Shortcut keys:
ESC = Close LCode
INS = Convert every Byte from Long Coding to Binary with space between each Byte
(Example: 224831 = 00100010 01001000 00110001)
INS = If short code showed, all + values is copied
(Example: 02289 = +1 +16 +32 +64 +128 +2048 or 000000000000100011110001)
Ctrl INS = Convert every Byte from Coding to Binary with space between each Bit (Goto Byte 1 first)
(Example: 224831 = 0 0 1 0 0 0 1 0 0 1 0 0 1 0 0 0 0 0 1 1 0 0 0 1)
END = Jump to last Byte in Coding
HOME = Jump to first Byte in Coding
Enter = Focus on current Byte number value
Arrow Up = Move to next higher Byte value
Arrow Down = Move to next lower Byte value
PageDown = Jump to 10 Bytes higher position, if possible
PageUp = Jump to 10 Bytes lower position, if possible
Ctrl 1 = Jump to long coding value
Ctrl 2 = Jump to Byte number (default active place)
Ctrl 3 = Jump to Hex coding value box
Ctrl 4 = Jump to Binary box
Ctrl 5 = Jump to search box
Ctrl O = Load file
Ctrl Enter = Load lbl/xpl file
Ctrl D = Change Hex coding to Decimal coding or reverse
Ctrl H = Change Decimal coding Hex coding or reverse
Ctrl PageDown = Insert a space between every Byte in Coding (ESC and it is in clipboard)
Ctrl Up = If a search value is used and more Bytes are found it jumps to next Byte with the search value
Ctrl Down = If a search value is used and more Bytes are found it jumps to previous Byte with the search value
Ctrl F11 = Remove VIN Bytes in ABS Coding
Ctrl F12 = Remove VIN is available and show Mirror Byte Value and VIN buttons
F1 = Open Help window
Alt F1 = Show About window
If you have coding value in Clipboard where each Byte is separated by space, the spaces are removed @ESC
Example: 07 00 5F 00 73 10 81 5A 00 39 = 07005F007310815A0039
