C7 A6 video cable for Image processing
buckeye
C?ID=305834
I'm having issues with my ACC system, suspect a bad cable or module. Does anyone have the wire diagram for J851 to J852 - camera to image processing module. I checked the camera connections and they look ok. I have had some intermittent water leaks in the front windshield and suspect this may be part of the issue. Thanks
Wednesday,18,September,2019,10:18:04:63491
VIN: WAUBGAFC0CN003433   License Plate:
Mileage: 153163km-95171mi   Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 19 28 36 3B 3C 42 44 46
          47 52 53 55 56 5F 62 6C 72 82 84 85 8B 8E 8F 90
VIN: WAUBGAFC0CN003433   Mileage: 153163km-95171miles
Address 01: Engine (J623-CGXB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4G0 907 551 A    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH05 0010
   Revision: --H05---
   Coding: 0A2A0034056600060000
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ECM30TFS0214G0907551A 003011
   ROD: EV_ECM30TFS0214G0907551A_003.rod
   VCID: 2708F2C05F62940FAB3-8072
7814 - Coolant Pump for Intercooler
          P190C 00 [044] - No Signal
                    Mileage: 147626 km
                    Date: 2019.02.07
                    Time: 17:37:19
                    Engine speed: 2011.00 /min
                    Normed load value: 76.1 %
                    Vehicle speed: 87 km/h
                    Coolant temperature: 60 °C
                    Intake air temperature: 15 °C
                    Voltage terminal 30: 14.116 V
                    Engine speed: actual: 1152 /min
                    MAF_ENVD: 190.64705 mg/stroke
                    Coolant temperature (unfiltered): 90.00 °C
                    Engine: operating status: IS
                    Engine load: 17.968750 %
                    Vehicle speed: actual: 0 km/h
   Part No SW: 4G0 927 158 E    HW: 0BK 927 156 R
   Component: 0BK 30TFSIUSA H08 1006
   Revision: --H08---
   Coding: 000002
   Shop #: WSC 09396 002 1048576
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: 303A199C6AACD3B77A9-8064
   Part No SW: 4G0 907 379 B    HW: 4G0 907 379 B
   Component: ESP PREMIUM   H09 0190
   Coding: 44A70F0022E5F0004B00
   ASAM Dataset: EV_ESPPremiAU57X 003013
   ROD: EV_ESPPremiAU57X_003.rod
   Part No SW: 4H0 907 064 AR    HW: 4H0 907 064 AR
   Component: BCM2 2.0      H24 0217
   Coding: 0D882000000000000000
   Shop #: WSC 02391 785 00200
   VCID: 79ACE4B8F9D6D2FF8D7-802C
   Subsystem 2 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Component: J764 ELV MLB  H38 0044
   Serial number: 2311000047859007
   Part No SW: 4G0 820 043 L    HW: 4G0 820 043 L
   Component: KLIMA 4 ZONEN H11 0056
   Serial number: 20031100040009
   Coding: 6601207A1C
   ASAM Dataset: EV_AirCondiComfoUDS 002029
   VCID: 280AF1FC527C9B77A29-807C
   Part No SW: 4H0 907 063 G    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0092
   Revision: 11012002    Serial number: 00000000830392
   Coding: 09072091073C9FE081000884A0003800CF9CD308A20801258001085C3B00
   VCID: 2C020DEC4604B757461-8078
   Component: WWS57X 110305  H32 0051
   Serial number:         110307172109
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 11335226
   Coding: 02512B
   Subsystem 3 - Part No SW: 4G0 941 531 H    HW: 4G0 941 531 H
   Component: E1 - LDS  H07 0044
   Serial number: 07 03 2011  00000596
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R0D3G06
   Subsystem 5 - Part No SW: 8K0 959 772 C    HW: 8K0 959 772
   Component: SLR-B8  H05 0006
   Serial number:           1002383203
   Coding: 853000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000014031100010248
   Coding: 110000
   Subsystem 7 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000015031100010241
   Coding: 110000
   Subsystem 8 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0280
   Serial number: WA101139000000205461
   Coding: 020300
   Subsystem 9 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 38588895000000000001
Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
   Part No SW: 8X0 035 110 C    HW: 8X0 035 110
   Component: CDC-MP3-Pana  H41 0490
   Revision: 00000006
   VCID: 2D0400E87D1EBE5F51F-8078
   Part No SW: 4H0 919 475 J    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0032
   Revision: 11001001    Serial number: 55901102300615
   Coding: 300906
   ASAM Dataset: EV_EPHVA18AU57X0000 001002
   ROD: EV_EPHVA18AU57X0000_001.rod
   VCID: 392C24B8B9D612FFCD7-806C
   Part No SW: 4G0 907 561     HW: 4G0 907 561
   Component: ACC3          H15 0160
   Coding: 3601010202
   ASAM Dataset: EV_AdaptCruisContrAU57X 001003
   ROD: EV_AdaptCruisContrAU57X_001.rod
   VCID: 6788B2C09FE2540F6B3-8032
10240 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
          [FAULT_BLR_BLK8_31]
                    Mileage: 149920 km
                    Date: 2019.05.20
                    Time: 16:37:12
                    Control Module temperature: 36 °C
                    Voltage terminal 15: 13.939 V
                    Velocity_vehicle_reference: 37.25 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.05 m/s²
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_VIDEO_FAIL]
                    Reset counter: 0
                    Mileage: 147626 km
                    Date: 2019.02.06
                    Time: 18:12:29
                    Control Module temperature: 31 °C
                    Voltage terminal 15: 11.642 V
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H31 0032
   Revision: --------    Serial number: 003D8001200R
   Coding: 303234373131303030324A55304C34473053
   VCID: 333016909BBAE8AF07B-8066
   Serial number: 6940000Y160001G5EL0V
   Serial number: 3575HRB405J0BI7U293B
   Serial number: 3585HRB40550DUOGC1AO
   Serial number: 3515JRB405D0BTBEF8JS
   Serial number: 3525JRB405L0BTBEI9S7
   Serial number: 3554VRB40650FUO8K8F6
   Serial number: 3564VRB40610FUO8M0I0
   Component: Lenks.Modul   H03 0003
   Revision: --------    Serial number: 90372KCF0001P
   Coding: 00003C
   VCID: 372822808F42048F3B3-8062
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Serial number: 28 10 2013  E0274985
   Part No SW: 4G8 920 981 M    HW: 4G8 920 981 M
   Component: TBenUsaAccNv  H34 0312
   Revision: 19100074    Serial number: 658140311592024
   Coding: 0BC609040F01D705020000
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K_AU57.rod
   VCID: 3D2430A8ADFE2EDFE1F-8068
   Part No SW: 4G0 907 468 C    HW: 4G0 907 468 A
   Component: J533--Gateway H08 0204
   Revision: --------    Serial number: 00000000117220
   Coding: 00C1033000
   ROD: EV_GatewUDS_AU57.rod
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650740619
   Part No SW: 4G0 919 158 C    HW: 4G0 919 158 C
   Component: KLIMA FOND    H07 0056
   Serial number: 24031100040020
   Coding: 00
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
   VCID: 2F381AE07792CC4F633-807A
   Part No SW: 4G8 959 760 A    HW: 4G8 959 760 A
   Component: MEM-FS        H03 0153
   Revision: AA000000    Serial number: 00000005220515
   Coding: C0581B008F002001000001010101102030303232203232
   VCID: 382A21BC825C0BF7329-806C
   Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
   Component: SARA 6D       H02 0004
   Revision: --------    Serial number: EJ1BPA4200JBVI0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 2D0400E87D9EBE5F51F-8078
   Part No SW: 4G0 907 566 C    HW: 4G0 907 566
   Component: J769  SWA MasterH01 0020
   Revision: 00H01000    Serial number: 6PZ 010 287-01
   Coding: 0000001
   VCID: 2F381AE07B12CC4F633-807A
   Subsystem 1 - Part No: 4G0 907 568 C
   Component: J770  SWA Slave H01 0020
   Subsystem 2 - Serial number: 6PZ 010 287-21
   Subsystem 3 - Serial number: 5F19.03.1100H010003CD20342ÿ
   Subsystem 4 - Serial number: D20342ÿ
   Part No SW: 4G8 959 793 B    HW: 4G8 959 793
   Component: TSG FA        H04 0210
   Coding: 011F17205E00628002000003
   Shop #: WSC 02312 785 00200
   VCID: 3FD84AA0A7723CCFF33-806A
   Part No SW: 4G0 909 144 L    HW: 4G0 909 144 F
   Component: RCEPS         H32 0010
   Revision: 00001000    Serial number: 0022050857
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323E139464A0E1A70CD-8066
   Revision: 00002001    Serial number: 0144585354
   Coding: 0106023A00FA448580B00880020500000000000000000000000000000000
   Component: GTO BF  H01 0070
   Serial number: 00000000000000025960
   Subsystem 3 - Part No SW: 7P5 959 591     HW: 4H0 959 591
   Component: J245 PS40.033  H07 0006
   Serial number:     WOO1160108Y
   Coding: 001F00
   Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
   Serial number: 0000000AP00000177663
03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
                    Fault Frequency: 46
                    Reset counter: 38
                    Mileage: 148613 km
                    Date: 2019.03.30
                    Time: 15:30:00
02771 - Bulb for Left Brake / Turn Signal / Tail Lamp (M69)
                    Fault Status: 00101100
                    Reset counter: 32
                    Mileage: 153091 km
                    Date: 2019.09.14
                    Time: 12:05:48
   Part No SW: 4G0 035 465 A    HW: 4G0 035 465
   Component: BO G3 C7      H07 0130
   Revision: 05S00000    Serial number: 0011623
   VCID: 2310E6D02BDA782FF7B-8076
   Subsystem 1 - Part No SW: 4G0 035 466     HW: 4G0 035 466
   Component: BO C7 SLAVE  H51 0100
   Serial number: 01602110001907
                    Reset counter: 79
                    Voltage: 12.00 V
                    Temperature: 39.0°C
                    Bin. Bits: 00000100
                    Voltage: 12.00 V
                    Temperature: 40.0°C
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
   Part No SW: 4G8 959 792 C    HW: 4G8 959 792 A
   Component: TSG BF        H04 0210
   Coding: 011F17205E00628002000002
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000050992
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A0E0BF44C70A967B4D-807E
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 110322-0004-071
   Coding: 1221A6601002A400
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C020DEC4684B757461-8078
   Component: Radio U SIRIU H51 0133
   Revision: AB001007    Serial number: 156CR0B7502209
   Coding: 020007010000000001
   VCID: 2412E5CC2ED47F178E1-8070
   Part No SW: 4G0 035 746 E    HW: 4G0 035 746
   Component: H-BNT-NA      H48 0735
   Revision: --------    Serial number: 031CE0B7503500
   Coding: 050200000003EDEF75168B2E00000003100001000000000000
   VCID: 290CF4F849F6A27FBD7-807C
   Subsystem 1 - Part No: 8R0 060 884 AC
   Component: NAR 2011  0503
   Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDB1300GQ1H
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 612 L
   Component: E380 BDT C7  H08 0204
   Serial number: 90349KCL0006Y
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
   Part No SW: 4G8 959 795 C    HW: 4G8 959 795 A
   Component: TSG HL        H03 0210
   Coding: 010F17204000628002000002
   VCID: 42DE4354D48051279CD-8016
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 A    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0050
   Revision: --H04---    Serial number: 525 PA8J13F05D
   Coding: 1020004
   VCID: 2514F8C829EE861F99F-8070
02203 - Audio / Video Input 1
                    Fault Status: 00101011
                    Fault Frequency: 11
                    Reset counter: 25
                    Mileage: 150083 km
                    Date: 2019.05.20
                    Time: 18:03:44
                        Reverse OFF
                    Count: 3
   Component: TSG HR        H03 0210
Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604     HW: 4G0 919 604
   Component: HeadUpDisplay 017 0042
   Coding: D20000
   ASAM Dataset: EV_HUDContiC7 001020
   ROD: EV_HUDContiC7.rod
   VCID: 688AB1FC92FC5B77629-803C
Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
   Part No SW: 4H0 907 547 E    HW: 4H0 907 547
   Component: NV-ECU-Gen1   H09 0026
   Serial number: 0K84AE40027954
   Coding: 1311
   ASAM Dataset: EV_NightVisioGen1 001002
   ROD: EV_NightVisioGen1.rod
   VCID: 313C1C9861A6DABF757-8064
   Night vision system camera:
   Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
   Component: NV-CAM-Gen1  H08 0007
   Serial number: 00000000001103300642
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H24 0034
   Coding: 6A060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 6594B8C865EE461F59F-8030
   Part No SW: 4G0 907 541     HW: 4G0 907 541
   Coding: 3601010202
   ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
   ROD: EV_AdaptCruisContr2AU57X_001.rod
   Part No SW: 4G0 907 107 B    HW: 4H0 907 107
   Component: BV-SG         H28 0034
   Serial number: 000040180903117
   Coding: 048198180111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 2514F8C8256E861F99F-8070
0080 - Video Cable for Image Processing
          C1107 02 [024] - Signal Failure
          [No_connection_to_camera]
                    Reset counter: 223
                    Mileage: 152082 km
                    Date: 2019.08.13
                    Time: 17:57:27
                    Outside air temperature: 37.5 °C
                    Voltage terminal 15: 13.1 V
                    Control Module temperature: 38.0 °C
0161 - Video Cable for Image Processing
          C1107 02 [009] - Signal Failure
          [No_camera_found_on_startup]
                    Fault Frequency: 236
                    Reset counter: 0
                    Mileage: 150373 km
                    Date: 2019.06.02
                    Time: 10:16:14
                    Outside air temperature: 29.0 °C
                    Voltage terminal 15: 13.0 V
                    Control Module temperature: 25.0 °C
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 0066E608031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 6FB8DAE0B7128C4F233-803A
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 70BAD99CAA2C93B73A9-8024
End----------(Elapsed Time: 02:46, VBatt start/end: 13.4V/14.1V)-----------
