It may, or may not, be of much assistance but I located two scans form this car back in 2015. I wouldn't typically post scans sent via e-mail into forum .. but I will in this instance.
Per the email description; Before clearing faults
Thursday,24,September,2015,21:12:29:59579
VCDS Version: 14.10.2.0
Data version: 20150311
VIN: 3VWGT81K06M058178 License Plate: NOEL
Mileage: 256770km-159549mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWGT81K06M058178 Mileage: 256770km-159549miles
15-Airbags -- Status: Sporadic communication error 1000
44-Steering Assist -- Status: Sporadic communication error 1000
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AC HW: 028 101 223 9
Component: R4 1,9L EDC G000DG 7551
Revision: --H05--- Serial number: VWZ7Z0F4544963
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 64CDB5F1A7B30401EA7-8031
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 043 HW: 02E 927 770 AE
Component: GSG DSG 070 1126
Revision: 04507000 Serial number: 00000607070561
VCID: 51A36C25C80181A9B11-8004
28775 - No Communication with Gear Selector Module
U0103 - 000 - - Intermittent
Fault Frequency: 255
Reset counter: 33
Mileage: 256497 km
Revision: 00H11001
Coding: 0021122
VCID: 73EFC6AD125D93B963D-8026
Part No: 1K0 820 047 FJ
Component: Climatic PQ35 120 0606
VCID: 71E3CCA56841A1A9911-8024
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 P HW: 3C0 937 049 P
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000000439073
Coding: 10018E234004150007140000001400000008730B5C0000
VCID: 36693FB941AFC691843-8063
Component: Wischer 270906 020 0501
Coding: 00038805
Shop #: WSC 00066
00093 - Terminal 15 for Starting Relevant Consumers
Fault Frequency: 31
Reset counter: 45
Mileage: 256497 km
Voltage: 13.65 V
02403 - Terminal 15 for Interior
Fault Status: 00100110
Fault Frequency: 27
Reset counter: 45
Mileage: 256497 km
Voltage: 13.65 V
Component: 6C AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D05WCD9
Coding: 0013891
VCID: 6CDDDDD14F634C41A27-8039
Subsystem 1 - Serial number: 6332MSME121A7E74H
Subsystem 2 - Serial number: 6342MSME1251677FG
Subsystem 3 - Serial number: 6351HSME0A591B3BH
Subsystem 4 - Serial number: 6361HSME0A6362566
Subsystem 5 - Serial number: 63727SME0A565251.
Subsystem 6 - Serial number: 63827SME0A5F12510
Part No SW: 1K0 953 549 AR HW: 1K0 953 549 AR
Component: J0527 035 0070
Coding: 0010021
VCID: 020193695DE7AA3178B-FFFF
Part No SW: 1K0 920 853 K HW: 1K0 920 853 K
Revision: V0003000 Serial number: VWZ7Z0F4544963
Coding: 0023303
Shop #: WSC 91590 999 52559
VCID: 326103A9ADC7DAB1A8B-8067
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001068020403
Coding: 3F3F0B4007001002
VCID: 2C5D1DD18FE38C41E27-8079
Reset counter: 37
Mileage: 256497 km
Time: 03:14:29
Reset counter: 37
Mileage: 256497 km
Time: 03:15:38
Reset counter: 37
Mileage: 256497 km
Time: 03:17:53
Reset counter: 45
Mileage: 256497 km
Time: 03:27:20
Reset counter: 37
Mileage: 256497 km
Time: 03:27:53
Component: IMMO 3HL 1610
01176 - Key
Mileage: 31987 km
Time: 03:15:07
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1127
Revision: 12007001 Serial number: 00000584968925
Coding: 0001205
VCID: 3B7F2E8D7A8D1BF97BD-806E
Fault Status: 00100101
Reset counter: 41
Fault Status: 01101000
Reset counter: 5
Mileage: 195985 km
Fault Frequency: 38
Reset counter: 43
Mileage: 254645 km
Reset counter: 38
Mileage: 256497 km
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
Shop #: WSC 02069 000 90108
VCID: 346D05B157D3D481BA7-8061
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0202
Coding: 1F900F880106083F0D040F8FB0880F0488FCA0
Shop #: WSC 00066 123 12345
00830 - Convertible Top Control Module (J256)
Fault Status: 00110100
Reset counter: 38
Mileage: 256497 km
Time: 03:14:36
Reset counter: 38
Mileage: 256497 km
Time: 03:15:39
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1127
Revision: 12007001 Serial number: 00000563068925
Coding: 0001204
VCID: 3C7D2D917F831CC1727-8069
Fault Status: 01100101
Reset counter: 5
Fault Status: 01101100
Reset counter: 5
Mileage: 249278 km
Reset counter: 38
Mileage: 256497 km
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 B HW: 1K0 035 161 B
Component: Radio DE2 014 0017
Revision: 00014000 Serial number: VWZ4Z7F6166885
Coding: 0040401
VCID: 1E39C719C95F6ED17C3-804B
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1115
Revision: 12004001 Serial number: 00000000298069
Coding: 0001168
VCID: 3E792799699F0ED15C3-806B
Reset counter: 41
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1115
Revision: 12005001 Serial number: 00000000369924
Coding: 0001168
VCID: 3F875A9D6E9507D9575-806A
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
VCID: 2D5B10D5B4F98549F59-8078
End-------------------------(Elapsed Time: 04:29)--------------------------
After clearing faults:
Thursday,24,September,2015,21:15:55:59579
VIN: 3VWGT81K06M058178 License Plate: NOEL2
Coding: 0050078
Revision: 00H11001
Coding: 0021122
Coding: 00038805
Shop #: WSC 00066
Reset counter: 5
Mileage: 256776 km
Voltage: 12.10 V
006 - Short to Plus
Fault Status: 01100110
Reset counter: 5
Mileage: 256776 km
Voltage: 12.10 V
Coding: 0013891
Coding: 0010021
VCID: 020193695DE7AA3178B-8057
Coding: 0023303
Coding: 0023303
Address 56: Radio
End-------------------------(Elapsed Time: 02:09)--------------------------
At a quick glance it would appear as if 09 and 16 were replaced. Although address 44 communicated it had communication errors in the so I'm inclined to suspect that's a preexisting issue. It would be highly unlikely in my opinion that the factory steering rack decided to fail during the diagnosis and/or be directly related to which 16 module is installed.
Matt, have you ruled out the possibility that this car has driver's door wiring harness issues that could be feeding back on to the Comfort bus? Broken (1K) Jetta harnesses were extremely common, and typically only cause comfort issues, however we had a caller with an (8P) A3 that had AC compressor shutdown problems due to broken door wiring. I believe that was due to 08-Auto HVAC and 42-Driver's door (among several other modules) using the same Comfort bus network. Address 16-Steering wheel is on that network so I'm wondering if any of the original symptoms may be pointing us at something like shorting wiring in a door?
I don't believe that would directly explain the lack-of 44 communication presently but it would be easy enough to unplug the entire door harness at the A pillar to see if any changes are noticed.
