Tuesday,24,September,2019,12:16:31:59660
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZF35K1064225 License Plate: FY301KH
Mileage: 1415km-879mi Repair Order:
Chassis Type: F3-AU37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 3C 42 44 4B 52 5F 75 A5 BB BC
CF D6 D7
VIN: WAUZZZF35K1064225 Mileage: 1415km-879miles
CF-Lane Chge Asst 2 -- Status: Malfunction 0010
Address 01: Engine (J623-DFGA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 QQ HW: 04L 907 309 P
Component: R4 2.0l TDI H26 6579
Revision: B4H26---
Coding: 0225001203641D082000
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TDI01104L906026QQ 004006
ROD: EV_ECM20TDI01104L906026QQ.rod
VCID: 094F9CB8E9B7D28F9D7-805C
34193 - Implausible Data Received from ESP Control Module
U0416 00 [032] - -
Mileage: 48 km
Date: 2019.07.31
Time: 00:00:54
Coolant temperature: 35 ∞C
Intake air temperature: 29 ∞C
Voltage terminal 30: 12.140 V
Unlearning counter according OBD: 12
Engine status: COENG_READY
Part No SW: 0GC 300 044 G HW: 0GC 927 711 H
Component: GSG DQ381 H06 2401
Revision: 00H06V08
ROD: EV_TCMDQ381061_VW37.rod
VCID: 2C01052C0685A7A7461-8078
Part No SW: 5Q0 614 517 EF HW: 5Q0 614 517 BP
Component: ESC H35 0107
Revision: 00000000 Serial number: 61239000002157
Coding: 14FF6A7F30260B7089790E0262C84828560CD091704612F21861F074923B4A0B00002E64121A03102F35351919323200
VCID: 79AFEC78B957C20F8D7-802C
0297 - Steering Angle Sensor
B1168 F2 [008] - Not Initialized
Reset counter: 42
Mileage: 48 km
Date: 2019.07.31
Time: 00:00:53
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 83A 820 043 HW: 83A 820 043
Component: AC Automat H04 0021
Revision: 20026000 Serial number: 00000000156075
Coding: 070001040020100010010000000010000000000000000000
ASAM Dataset: EV_AirCondiFrontVaAU326 001003
ROD: EV_AirCondiFrontVaAU326.rod
VCID: 5DE798E80DBF1E2F81F-8008
Subsystem 1 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: CAB197A900PAG0MUFU02
Part No SW: 5Q0 937 084 DC HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H38 0273
Serial number: 01001912902255
ASAM Dataset: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 7CA1F56CB665F727961-8028
Subsystem 1 - Part No SW: 83B 955 119 HW: 83B 955 119
Component: J400FRWISCH 062 0030
Serial number: 890153F0401833500989
Coding: 5DC72F
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 22906365X81A955555A0
Coding: 00005D
Subsystem 3 - Part No SW: 4K1 941 501 D HW: 4K1 941 501 D
Component: E1 - LTM H05 0053
Serial number: 16S02.05.1900301906
Subsystem 4 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY190640486
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000031029251
Steering Column Switch:
Subsystem 6 - Part No SW: 82A 953 521 H HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0070
Serial number: 00000005051920240014
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5QA 919 283 C HW: 5QA 919 283
Component: PDC 4 KanalH07 0050
Serial number: 000308419619119
Coding: 0601040011
ASAM Dataset: EV_EPHVA14AU3700000 009037
ROD: EV_EPHVA14AU3700000_009.rod
VCID: 4ACD63B4AC31999754D-801E
13637426 - Databus
Reset counter: 42
Mileage: 48 km
Date: 2019.07.31
Time: 00:00:54
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 Q HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0342
Coding: 3200E71158FF8728747C61458050A700080000000000000000
ASAM Dataset: EV_ACCMRRCONTIVW376 003015
ROD: EV_ACCMRRCONTIVW376_003_VW37.rod
VCID: 42DD4B94940141D79CD-8016
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Reset counter: 42
Mileage: 48 km
Date: 2019.07.31
Time: 00:00:54
Voltage terminal 15: 12.0 V
Control Module temperature: 28 ∞C
Vehicle speed: 0.00 m/s
Longitudinal acceleration: 0.00 m/s≤
Adaptive distance regulation: status: ACC_StandBy
2055 - Databus
[FAULT_ALP_STEERINGWHEEL_INIT]
Reset counter: 42
Mileage: 48 km
Date: 2019.07.31
Time: 00:00:58
Voltage terminal 15: 12.3 V
Control Module temperature: 29 ∞C
Longitudinal acceleration: 0.53 m/s≤
Adaptive distance regulation: status: ACC_reversible_error
0800 - Databus
[FAULT_SWA_RELEVANT_ERROR]
Reset counter: 42
Mileage: 48 km
Date: 2019.07.31
Time: 00:00:54
1389 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[FAULT_VBAT_BUSMON_LOW]
Reset counter: 42
Mileage: 48 km
Date: 2019.09.08
Time: 23:47:21
Voltage terminal 15: 9.5 V
Control Module temperature: 20 ∞C
Longitudinal acceleration: -0.06 m/s≤
Adaptive distance regulation: status: ACC_Init
Part No SW: 5Q0 959 655 BN HW: 5Q0 959 655 BN
Component: AirbagVW21 007 0403
Serial number: 003FHR57ARYG
Coding: 88CCF0C000000000985400DFC048005400C5
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 0D47A8A89DDFCEAFB1F-8058
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1040
Serial number: 83A857705C0134T01873
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1040
Serial number: 83A857706C0135T01726
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 480 000 905 19
Serial number: 35700000000205052C31
Subsystem 4 - Part No SW: ----------- HW: 480 000 905 19
Serial number: 35800000000CF4052C3Q
Subsystem 5 - Part No SW: ----------- HW: 480 400 405 19
Component: SideSensor_Dr 005 6149
Serial number: 3510001B6EE9B783913K
Subsystem 6 - Part No SW: ----------- HW: 480 400 405 19
Component: SideSensor_Pr 005 6149
Serial number: 3520001B6EE9B783B8D/
Subsystem 7 - Part No SW: ----------- HW: 480 401 204 19
Component: FrontSensor_D 004 6149
Serial number: 3550001022B7DBE2C57E
Front Sensor Passenger:
Subsystem 8 - Part No SW: ----------- HW: 480 401 204 19
Component: FrontSensor_P 004 6149
Serial number: 3560001022B7DBE2C36C
1050117 - Databus
Reset counter: 42
Mileage: 48 km
Date: 2019.07.31
Time: 00:00:58
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 83A 920 700 HW: 83A 920 700
Component: KOMBI H11 1712
Coding: 018501086F8800080480E0401000000000000000
ASAM Dataset: EV_DashBoardVDDMQBA0 001027
ROD: EV_DashBoardVDDMQBA0_VW37.rod
VCID: 5EE59FE400B90537985-800A
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_Audio_0x31 keine Kommunikation]
Reset counter: 42
Mileage: 49 km
Date: 2019.07.30
Time: 16:13:24
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 04051910521654
Coding: 030100041F0873005B10005C180B00000001010000000000000000000000
ROD: EV_GatewNF.rod
VCID: 6E85CF24F01995B7285-803A
Component: 1-01-13-01-04
Subsystem 2 - Part No SW: 83A 951 523 A HW: 83A 951 523 A
Component: J453 MFL H07 0004
Serial number: 20190319114002 31170
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 9523611205
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 G HW: 3Q0 907 566
Component: MRR1Rear H25 0530
Revision: --------
Coding: 00C002
VCID: 3C21356CF6E53727D61-8068
1188165 - Databus
[databus unreasonable message - LWI_Lenkradwinkel]
Reset counter: 42
Mileage: 48 km
Date: 2019.07.31
Time: 00:00:54
Control Module temperature: 26 ∞C
Voltage terminal 30: Measured value not available
Vehicle speed: 0.00 km/h
Terminal 15 status: Measured value not available
Voltage terminal 15: 12.00 V
267010 - Databus
[FAULT_SLAVE]
Reset counter: 42
Mileage: 48 km
Date: 2019.07.31
Time: 00:00:54
Voltage terminal 15: 11.80 V
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS001 0287
Serial number: YE007SD809694
Coding: 001E0A005000008000001012
VCID: 44D14D8C8E154FE7AE1-8010
Address 44: Steering Assist (J500) Labels:| 5Q0-910-143.clb
Part No SW: 5Q0 910 143 C HW: 5Q0 910 143
Component: MQB_VWBS_GEN2 212 2211
Serial number: 920048 00
Coding: 0100001100500010
ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
VCID: 2B030630038BA09F4FB-807E
5262656 - Steering Angle Sensor
Reset counter: 42
Time: 00:00:00
Write only channel
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 03051910803892
Coding: 000000050900196A00022303000000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW41.rod
VCID: 35372048D5CFE66F29F-8060
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS001 0287
Serial number: YE007SD627574
Coding: 001E0A005C00008000001010
VCID: 43D34E908B1B48DF97B-8016
Part No SW: 83A 035 064 A HW: 83A 035 064
Component: MU-H-LN-EU 046 2493
Coding: 01230601FF0A020041110001000800102F00016401700800CE
ROD: EV_MUHigGen2pALPI_AU37.rod
VCID: 1F1BE2E047334C3FD33-804A
Subsystem 1 - Part No: V03 959 804 BH
Component: MIB2P_EU_Q119 0360
Subsystem 2 - Part No SW: 83A 919 605 B HW: 83A 919 605 B
Component: DU AU326 High H42 0133
Serial number: MA48X1AEA0157142
Component: Gracenote2 1008
Volume Control 1:
Subsystem 4 - Part No SW: 83A 919 616 HW: 83A 919 616
Component: LSR-D5/C8 H33 0108
Serial number: 00004419000049818015
1543 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 30
Mileage: 1411 km
Date: 2019.09.23
Time: 16:22:34
Voltage terminal 30: 12.0 V
Byte_Coding_Condition-byte_0_condition: OK
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: OK
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: ERROR
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
6922 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Park assist OPS (0x0A) - function restriction due to communication error - BapErr_timeout: heartbeat]
Reset counter: 70
Mileage: 1411 km
Date: 2019.09.23
Time: 16:24:56
7178 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 70
Mileage: 1411 km
Date: 2019.09.23
Time: 16:25:12
Voltage terminal 30: 14.3 V
BAP-BAP_Function_ID: 02
1556 - Internal Control Module Memory Check Sum Error
B2000 87 [008] - Missing message
Reset counter: 52
Mileage: 541 km
Date: 2019.09.14
Time: 08:49:13
Voltage terminal 30: 12.2 V
Software module: status-SW_Status_Consistency: 00 00 01
Software module: status-SW_Status_Device: NavDB
7223 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[ENI (0x37) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 70
Mileage: 1414 km
Date: 2019.09.24
Time: 11:38:06
Voltage terminal 30: 13.2 V
BAP-BAP_Function_ID: 10
Part No SW: 5NA 035 284 C HW: 5NA 035 284 C
Component: OCULowMQBLGE H19 0825
Revision: --------
Coding: 01230601EA770A0F05109C0000354003804651
ASAM Dataset: EV_OCULowMQBLGE 004049
ROD: EV_OCULowMQBLGE_004_VW25.rod
VCID: 3D273868EDFF3E2FE1F-8068
Part No SW: 3Q0 980 654 M HW: 3Q0 980 654 A
Component: MQB_B_MFK H09 0451
Serial number: 26041915P22041
Coding: 040302060000040101222346814E440084000E20000000
ROD: EV_MFKBoschMQBB_002_VW36.rod
VCID: 41DF449891075ACF857-8014
1123173 - Databus
[ESP_21_ESP_Systemstatus]
Reset counter: 42
Mileage: 48 km
Date: 2019.07.31
Time: 00:00:56
Control Module temperature: 27 ∞C
Outside air temperature: 27.0 ∞C
System run time: 4.1 s
Voltage terminal 15: 11.7 V
mid: 02 E0
Status of camera: operational
Engine_Running_Info: 1
Software_Info_4: 1
Software_Info_3: 5
Software_Info_2: 4
Software_Info_1: 0
Part No SW: 8W1 959 595 D HW: 8W1 959 595 D
Component: TSG HFS004 0189
Serial number: YE007SDA05761
Coding: 000E08004000008000001000
VCID: 4EC56FA45059B5B7085-801A
Component: TSG HBFS004 0189
Serial number: YE007SDA05766
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 G HW: 3Q0 907 590
Revision: --------
Coding: 00C002
ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
VCID: 392F2C78F9D7020FCD7-806C
1188165 - Databus
Reset counter: 42
Mileage: 48 km
Date: 2019.07.31
Time: 00:00:54
Address D6: Light Ctrl Left 2 (A31) Labels: None
Part No SW: 4K0 941 571 BC HW: 4K0 941 571 B
Component: LMS_MQB H06 0031
ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
ROD: EV_LMSLeftHELLAAU58X_AU37.rod
VCID: 6FBBD220F7139CBF233-803A
Address D7: Light Ctrl Right 2 (A27) Labels: None
ASAM Dataset: EV_LMSRightHELLAAU58X 001013
ROD: EV_LMSRightHELLAAU58X_AU37.rod
End----------(Elapsed Time: 01:35, VBatt start/end: 12.1V/12.0V)-----------
