- Sep 18, 2019
- 65
- 9
- Alberta, Canada
- C?ID=146868
ok hope i did this right
meanwhile i am on the warpath to try to get back the original relay block thing
VIN: 3VWGT81K06M058178 License Plate: NOEL5
Mileage: 258390km-160556mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWGT81K06M058178 Mileage: 258390km-160556miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: Cannot be reached 1100
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H05--- Serial number: VWZ7Z0F4544963
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 64CDB5F1A7B3046F23-8030
Part No SW: 02E 300 043 HW: 02E 927 770 AE
Component: GSG DSG 070 1126
Revision: 04507000 Serial number: 00000607070561
VCID: 51A36C25C80181C778-8004
18036 - Powertrain Data Bus
P1628 - 000 - Missing Message from Steering Angle Sensor
Fault Frequency: 255
Mileage: 258399 km
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73EFC6AD125D93D7AA-8026
Part No: 1K0 820 047 FJ
Component: Climatic PQ35 120 0606
VCID: 71E3CCA56841A1C758-8024
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000335953
Coding: 10018E234004150000140000001400000008730B5C
Shop #: WSC 91590 999 58568
VCID: 2A511BC98517921FD9-807E
Component: Wischer 270906 020 0501
Coding: 00038805
Shop #: WSC 91590
Reset counter: 57
Mileage: 258399 km
Voltage: 12.10 V
Reset counter: 57
Mileage: 258399 km
Voltage: 12.10 V
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6C AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D05WCD9
Coding: 0013891
VCID: 6CDDDDD14F634C2F6B-8038
Subsystem 1 - Serial number: 633 SME
Subsystem 2 - Serial number: 6342MSME1251677FG
Subsystem 3 - Serial number: 6351HSME0A591B3BH
Subsystem 4 - Serial number: 6361HSME0A6362566
Subsystem 5 - Serial number: 63727SME0A565251.
Subsystem 6 - Serial number: 63827SME0A5F12510
01221 - Crash Sensor Side Airbag; Driver Side (G179)
008 - Implausible Signal - MIL ON
Part No SW: 1K0 953 549 AL HW: 1K0 953 549 AL
Component: J0527 036 0070
Coding: 0010021
VCID: 7CFDED913F03DCAFFB-8028
Part No SW: 1K0 920 853 K HW: 1K0 920 853 K
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0F4544963
Coding: 0023303
Shop #: WSC 91590 999 52559
VCID: 326103A9ADC7DADF61-8066
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001068020403
Coding: 3F3F0B4007001002
VCID: 2C5D1DD18FE38C2F2B-8078
Reset counter: 57
Mileage: 258399 km
Time: 10:24:37
Reset counter: 57
Mileage: 258399 km
Time: 10:24:38
Reset counter: 57
Mileage: 258399 km
Time: 10:24:38
Component: IMMO 3HL 1610
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
Shop #: WSC 02069 000 90108
VCID: 346D05B157D3D4EF73-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 1F900F880106083F0D040F8FB0880F0488FCA0
Shop #: WSC 00066 123 12345
Reset counter: 57
Mileage: 258399 km
Time: 10:24:39
Reset counter: 57
Mileage: 258399 km
Time: 10:24:39
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1127
Revision: 12007001 Serial number: 00000563068925
Coding: 0001204
VCID: 3C7D2D917F831CAFBB-8068
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 B HW: 1K0 035 161 B
Component: Radio DE2 014 0017
Revision: 00014000 Serial number: VWZ4Z7F6166885
Coding: 0040401
VCID: 1E39C719C95F6EBFB5-804A
Address 62: Door, Rear Left
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1115
Revision: 12005001 Serial number: 00000000369924
Coding: 0001168
VCID: 3F875A9D6E9507B79E-806A
Component: PTC-Element 0404
VCID: 2D5B10D5B4F985273C-8078
End-------------------------(Elapsed Time: 02:05)--------------------------
VIN: 3VWGT81K06M058178 License Plate: JETTA7
42-Door Elect, Driver -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Sporadic communication error 1000
7D-Aux. Heat -- Status: Malfunction 0010
Coding: 0050078
Revision: 00H11001
Coding: 0021122
Coding: 00038805
Shop #: WSC 91590
Coding: 0013891
Subsystem 1 - Serial number: 6332MSME121A7E74H
Coding: 0010021
Coding: 0023303
Reset counter: 57
Mileage: 258399 km
Time: 00:53:48
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1127
Revision: 12007001 Serial number: 00000584968925
Coding: 0001205
VCID: 3B7F2E8D7A8D1B97B2-806E
Fault Status: 01100101
Reset counter: 57
Mileage: 258399 km
Coding: 0001204
Coding: 0040401
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1115
Revision: 12004001 Serial number: 00000000298069
Coding: 0001168
VCID: 3E792799699F0EBF95-806A
Coding: 0001168
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End-------------------------(Elapsed Time: 02:36)--------------------------
