2011 JSW and stupid TPMS question with VCDS
carboncow
Central Ohio
C?ID=266014
I'm not sure why VW makes this so hard on us. My 2008 Toareg told me what the pressure was on each tire. Now I got the dummy light on for 2011 Jetta Sportwagen and I pulled out my trusty VCDS to only find out it will not tell me which wheel is offending.
Also the error code message stated something about pressure (forgot to take screenshot). Is there a different message if the sender is offline (dead battery?) such as low signal or does it just give a generic low pressure message?
FYI I put my tire gauge on all 4 tires and really cannot figure out which one may have lower pressure...although I'm questioning the health of my ancient pressure gauge.
Is there a live pressure value I can track in the system?
Have you posted an Auto-Scan from this car? Does it actually have sensor-based ("direct") TPMS? Because that's kind of a per-requisite in order for it to be able to show you (or know) the individual pressures. Lots of newer cars have indirect TPMS based on a crazy analysis of wheel speed measurements.
carboncow
Central Ohio
C?ID=266014
Uwe,
Thanks for jogging my brain on that tech...now that you say this I seem to recall reading about that kind of tech...just never thought my lowly Jetta would have that. I've only got the mobile scanner handy this week since my laptop is offline. I've included a couple screenshots from the version. Maybe someone can tell me if data shows what type of TPMS I have.
When I got home last night I reset the TPMS with the button in the glove box and after a 60 mile commute to work it didn't return. (this is the 2nd time in two weeks the light has come on). So wondering if the issue is the sensor itself or in the case of wheel speed measurement maybe it's getting a bad value.
QUESTION: Does a full Auto-Scan show more information about a singular module more then what I just shared from the ABS/Brake screens?
QUESTION #2: Is there no way to upload a screenshot to this forum? It's all txt and URL based for such needs?
If there's reset button in the glovebox, I think chances are quite good that this car has an indirect system. Another thing you can do is look at the valve stems. Direct systems use metal valve stems connected to the sensors inside the wheels. Indirect systems use traditional rubber valve stems.
A full Auto-Scan shows how the entire car is equipped. A direct TPMS system will ususally have its own control module, although in some case they are integrated into the BCM or CCM.
That is correct. We do not wish to be responsible for hosting content that might infringe on someone's IP right (particularly VW's!)
carboncow
Central Ohio
C?ID=266014
Button in glove box
Black mental vale stems
The low tire fault code showed up in the ABS module
I'd saw we prob have individual old school TPMS based on your points.
Does a bad sensor throw a low value code or does it show another code such as missing signal?
I don't think so. The ABS is not involved in a direct (sensor-based) system.
South Molton, UK
That's indicative that you have an INDIRECT TPMS system which doesn't have wheel pressure sensors, with a direct TPMS system the fault code would show in the separate TPMS module.
carboncow
Central Ohio
C?ID=266014
That's indicative that you have an INDIRECT TMPS system which doesn't have wheel pressure sensors, with a direct TPMS system the fault code would show in the separate TPMS module.
OK...so the metal valve stems really doesn't confirm much then.
So with the fault code in the ABS and the button in the glove box I'm INDIRECT then.
Are we then stating I should (or should not) be able to get individual pressure values in live data? As I'm not seeing it as a check box option anywhere in the ABS module.
What is the failure trend with the INDIRECT system? I got a error (low pressure) a few weeks back, rotated the tires and got another error (low pressure) this week.
South Molton, UK
Since an INDIRECT system does not have pressure sensors in the wheels, there is no way to see pressure values as live data.
The indirect systems have software that analyses the data from all the ABS wheel speed sensors and looks for changes in the patterns of wheel rotation (not just speed but also vibration, etc.).
It sounds to me like you may have a deformed wheel (hit any large objects or curbs recently?) or a tire that either has some uneven wear patterns or some sidewall damage. I would inspect each wheel/tire carefully.
Any possibility they are aftermarket?
Maybe you could post an Auto-Scan? VCDS-Mobile can do an Auto-Scan. ;)
Did you reset the system after rotating the tires? Make sure they are inflated properly, reset using the button, and let it learn. I would not be at all surprised to see a warning from an indirect system sometime after after rotating the tires if it has not been told to re-learn after the rotation.
carboncow
Central Ohio
C?ID=266014
1. Very posible as this car was bought used and they are 16" OEM wheels, not the standard setup for the JSW SE
2. Yeah...yeah...yeah. I got it, I just find it to be a mild PIA when in AP mode! Plus, isn't there a way to have it appear in a scrollable window on this forum?
3. The warning occurred before and after the rotate with a reset/relearn in between. With that said I've always had vibration in one of the wheels. Sometimes my tech gets it balanced out and sometimes (like now) it's pronounced above 65MPH...so good chance this is a culprit and although not any worse some variable has prob changed. Been kicking around the idea of new wheels to eliminate the vibration (as it's not tie rods, ball joints, inner drivers, ect).
VCDS Mobile 0.4508.0.4
VIN: 3VWPZ7AJ5BM612681
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
[B]03-ABS Brakes -- Status: OK 0000[/B]
Address 01: Engine    Labels: 07K-906-055-CBT.clb
    Part No SW: 07K 906 055 BE    HW: 07K906055
    Component: 2,5l R5/4V      G01  9213
    Revision: T4H04---    Serial Number:
    Coding: 0000075
    Shop #: WSC 08151 444 84507
    VCID: 72A749CB3BDE31D11D6675-8027
No fault codes found.
Address 02: Auto Trans    Labels: 09G-927-750.lbl
    Part No SW: 09G 927 750 LM    HW: 09G927750LM
    Component: AQ 250 6F            1734
    Revision: 00H90000    Serial Number:
    Coding: 0000840
    Shop #: WSC 00066 000 00000
    VCID: 8751881FA05CA479DA584C-80D2
[B]Address 03: ABS Brakes  (J104)    Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
    Component: ESP MK60EC1   H30 0106
    Revision: 00H30001
    Coding: 114B400C492300FC881102EC921A0041B70000
    VCID: 74AB4FD341CABFE10F9A63-8021[/B]
Address 08: Auto HVAC  (J301)    Labels: 3C8-907-336.clb
    Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
    Revision: 00009001
    Coding: 0000001002
    Shop #: WSC 00066 000 00146
    ROD: N/A
    VCID: 75AD72D74AB0BEE9388496-8020
    No ASAM data for: "EV_Climatic"
Address 09: Cent. Elect.  (J519)    Labels: 1K0-937-08x-09.clb
    Part No SW: 5K0 937 084 E    HW: 5K0 937 084 E
    Component: BCM PQ35 B    011 0035
    Revision: BG011001
    Coding: 2D380E1F902F3EC400080081600000C401000086435D8D60648020000040
    VCID: 342B8FD3014AFFE1CF1AA3-8061
    Subsystem 1 -  Part No SW: 1K1-955-119-F    Labels: 1Kx-955-119.clb
    Component: Wischer 2907121  0512
    Coding: 009795
Address 15: Airbags  (J234)    Labels: 5K0-959-655.clb
    Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
    Component: AirbagVW10G   021 0706
    Coding: 00003044
    ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
    ROD: N/A
    VCID: 3935BEE726281A891C2CEA-806C
    No ASAM data for: "EV_AirbaVW10SMEVW360"
    Subsystem 1 -  Part No SW: 1KM-959-339
    Component: BF-Gewichtss.007 0001
    Serial Number: ---0000R--0005BXZ300
    Subsystem 2 -  Part No SW: 1KM-955-557
    Component: S.Sens.Fahr.VH01 ----
    Serial Number: 3572MSME6A0E3154ZZZ-
    Subsystem 3 -  Part No SW: 1KM-955-557
    Component: S.Sens.Beif.VH01 ----
    Serial Number: 3582MSME03393654ZZZR
    Subsystem 4 -  Component: S.Sens.Fahr.H--- ----
    Serial Number: 3511HSME5C675422ZZZO
    Subsystem 5 -  Component: S.Sens.Beif.H--- ----
    Serial Number: 3521HSME16094A22ZZZG
    Subsystem 6 -  Component: F.Sens.Fahr  --- ----
    Serial Number: 35527SME361D7721ZZZG
    Subsystem 7 -  Component: F.Sens.Beif  --- ----
    Serial Number: 35627SME2C4A4421ZZZG
Address 16: Steering wheel  (J527)    Labels: 5K-16.lbl
    Component: Lenks.Modul   007 0080
    Revision: --------
    Coding: 188A140000
    Shop #: WSC 00066 000 00186
    ROD: N/A
    VCID: 76AF75DB57B6B5F1318E89-8023
    No ASAM data for: "EV_SMLSNGKUDS"
Address 17: Instruments  (J285)    Labels: 5K0-920-xxx-17.clb
    Part No SW: 5K0 920 971 B    HW: 5K0 920 971 B
    Component: KOMBI         H03 0406
    Coding: 270F01
    ROD: N/A
    VCID: 2E1F9DBBEF66CD31B9DE61-807B
    No ASAM data for: "EV_Kombi_UDS_VDD_RM09"
Address 19: CAN Gateway    Labels: 7N0-907-530-V1.clb
    Part No SW: 7N0 907 530 A    HW: 1K0907951
    Component: J533  Gateway   H25  5603
    Revision:   H25    Serial Number: 03081001200958
    Coding: ED807F0600160300002002
    Shop #: WSC 00066 123 12345
    VCID: 2E1F9DBBEF665531B9DE61-807B
Address 1C: Position Sensing    Labels: 1Kx-919-xxx-1C.lbl
    Part No SW: 5N0 919 879    HW: 5N0919879
    Component: Kompass         001  0001
    Revision: 00001000    Serial Number: 1225223R99HH06
    Coding: 0000002
    VCID: FEBFEDFBFF86E5B1E9FE71-80AB
Address 25: Immobilizer  (J334)    Labels: 5K0-920-xxx-25.clb
    Part No SW: 5K0 953 234    HW: 5K0 953 234
    Component: IMMO          H03 0406
    ROD: N/A
    VCID: EA97D1AB930EE11125368D-80BF
    No ASAM data for: "EV_Immo_UDS_VDD_RM09"
Address 42: Door Elect, Driver  (J386)    Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 3C0 959 701 B    HW: 3C0 959 793
    Component: TUER-SG FT    002 0307
    Revision: 13101005
    Coding: 0004B5
    Shop #: WSC 01383 790 50316
    ROD: N/A
    VCID: 2711689FC09C9C797A982C-8072
    No ASAM data for: "EV_DCU42BroseDriveSide"
Address 44: Steering Assist    Labels: 1Kx-909-14x-44.clb
    Part No SW: 1K0 909 144 J
    Component: EPS_ZFLS Kl. 70      3001
    Revision: 00H17000
    Shop #: WSC 02069 000 90108
    VCID: 312586C7FE584AC9A4FC82-8064
Address 46: Failed to respond
Address 4F: Centr. Electr. II  (J520)    Labels: 1K0-907-532.clb
    Part No SW: 7N0 907 532    HW: 1K0 907 951
    Component: EZE_2         H25 5603
    Revision:   H25
    Coding: 000B0500
    VCID: EFA1C0BFA8EC1C397248D4-80BA
02071 - Local Databus
    000 -  -
Address 52: Door Elect, Pass.  (J387)    Labels: 3C0-959-70X-GEN4.clb
    Part No SW: 3C0 959 702 B    HW: 3C0 959 792
    Component: TUER-SG BT    002 0307
    Revision: 15101005
    Coding: 0004B4
    ROD: N/A
    VCID: 28136BA3CD829301738227-807D
    No ASAM data for: "EV_DCU52BrosePasseSide"
Address 56: Radio  (J503)    Labels: 5M0-035-1xx-56.clb
    Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
    Component: MIB2-S-R-CN   036 0317
    Revision: -----001
    Coding: 1700040004000A
    Shop #: WSC 00081 790 00117
    VCID: 46CFC51B67D67D7161AE99-8013
00856 - Radio Antenna
    007 - Short to Ground
Address 77: Telephone  (J412)    Labels: 7P6-035-730.clb
    Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
    Component: TELEFON       H05 0440
    Revision: 1B001001
    Coding: 0A00000000010100
    ASAM Dataset: UHVNA A01007
    ROD: N/A
    VCID: 322789CBFB5EE9D1DDE6B5-8067
    No ASAM data for: "UHVNA"
9457427 - ROD - Unknown faultcode
9457171 - ROD - Unknown faultcode
End--(Elapsed Time: 02:11, VBatt start/end: 12.2/12.0 Vign: 0.0)-
I see no TPMS module.
ABS Coding indicates "Tire Pressure Monitoring (TPMS/PR-7K6)", which I think is indirect.
carboncow
Central Ohio
C?ID=266014
Thx. So you ran that code thru something on your side that spits out the TPMS/PR-7k6?
Well, that something is my brain, against the few bits in the MK60EC1 coding that I have familiarity with.
Also, with the VIN, there are people here who can pull the complete PR-Codes from an official parts catalog site, but I'm not one of them.
MasterTommy
Amsterdam
C?ID=295586
One of the many online PR decoders spits out ‘7K6 RDK Indirect Tire Pressure Monitoring System’.
South Molton, UK
Sounds like you may be closer to finding the cause...
United States
Any deviation in WSS readings (i.e. wheel/tire issues, wheel speed sensor issues, rusted wheel bearing pick-up, etc) will prevent indirect TPMS from learning pressures and/or set false pressure codes so the guys already have you on the right path.
I can confirm your vehicle was factory equipped with 7K6 Indirect (ABS based) TPMS.
2006 - 2010 Golf 5 and 6 based US models used direct TPMS however they did NOT have wheel position recognition like your T'reg. PR-Codes can be obtained using PartsLink24. Your full list is:
[TABLE="class: vinInfoTable"]
[TR]
[TH]Vehicle Identification No.[/TH]
[TD="colspan: 2"]3VWPZ7AJ5BM612681[/TD]
[/TR]
[TR]
[TH]Model[/TH]
[TD="colspan: 2"]Jetta Variant
GOV[/TD]
[/TR]
[TR]
[TH]Date of production[/TH]
[TD="colspan: 2"]05.08.2010[/TD]
[/TR]
[TR]
[TH]Model year[/TH]
[TD="colspan: 2"]2011[/TD]
[/TR]
[TR]
[TH]Sales type[/TH]
[TD="colspan: 2"]AJ53S3[/TD]
[/TR]
[TR]
[TH]Engine Code[/TH]
[TD="colspan: 2"]CBUA[/TD]
[/TR]
[TR]
[TH]Transmission Code[/TH]
[TD="colspan: 2"]MAN[/TD]
[/TR]
[TR]
[TH]Axle drive[/TH]
[TD="colspan: 2"]6A[/TD]
[/TR]
[TR]
[TH]Equipment[/TH]
[TD="colspan: 2"]NT[/TD]
[/TR]
[TR]
[TH]Roof color[/TH]
[TD="colspan: 2"]4Y[/TD]
[/TR]
[TR]
[TH]Carpet color code[/TH]
[TD="colspan: 2"][/TD]
[/TR]
[TR]
[TH]Exterior color / Paint Code[/TH]
[TD="colspan: 2"]4Y / A3H[/TD]
[/TR]
[TR]
[TH]Seat combination no.[/TH]
[/TR]
[TR]
[TH]Number of Z-Orders[/TH]
[/TR]
[/TABLE]
[TR]
[TH]Special editions[/TH]
[TD="class: prCode"]E0A[/TD]
[TD]Without special action equipment[/TD]
[/TR]
[TR]
[TH]Lockable wheel bolts[/TH]
[TD="class: prCode"]1PE[/TD]
[TD]Wheel bolts with anti-theft protection
(unlockable)[/TD]
[/TR]
[TR]
[TH]Vehicle class differentiation
units/platform components[/TH]
[TD="class: prCode"]0HM[/TD]
[TD]Vehicle class differentiation -1KM-
Build status corresponds to production
in Mexico[/TD]
[/TR]
[TR]
[TH]tail pipe[/TH]
[TD="class: prCode"]0P1[/TD]
[TD]Rear side exhaust tailpipe[/TD]
[/TR]
[TR]
[TH]drive-off assistance[/TH]
[TD="class: prCode"]UG1[/TD]
[TD]Hill hold control[/TD]
[/TR]
[TR]
[TH]Emission standard[/TH]
[TD="class: prCode"]0GT[/TD]
[TD]Emission standard SULEV[/TD]
[/TR]
[TR]
[TH]Trailer hitch[/TH]
[TD="class: prCode"]1D0[/TD]
[TD]without trailer towing[/TD]
[/TR]
[TR]
[TH]airbag[/TH]
[TD="class: prCode"]4UM[/TD]
[TD]Driver's and front passenger air bag, NAR with front
passenger air bag deactivation (2-stage) -
SMART airbag with automatic deactivation[/TD]
[/TR]
[TR]
[TH]Aktivkohlebehälter / Ottopartikelfilter[/TH]
[TD="class: prCode"]1E7[/TD]
[TD]Activated carbon canister (ORVR), for
intensified evaporation system,
siphoning device for fueling[/TD]
[/TR]
[TR]
[TH]Aerials[/TH]
[TD="class: prCode"]8L6[/TD]
[TD]"diversity" window antenna[/TD]
[/TR]
[TR]
[TH]Exterior mirror setting[/TH]
[TD="class: prCode"]6XN[/TD]
[TD]Exterior mirrors, power-adjustable/
separately heated[/TD]
[/TR]
[TR]
[TH]Left exterior mirror[/TH]
[TD="class: prCode"]5SH[/TD]
[TD]Left exterior mirror, flat (US)[/TD]
[/TR]
[TR]
[TH]Right exterior mirror[/TH]
[TD="class: prCode"]5RR[/TD]
[TD]Right exterior mirror, convex (US)[/TD]
[/TR]
[TR]
[TH]Drive type[/TH]
[TD="class: prCode"]1X0[/TD]
[TD]Front-wheel drive[/TD]
[/TR]
[TR]
[TH]"Multimedia"video/DVD/notebook connection[/TH]
[TD="class: prCode"]9WL[/TD]
[TD]Jack for external audio source[/TD]
[/TR]
[TR]
[TH]Equipment levels[/TH]
[TD="class: prCode"]A8C[/TD]
[TD]Comfort equipment[/TD]
[/TR]
[TR]
[TH]Brake type in rear[/TH]
[TD="class: prCode"]1KS[/TD]
[TD]Disc brakes in rear (Geomet D)[/TD]
[/TR]
[TR]
[TH]batteries[/TH]
[TD="class: prCode"]J1L[/TD]
[TD]Battery 280 A (60 Ah)[/TD]
[/TR]
[TR]
[TH]Brake type, front[/TH]
[TD="class: prCode"]1ZP[/TD]
[TD]Disc brakes in front (Geomet D)[/TD]
[/TR]
[TR]
[TH]Components with special surface[/TH]
[TD="class: prCode"]6FF[/TD]
[TD]Exterior mirror housing and various attachments
colour coded to vehicle[/TD]
[/TR]
[TR]
[TH]Battery/alternator capacity[/TH]
[TD="class: prCode"]NY0[/TD]
[TD]Standard battery/alternator capacity[/TD]
[/TR]
[TR]
[TH]Component part sets with
country-specific design requirements[/TH]
[TD="class: prCode"]B0D[/TD]
[TD]Assembly kit, USA corresponding vehicle
version (not California), various parts[/TD]
[/TR]
[TR]
[TH]vehicle tools and jack[/TH]
[TD="class: prCode"]1S1[/TD]
[TD]vehicle tools and jack[/TD]
[/TR]
[TR]
[TH]Brake systems[/TH]
[TD="class: prCode"]1AT[/TD]
[TD]Electronic stability control (ESC)[/TD]
[/TR]
[TR]
[TH]Owner's manuals[/TH]
[TD="class: prCode"]0VM[/TD]
[TD]Information kit in American English[/TD]
[/TR]
[TR]
[TH]Operating voltage[/TH]
[TD="class: prCode"]9Z0[/TD]
[TD]Operating voltage 12 V[/TD]
[/TR]
[TR]
[TH]brake wear indicator[/TH]
[TD="class: prCode"]9U1[/TD]
[TD]brake wear indicator[/TD]
[/TR]
[TR]
[TH]Heated washer nozzles[/TH]
[TD="class: prCode"]9T1[/TD]
[TD]Heated washer nozzles in front[/TD]
[/TR]
[TR]
[TH]CD ROM/DVD/SD card[/TH]
[TD="class: prCode"]7QA[/TD]
[TD]Without CD/DVD for navigation[/TD]
[/TR]
[TR]
[TH]CD changer/CD player[/TH]
[TD="class: prCode"]7A0[/TD]
[TD]Without CD changer/CD player[/TD]
[/TR]
[TR]
[TH]"Charism"[/TH]
[TD="class: prCode"]2H0[/TD]
[TD]Without "drive select"[/TD]
[/TR]
[TR]
[TH]Chrome package[/TH]
[TD="class: prCode"]QJ1[/TD]
[TD]Chrome package[/TD]
[/TR]
[TR]
[TH]General operating permit, alterations[/TH]
[TD="class: prCode"]C18[/TD]
[TD]Operating permit, alteration[/TD]
[/TR]
[TR]
[TH]Roof rails/roof load rack[/TH]
[TD="class: prCode"]3S2[/TD]
[TD]Black roof rails[/TD]
[/TR]
[TR]
[TH]Roof insert/convertible top[/TH]
[TD="class: prCode"]3FU[/TD]
[TD]Big roof system[/TD]
[/TR]
[TR]
[TH]Suspension system in rear[/TH]
[TD="class: prCode"]1JA[/TD]
[TD]Rear shock absorption, basic design 1[/TD]
[/TR]
[TR]
[TH]Suspension system in front[/TH]
[TD="class: prCode"]G46[/TD]
[TD]Shock absorption in front[/TD]
[/TR]
[TR]
[TH]Load-through hatch/ski bag[/TH]
[TD="class: prCode"]3X0[/TD]
[TD]without load through system[/TD]
[/TR]
[TR]
[TH]Insert for the filling up of unleaded
fuel/fuel type[/TH]
[TD="class: prCode"]2G7[/TD]
[TD]Filler neck module 1 with insert[/TD]
[/TR]
[TR]
[TH]Installation differentiation for components[/TH]
[TD="class: prCode"]0ER[/TD]
[TD]Installation differentiation for
transmission AQ250
-- vehicle components --[/TD]
[/TR]
[TR]
[TH]Theft protection system[/TH]
[TD="class: prCode"]7AG[/TD]
[TD]Electronic immobilizer
with anti-theft alarm system (for USA)[/TD]
[/TR]
[TR]
[TH]Inserts[/TH]
[TD="class: prCode"]5MB[/TD]
[TD]Decorative inserts[/TD]
[/TR]
[TR]
[TH]Scuff plates[/TH]
[TD="class: prCode"]7M5[/TD]
[TD]Without impact protection film for door sill[/TD]
[/TR]
[TR]
[TH]Park distance control[/TH]
[TD="class: prCode"]7X0[/TD]
[TD]Without park distance control[/TD]
[/TR]
[TR]
[TH]Electric interface for external use[/TH]
[TD="class: prCode"]UF0[/TD]
[TD]Without electric interface[/TD]
[/TR]
[TR]
[TH]Manufacturing sequence differentiation[/TH]
[TD="class: prCode"]0FL[/TD]
[TD]Mexico manufacturing sequence[/TD]
[/TR]
[TR]
[TH]window regulator[/TH]
[TD="class: prCode"]4R4[/TD]
[TD]Power windows with comfort operation and
circuit breaker[/TD]
[/TR]
[TR]
[TH]fire extinguisher[/TH]
[TD="class: prCode"]6A0[/TD]
[TD]without fire extinguisher[/TD]
[/TR]
[TR]
[TH]Pedestrian protection[/TH]
[TD="class: prCode"]VL0[/TD]
[TD]Standard pedestrian protection measures[/TD]
[/TR]
[TR]
[TH]Pedal cluster[/TH]
[TD="class: prCode"]VF0[/TD]
[TD]Standard pedal cluster[/TD]
[/TR]
[TR]
[TH]Headlight activation[/TH]
[TD="class: prCode"]8K4[/TD]
[TD]Separate daytime running lights
NAR[/TD]
[/TR]
[TR]
[TH]Vehicle tracing system[/TH]
[TD="class: prCode"]7G0[/TD]
[TD]Without preparation for VTS (Vehicle Tracing System)[/TD]
[/TR]
[TR]
[TH]Vehicle specifications[/TH]
[TD="class: prCode"]F0A[/TD]
[TD]No special purpose vehicle, standard
equipment[/TD]
[/TR]
[TR]
[TH]Alternators[/TH]
[TD="class: prCode"]8GU[/TD]
[TD]Alternator 140 A[/TD]
[/TR]
[TR]
[TH]Weight category rear axle[/TH]
[TD="class: prCode"]0YJ[/TD]
[TD]Weight range 9
installation control only, no
requirement forecast[/TD]
[/TR]
[TR]
[TH]Weight category front axle[/TH]
[TD="class: prCode"]L13[/TD]
[TD]Suspension range 13
[/TR]
[TR]
[TH]Base engine[/TH]
[TD="class: prCode"]T8K[/TD]
[TD]5-cylinder SI engine 2.5 l
unit 07K.1[/TD]
[/TR]
[TR]
[TH]Luggage netting/pocket on backrest(s)[/TH]
[TD="class: prCode"]4U5[/TD]
[TD]Luggage pockets on backrest[/TD]
[/TR]
[TR]
[TH]Luggage compartment cover[/TH]
[TD="class: prCode"]3U2[/TD]
[TD]Sliding trunk cover[/TD]
[/TR]
[TR]
[TH]cruise control system[/TH]
[TD="class: prCode"]8T2[/TD]
[TD]Electronic cruise control system (CCS)[/TD]
[/TR]
[TR]
[TH]Garage door opener[/TH]
[TD="class: prCode"]VC0[/TD]
[TD]without Garage door opener[/TD]
[/TR]
[TR]
[TH]Luggage compartment trim[/TH]
[TD="class: prCode"]5A2[/TD]
[TD]Comfort luggage compartment trim[/TD]
[/TR]
[TR]
[TH]Transmission specifications[/TH]
[TD="class: prCode"]G1A[/TD]
[TD]6-speed automatic transmission[/TD]
[/TR]
[TR]
[TH]Brackets[/TH]
[TD="class: prCode"]3P0[/TD]
[TD]Without bracket for first aid kit and
warning triangle[/TD]
[/TR]
[TR]
[TH]handle for hand brake lever[/TH]
[TD="class: prCode"]6PC[/TD]
[TD]handbrake lever grip (leather)[/TD]
[/TR]
[TR]
[TH]Rear spoiler[/TH]
[TD="class: prCode"]5J0[/TD]
[TD]Without rear spoiler[/TD]
[/TR]
[TR]
[TH]Rear window wiper and washer system[/TH]
[TD="class: prCode"]8M1[/TD]
[TD]Rear window wiper washer system with
intermittent wipe[/TD]
[/TR]
[TR]
[TH]Rear seats[/TH]
[TD="class: prCode"]3NE[/TD]
[TD]Rear seat bench/backrest, split folding
with center armrest[/TD]
[/TR]
[TR]
[TH]Heating and air-conditioning system[/TH]
[TD="class: prCode"]9AP[/TD]
[TD]Climatic air-conditioning system (semi-automatic)[/TD]
[/TR]
[TR]
[TH]Headlamps[/TH]
[TD="class: prCode"]8ES[/TD]
[TD]Twin headlamps for driving on the right,
with integrated high beam (US design)[/TD]
[/TR]
[TR]
[TH]Customized installation[/TH]
[TD="class: prCode"]FC0[/TD]
[TD]Without individual installation[/TD]
[/TR]
[TR]
[TH]Interior light in footwell[/TH]
[TD="class: prCode"]6T1[/TD]
[TD]Interior light in footwell[/TD]
[/TR]
[TR]
[TH]Instrument clusters[/TH]
[TD="class: prCode"]U5C[/TD]
[TD]Instrument cluster, mph speedometer
- USA -[/TD]
[/TR]
[TR]
[TH]Breakaway interior rearview mirror[/TH]
[TD="class: prCode"]4L2[/TD]
[TD]Breakaway interior rearview mirror,
dimming[/TD]
[/TR]
[TR]
[TH]Sticker (customized or special edition)[/TH]
[TD="class: prCode"]0KA[/TD]
[TD]Without decals and emblems[/TD]
[/TR]
[TR]
[TH]Body style[/TH]
[TD="class: prCode"]K8D[/TD]
[TD]Wagon/Avant[/TD]
[/TR]
[TR]
[TH]Cassette and CD storage unit[/TH]
[TD="class: prCode"]4W0[/TD]
[TD]without cassette / CD tray[/TD]
[/TR]
[TR]
[TH]coolbox[/TH]
[TD="class: prCode"]1W2[/TD]
[TD]Glove compartment cooling system[/TD]
[/TR]
[TR]
[TH]child safety[/TH]
[TD="class: prCode"]4H3[/TD]
[TD]Manual child lock[/TD]
[/TR]
[TR]
[TH]Electronic map cooling system[/TH]
[TD="class: prCode"]QS0[/TD]
[TD]Without electronic map cooling system[/TD]
[/TR]
[TR]
[TH]Child seats[/TH]
[TD="class: prCode"]QA0[/TD]
[TD]without child seat[/TD]
[/TR]
[TR]
[TH]Climatic zones[/TH]
[TD="class: prCode"]0Y2[/TD]
[TD]Tropical zones[/TD]
[/TR]
[TR]
[TH]Compass/road sign display[/TH]
[TD="class: prCode"]QR1[/TD]
[TD]With compass[/TD]
[/TR]
[TR]
[TH]headrest for seat, rear[/TH]
[TD="class: prCode"]3Q9[/TD]
[TD]Three rear head restraints[/TD]
[/TR]
[TR]
[TH]Head restraints[/TH]
[TD="class: prCode"]3J2[/TD]
[TD]Height-adjustable headrests[/TD]
[/TR]
[TR]
[TH]Fuel tank treatment[/TH]
[TD="class: prCode"]2LF[/TD]
[TD]Fuel tank with special material
treatment (coextrusion) with changed
protective layer[/TD]
[/TR]
[TR]
[TH]Fuel quantity for initial filling[/TH]
[TD="class: prCode"]1Z0[/TD]
[TD]Initial standard fuel filling[/TD]
[/TR]
[TR]
[TH]Fuel systems[/TH]
[TD="class: prCode"]1A1[/TD]
[TD]Fuel system for fuel-injected SI engine,
injection system without fuel return[/TD]
[/TR]
[TR]
[TH]Body measures[/TH]
[TD="class: prCode"]5C1[/TD]
[TD]Body measures for increased safety
requirements[/TD]
[/TR]
[TR]
[TH]Child seat anchors in front[/TH]
[TD="class: prCode"]3G0[/TD]
[TD]Without child seat anchora in front
(ISOFIX)[/TD]
[/TR]
[TR]
[TH]Radiator grille[/TH]
[TD="class: prCode"]6KC[/TD]
[TD]Radiator grille[/TD]
[/TR]
[TR]
[TH]Rear license plate bracket[/TH]
[TD="class: prCode"]6P2[/TD]
[TD]License plate bracket, rear (NAR)[/TD]
[/TR]
[TR]
[TH]Front license plate bracket[/TH]
[TD="class: prCode"]6W3[/TD]
[TD]License plate bracket front (small, NAR)[/TD]
[/TR]
[TR]
[TH]Paint preservative/transit coating[/TH]
[TD="class: prCode"]5K5[/TD]
[TD]Transport protection film with
additional transport protection measures[/TD]
[/TR]
[TR]
[TH]Paint coating[/TH]
[TD="class: prCode"]FB0[/TD]
[TD]standard paint coating[/TD]
[/TR]
[TR]
[TH]Rear cargo area[/TH]
[TD="class: prCode"]3GD[/TD]
[TD]Plane rear cargo area[/TD]
[/TR]
[TR]
[TH]Steering system arrangement[/TH]
[TD="class: prCode"]L0L[/TD]
[TD]Left-hand drive[/TD]
[/TR]
[TR]
[TH]Reading lamp[/TH]
[TD="class: prCode"]8S4[/TD]
[TD]Two reading lights front, two rear[/TD]
[/TR]
[TR]
[TH]steering[/TH]
[TD="class: prCode"]1N3[/TD]
[TD]Speed-related variable steering assist
(Servotronic)[/TD]
[/TR]
[TR]
[TH]Backrest release[/TH]
[TD="class: prCode"]3H0[/TD]
[TD]Without backrest release for front seats[/TD]
[/TR]
[TR]
[TH]Air duct, front area[/TH]
[TD="class: prCode"]VK1[/TD]
[TD]Air duct, type 1[/TD]
[/TR]
[TR]
[TH]Light control systems[/TH]
[TD="class: prCode"]8G0[/TD]
[TD]Without Light Assist[/TD]
[/TR]
[TR]
[TH]Load edge protection[/TH]
[TD="class: prCode"]2P1[/TD]
[TD]Plastic loading edge protection[/TD]
[/TR]
[TR]
[TH]Lumbar support[/TH]
[TD="class: prCode"]7P4[/TD]
[TD]Manually adjustable lumbar support in
front seats[/TD]
[/TR]
[TR]
[TH]steering wheels[/TH]
[TD="class: prCode"]2PP[/TD]
[TD]Leather-wrapped multi-function steering
wheel[/TD]
[/TR]
[TR]
[TH]Speaker installation[/TH]
[TD="class: prCode"]8RW[/TD]
[TD]10 speakers (passive)[/TD]
[/TR]
[TR]
[TH]Headlight range control[/TH]
[TD="class: prCode"]8Q0[/TD]
[TD]without beam length regulator[/TD]
[/TR]
[TR]
[TH]Center armrest[/TH]
[TD="class: prCode"]6E3[/TD]
[TD]Center armrest in front[/TD]
[/TR]
[TR]
[TH]Marten repeller[/TH]
[TD="class: prCode"]UM0[/TD]
[TD]Without marten repeller[/TD]
[/TR]
[TR]
[TH]Multi-function display/trip computer[/TH]
[TD="class: prCode"]9Q5[/TD]
[TD]Multi-function display with control[/TD]
[/TR]
[TR]
[TH]Engine cooling[/TH]
[TD="class: prCode"]8Z6[/TD]
[TD]Hot country[/TD]
[/TR]
[TR]
[TH]Engine specifications[/TH]
[TD="class: prCode"]D77[/TD]
[TD]5-cylinder SI engine 2.5 l/125 kW (20V)
(R-5)
base engine is T8K[/TD]
[/TR]
[TR]
[TH]Left vanity mirror[/TH]
[TD="class: prCode"]4SH[/TD]
[TD]Left vanity mirror illuminated with
cover and special mirror imprint (NAR),
extractable[/TD]
[/TR]
[TR]
[TH]Right vanity mirror[/TH]
[TD="class: prCode"]4TQ[/TD]
[TD]Vanity mirror, right, illuminated, with
cover and special mirror imprint (NAR)[/TD]
[/TR]
[TR]
[TH]Navigation device[/TH]
[TD="class: prCode"]7Q0[/TD]
[TD]without navigation system[/TD]
[/TR]
[TR]
[TH]rear fog lamp[/TH]
[TD="class: prCode"]8TA[/TD]
[TD]witout rear fog lamp[/TD]
[/TR]
[TR]
[TH]Front fog lamp/additional headlamp[/TH]
[TD="class: prCode"]8WA[/TD]
[TD]Without fog lights[/TD]
[/TR]
[TR]
[TH]Upgrading measures[/TH]
[TD="class: prCode"]GP1[/TD]
[TD]Vehicles with special upgrade measures[/TD]
[/TR]
[TR]
[TH]Rear of platform module base[/TH]
[TD="class: prCode"]4P3[/TD]
[TD]Rear floor panel module, type 4[/TD]
[/TR]
[TR]
[TH]Platform group class[/TH]
[TD="class: prCode"]7PA[/TD]
[TD]Platform group class 1[/TD]
[/TR]
[TR]
[TH]Hubcaps[/TH]
[TD="class: prCode"]1NL[/TD]
[TD]Trims for alloy wheels[/TD]
[/TR]
[TR]
[TH]Wheels[/TH]
[TD="class: prCode"]CV0[/TD]
[TD]Alloy wheels 7J x 17[/TD]
[/TR]
[TR]
[TH]Radios[/TH]
[TD="class: prCode"]8AX[/TD]
[TD]Radio Premium 8[/TD]
[/TR]
[TR]
[TH]Smoker's/non-smoker's package[/TH]
[TD="class: prCode"]9JF[/TD]
[TD]Non-smoking package (NAR)[/TD]
[/TR]
[TR]
[TH]Tire pressure monitoring system[/TH]
[TD="class: prCode"]7K6[/TD]
[TD]Tire pressure monitoring system[/TD]
[/TR]
[TR]
[TH]tire[/TH]
[TD="class: prCode"]H7K[/TD]
[TD]All-season tires 225/45 R17 91H (NAR)[/TD]
[/TR]
[TR]
[TH]Tire suppliers[/TH]
[TD="class: prCode"]V0A[/TD]
[TD]Tires without specification of tire
brand[/TD]
[/TR]
[TR]
[TH]Spare wheel/breakdown kit[/TH]
[TD="class: prCode"]1G1[/TD]
[TD]Space-saving spare wheel[/TD]
[/TR]
[TR]
[TH]Restraint systems, front[/TH]
[TD="class: prCode"]4QQ[/TD]
[TD]3-point seat belts in front with
pretensioner and height adjustment,
US label[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]P75[/TD]
[TD]Panoramic sunroof & 17-inch alloy
wheelspackage[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]PMC[/TD]
[TD]California emission standard[/TD]
[/TR]
[TR]
[TH][/TH]
[TD="class: prCode"]WSE[/TD]
[TD]WAGON SE (US)[/TD]
[/TR]
[TR]
[TH]Side airbag[/TH]
[TD="class: prCode"]4X3[/TD]
[TD]Side airbag in front, with curtain
airbag[/TD]
[/TR]
[TR]
[TH]Gearshift knob/handle[/TH]
[TD="class: prCode"]6Q2[/TD]
[TD]Gearshift knob/handle in leather[/TD]
[/TR]
[TR]
[TH]Special labels/plates[/TH]
[TD="class: prCode"]0SS[/TD]
[TD]Labels in English and French[/TD]
[/TR]
[TR]
[TH]Locking mechanism for boot lid/cover
rear[/TH]
[TD="class: prCode"]4E2[/TD]
[TD]Tailgate/trunk lid release
from inside (electrically)[/TD]
[/TR]
[TR]
[TH]Front seat, left[/TH]
[TD="class: prCode"]3TF[/TD]
[TD]Front left comfort seat[/TD]
[/TR]
[TR]
[TH]Front seat, right[/TH]
[TD="class: prCode"]3SF[/TD]
[TD]Comfort seat, front right[/TD]
[/TR]
[TR]
[TH]Nameplates for sales name[/TH]
[TD="class: prCode"]QD3[/TD]
[TD]Lettering for sales name[/TD]
[/TR]
[TR]
[TH]Seat belt check[/TH]
[TD="class: prCode"]9P7[/TD]
[TD]Visual and acoustic seat belt reminder,
electric contact in buckle[/TD]
[/TR]
[TR]
[TH]Outer rear seat belts[/TH]
[TD="class: prCode"]3ZD[/TD]
[TD]3-point seat belts, outer rear with US
label[/TD]
[/TR]
[TR]
[TH]Center rear seat belts[/TH]
[TD="class: prCode"]3C8[/TD]
[TD]3-point seat belt, center rear with US
label[/TD]
[/TR]
[TR]
[TH]seat covers[/TH]
[TD="class: prCode"]N2Q[/TD]
[TD]Seat trim covers in leatherette[/TD]
[/TR]
[TR]
[TH]Seat adjustment[/TH]
[TD="class: prCode"]3PT[/TD]
[TD]Manual height adjustment for front seats[/TD]
[/TR]
[TR]
[TH]seat heater[/TH]
[TD="class: prCode"]4A3[/TD]
[TD]seat heating for front seats separat controlable[/TD]
[/TR]
[TR]
[TH]Safety head restraint system[/TH]
[TD="class: prCode"]3K0[/TD]
[TD]w/o safety head restraint system[/TD]
[/TR]
[TR]
[TH]Side lights[/TH]
[TD="class: prCode"]7R4[/TD]
[TD]Side marker lamps and turn signal
repeaters (turn signals with white lens)[/TD]
[/TR]
[TR]
[TH]Start-stop system/regenerative braking[/TH]
[TD="class: prCode"]7L3[/TD]
[TD]Without start/stop system without
regenerative braking[/TD]
[/TR]
[TR]
[TH]Horns[/TH]
[TD="class: prCode"]8Y1[/TD]
[TD]Two-tone horn[/TD]
[/TR]
[TR]
[TH]Side and rear windows[/TH]
[TD="class: prCode"]4KC[/TD]
[TD]Side and rear windows in heat-insulating
glass[/TD]
[/TR]
[TR]
[TH]Protective side molding[/TH]
[TD="class: prCode"]4B0[/TD]
[TD]with no protective side strip[/TD]
[/TR]
[TR]
[TH]Sunroof roller blind for rear/side windows[/TH]
[TD="class: prCode"]3Y0[/TD]
[TD]without roller blind[/TD]
[/TR]
[TR]
[TH]Supertone system and tone sequence
control[/TH]
[TD="class: prCode"]9J0[/TD]
[TD]Without supertone system and tone
sequence control[/TD]
[/TR]
[TR]
[TH]power outlet[/TH]
[TD="class: prCode"]7B2[/TD]
[TD]12 volt socket in luggage compartment[/TD]
[/TR]
[TR]
[TH]Bumper[/TH]
[TD="class: prCode"]2JB[/TD]
[TD]Standard bumpers[/TD]
[/TR]
[TR]
[TH]Rear stabilizer[/TH]
[TD="class: prCode"]0BG[/TD]
[TD]Rear stabilizer[/TD]
[/TR]
[TR]
[TH]Front stabilizer bar[/TH]
[TD="class: prCode"]0AH[/TD]
[TD]Front stabilizer bar[/TD]
[/TR]
[TR]
[TH]Drawers under front seats[/TH]
[TD="class: prCode"]QN0[/TD]
[TD]Without drawers under front seats[/TD]
[/TR]
[TR]
[TH]Heavy-duty/sports version[/TH]
[TD="class: prCode"]2UA[/TD]
[TD]Standard design[/TD]
[/TR]
[TR]
[TH]Headlamp washer system[/TH]
[TD="class: prCode"]8X0[/TD]
[TD]Without headlamp washer system[/TD]
[/TR]
[TR]
[TH]Windshield wiper intermittent control/
light/rain sensor[/TH]
[TD="class: prCode"]8N4[/TD]
[TD]Windshield wiper intermittent control
with potentiometer (four speeds)[/TD]
[/TR]
[TR]
[TH]Special approval measures[/TH]
[TD="class: prCode"]3M0[/TD]
[TD]Without special measures[/TD]
[/TR]
[TR]
[TH]Nameplate set[/TH]
[TD="class: prCode"]0QM[/TD]
[TD]Nameplate set "SE"[/TD]
[/TR]
[TR]
[TH]Special alarm systems[/TH]
[TD="class: prCode"]9A0[/TD]
[TD]Without taxi alarm system[/TD]
[/TR]
[TR]
[TH]Door storage compartments in front[/TH]
[TD="class: prCode"]3YR[/TD]
[TD]Door pockets with insert mats[/TD]
[/TR]
[TR]
[TH]Mass damper for steering wheels[/TH]
[TD="class: prCode"]1Q1[/TD]
[TD]Mass damper for steering wheel, 26.5Hz[/TD]
[/TR]
[TR]
[TH]Door and lid locking system[/TH]
[TD="class: prCode"]4K0[/TD]
[TD]Central locking w/ radio remote control
and interior controls[/TD]
[/TR]
[TR]
[TH]Type approval countries/countries with
special requirements[/TH]
[TD="class: prCode"]B38[/TD]
[TD]Legal requirements California[/TD]
[/TR]
[TR]
[TH]Carrier frequency for remote control[/TH]
[TD="class: prCode"]5D2[/TD]
[TD]Carrier frequency 315 MHz[/TD]
[/TR]
[TR]
[TH]Partition[/TH]
[TD="class: prCode"]3CA[/TD]
[TD]without partition[/TD]
[/TR]
[TR]
[TH]Door and side trim panels[/TH]
[TD="class: prCode"]3LJ[/TD]
[TD]Door and side trim panel in foam film,
insert in leatherette[/TD]
[/TR]
[TR]
[TH]doors[/TH]
[TD="class: prCode"]0A2[/TD]
[TD]4 doors[/TD]
[/TR]
[TR]
[TH]TV reception/digital radio reception[/TH]
[TD="class: prCode"]QU4[/TD]
[TD]Satellite radio reception NAR
integrated in device[/TD]
[/TR]
[TR]
[TH]Front underbody guard[/TH]
[TD="class: prCode"]1SA[/TD]
[TD]Without additional front underbody guard[/TD]
[/TR]
[TR]
[TH]Identification plates[/TH]
[TD="class: prCode"]1EB[/TD]
[TD]without identification plate[/TD]
[/TR]
[TR]
[TH]Delivery equipment[/TH]
[TD="class: prCode"]2A8[/TD]
[TD]Delivery equipment, water border[/TD]
[/TR]
[TR]
[TH]First aid kit / warning triangle[/TH]
[TD="class: prCode"]1T0[/TD]
[TD]Without first-aid material, without warning triangle[/TD]
[/TR]
[TR]
[TH]Two-way radio installation preparation[/TH]
[TD="class: prCode"]9D0[/TD]
[TD]without prepared for two way radio system[/TD]
[/TR]
[TR]
[TH]Preparation for rotating beacon/siren
combination[/TH]
[TD="class: prCode"]9F0[/TD]
[TD]Without preparation for rotating
beacon/siren combination[/TD]
[/TR]
[TR]
[TH]Telephone / telematics[/TH]
[TD="class: prCode"]9W7[/TD]
[TD]Mobile phone interface (NAR)[/TD]
[/TR]
[TR]
[TH]Additional warning lights[/TH]
[TD="class: prCode"]9TC[/TD]
[TD]Additional retro-reflectors (door area)[/TD]
[/TR]
[TR]
[TH]LongLife Service Regime[/TH]
[TD="class: prCode"]QG0[/TD]
[TD]without service interval extension[/TD]
[/TR]
[TR]
[TH]Heat accumulator system/auxiliary heater[/TH]
[TD="class: prCode"]7E0[/TD]
[TD]W/o heat accumulator/auxiliary heating[/TD]
[/TR]
[TR]
[TH]Windshield Glass[/TH]
[TD="class: prCode"]4GF[/TD]
[TD]Windshield in heat-insulating glass[/TD]
[/TR]
[TR]
[TH]Washer fluid level indicator[/TH]
[TD="class: prCode"]8W1[/TD]
[TD]Washer fluid level indicator[/TD]
[/TR]
[TR]
[TH]Additional tires (snow tires)[/TH]
[TD="class: prCode"]2WA[/TD]
[TD]without spare tyre[/TD]
[/TR]
[TR]
[TH]floor mats[/TH]
[TD="class: prCode"]0TD[/TD]
[TD]Front and rear floor mats[/TD]
[/TR]
[TR]
[TH]Additional body panels,
side[/TH]
[TD="class: prCode"]6EA[/TD]
[TD]Without additional side body covers
(stone guard)[/TD]
[/TR]
[TR]
[TH]Additional child seat anchors[/TH]
[TD="class: prCode"]3B7[/TD]
[TD]Child seat anchors as per Canadian
requirements a. ISOFIX child seat system[/TD]
[/TR]
[TR]
[TH]Auxiliary heating system[/TH]
[TD="class: prCode"]9M0[/TD]
[TD]Without auxiliary heater/parking heater[/TD]
[/TR]
[/TABLE]
P.S. If you haven't coded 4F to 050B0500 I would do so to see if any of those problems are resolved.
