Latest LCode version
   #181
NEtech
Denmark
C?ID=56995
So we agree on removing "Expert user" :confused:
   #182
Sebastian
Magdeburg, Germany
HN0-nnnnnn
No, but the standard behavior when being started externally (w/o VCDS) should be to allow bit selection.
If this was a first release of a new assist/tool, I'd agree of this being an expert view/functionality but since both LCode 1 & 2 have always behaved this way, it's IMO not good practice to change this behavior - especially w/o notice.
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Thank You! :thumbs:
Then you see a button [Remove VIN
1150600F492A00FB880E06E792220041BF0C00
11666066496600668866066692660041BF0C00 insert 66 VIN
11__60__49__00__88__06__92__0041BF0C00 w/o VIN
I like it :cool:
   #187
hadez16
C?ID=289891
I finally pushed myself discarding the old LCode and start using the new LCode....
Excerpt from label file:
LC,09,0,Market,0=ECE / 1=NAR
LC,09,4~7,headlamp_coding_word (HEX)
Why is LCode not displaying that placeholder label "headlamp_coding_word (HEX)" ?
It only says "none found".
EDIT: I just tried 2.1.11.0, same behaviour.
   #188
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Because the syntax in your example is incorrect.
   #189
hadez16
C?ID=289891
The syntax comes from the label file which was not created by myself, it's a grabbed experimental label from Unit 4B (3Q0-907-338).
The old LCode does show it:
   #190
NEtech
Denmark
C?ID=56995
I can look at it, but experimental data is loaded in experimental "mode" (yellow screen).
Is it not loading okay, when it is standard label format file?
   #191
Sebastian
Magdeburg, Germany
HN0-nnnnnn
IMO LCode behaves as expected here, the input data is incorrect due to VW supplying incorrect data. This is why "experimental data" should not be used as a standard, only as a fallback.
   #192
hadez16
C?ID=289891
VW datasets incorporate the translation to LCode label files? Didn't know about that.... :facepalm:
Does the "yellow mode" read label files different to "normal mode"?
It is just a label file with a description of a bit-range that worked in old LCode but not in new LCode :)
   #193
Is it incorrect, or just incomplete?
I would guess the newer LCode wants at least some values for the bit field?
@hadez16, try:
LC,09,4~7,00,Headlight Type 1
LC,09,4~7,10,Headlight Type 2
... and so on.
hadez16
C?ID=289891
I try to clarify again: this is *not* a custom label file created by one individual, it comes like this out of VCDS for the experimantal coding!
So there is either some issue with LCode by having changed the expected syntax for bit-ranges, or some issue with VCDS because it does not follow that new syntax ;)
   #195
NEtech
Denmark
C?ID=56995
To clarify, that label file is not public available.
Yes, "yellow mode" data is "Machine made".
Is a bug in old LCode:)
AINils
Germany (AIB)
C?ID=56975
I have access to a car (my own) with this ECU tomorrow in the evening. Can try different things if some help is needed
   #197
NEtech
Denmark
C?ID=56995
And as Sebastian wrote incorrect syntax.
What should LCode show, for that string, HEX, 00, 10, 20, 80 etc. !
   #199
hadez16
C?ID=289891
I just tested this at my car.
"Yellow mode" does it correct:
Why the hell does "yellow mode" read that piece:
...differently compared to "normal mode"?
Some reason for switching back to buggy old LCode :D
   #200
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Step 1: Understand, that you do not know all context.
Step 2: Understand, that you are using data in a way it was never meant to be used.
Step 3: Understand, that this is not a problem a regular user would ever see/experience.
