2013 Passat 2.0 p0405 egr circuit
machado
Canada
C?ID=59468
This Passat had the egr valve replaced not sure what the fault was at the time, but now sets po405 always sets at high speeds between 70 to 100 kms. It won set at idle or by wiggling the harness or loading the engine. Any thoughts. Thank you ,Mario
Tuesday,17,September,2019,10:42:26:15785
VCDS Version: 19.6.1.0 (x64)
VIN: 1VWCN7A3XDC139151   License Plate: ADRIAN
Mileage: 176990km-109976mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 72 77
VIN: 1VWCN7A3XDC139151   Mileage: 176990km-109976miles
   Component: R4 2.0l TDI   H24 9982
   Revision: 71H24---    Serial number:
   Coding: 001D0012842400008000
   Shop #: WSC 93778 999 00000
   ROD: EV_ECM20TDI01103L997009J.rod
   VCID: 3B7E8A76B25809978C-806E
4900 - EGR Sensor 1
          P0405 00 [038] - Signal too Low
                    Mileage: 176998 km
                    Date: 2019.09.17
                    Time: 10:38:01
                    Engine speed: 1891.50 /min
                    Normed load value: 99.6 %
                    Vehicle speed: 97 km/h
                    Coolant temperature: 100 °C
                    Intake air temperature: 33 °C
                    Voltage terminal 30: 13.960 V
                    Air mass: actual value (mg/stroke): 1068.5 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                    EGR Solen.val.: actual value: 104.85 %
                    EGR valve: offset closed: -0.39 %
                    Actuator for high pressure EGR: status-Bits 0-7: 55
                    Actuator for high pressure EGR: status-Bits 0-7: 0
                    Actuator for high pressure EGR: status-Bits 0-7: 2
                    High press EGR actuator: actual unconditioned volt val: 14.6 mV
   Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 9436
   Revision: 05651213    Serial number: 00001302041648
   Shop #: WSC 09003 957 00200
   VCID: 244C510AE7E6566FDD-8070
   Revision: 00H31001
   Coding: C54BC0F549250003A30C03E9921A0042271000
   VCID: 7DFA446EE4CCC7A7F2-8028
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Revision: 00086000    Serial number: 0205288523
   Coding: 130C0C
   VCID: 346CA14A9F06C6EF4D-8060
   Part No SW: 561 907 044 R    HW: 561 907 044 R
   Component: Climatronic   H03 0405
   Revision: 00001K01
   Coding: 0010001012
   VCID: 26484B0259DAA47FC3-8072
9473297 - Motor for Right Temperature Flap
          B108D 11 [009] - Short to Ground
                    Reset counter: 82
                    Mileage: 176311 km
                    Date: 2019.09.11
                    Time: 12:28:45
   Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
   Component: BCM PQ35 H+   121 0168
   Revision: BL121001
   Coding: 6F200E1B882B2AD408880201360085480071008645A005F064806000BC70
   VCID: 74EC614AD78686EF8D-8020
   Component: RLS 210313 05  54  0403
   Coding: 22300A
   Serial number: 003MWM01MX8E
   Coding: 00005033
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 75EA5C4ED4FC9FE7BA-8020
   Serial number: 6940000Y130000T9UK0G
   Coding: 303047
   Serial number: 3572MSME65247378ZZZZ
   Serial number: 3582MSME35406478ZZZV
   Serial number: 3516KSME35627D22ZZZT
   Serial number: 3526KSME27472023ZZZH
   Serial number: 3556LSME7D646921ZZZ%
   Serial number: 3566LSME116C6921ZZZX
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Revision: FF010041    Serial number: 20130221201828
   Coding: 001A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DFA446EECCCC7A7F2-8028
   Coding: E30000
   Part No SW: 561 920 870 C    HW: 561 920 870 C
   Component: KOMBI         H07 0705
   Coding: 331E01
   VCID: 193270FE18A41B877E-804C
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 28041303290352
   Coding: 461000
   VCID: 76E85B42C1FA94FFB3-8022
   Component: IMMO          H07 0705
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6AD07F328D42401F27-803E
   Revision: 00000000    Serial number: 13000013122005
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3064AD5A6B1EFACF29-8064
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664589784
   Coding: 010100
   VCID: 2A50BF3245C2801FE7-807E
   Part No SW: 561 959 760     HW: 561 959 760
   Component: MEM-FS        H04 0181
   Revision: AA000000    Serial number: 00000055321739
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: 60C41D1A737E0A4FF9-8034
   Part No SW: 3C0 035 684 G    HW: 3C0 035 684 G
   Component: RNS-MID       H03 3696
   Revision: AB001001    Serial number: VWZ6Z7N8064081
   Coding: 24090042010000A6000B
   VCID: 2756460656D0BD77F8-8072
                    Fault Frequency: 21
                    Reset counter: 94
                    Mileage: 176296 km
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Revision: 12110009    Serial number: 0006532695
   Coding: 0405FD
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1C3C69EA17966EAF65-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14102630130429161347
   Coding: 800000
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 121
67589 - Turn Signal in Exterior Mirror
          B11FD 01 [009] - Electrical Failure
                    Reset counter: 81
                    Mileage: 176302 km
                    Date: 2019.09.10
                    Time: 08:53:29
131584 - Motor for Rear Window Regulator
          B11EE 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 121
                    Mileage: 176302 km
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 290    3305
   Revision: 00H22000
   VCID: 3776964646702DF768-8062
   Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
   Component: KonzernAmp10K H07 6813
   Revision: --------    Serial number: EAA098A0035118
   ROD: EV_AudioVerst10KanalSTT3.rod
9457664 - Function limitation due to excessive temperature
          B1050 00 [008] - -
                    Reset counter: 130
                    Mileage: 176375 km
                    Date: 2019.09.11
                    Time: 13:18:14
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 01030108
   VCID: 6FE66E26BEA0A53770-803A
   Serial number: 53388786011235700831
   Coding: 181100
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Revision: 14110009    Serial number: 0006541800
   Coding: 0405FC
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1D3A64EE0C8C67A792-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14202631130430190455
   Coding: 800000
                    Reset counter: 121
                    Mileage: 176302 km
                    Fault Frequency: 21
                    Reset counter: 94
                    Mileage: 176296 km
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007664432633
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A708F72BD62309F97-806E
End-------------------------(Elapsed Time: 03:31)--------------------------
Address 01: DTCs cleared
machado
Canada
C?ID=59468
          52 56 62 72 77
4900 - EGR Sensor 1
                    Mileage: 176998 km
                    Date: 2019.09.17
                    Time: 10:38:01
   Revision: 00H31001
   Coding: 130C0C
   Revision: 00001K01
   Coding: 0010001012
                    Reset counter: 82
                    Mileage: 176311 km
                    Date: 2019.09.11
                    Time: 12:28:45
   Revision: BL121001
   Coding: 22300A
   Coding: 00005033
   Coding: 303047
   Coding: 001A140000
   Coding: E30000
   Coding: 331E01
   Coding: 461000
   Coding: 000007
   Coding: 010100
                    Fault Frequency: 21
                    Reset counter: 94
                    Mileage: 176296 km
   Coding: 0405FD
   Slave Driver:
   Coding: 800000
                    Reset counter: 121
                    Reset counter: 81
                    Mileage: 176302 km
                    Date: 2019.09.10
                    Time: 08:53:29
                    Reset counter: 121
                    Mileage: 176302 km
   Revision: 00H22000
          B1050 00 [008] - -
                    Reset counter: 130
                    Mileage: 176375 km
                    Date: 2019.09.11
                    Time: 13:18:14
   Coding: 01030108
   Coding: 181100
   Coding: 0405FC
   Slave Passenger:
   Coding: 800000
                    Reset counter: 121
                    Mileage: 176302 km
                    Fault Frequency: 21
                    Reset counter: 94
                    Mileage: 176296 km
I removed the air box and found a few wires running from boost sensor to ECU, i believe there are more broken wires but customer has denied any further work.
Jef
HQ
4900 - EGR Sensor 1
In many cases a "Signal too Low" description is due to an open circuit, so yeah, a failing wire is possible.
