Passat B8 Electronic Parking Brake activation
pojic
Hi all,
I can't access the Parking Brake controller on my Passat B8 (2015, G3) to open the electronic parking brake (EPB) and change the rear brake pads. There's no reference to EPB in the scan log either. Has anyone found out how to do it on this model? Scan log below.
Thanks,
pojic
Friday,13,September,2019,19:26:34:08713
VCDS Version: 19.6.1.0 (x64)
VIN: WVWZZZ3CZFE513958   License Plate:
Mileage: 190993km-118677mi   Repair Order:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 5F
VIN: WVWZZZ3CZFE513958   Mileage: 190993km-118677miles
Address 01: Engine (J623-CRLB)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 AS    HW: 04L 907 309 R
   Component: R4 2,0L EDC   H21 1147
   Revision: B5H21---
   Coding: 0119001203451D083000
   Shop #: WSC 05311 115 00301
   ASAM Dataset: EV_ECM20TDI01104L906026AS 001006
   ROD: EV_ECM20TDI01104L906026AS_VW48.rod
   VCID: 7BF47E5CF2C76997CC-802E
20004 - Oxygen (Lambda) Sensor B1 S2
          P0136 00 [237] - Malfunction in Circuit
                    Fault Frequency: 16
                    Mileage: 188910 km
                    Date: 2019.08.16
                    Time: 15:38:25
                    Engine speed: 1713.50 /min
                    Normed load value: 83.1 %
                    Vehicle speed: 65 km/h
                    Coolant temperature: 90 °C
                    Intake air temperature: 106 °C
                    Voltage terminal 30: 13.100 V
                    Oxyg.sens.bank 1 after oxi cat: signal qual.pump current regul.: 14
                    Oxyg.sensor bank 1 after oxi cat: signal quality temp regulator: 6
                    O2 bank 1 dwnstrm. of oxi cat: elec. corrected pump current: 0.0000000 A
                    Oxygen sensor bank 1 after oxi cat: heater activation: 83.990 %
                    O2 sensor bank 1 dwnstrm oxi cat: adjustable resistor value: 1231.1 Ohm
                    Oxyg.sens.bank 1 after oxi cat: curr.pump curr.adaptat.: 1.0276
20005 - Oxygen (Lambda) Sensor B1 S2
          P0136 00 [096] - Malfunction in Circuit
                    Mileage: 190020 km
                    Date: 2019.09.02
                    Time: 16:43:26
                    Engine speed: 1807.00 /min
                    Normed load value: 42.0 %
                    Vehicle speed: 48 km/h
                    Coolant temperature: 57 °C
                    Intake air temperature: 56 °C
                    Voltage terminal 30: 12.580 V
                    Unlearning counter according OBD: 23
                    Oxygen sensor bank 1 after oxi cat: heater activation: 92.249 %
                    O2 sensor bank 1 dwnstrm oxi cat: adjustable resistor value: 1229.9 Ohm
                    Oxyg.sens.bank 1 after oxi cat: curr.pump curr.adaptat.: 1.0176
19998 - Oxygen (Lambda) Sensor B1 S2; Heating Circuit
          P0141 00 [096] - Malfunction
                    Mileage: 189491 km
                    Date: 2019.08.24
                    Time: 21:38:44
                    Engine speed: 1432.50 /min
                    Normed load value: 80.0 %
                    Vehicle speed: 70 km/h
                    Coolant temperature: 60 °C
                    Intake air temperature: 60 °C
                    Voltage terminal 30: 13.260 V
                    Unlearning counter according OBD: 34
                    Mass airflow sensor 1 bank 1 airflow: raw value: 412.4 mg/stroke
                    Mean injection quantity: 22.39 mg/stroke
                    Particl.filt.: different.press.sensor 1 bank 1: adaptat. value: 36 hPa
                    O2 bank 1 dwnstrm. of oxi cat: elec. corrected pump current: 0.0009660 A
                    Oxygen sensor bank 1 after oxi cat: heater activation: 82.724 %
                    Oxygen sensor bank 1 after oxi cat: status signal quality: 14
                    Oxyg.sens.bank 1 after oxi cat: curr.pump curr.adaptat.: 1.0239
Readiness: 1 1 0 0 0
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 61115000002900
   Coding: 0FEC928F34210B6F0780060541CB49F0492CD0E0608292F11460F078C002
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 7EF27748E1D57CBFEB-802A
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 140
                    Mileage: 158093 km
                    Date: 2018.07.22
                    Time: 14:03:33
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0524
   Revision: 00023000    Serial number: 0367869139
   Coding: 000F0F0603
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   ROD: EV_KessyHellaMQBAB_VW48.rod
   VCID: 77FC626CCEEF4DF7A8-8022
   Part No SW: 5G0 907 426 T    HW: 5G0 907 426 T
   Component: AC Manuell    H02 1001
   Revision: 00001K06
   Coding: 12120104202100002000400000000002
   Shop #: WSC 00015 115 00001
   VCID: 3C76BD40B749AEAF85-8068
   Part No SW: 5Q0 937 086 BB    HW: 5Q0 937 086 BB
   Component: BCM PQ37BOSCH 028 0146
   Revision: --------    Serial number: 86580904150653
   Coding: 03010842C241027F0BA44084B10407281880000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    150325  043 0607
   Serial number:         150401022523
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S2Y15M04D16H08M23S24
   Coding: 90A8DD
   Subsystem 3 - Part No SW: 3G0 941 633     HW: 3G0 941 633
   Serial number: 01 03 2015  00000043
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Serial number: 000000000ZY150751UQT
   Serial number: 00000000000032223138
6666 - Bulb for Low Beam Headlamp Left
          B1217 15 [008] - Open or Short to Plus
8458 - Bulb for Right DRL
          B121E 15 [008] - Open or Short to Plus
                    Fault Frequency: 41
                    Reset counter: 92
                    Mileage: 186081 km
                    Date: 2019.07.15
                    Time: 16:36:40
8711 - Bulb for Left Fog Lamp
          B121F 11 [008] - Short to Ground
8202 - Bulb for Left DRL
          B121D 15 [008] - Open or Short to Plus
                    Reset counter: 92
                    Mileage: 188660 km
                    Date: 2019.08.13
                    Time: 19:10:50
204290 - Remote key 1
          B1479 18 [008] - Current Too Low
262664 - Switch for Interior Monitoring / Inclination Sensor
          B131B 29 [008] - Signal Implausible
   Part No SW: 5Q0 919 294 H    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0053
   Revision: --------    Serial number: 39391510505903
   Coding: 0071051001
   Shop #: WSC 05311 115 00073
   VCID: 408EC9B0DBA1CA4FD9-8014
   Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
   Component: ACC BOSCH MQB H04 0130
   Coding: 2A40608110FFC428949C804C
   ASAM Dataset: EV_ACCBOSCHVW48X 001007
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3364967C9A1761D754-8066
   Part No SW: 3Q0 959 655 AE    HW: 3Q0 959 655 AE
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R1P7HQ0S5
   Coding: 98FCC0C0000000005C5400CC008800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 01080CB4902B034796-8054
   Belt Pretensioner left:
   Serial number: 3G2857705C0120P00450
   Coding: 80000A
   Belt Pretensioner right:
   Serial number: 3G2857706C0125P00162
   Coding: 80000A
   Subsystem 3 - Part No SW: -----------    HW: 454 001 404 15
   Serial number: 3576U000000A407D0414
   Subsystem 4 - Part No SW: -----------    HW: 454 001 504 15
   Serial number: 3586U00000092370241.
   Subsystem 5 - Part No SW: -----------    HW: 454 801 604 15
   Serial number: 3516R64486606000000$
   Subsystem 6 - Part No SW: -----------    HW: 454 801 504 15
   Serial number: 3526R3E416B060000002
   Subsystem 7 - Part No SW: -----------    HW: 454 802 903 15
   Serial number: 3556VFC705406000000D
   Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150418400772
   Coding: 0400
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3D70B044AC53A7A7B2-8068
   Part No SW: 3G0 920 941     HW: 3G0 920 941
   Component: KOMBI         209 4311
   Coding: 27A409102780260001886A001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009043
   VCID: 63C4263C6A77B157E4-8036
   Revision: --------    Serial number: 25041510800463
   Coding: 030300044F087300EF00005C080F00010001070000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 72EA5378A58D28DF9F-8026
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150000790720055166
   Coding: 2CFFFF
   Serial number: 2880236403
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
   Serial number: 15000069608008
   Coding: 0000000000000000
   Shop #: WSC 00015 115 08193
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71E85C74A08B13C766-8024
   Serial number: 070415BD504189
   Coding: 00350A20D001028000001000
   VCID: 428AC3B8D5ADD85FCF-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001286180
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 8103
   Shop #: WSC 00015 115 00301
   VCID: 4384C6BCCAB7D157C4-8016
   Serial number: 100415BD917516
   Coding: 00350020D001028000001000
   VCID: 4188CCB4D0ABC347D6-8014
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001295693
   Coding: 050000
   Part No SW: 3Q0 035 874     HW: 3Q0 035 874
   Component: MU-S-ND-ER    H10 0138
   Serial number: VWZAZ2R8523748
   Coding: 02840201FF00000011111201000808001F0100C601200100CC
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_VW48.rod
   VCID: 6FEC5A0CB6BF053770-803A
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H44 1017
   Serial number: VWZ8Z9RD801X41
   Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
End-------------------------(Elapsed Time: 04:13)--------------------------
Saturday,14,September,2019,12:44:16:08713
VIN: WVWZZZ3CZFE513958   License Plate: WL15CSO
   Revision: B5H21---
                    Fault Frequency: 16
                    Mileage: 188910 km
                    Date: 2019.08.16
                    Time: 15:38:25
                    Mileage: 190020 km
                    Date: 2019.09.02
                    Time: 16:43:26
                    Mileage: 189491 km
                    Date: 2019.08.24
                    Time: 21:38:44
          C102D 00 [008] - -
                    Reset counter: 140
                    Mileage: 158093 km
                    Date: 2018.07.22
                    Time: 14:03:33
   Coding: 000F0F0603
   Revision: 00001K06
   Coding: 90A8DD
                    Fault Frequency: 42
                    Reset counter: 92
                    Mileage: 186081 km
                    Date: 2019.07.15
                    Time: 16:36:40
                    Reset counter: 92
                    Mileage: 188660 km
                    Date: 2019.08.13
                    Time: 19:10:50
   Coding: 0071051001
   Coding: 80000A
   Coding: 80000A
   Coding: 0400
   Coding: 2CFFFF
   Analog clock:
   Coding: 0D0000
   Coding: 8103
   Coding: 050000
Saturday,14,September,2019,13:32:06:08713
   Revision: B5H21---
   Coding: 000F0F0603
   Revision: 00001K06
   Coding: 90A8DD
                    Reset counter: 92
                    Mileage: 190993 km
                    Date: 2019.09.14
                    Time: 13:00:16
                    Reset counter: 92
                    Mileage: 190993 km
                    Date: 2019.09.14
                    Time: 13:00:20
   Coding: 0071051001
   Coding: 80000A
   Coding: 80000A
   Coding: 0400
   Coding: 2CFFFF
   Analog clock:
   Coding: 0D0000
   Coding: 8103
   Coding: 050000
End-------------------------(Elapsed Time: 04:08)--------------------------
golfi_vend
Tartu, Estonia
C?ID=195131
Because there isn't one.
I wanna write the solution here, but uncertain because of the unverified status.
Looks to be a borrowed or second-hand VCDS. I'm confident it's legit.
ABS is "MK100IPB". I believe IPB stands for Integrated Parking Brake.
Should work just like the Mk.7 Golf and other MQB cars with EPB:
wiki.ross-tech.com/wiki/index.php/VW_Golf_VII_(5G/AU)_ABS_Brakes
pojic
Thanks for the vote of confidence Uwe, much appreciated. And yes, the VCDS cable is borrowed. To give you confidence in that, the owner (Mr Andrew R. from Barry in the UK) informs me that the lead was on invoice number [redacted] dated 07/11/2016, paid for on credit card. Although not an owner, is this enough to have me verified? Verified user that is, not insane or daft. Although the latter is definitely a moot point.
I'll look into MK100IPB and let you know how I get on.
Thanks again for the response,
Jason (aka pojic)
pojic
That Golf Mk7 link worked a treat. I'll be changing the pads this weekend.
Should I use the Golf Mk7 forums for VCDS info about the Passat B8 systems?
Thanks,
Jason
I'm afraid not. Only registered users are eligible for "Verified" status here. But that doesn't prevent you from asking questions, or even getting answers. ;)
