VW Tiguan 2010 5N
Lothar
Ecuador
C?ID=123259
Hello, This is my first post and hope to learn a lot from this amazing community. The problem that we have with this VW Tiguan is that we wanted to change the Instrument Cluster with a used one. One of the mechanics who was given this job installe the used Instrument Cluster wihout making an Autoscan first, so the ABC control module has lost its coding. Can somebody help me to figure out the code that we need? Thanks for your help!!
Wednesday,18,September,2019,16:43:24:09355
VCDS Version: 18.9.1.0 (x64) Data version: 20190114 DS296.0
VIN: WVGZZZ5NZ9W519664   License Plate:
Chassis Type: 5N (1K0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 53 56 62 72
VIN: WVGZZZ5NZ9W519664   Mileage: 105070km-65287miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 HC    HW: 03L 906 022 G
   Component: R4 2,0L EDC 0000AG  3018
   Revision: 13H01---    Serial number: VWX7Z0H83NG0WO
   Coding: 0000175
   Shop #: WSC 03428 873 89750
   VCID: 6DDB356474B5752206-8038
000115 - Sensor for Ambient Air Temperature (G17)
               P0073 - 000 - Signal too High
                    Mileage: 105077 km
                    Time: 01:11:00
                    Voltage: 10.94 V
                    Temperature: 24.3°C
                    Temperature: 22.5°C
                    Temperature: 31.5°C
                    Temperature: 36.9°C
               U1017 - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 105077 km
                    Time: 01:11:01
                    Voltage: 10.94 V
                    Torque: 219.0 Nm
                    Hex Value: 0xFF02
                    Bin. Bits: 00000111
               U1017 - 000 -
                    Mileage: 105077 km
                    Time: 01:11:01
                    Voltage: 10.87 V
                    Bin. Bits: 00000111
                    Bin. Bits: 00000000
                    (no units): 0.0
000256 - Mass Air Flow Sensor (G70)
               P0100 - 000 - Supply Voltage - Intermittent
                    Mileage: 105077 km
                    Time: 04:08:20
                    Voltage: 7.37 V
                    Load: 100.0 %
                    Load: 100.0 %
                    Mass Air / Rev.: 1040.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
000257 - Mass Air Flow Sensor (G70)
               P0101 - 000 - Implausible Signal - Intermittent
                    Mileage: 105077 km
                    Time: 04:12:33
                    Voltage: 6.08 V
                    Load: 100.0 %
                    Load: 100.0 %
000258 - Mass Air Flow Sensor (G70)
               P0102 - 000 - Signal too Low - Intermittent
                    Voltage: 4.94 V
                    Load: 100.0 %
                    Load: 100.0 %
                    Mass Air / Rev.: 750.0 mg/str
   Part No SW: 09G 927 750 FD    HW: 09G 927 750 FD
   Component: AQ 250 6F           1124
   Revision: 00H76000    Serial number:
   Coding: 0000328
   VCID: 78F514300BF7C08AE5-802C
Address 03: ABS Brakes        Labels: 5N0-614-517.lbl
   Part No SW: 5N0 614 517 K    HW: 5N0 614 517 K
   Component: J104    C2 450 V1   0006
   Revision: --H12---    Serial number: 00000001349098
   Coding: 0010000
   Shop #: WSC 03128 229 100586
   VCID: 3669DA084163F6FA37-8062
7 Faults Found:
            000 -  -
                    Fault Frequency: 17
                    Reset counter: 126
                    Mileage: 105077 km
                    Time: 01:11:03
                    Hex Value: 0x0000
                    Voltage: 10.75 V
                    Bin. Bits: 00011111
                    Count: 166
                    Hex Value: 0x0000
                    Reset counter: 126
                    Mileage: 105077 km
                    Time: 04:07:29
                    Hex Value: 0x0000
                    Voltage: 7.75 V
                    Bin. Bits: 00000010
                    Count: 112
                    Hex Value: 0x0000
03201 - Adaptation Overboost
                    Reset counter: 126
                    Mileage: 105077 km
                    Time: 04:07:29
                    Reset counter: 126
                    Mileage: 105077 km
                    Time: 04:07:29
                    Reset counter: 126
                    Mileage: 105077 km
                    Time: 04:07:29
                    Reset counter: 126
                    Mileage: 105077 km
                    Time: 04:07:29
                    Reset counter: 126
                    Mileage: 105077 km
                    Time: 04:07:29
   Part No SW: 1K0 907 044 CT    HW: 1K0 907 044 CT
   Component: ClimatronicPQ35 133 1213
   Revision: 00133026    Serial number: 00000000000000
   VCID: 7BFF0B3C3AC1EB9288-802E
            013 - Check DTC Memory
00716 - Air recirculation Flap Positioning Motor (V113)
            000 -  -  - Intermittent
            000 -  -
            014 - Defective
   Revision: 00H54000    Serial number: 00000008938875
   Coding: 01880FA300041C0047190000140000000009FF475C400104420000000000
   Shop #: WSC 01367 785 00200
   VCID: 336FE31C5211E3D210-8066
   Subsystem 1 - Part No: 5N1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer 200908  012 0203
   Coding: 00038805
   Shop #: WSC 01367
                    Reset counter: 166
                    Mileage: 105077 km
                    Voltage: 8.80 V
                    Reset counter: 166
                    Mileage: 105077 km
                    Voltage: 5.00 V
01598 - Drive Battery Voltage
                    Reset counter: 166
                    Mileage: 94403 km
                    Voltage: 13.00 V
   Component: J234__200 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPK4WKVS
   Coding: 0012336
   VCID: 3B7FCB3C7A412B92C8-806E
   Subsystem 1 - Serial number: 6333FTS600092428
   Subsystem 2 - Serial number: 6343FTS645642408
   Subsystem 3 - Serial number: 6353ETS62PN3VVNR
   Subsystem 4 - Serial number: 6363ETS645N7VVNR
                    Reset counter: 166
                    Mileage: 105077 km
                    Time: 03:56:10
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
                    Fault Status: 11100001
                    Reset counter: 126
                    Mileage: 105077 km
                    Time: 01:11:21
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
                    Reset counter: 126
                    Mileage: 105077 km
                    Time: 01:11:21
00589 - Airbag Igniter 1; Passenger Side (N131)
                    Reset counter: 126
                    Mileage: 105077 km
                    Time: 01:11:21
   Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
   Coding: 0010012
   VCID: 77F7170C06E9CFF2EC-8022
   Part No SW: 5N0 920 870 D    HW: 5N0 920 870 D
   Component: KOMBIINSTRUMENT VDD 2420
   Revision: V0004000    Serial number: VWX7Z0H83NG0WO
   Coding: 0001102
   Shop #: WSC 32662 210 01865
   VCID: 3163E914A80DD1C262-8064
00771 - Fuel Level Sensor (G)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 126
                    Mileage: 105077 km
                    Time: 00:05:53
00438 - Fuel Supply Sensor 2 (G169)
                    Reset counter: 126
                    Mileage: 105077 km
                    Time: 00:05:53
                    Reset counter: 126
                    Mileage: 105077 km
                    Time: 00:05:53
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 090908F1002178
   Coding: FD827F060002026002
   VCID: 356BDD045C65FDE23E-8060
   Part No SW: 0AY 907 554 C    HW: 0AY 907 554 C
   Component: Haldex 4Motion      0041
   Coding: 0000005
   VCID: 4B9F9BFC2AE19B1278-801E
   Component: IMMO            VDD 2420
   Part No SW: 5N0 959 701     HW: 5N0 959 701
   Component: Tuer-SG         006 1205
   Coding: 0000188
   VCID: 72E126186D8BAADADB-8026
   Part No SW: 5N1 909 144 G    HW: 5N1 909 148 E
   Component: J500__APA-BS KL.097 0401
   Revision: 1AH01251    Serial number: 00080510010602
   Coding: 0000258
   Shop #: WSC 01287 785 00200
01288 - Terminal 30; Steering Assist
                    Fault Status: 00101011
                    Fault Priority: 9
                    Reset counter: 166
                    (no units): 2.0
                    Voltage: 11.40 V
02546 - Steering Limit Stop
                    Fault Status: 11100101
                    Reset counter: 126
                    (no units): 4.0
                    Voltage: 12.40 V
                    Reset counter: 166
                    Mileage: 105077 km
                    Time: 04:13:19
                    Voltage: 0.10 V
                    Voltage: 6.10 V
                    Voltage: 0.10 V
                        Not Occup.
                        Not Occup.
01312 - Powertrain Data Bus
                    Reset counter: 166
                        Term 15 Off
                    Speed: 50.0 km/h
                    (no units): 4.0
                    Voltage: 14.10 V
   Component:    KSG PQ35 G2  020 0205
   Coding: 81800A0052830C7F3F04840570084FCEF0FC00
   VCID: 030F73DC42319352C0-8056
   Subsystem 2 - Part No: 1K8 951 171
   Component: DWA-Sensor      001 0104
                    Reset counter: 126
                    Mileage: 105077 km
                    Time: 01:12:47
                    Fault Status: 00110010
                    Reset counter: 166
                    Mileage: 105077 km
                    Time: 04:04:09
   Part No SW: 5N0 959 702     HW: 5N0 959 702
   Coding: 0000188
   VCID: 73EF231C1291A3D2D0-8026
   Part No SW: 5N0 907 801 B    HW: 5N0 907 801 B
   Component: J540 EPB3  VW-09384 0005
   Revision:   H09       Serial number: 00000000134967
   Coding: 0010000
   VCID: 2E59F268B933CE3A7F-807A
                    Fault Status: 11101101
                    Fault Frequency: 11
                    Reset counter: 126
                    Mileage: 105077 km
                    Voltage: 10.60 V
                    Count: 71
                    Hex Value: 0x12C1
                    Hex Value: 0x0001
                    Hex Value: 0x1010
            000 -  -  - MIL ON
                    Fault Status: 11110000
                    Reset counter: 126
                    Mileage: 277995 km
                    Voltage: 10.60 V
                    Count: 100
                    Hex Value: 0x1251
                    Hex Value: 0x0001
                    Hex Value: 0x1010
            000 -  -  - MIL ON
                    Reset counter: 126
                    Mileage: 277995 km
                    Voltage: 10.60 V
                    Count: 43
                    Hex Value: 0x1251
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Fault Status: 11110101
                    Reset counter: 126
                    Mileage: 277995 km
                    Voltage: 10.60 V
                    Count: 101
                    Hex Value: 0x1251
                    Hex Value: 0x0001
                    Hex Value: 0x1010
                    Reset counter: 166
                    Mileage: 105077 km
                    Voltage: 8.30 V
                    Count: 50
                    Hex Value: 0x1241
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Part No SW: 1K0 035 180 M    HW: 1K0 035 180 M
   Component: Radio PM6       125 0037
   Revision: 00125000    Serial number: VWZ5Z7H2261149
   Coding: 0040401
   VCID: 2A51FE7885DBA21AA3-807E
                    Reset counter: 166
                    Mileage: 105077 km
                    Time: 03:56:25
   Part No SW: 5N0 959 703     HW: 5N0 959 703
   Component: Tuer-SG         006 1301
   Coding: 0000144
   Shop #: WSC 01367 785 1012552
   VCID: 74ED2000179FA4EAC9-8020
01813 - Supply Voltage for Door Controller; Rear Left (J388)
   Part No SW: 5N0 959 704     HW: 5N0 959 704
   Coding: 0000144
   VCID: 75EB1D041CE5BDE2FE-8020
01814 - Supply Voltage for Door Controller; Rear Right (J389)
End-------------------------(Elapsed Time: 02:02)--------------------------
VCDS seems to be working fine (despite needing an update). Moving to Car Repair Support.
Lothar
Ecuador
C?ID=123259
Well, I managed to programm everything with an old autoscan that we had from the same car. The only thing that we have now is this code:
Reset counter: 126
Mileage: 105077 km
Date: 2000.00.0
I tried to go to channel 21, but there is no communication. Any suggestions on how to do the basic setting?
Thanks for your help.
