Audi A7 2013 - 3.0TDI Rear Aircon/HVAC issue
Demonmeister
C?ID=373150
Hi all,
First post with my shiny new VCDS cable!
My car runs/works fine as far as I can tell, but when I did a scan, I noticed an error on the rear HVAC.
At first, I thought it was a faulty motor, so bought x2 more 2nd hand ones - still showing the error.
Swapped the left motor (which seems to have no error on it over and - still showing the error.
I've tried to do a basic setting, but when I do the flap adjust, it runs for a few seconds (I can see/hear BOTH rear flaps moving) and then instead of ending with 'successful', it ends with 'unknown'.
The system does appear to work, but I don't want errors on my car.
Any help greatly appreciated!
Thanks,
Now onto the full auto scan:
a\SZQTuesday,17,September,2019,17:37:25:13701
VIN: WAUZZZ4G3EN016385   License Plate:
Gateway Installation List:  4G0 907 468 AC
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 30 36 3B 42 44 46 52 53
          55 56 5F 62 6D 72 82 85
VIN: WAUZZZ4G3EN016385   Mileage: 83810km-52077miles
Address 01: Engine (J623-CLAA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4G0 907 311 E    HW: 4G0 907 401
   Component: 3.0TDI EDC17  X41 0002
   Revision: 53X41---
   Coding: 1A254012042601020800
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TDI0114G0907311E 001002
   ROD: EV_ECM30TDI0114G0907311E.rod
   VCID: 2517F1B2B5625E7F99F-8070
   Part No SW: 4G5 927 156     HW: 0B5 927 156 J
   Component: 0B5 30 TDIRdW H02 0002
   Revision: --H02---
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 6E85CE9E20145D27285-803A
   Part No SW: 4G0 907 379 L    HW: 4G0 907 379 L
   Component: ESP PREMIUM   H09 0450
   Coding: 07A69F03E065F9C0DB00
   ASAM Dataset: EV_ESPPremiAU57X 004039
   VCID: 3A2D32CE2CDCC187C4D-806E
   Part No SW: 4H0 907 064 CP    HW: 4H0 907 064 CP
   Component: BCM2 2.0      H33 0433
   Coding: 05BA2F46000000000000
   VCID: 79AFEDC269DA0A9F8D7-802C
   Serial number: 2313000099284011
   Part No SW: 4G0 820 043 AE    HW: 4G0 820 043 AE
   Component: KLIMA 4 ZONEN H13 0087
   Serial number: 11061300040533
   Coding: 362300B83D
   ASAM Dataset: EV_AirCondiComfoUDS 002040
   VCID: 629DAAAEE4CCE947BCD-8036
   Part No SW: 4H0 907 063 CF    HW: 4H0 907 063 F
   Revision: 20012002    Serial number: 00000001448647
   Coding: 0200A01050B49FE04181008380001908CF9DC30A2F080201000008406100
   VCID: 6E85CE9E20945D27285-803A
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 130526  H36 0080
   Serial number:         130603050609
   Coding: 0045F7
   Serial number: 21399059
   Coding: 02006E
   Subsystem 3 - Part No SW: 4G0 941 531 AA    HW: 4G0 941 531 AA
   Component: E1 - LDS  H07 0044
   Serial number: 04 06 2013  00001537
   Serial number: B6498FA6000000000001
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061315800360
   Coding: 88C304
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71BFD5E2312A42DF357-8024
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG00DKW0H
   Coding: 3031453032314E303133554A305234473853
   VCID: 363526FE18C425E7205-8062
   Serial number: 3575HRB405J20N96BHCB
   Serial number: 3585HRB405B217NU3GDJ
   Serial number: 3515JRB400G50HQCJQ3R
   Serial number: 3525JRB401250IBUI1VL
   Serial number: 3554VRB400O50ITUJA2C
   Serial number: 3564VRB401050ITU5PJ8
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20130614000167
   Coding: 000034
   VCID: 303910E6FA200BD77A9-8064
   Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
   Part No SW: 4G8 920 984 H    HW: 4G8 920 984 H
   Component: TDieGb        H80 0618
   Revision: 30460230    Serial number: 658040613596008
   Coding: 23AF00020B432600010300
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 3B2337CA23E6F88FDFB-806E
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000973384
   Coding: 00CD077D00
   ASAM Dataset: EV_GatewPkoUDS 001018
   Serial number: 5250870503
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 13040500000000000305
   Part No SW: 4G0 919 158 K    HW: 4G0 919 158 K
   Component: KLIMA FOND    H07 0087
   Serial number: 08061300040014
   Coding: 22
   ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
   VCID: 372B2BFA1FCEDCEF3B3-8062
0033 - Motor for Rear Right Upper Body Vent
          B10D4 22 [009] - Signal Amplitude Too High
                    Reset counter: 103
                    Mileage: 83810 km
                    Date: 2019.09.17
                    Time: 17:35:45
                    Voltage terminal 30: 12.27 V
                    Outside air temperature: 26.0 °C
                    Right Rear Upper Body Vent Motor-Act.val.: 11701
                    Right Rear Upper Body Vent Motor-Specified value: 11701
                    Right Rear Upper Body Vent Motor-Stop open: 10000
                    Right Rear Upper Body Vent Motor-Stop closed: 10000
0094 - No Basic Setting
          B2010 00 [009] - -
          [Basic settings not carried out]
                    Reset counter: 103
                    Mileage: 83810 km
                    Date: 2019.09.17
                    Time: 17:33:55
                    Basic setting of flap motors-Left Rear Upper Body Vent Motor: OK
                    Basic setting of flap motors-Right Rear Upper Body Vent Motor: ERROR
Address 30: Special Function II (J843)       Labels: 8K0-907-440.clb
   Part No SW: 4H0 907 440     HW: 4H0 907 440
   Component: STS           H06 0030
   Revision: S0H06000    Serial number: 00000000044277
   Coding: 01010101000000000001000202
   VCID: 6491ACB6FE58E7774E1-8030
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000063605523
   Coding: 00781B0000006001000001010101102030303232203232
   VCID: 77ABEBFA5FCE1CEFFB3-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H02 0056
   Revision: --------    Serial number: EJ1BPA8203U5UT
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Component: TSG FA        H03 0507
   Coding: 011F56025E21620002080402
   VCID: 47CB5B3A6FAEAC6F4B3-8012
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0008568708
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D1AEEF4AC39C70CD-8066
   Revision: 00002001    Serial number: 0308908935
   Coding: 013F0E22A0B9B88583200A0400030D470000000000000000000000000000
   Subsystem 1 - Part No: 4G0 951 177
   Component: DWA-Sensor  H01 0010
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO2224502Y
   Coding: 901E00
   Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
   Component: HSP-SG  H11 0029
   Serial number: WA106023000003815468
   Subsystem 5 - Part No SW: 3AA 962 243 B    HW: 3AA 962 243 B
   Component: GEB.F.Heckoef  H16 0810
   Serial number: 93027703
   Component: TSG BF        H03 0507
   VCID: 46D5563E68A4B567B05-8012
   Part No SW: 4H0 907 801 G    HW: 4H0 907 801 A
   Component: EPB-4         H03 0014
   Revision: --------    Serial number: 00000000718194
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2C010496D6886F37461-8078
Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
   Part No SW: 4H4 907 357 C    HW: 4H4 907 357 A
   Component: ....AFS13.... H01 0020
   Serial number: 130608-0004-024
   Coding: 1123A633F918EB00
   ASAM Dataset: EV_AdvanFrontSyste 005001
   ROD: EV_AdvanFrontSyste_AU21.rod
H01 0031
   Coding: 3A0000
H01 0031
   Coding: 3A0000
   Part No SW: 4G0 035 061 S    HW: 4G0 035 061
   Component: Radio U DAB   H60 0154
   Revision: AB001007    Serial number: 109FZ0D7684311
   Coding: 010103020100000001
   VCID: 2D070992ED12663F51F-8078
   Part No SW: 4G0 035 670 Q    HW: 4G0 035 670 H
   Component: H-BNT-EU      H51 1034
   Revision: --------    Serial number: 190FR0D7542310
   Coding: 000101040203E5ED45808F3E00000003000001000000000000
   VCID: 313F15E2F12A02DF757-8064
   Subsystem 1 - Part No: 8R0 060 884 GA
   Component: EUR 2019  2802
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDDD001MPMC
   Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349MF6001BB
   Component: CD-Database  5298
   Component: TSG HL        H03 0507
   Coding: 010F14024021620002080002
   VCID: 49CF5D0279BA5A1F5D7-801C
   Part No SW: 4G8 959 107 Q    HW: 4G8 959 107 F
   Component: HDSG-Modul    H13 0043
   Revision: 11013001    Serial number: 140300152
   Coding: 0A3305C002
   ASAM Dataset: EV_HDSGAu573 001022
   ROD: EV_HDSGAu571.rod
   VCID: 43D34F2A5B16804F97B-8016
   Component: TSG HR        H03 0507
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 4G8 919 604 L    HW: 4G8 919 604 L
   Component: HeadUpDisplay 004 0201
   Coding: A20000
   ASAM Dataset: EV_HUDContiC7 001023
   ROD: EV_HUDContiC7.rod
   VCID: 3C2134D626E8FFB7D61-8068
   Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
   Component: DPC-SG        H26 0038
   Coding: 64040000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2615F6BEC8645567905-8072
End----------(Elapsed Time: 02:16, VBatt start/end: 12.2V/12.4V)-----------
Demonmeister
C?ID=373150
Anyone?
Really would appreciate any suggestions/help...
I could buy a whole new rear duct and replacement motors from a scrapped car, but they are like £100GBP so seems excessive if it's not something that I know will fix it.
mak
C?ID=219607
Anyone?
Have you attempted to perform basic setting on the module? I don't know what the procedure is but that's what I would think the car is looking for by that error message.
morski
Cheshire UK
C?ID=90186
Common fault on the 4G platform for the rear hvac motor gears to get stripped. Pull the rear vent out and have a look at the gears to check if they are all still intact.
Demonmeister
C?ID=373150
Thanks for the replies...
This is what is confusing me... I've pulled the rear vent out (so I can see the vent flaps, but the vent is still connected).
I've tried to run basic settings and whilst running, I can see the vent flaps moving quite easily/freely, but instead of saying 'Complete', I get a status of 'Unknown' for the outcome of Vent flap calibration.
As it can't seem to complete the basic setting, I can't get rid of the 'basic settings' error, but can't see/hear any creaking/groaning/stuck flaps.
What does it mean when it gives a status of 'Unknown' for basic settings on VCDS?
Thanks,
Those sorts of status messages come directly from the control module. In this case, I would take it to mean that the control module was unable to complete the requested procedure (the Basic Setting) successfully, and doesn't know why it was unable.
South Molton, UK
Isn't there a potentiometer that provides feedback of the flap position?
If the feedback from this isn't getting back to the module then the flap position would be flagged as unknown.
Worth checking the WD and then checking the appropriate connections I would suggest.
