Latest LCode version
   #163
Paskal
Czech Republic
C?ID=508876
Is it possible to supply the CZ language, please?
   #165
Paskal
Czech Republic
C?ID=508876
And how to use that file please? I copied it to the folder where Lcode is and I can't select the CZ language.
   #166
NEtech
Denmark
C?ID=56995
Sorry I understood you wanted to translate.
If not, then you cannot use the file, all translations that are made, are already in the program.
CZ language is not, as you can see.
   #171
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Minor glitch, when opening "About for the first time, the English translation is shown in localized view. When reopening it, the translation is properly displayed.
(No need for fresh builds, cosmetic issue only it seems.)
   #172
Sebastian
Magdeburg, Germany
HN0-nnnnnn
*duplicate post*
   #174
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Customer reported LCode 2.1.7.0 would not show bit selection boxes (for Byte 01 and up), when starting the application externally/standalone. The behavior is reproducible for me as well.
Screenshot(121).png.9579aa797bbfde23ada7b1ace4eaea79.pngScreenshot(122).png.29d831d5ea33ee873b3c805957e36c88.pngScreenshot(123).png.7b243e1aaa89eaac785df11a84f2f540.png
   #175
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Yes, it's the same with me. When I "call" lbl. then it's OK.
Truth be told, I couldn't remove the VIN bytes with ctrl F11. I tried standalone, "off-line".
   #176
NEtech
Denmark
C?ID=56995
They are on with expert user.
   #177
Boki Ar
C?ID=57300
Yes, I read your private one, but I didn't succeed.
I would appreciate a little more explanation. ;)
   #178
NEtech
Denmark
C?ID=56995
The above answer was most intended for Sebastian.
Ctrl F12 was not for general use.
But to use Ctrl F12, you must activate "Expert user" in [Language]
Then you see a button [Remove VIN], I prefer not to use mouse, so now you can press Ctrl F11.
   #179
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Not sure this is ideal, first of all because the behavior between Byte 00 and Byte 01+ is inconsistent. Second because the user base is simply used to the original implementation. I'll relay that for now, but I'd like to ask for reconsideration reg. this removal / move of features.
   #180
J.Wittl
Germany (PCI)
Not sure this is ideal [...] because the user base is simply used to the original implementation. I'll relay that for now, but I'd like to ask for reconsideration reg. this removal / move of features.
I totally agree with that :)
