A6 2014 ABS coding
Pedja
Serbia
C?ID=48712
please help coding.
Friday,20,September,2019,09:25:49:64546
VCDS Version: 19.6.1.0  HEX-NET CB: 0.4508.4
VIN: WAUZZZ4G1EN161697   License Plate: 4G NIKOLA KARAVAN
Mileage: 188378km-117052mi   Repair Order:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 3B 42 44 46 52 53 55 56
          5F 62 69 6C 6D 72
VIN: WAUZZZ4G1EN161697   Mileage: 188378km-117052miles
Address 01: Engine (J623-CGLD)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 HA    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H25 9978
   Revision: 45H25---
   Coding: 12034012243401080000
   Shop #: WSC 44623 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018HA 003011
   ROD: EV_ECM20TDI01103L906018HA.rod
   VCID: 70ACD6A1AB5F31CF69-8024
          U1113 00 [039] - -
                    Mileage: 188378 km
                    Date: 2019.09.18
                    Time: 00:15:22
                    Engine speed: 889.00 /min
                    Normed load value: 31.4 %
                    Coolant temperature: 54 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 13.660 V
                    Cruise Control System (CCS): switch position-Bits 0-7: 129
                    Cruise Control System (CCS): status-Bits 0-7: 44
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
          U1113 00 [039] - -
                    Mileage: 188378 km
                    Date: 2019.09.18
                    Time: 00:15:22
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 4G1 927 155 P    HW: 0AW 927 156 K
   Component: 0AW_20TDI_RdW H06 0004
   Revision: --H06---    Serial number: 0000001515
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_TCMVL381 A02433
   ROD: EV_TCMVL381.rod
   VCID: 393A2B85B8A5B0879E-806C
   Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
   Component: ESP PREMIUM   H09 0450
   Coding: 00000000000000000000
   ASAM Dataset: EV_ESPPremiAU57X 004039
   VCID: 3A383489BDA3BB9F97-806E
   Part No SW: 4H0 907 064 EN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0521
   Coding: 01A93006000000000000
   VCID: 79BAEB85F0257087DE-802C
   Part No SW: 4G0 820 043 AM    HW: 4G0 820 043 AM
   Component: KLIMA 4 ZONEN H14 0096
   Serial number: 06051400041985
   Coding: 34020078A1
   ASAM Dataset: EV_AirCondiComfoUDS 004003
   ROD: EV_AirCondiComfoUDS_004.rod
   VCID: 6A98C4C98D83CB1F27-803E
   Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
   Revision: 20012002    Serial number: 00000001740894
   Coding: 2600201040349FE00181008300001D0C0F9CE70826090201000008606101
   VCID: 6E90C8D9B96B273F7B-803A
   Component: WWS57X 140423  H37 0080
   Serial number:         140426024437
   Coding: 0045F7
   Serial number: 22599590
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 S    HW: 4G0 941 531 S
   Component: E1 - LDS  H07 0044
   Serial number: 30 04 2014  00000454
   Serial number: 5AA88827000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061412801817
   Coding: A9C308
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71AAD3A5A05538C766-8024
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00HUJFX
   Coding: 3032343631324E303039554A304C34473053
   VCID: 362020B989BB5FFF73-8062
   Serial number: 3575HRB405N2M1H61P9I
   Serial number: 3585HRB405F2KAFQ6G2P
   Serial number: 3515JRB401652JN2HH94
   Serial number: 3525JRB400O52JN2J95C
   Serial number: 3554VRB401450VL051I4
   Serial number: 3564VRB401I50VVKCH3E
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20171005000023
   Coding: 000015
   Shop #: WSC 28528 002 1048576
   VCID: 302C16A163DF71CF29-8064
   Subsystem 1 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Part No SW: 4G8 920 932 S    HW: 4G8 920 932 S
   Component: TDieRdw       H58 0622
   Revision: 29460237    Serial number: 658080514596026
   Coding: 13AF10000B4100080D0000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 3FCE459DA6819EB7A0-806A
   Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
   Component: J533--Gateway H13 0050
   Revision: --------    Serial number: 00000001384038
   Coding: 00CD074400
   ASAM Dataset: EV_GatewPkoUDS 001019
   VCID: 72A8DCA9A55303DF9F-8026
   Serial number: 2319113303
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 1402270000000000046F
   Part No SW: 4G0 919 158 M    HW: 4G0 919 158 M
   Component: KLIMA FOND    H08 0096
   Serial number: 07051400041601
   Coding: 20
   ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H03 0056
   Revision: --------    Serial number: EJ1BPA7209V325
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 332619AD9AC94AD754-8066
   Component: TSG FA        H03 0507
   Coding: 011C16005C00620002080002
   VCID: 47DE5D7DF651D67718-8012
   Component: RCEPS         H40 0010
   Revision: 00001000    Serial number: 0028536754
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 32281CA965D343DF5F-8066
   Revision: 00002001    Serial number: 0335436500
   Coding: 013A0620A0B930808320090420010F470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Component: TSG BF        H03 0507
   Coding: 011C16005E00620002080002
   VCID: 46C05079F15BCF7FE3-8012
   Part No SW: 4H0 907 801 H    HW: 4H0 907 801 A
   Component: EPB-4         H03 0015
   Revision: --------    Serial number: 00000001059778
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D120FD57CED1C2702-8078
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 140505-0002-063
   Coding: 112296101002A300
   ROD: EV_HeadlRegulBasic.rod
   Part No SW: 4G0 035 056 J    HW: 4G0 035 056
   Component: Radio U STD   H60 0133
   Revision: AB001007    Serial number: 230EV0E3057349
   Coding: 010003020100000001
   VCID: 281CFEC15B0F390FF1-807C
   Part No SW: 4G0 035 666 N    HW: 4G0 035 666 H
   Component: H-BN-EU       H52 0939
   Revision: --------    Serial number: 189EA0E7581784
   Coding: 050100010103A1EF0580AB3E00000003E00001020000000000
   VCID: 332619AD92C94AD754-8066
   Subsystem 1 - Part No: 8R0 060 884 BK
   Component: EUR 2014  1703
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDED004HR3.
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349NE7000OI
   Component: CD-Database  5571
                    Reset counter: 129
                    Mileage: 188378 km
                    Date: 2019.09.18
                    Time: 00:13:44
                    Bin. Bits: 00000000 10000000
                    Bin. Bits: 00000000 00000000
   Component: TSG HL        H03 0507
   Coding: 010814004000620002080002
   VCID: 49DA5B45E04520070E-801C
Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
   Part No SW: 4G8 907 383     HW: 4G8 907 383
   Component: Anhaenger     H11 0100
   Revision: 5G001001    Serial number: 00008200348043
   Coding: 0109080000000000
   VCID: 71AAD3A5A85538C766-8024
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H08---    Serial number: 525 PA8J44G0MQ
   Coding: 1090005
   VCID: 2600F0F9911B2F7FC3-8072
   Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
   Component: HDSG-Modul    H03 0143
   Revision: 14003001    Serial number: 124401188
   Coding: 097205C011
   ROD: EV_HDSGAu571.rod
   VCID: 352227B594BD54E77A-8060
0004 - No Basic Setting
          B2010 00 [137] - -
          [Steuergerät nicht kalibriert]
                    Reset counter: 129
                    Mileage: 188378 km
                    Date: 2019.09.18
                    Time: 00:13:41
                    Voltage terminal 30: 12.17 V
0114 - Load Space Cover
          B12EF 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 129
                    Mileage: 188378 km
                    Date: 2019.09.18
                    Time: 00:13:41
   Component: TSG HR        H03 0507
End----(Elapsed Time: 01:59, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Pedja
Serbia
C?ID=48712
does not accept encoding
NEtech
Denmark
C?ID=56995
Was SA accepted ?
What was the message after coding is saved ?
First:
[Options]
[User Interface and Identification]
write numbers for wsc, importer, device no.
For example 12345 123 23456
[Save]
[Close VCDS]
Start VCDS
Use batterycharger.
Ignition OFF
Wait
Ignition ON
Try again.
Also:
Please use a battery charger!
Pedja
Serbia
C?ID=48712
Coding rejected
error 13 Incorrect message length or invalid format.
Pedja
Serbia
C?ID=48712
06A19F016085F980DB00 coding ok
Monday,23,September,2019,10:32:56:64546
Workshop Code: 123 12345 023456
VIN: WAUZZZ4G1EN161697   License Plate: A6 4G 2014 ABS OK NIKOLA
Mileage: 188382km-117055mi   Repair Order:
          5F 62 69 6C 6D 72
VIN: WAUZZZ4G1EN161697   Mileage: 188382km-117055miles
   Revision: 45H25---
   Coding: 06A19F016085F980DB00
   Shop #: WSC 12345 123 23456
   Coding: 34020078A1
   Coding: 0045F7
   Coding: 02006D
   Coding: A9C308
   Coding: 000015
   Coding: 00CD074400
   Voltage stabilizer:
   Coding: 20
   ROD: EV_SARA2.rod
   Coding: 112296101002A300C
   Coding: 1090005
   Coding: 097205C011
          B2010 00 [137] - -
                    Reset counter: 129
                    Mileage: 188382 km
                    Date: 2019.09.21
                    Time: 01:46:35
                    Voltage terminal 30: 13.85 V
                    Reset counter: 129
                    Mileage: 188382 km
                    Date: 2019.09.21
                    Time: 01:46:35
End----------(Elapsed Time: 02:01, VBatt start/end: 13.9V/14.2V)-----------
