DPF pressure sensor adaptation procedure (BRE engine)
wasylek
Norway
C?ID=262585
audi 2006 A6 Avant (4F5, C6) 2.0tdi pd bre vin WAUZZZ4F16N155133
how to do adaptation for dpf and dpf pressure sensor??
vcds didnt have map for this ecu.
and everything i need to do manually...
wasylek
Norway
C?ID=262585
Thursday,19,September,2019,18:41:40:61642
VCDS Version: 19.6.1.0 (x64)
VIN: WAUZZZ4F16N155133   License Plate:
Chassis Type: 4F (4F0)
Scan: 01 03 05 07 08 09 0E 15 16 17 18 19 37 42 46 47 4F 52 53 55
          56 61 62 69 72 77
VIN: WAUZZZ4F16N155133   Mileage: 201330km-125100miles
   Part No SW: 03G 906 016 GB    HW: 03G 906 016 GB
   Component: R4 2,0L EDC G000SG  9663
   Revision: --H02---    Serial number:
   Coding: 0020072
   Shop #: WSC 00011 888 81093
   VCID: 69D9DE7E408928072E-803C
001139 - Exhaust Pressure Sensor 1
               P0473 - 000 - Signal too High
                    Mileage: 201338 km
                    Date: 2019.09.19
                    Time: 18:39:27
                    Voltage: 11.86 V
                    Mileage: 10 km
                    Temperature: 36.0°C
                    Absolute Pres.: 999.6 mbar
Readiness: 0 0 1 1 1
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 K    HW: 4F0 614 517 K
   Component: ESP 8.0 front   H05 0090
   Coding: 0004471
   Shop #: WSC 02325 785 00200
   VCID: 2C57676A8FFBFD2F15-8078
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10604000355589
   Coding: 0000129
   Shop #: WSC 35228 001 1048576
   VCID: 63C5CC56A2A57257E4-8036
   Subsystem 1 - Part No: 4F0 910 131 D
   Component: FBSAUDIC6 EZS   H45 0080
   Subsystem 2 - Part No: 4F0 910 220 D
   Component: FBSAUDIC6 IDG   H39 0040
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
   Part No SW: 4F0 910 730 F    HW: 4E0 035 729
   Component: Interfacebox    H43 2120
   Revision: 00000000    Serial number: 350BF067653060
   Coding: 0001001
   Shop #: WSC 02335 785 00200
   VCID: 24478F4AE72B356FDD-8070
   Component: Bedienteil MMIC6H08 0050
   Subsystem 2 - Serial number: 00000000343899
   Subsystem 3 - Serial number: 0116.02.060000000100011212˙
   Subsystem 4 - Serial number: 011212˙
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043     HW: 4F1 820 043 S
   Component: KLIMABETAETIGUNGH12 0170
   Revision: 00000030    Serial number: 00000000234270
   Coding: 0002324
   VCID: 5BB5F4B69AD54A97AC-800E
                    Fault Status: 00101010
                    Reset counter: 6
                    Mileage: 200949 km
                    Date: 2019.09.04
                    Time: 17:24:32
                    Temperature: 18.0°C
   Part No SW: 4F0 910 279 D    HW: 4F0 907 279
   Component: ILM Fahrer      H15 0190
   Coding: 0002121
   VCID: 2A5B6172850FE31FE7-807E
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH11 0050
   Coding: 00141886
   Shop #: WSC 02335
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBF8062634
   VCID: 1C37B7AADF5B0DAF65-8048
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
   Component: 43 AIRBAG AUDI8RH29 0280
   Revision: 08H29000    Serial number: 0037LD0D5SJN
   Coding: 0013363
   VCID: 29599E7E8009E807EE-807C
   Subsystem 1 - Serial number: 6332CSME0E3E630CD
   Subsystem 2 - Serial number: 6342CSME0E193440/
   Subsystem 3 - Serial number: 6352QSME054B3447F
   Subsystem 4 - Serial number: 6362QSME0430211F4
   Subsystem 5 - Serial number: 63734SME09724B0F6
   Subsystem 6 - Serial number: 63834SME097A2E63A
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90026060380193
   Coding: 0002042
   Shop #: WSC 02323 785 00200
   VCID: 66C3D5425197077F03-8032
   Component: Lenkradmodul    H07 0090
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 A    HW: 4F0 920 931 B
   Component: KOMBIINSTR. M73 H17 0660
   Revision: 00200000    Serial number: 4PT54ZD26
   Coding: 2052143
   Shop #: WSC 80093 222 69422
   VCID: 2149865EF8392047B6-8074
Address 18: Aux. Heat        Labels: None
   Part No SW: 4F0 910 105 A    HW: 4F0 265 081 L
   Component: Heizgeraet      H08 0060
   Revision:        B    Serial number: 09011480
   Coding: 0000111
   VCID: 1B35B4B6DA550A976C-804E
Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
   Component: Gateway         H11 0070
   Revision: 11          Serial number: 1300806204806D
   Coding: 6DEE73C61B3104
   Shop #: WSC 02334 785 00200
   VCID: 275D9846961DDE77F8-8072
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 D
   Component: MNS ECE         H47 1060
   Revision: 00000000    Serial number: 364BQ067531980
   VCID: 3B7554367A956A978C-806E
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 F    HW: 4F0 959 793 F
   Component: TSG FA          H21 0050
   Coding: 0001546
   Shop #: WSC 02327 785 00200
   VCID: 2D516A6EB4E1F42702-8078
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 F    HW: 4F0 907 289 F
   Component: Komfortgeraet   H19 0140
   Revision: 01400019    Serial number: 01010666820000
   Coding: 0131717
Address 47: Sound System        Labels: 4F0-910-223-AS.lbl
   Part No SW: 4F0 910 223 C    HW: 4F0 035 223
   Component: Amp.-ASK        H10 0320
   Revision: 33S00001    Serial number: 01402060222818
   Coding: 0000108
   VCID: 1E33BDA2C9471FBF8B-804A
   Part No SW: 4F0 910 280     HW: 4F0 907 280
   Component: ILM Beifahrer   H10 0080
   Revision:             Serial number: 00000000120852
   Coding: 0001004
   VCID: 5EB3FDA289C75FBFCB-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 792 F    HW: 4F0 959 792 F
   Component: TSG BF          H21 0050
   Coding: 0001546
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 A    HW: 4F0 907 801
   Component: EPB  CA3C0040   H03 0040
   Revision: --H03---
   Coding: 0000111
   Shop #: WSC 00000 785 00200
   Part No: 8P0 907 357 C
   Coding: 0000003
   VCID: 3A7B513275AF539F97-806E
   Part No SW: 4E0 910 541 L    HW: 4F0 035 541 E
   Component: TUNER EU/US/RDW H42 0560
   Revision: 00000000    Serial number: 352BK067624452
   Coding: 0000001
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: J0644 BEM       H12 0590
   Revision: 00000000    Serial number: 00000000025199
   Shop #: WSC 22222 111 59065
   VCID: 23458C56E2253257A4-8076
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  1602051024
   Coding: 344630393135313035442056413031363032303531303234
   Shop #: WSC 00000 384 00290
02272 - Quiescent Current Stage 1
                    Mileage: 201325 km
                    Date: 2019.09.18
                    Time: 22:51:40
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 F    HW: 4F0 959 795 F
   Component: TSG HL          H21 0050
   Coding: 0001026
   VCID: 2F6D7066BEED863730-807A
Address 69: Trailer        Labels: 4F0-910-383.lbl
   Part No SW: 4F0 910 383     HW: 4F0 907 383
   Component: ANHAENGERELEKTR H02 0020
   Coding: 0000331
   VCID: 62CBC952BDBF7B5FEF-8036
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 F    HW: 4F0 959 794 F
   Component: TSG HR          H21 0050
   Coding: 0001026
   Part No SW: 4E0 910 336 F    HW: 4E0 862 335
   Component: Handyvorb2      H13 0580
   Revision: 00000000    Serial number: 00000007614157
   Coding: 0010900
   VCID: 2541924EEC11CC67CA-8070
End-------------------------(Elapsed Time: 02:27)--------------------------
Differential Pressure Sensor Adaptation:
Key on, engine not running. Coding-II: Put in 30605.
Wait a bit (not sure how long). Then turn off ignition for at least 10 seconds and turn it back on.
DPF itself:
Adaptation Channel 12:
Set New Value to 0.
You may need to do a Coding II with 12233 in order for this to be possible.
wasylek
Norway
C?ID=262585
DPF itself:
Set New Value to 0.
are you shore?? its not help
wasylek
Norway
C?ID=262585
I will try disconnect batteri and try one more time. In signal kabel is 5,6v and its going from edc....
wasylek
Norway
C?ID=262585
i have adaptation dpf pressure sensor done. The procedure is correct. probably the driver has stopped. it helped to disconnect the battery overnight
time to wait its about 30s. Thank you very much for your help.
