the G676-Gear Sensor.
ref:
P179E 00 - Selector Lever Sensor: Electrical Malfunction
P179F 00 - Selector Lever Sensor: Malfunction
- Factory documentation states that "In the event of a fault, the gearbox switches to emergency mode. Once the vehicle comes to a standstill, no gear can be engaged."
- You can use VCDS to check the Advanced Measuring Values in the [02-Auto Trans] to try and evaluate the Selector Lever values/G676.
Have a look at the [Selector lever position] and [Transmission position], then try and see if these value changes when attempting to shift after clearing the fault code.
Once the concern has been corrected, you will need to calibrate the G676, please see this Ross-Tech wiki page ...
7-Speed S-Tronic Direct-Shift Gearbox (DSG/0B5)
This fault code in the [01-Engine] controller is for information purposes and will clear when the concern in the [02-Auto Trans] has been corrected.
P0919 - Selector Lever: Malfunction
Bye the way...
There is a TSB/TPI document that maybe helpful too. Official Factory Repair Information This document makes mention of the replacement of the G676 sensor.
Technical product information, Transaction No.: 2027068
Gearbox in emergency operation (P179E, P179F) - 0B5 gearbox
If the Mechatronic controller is replaced, it will be necessary for the vehicle to have the end-of-line programing / Parameterization, this is completed with an online connection to the manufacture, VCDS does not perform these online functions at this time.
Hope this helps,
drpeter
Golftwincharged
Guyana
C?ID=320847
I've had 3 occasions with this same fault code/s and indeed , confirmed this is the fault of the G676 sensor which needs replacing, unforntuately its quite some work to have replaced, which requires special tools, Good luck!
Samson
Sweden
C?ID=229490
OK, thanks! My suspicion was also that it concerned the sensor deep inside the gearbox after reading a lot with help from doctor Google. I will talk with the customer to see what will happen next.
I have already performed the basic setting of the gearbox a couple of weeks ago and after that it started to work OK for a while. But since two weeks it came back
Thanks for your help.
Have a nice weekend
//Kjell
IronMike021
Canada
C?ID=346674
DrPeter,
I recently had the exact same codes come up on my 2013 Audi S7. Took it into the Audi dealership and they said since the code was 'intermittent' to continue driving until it becomes more of a problem. Reading thru Ross Tech forums (and others), it's pretty clear that my Selector lever G676 will have to be replaced sooner or later. Most information I have read indicate the GEARBOX MALFUNCTION fault keeps coming back, getting progressive worse over time as the sensor fails. The dealer was kind enough to quote me a figure of $9800.00 (Cdn) to replace the faulty sensor!!!
My question is, since this is the first event or GEARBOX MALFUNCTION is there any value in calibrating the G676 sensor as described in the link you provided above? Basically, I'm hoping to get as much mileage out of the transmission before I have to take it in and spend a lot of money. Any advice you can provide would be greatly appreciate, thank you in advance.
Kindly, Mike
IronMike021
Canada
C?ID=346674
Here is the scan:
Tuesday,19,November,2019,17:37:05:49106
Dealer/Shop Name: Mike
VIN: WAUW2CFC6DN0   License Plate:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 28 34 36 3B 3C 42 44
          46 47 52 53 55 56 5F 62 6C 6D 72 82 84 85 8B 8E 8F 90 A9 BA
VIN: WAUW2CFC6DN0xxxxx   Mileage: 97943km-60858miles
Address 01: Engine (------CEUC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 906 014 B    HW: 4H0 906 014
   Component: 4.0l V8TFSI / H56 0009
   Revision: NCH56---
   Coding: 1A2500326546000E1000
   Shop #: WSC 56360 001 1048576
   ASAM Dataset: EV_ECM40TFS0114G0906014B 001009
   ROD: EV_ECM40TFS0114G0906014B.rod
   VCID: 211FE6132142172FE57-8074
          P0919 00 [044] - Malfunction
                    Mileage: 97942 km
                    Date: 2019.11.19
                    Time: 16:27:15
                    Engine speed: 664.00 /min
                    Normed load value: 7.5 %
                    Coolant temperature: 99 °C
                    Intake air temperature: 70 °C
                    Voltage terminal 30: 14.017 V
                    Engine status: COENG_RUNNING
Readiness: 1010 1101
   Part No SW: 4G1 927 156 S    HW: 0B5 927 156 J
   Component: 0B5 40TFSINAR H01 0011
   Revision: --H01---
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 3D273A63BDFA53CFE1F-8068
          P179F 00 [044] - Malfunction
                    Mileage: 97942 km
                    Date: 2019.11.19
                    Time: 16:27:15
                    Engine speed: 662 /min
                    Transmission input speed: 662 /min
                    Engine torque: 4 Nm
                    Transmission fluid temperature: 78 °C
                    Accelerator position: 0.0 %
                    Clutch status: Beide Kupplungen offen
                    Voltage terminal 30: 14.600 V
                    W006_Vwh_PrzWh_Whs1-Data: 51.15 %
                    W007_Vwh_PrzWh_Whs2-Data: 55.25 %
   Part No SW: 4G0 907 379 J    HW: 4G0 907 379 J
   Component: ESP PREMIUM   H09 0361
   Coding: 65B64F03A66DF2C04B00
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 38292B7792D876E7329-806C
0486 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Ldm_ApbFailureState]
                    Reset counter: 182
                    Mileage: 97942 km
                    Date: 2019.11.19
                    Time: 16:26:06
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 02
                    F-Type: 04
                    Uz: B8
0712 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [SCL_GE_Waehlhebel_Error]
                    Reset counter: 182
                    Mileage: 97942 km
                    Date: 2019.11.19
                    Time: 16:26:06
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 02
                    Bit Info 4: 1F
                    F-Path: 00
                    F-Type: C4
                    Uz: B7
   Part No SW: 4H0 907 064 CR    HW: 4H0 907 064 CR
   Component: BCM2 2.0      H32 0421
   Coding: 0D8A2006000000000000
   VCID: 7BA3F47BE3EE9DFF9FB-802E
   Serial number: 2312000150030007
                    Reset counter: 182
                    Mileage: 97942 km
                    Date: 2019.11.19
                    Time: 16:26:09
   Part No SW: 4G0 820 043 AE    HW: 4G0 820 043 AE
   Component: KLIMA 4 ZONEN H13 0076
   Serial number: 18071200110859
   Coding: 688320B85D
   ASAM Dataset: EV_AirCondiComfoUDS 002036
   VCID: 629DA91F64C44C37BCD-8036
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001559283
   Coding: 0D072012073E8FE2A90008C7A0003820CF9CD308A2090221800308457B00
   VCID: 6FBBD02BA796F15F233-803A
   Component: WWS57X 120621  H36 0080
   Serial number:         120711121033
   Coding: 0045F7
   Serial number: 20431503
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 H    HW: 4G0 941 531 H
   Component: E1 - LDS  H07 0044
   Serial number: 18 07 2012  00000508
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R2B2X02
   Subsystem 5 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A31 LED Mod1L  H02 0002
   Serial number: 00000000001205243627
   Subsystem 6 - Part No SW: 4G0 907 472     HW: 4G0 907 472
   Component: A27 LED Mod1R  H02 0002
   Serial number: 00000000001205250346
   Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA103815000001585443
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 21184A36000000000001
   Subsystem 9 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A32 LED Mod2L  H02 0002
   Serial number: 00000000001205251802
   Subsystem 10 - Part No SW: 4G0 907 472 A    HW: 4G0 907 472 A
   Component: A28 LED Mod2R  H02 0002
   Serial number: 00000000001205252274
                    Reset counter: 182
                    Mileage: 97942 km
                    Date: 2019.11.19
                    Time: 16:26:00
   Part No SW: 4H0 919 475 AG    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0072
   Revision: 11001001    Serial number: 61061219102434
   Coding: A8C909
   ASAM Dataset: EV_EPHVA18AU57X0000 003008
   ROD: EV_EPHVA18AU57X0000_003.rod
   VCID: 77ABE84BDF46B99FFB3-8022
   Part No SW: 4G0 907 561 A    HW: 4G0 907 561
   Component: ACC3          H21 0410
   Coding: 7601010101
   Shop #: WSC 53164 001 1048576
   ASAM Dataset: EV_AdaptCruisContrAU57X 002010
   VCID: 2809FB374278E667A29-807C
105984 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_EPB_FAIL]
                    Reset counter: 182
                    Mileage: 97942 km
                    Date: 2019.11.19
                    Time: 16:26:06
                    Voltage terminal 15: 14.065 V
140288 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_ECD_FAIL]
                    Reset counter: 182
                    Mileage: 97942 km
                    Date: 2019.11.19
                    Time: 16:26:06
103936 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_GPOS_FAIL]
                    Reset counter: 182
                    Mileage: 97942 km
                    Date: 2019.11.19
                    Time: 16:26:06
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H32 0032
   Revision: --------    Serial number: 003D8002901-
   Coding: 30314531313130303036554A304C34473853
   VCID: 33331C5B8BBE95BF07B-8066
   Serial number: 3575HRB404R1G0QM897R
   Serial number: 3585HRB405P1F0BCEPIY
   Serial number: 3515JRB400O4UJ4OIA3$
   Serial number: 3525JRB40144UJ4Q697E
   Serial number: 3554VRB405J1AP623HGM
   Serial number: 3564VRB40671AP6249A%
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372MBR001R3
   Coding: 00043C
   Shop #: WSC 91445 999 124038
   VCID: 38292B77925876E7329-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Component: E221 - MFL  H08 0009
   Serial number: 22 05 2012  B0179581
   Part No SW: 4G8 920 932 L    HW: 4G8 920 932 L
   Component: TBenRdwAccNv  H76 0515
   Revision: 28460207    Serial number: 658120712596040
   Coding: 0B8F01079F430008020300
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU57.rod
   Part No SW: 4G0 907 468 AB    HW: 4G0 907 468 AA
   Component: J533--Gateway H10 0028
   Revision: --------    Serial number: 00000000613503
   Coding: 00E1034800
   ASAM Dataset: EV_GatewPkoUDS 001013
   VCID: 70B9D357BA28EEA73A9-8024
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790856198
   Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H15 0013
   Serial number: 001007120001004
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
   VCID: 270BF80B4F66E91FAB3-8072
   Part No SW: 4G0 919 158 K    HW: 4G0 919 158 K
   Component: KLIMA FOND    H07 0076
   Serial number: 17071200040938
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002018
   VCID: 372B284B9FC6799F3B3-8062
   Part No SW: 4G0 907 553 F    HW: 4G0 907 553 F
   Component: LUFE-DAEMPFER H18 0782
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003024
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2E050D2F609CB857685-807A
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000034181668
   Coding: 00581B0000002001000001010101102030303232203232
   VCID: 77ABE84BDFC6B99FFB3-8022
   Component: SARA 6D red   H02 0053
   Revision: --------    Serial number: EJ1BPA7E002P32
   ASAM Dataset: EV_SARA2 005011
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 J    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0060
   Revision: 00H02000    Serial number: 6PZ 010 287-08
   Coding: 0000003
   VCID: 3635254F944C8097205-8062
   Subsystem 1 - Part No: 4G0 907 568 J
   Component: J770  SWA Slave H02 0060
   Subsystem 2 - Serial number: 6PZ 010 287-28
   Subsystem 3 - Serial number: 5F17.07.1200H02000AMS15016ÿ
   Subsystem 4 - Serial number: S15016ÿ
   Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
   Component: TSG FA        H04 0506
   Coding: 011F57025E00628002000413
   VCID: 45D75283D5AA1B0FB9F-8010
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0005703681
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D195F74A49CB70CD-8066
   Revision: 00002001    Serial number: 0180421318
   Coding: 0126063A20FAF08582B00A80020102000000000000000000000000000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000098322
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO17256735
   Coding: 101F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00001757627
   Subsystem 5 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0028
   Serial number: WA103990000001765559
                    Reset counter: 182
                    Mileage: 97942 km
                    Date: 2019.11.19
                    Time: 16:26:09
   Part No SW: 4G1 035 223 A    HW: 4G1 035 223 A
   Component: BOSE-G3C7-ANC H02 0540
   Revision: CJ002700    Serial number: 00000000002474
   Coding: 030000
   VCID: 1C61D7E706A03AC7361-8048
   Component: TSG BF        H03 0506
   Coding: 011F57025E00628002000402
   VCID: 46D5558FE8AC1017B05-8012
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000420220
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B03043B538ECD7F4FB-807E
461056 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FC_SIGNAL_GE_WAEHLHEBEL_ERROR_VALUE]
                    Reset counter: 182
                    Mileage: 97942 km
                    Date: 2019.11.19
                    Time: 16:26:06
                    Voltage terminal 30: 14.2 V
                    Internal Fault ID: 145
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Set
                    Status ParkingBrake right: Set
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 120723-0001-048
   Coding: 12236F601002A200
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C0107275680CA47461-8078
   Part No SW: 4G0 035 082 D    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0112
   Revision: AB001007    Serial number: 156G.0C7616523
   Coding: 020007010000000001
   VCID: 211FE61321C2172FE57-8074
   Part No SW: 4G0 035 664 B    HW: 4G0 035 664 B
   Component: H-BN-NA       H49 0549
   Revision: --------    Serial number: 193G-0C7502374
   Coding: 0A0200040203FDEF75168F0E00000003F00001020000000000
   VCID: 2517F20335EAFB0F99F-8070
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDC94023Q4J
   Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
   Component: E380 BDT C7  H11 0204
   Serial number: 90349LGC001CO
   Subsystem 4 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
   Component: TSG HL        H03 0506
   Coding: 010F17024000628002000002
   VCID: 49CF5EB3F9B2FF6F5D7-801C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H06---    Serial number: 525 PA8J26G52V
   Coding: 1080013
   VCID: 2615F50F44ECF017905-8072
   Part No SW: 4G8 959 107 P    HW: 4G8 959 107 G
   Component: HDSG-Modul    H13 0039
   Revision: 12013001    Serial number: 154200716
   Coding: 0A3305C102
   ASAM Dataset: EV_HDSGAu573 001014
   ROD: EV_HDSGAu571.rod
   VCID: 42DD499FC4042C379CD-8016
   Component: TSG HR        H03 0506
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4G8 919 604 G    HW: 4G8 919 604 G
   Component: HeadUpDisplay 010 0106
   Coding: DA0000
   ASAM Dataset: EV_HUDContiC7 001020
   ROD: EV_HUDContiC7.rod
Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
   Part No SW: 4H0 907 547 F    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H09 0042
   Serial number: 0K84AE40076998
   Coding: 1411
   ASAM Dataset: EV_NightVisioGen1 001002
   ROD: EV_NightVisioGen1.rod
   Night vision system camera:
   Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
   Component: NV-CAM-Gen1  H08 0007
   Serial number: 00000000001218400025
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H25 0038
   Coding: EA060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2615F50F486CF017905-8072
   Part No SW: 4G0 907 541 A    HW: 4G0 907 541
   Component: ACC3          H17 0400
   Coding: 7601010101
   ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
          U1113 00 [008] - -
                    Reset counter: 182
                    Mileage: 97942 km
                    Date: 2019.11.19
                    Time: 16:26:06
                    Control Module temperature: 25 °C
                    Voltage terminal 15: 14.089 V
                    Velocity_vehicle_reference: -0.00 m/s
          U1113 00 [008] - -
                    Reset counter: 182
                    Mileage: 97942 km
                    Date: 2019.11.19
                    Time: 16:26:06
          U1113 00 [008] - -
                    Reset counter: 182
                    Mileage: 97942 km
                    Date: 2019.11.19
                    Time: 16:26:06
   Part No SW: 4G0 907 107 D    HW: 4H0 907 107
   Component: BV-SG         H30 0038
   Serial number: 005000051607127
   Coding: 03819A1A0111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   Coding: 0066E608031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 313F165371A2A7AF757-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0010
   Serial number: 120710201073
   Part No SW: 4H0 907 145     HW: 4H0 907 145
   Component: AEM - LEAR    H05 0006
   Revision: 00001001    Serial number: 97804000524904
   ASAM Dataset: EV_AEMLearAU64X 002014
   ROD: EV_AEMLearAU64X_AU57.rod
   VCID: 6695B50F88EC3017505-8032
End----(Elapsed Time: 02:59, VBatt start/end: 12.0V/11.9V. VIgn 11.8V)-----
In regards to "did you JPPSG useful life warranty yet and how your vehicle was certified to comport with delivery or importation to Canada?", I don't understand your question, if you could please clarify.
Regards, Mike
NostraJackAss
Hello Mike,
America is currently closed, did you read what the words mean in the JPPSG or the Webster's Dictionary and than legal dictionary, wouldn't that make things more clear?
