Golf Mk 7 DSG Trouble
Teamox
h11-004764
Hi guys,
i'm used to check measuringblocks 95-115 to check the condition of clutch 1 and 2 of the dsg gearbox.
Can u tell me how to check the condition of clutch 1 and 2 using measuringblocks on this golf 7 it uses a different protocol?
The problem with this car is that it doesn't shift smooth, it slams into 1st and Reverse.
After a basic setting, it drives/shifts like it's supposed to.
when i let it sit a coupple of days, it shifts rough again.
i have been told that there is a TPI for the code i have ( P189A) i cant find it..
I'm suspecting the clutch, that's why i want to check te condition using the measuringblocks
Thnx :)
Tuesday,17,September,2019,10:19:07:64070
VIN: WVWZZZAUZFP574488   License Plate:
Mileage: 155021km-96325mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZFP574488   Mileage: 155021km-96325miles
Address 01: Engine (J623-CJZA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 A    HW: 04E 907 309 A
   Component: 1.2l R4 TSI   H10 7697
   Revision: WAH10---
   Coding: 01250032232405082000
   Shop #: WSC 00028 028 00074
   ASAM Dataset: EV_ECM12TFS01104E906016A 001008
   ROD: EV_ECM12TFS01104E906016A.rod
   VCID: 20191D366A4C4767EA9-8074
5604 - Park/Neutral Switch Input Circuit
          P0850 00 [032] - Open or Short to Plus
                    Mileage: 155020 km
                    Date: 2019.09.16
                    Time: 15:57:31
                    Engine speed: 873.00 /min
                    Normed load value: 32.9 %
                    Coolant temperature: 35 °C
                    Intake air temperature: 27 °C
                    Voltage terminal 30: 14.277 V
                    Brake actuated status-Bits 0-7: 3
                    Selector lever position-Bits 0-7: 8
                    Engine status: COENG_RUNNING
Readiness: 0110 0001
   Part No SW: 0CW 300 047 D    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5203
   Revision: 00043014    Serial number: CU501411065326
   Shop #: WSC 00028 028 00066
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 3C21C946E6E40387D61-8068
10817 - Clutch 1
          P189A 00 [072] - Clearance too Small
                    Mileage: 155020 km
                    Date: 2019.09.16
                    Time: 15:58:15
                    Engine speed: 5126.00 /min
                    Engine torque: -100 Nm
                    Vehicle speed: 72 km/h
                    Control Module temperature: 91 °C
                    CURRENT pressure: -9.5 bar
                    Clutch: primary stat: Anfahren - Gangwechsel
                    selected gear: GANG_6
                    Driving position: N
                    Accelerator position: 0.0 %
                    DTC memory status: 47616
   Part No SW: 3Q0 907 379 F    HW: 3Q0 907 379 F
   Component: ESC           H42 0609
   Revision: 00000000    Serial number: 63174000003171
   Coding: 04FA6AA114271170077B060841CB2520562888E06082A4F300220078C202
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 3D27C442FDFE0A8FE1F-8068
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 02020004200100011005000000101000
   VCID: 6A8D3F1EDCF04D3774D-803E
   Air quality sensor:
   Part No SW: 5Q0 937 086 AD    HW: 5Q0 937 086 AD
   Revision: --------    Serial number: 86580611140255
   Coding: 00001846C24102FB4BE44080B10403081000000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: 7CA10946A664C387961-8028
   Component: WWS    141027  043 0551
   Serial number:         141108074854
   Component: RLHS  037 0059
   Serial number: S5Y14M11D20H08M01S47
   Coding: 00A8DD
   Serial number: 000000000ZY142741A3Z
   Serial number: 00000000000061015905
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 118
                    Mileage: 155020 km
                    Date: 2019.09.16
                    Time: 15:00:23
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331431103932
   Coding: 0031151011
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR0A9D4N
   Shop #: WSC 00028 028 00061
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F5BFE4AB772D89FB33-802A
   Belt Pretensioner left:
   Serial number: 34169667B14111480878
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169668B14111470903
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 811 14
   Serial number: 357670000002A9F0911W
   Subsystem 4 - Part No SW: -----------    HW: 480 001 211 14
   Serial number: 35867000000834A0C11P
   Subsystem 5 - Part No SW: -----------    HW: 480 401 111 14
   Serial number: 3516502A3188FC0161CD
   Subsystem 6 - Part No SW: -----------    HW: 480 401 111 14
   Serial number: 3526502B9188FC02A32I
   Subsystem 7 - Part No SW: -----------    HW: 480 403 110 14
   Serial number: 3556502B71860BC1B0EM
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20141112400579
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FDBBE4AF7F2189FF33-806A
   Part No SW: 5G1 920 750     HW: 5G1 920 750
   Component: KOMBI         304 4270
   Coding: 07A412082380000800086A001400000000000000
   VCID: 649151263ED41B474E1-8030
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 10111410800878
   Coding: 030100042F085700EF00024C1C0F00010001050000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 71BF2872F126BEEF357-8024
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0038
   Serial number: 21140000169980064462
   Coding: 28FFFF
   Serial number: 3277405003
   Part No SW: 5Q4 959 593 C    HW: 5Q4 959 593 B
   Component: TSG FS        009 0015
   Serial number: 0000126292382
   Coding: 003A03208000028000001000
   VCID: 45D7ACA2952E424FB9F-8010
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000007186499
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   VCID: 43D3B2BA9B1A7C7F97B-8016
   Part No SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0015
   Serial number: 0000126302200
   Coding: 003A01208E00028000801000
   VCID: 44D1B1A69E147B47AE1-8010
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000007117573
   Coding: 090000
   Part No SW: 5G0 035 846 A    HW: 5G0 035 846 A
   Component: MU-S-N-ER     041 0430
   Serial number: V1F01611140255
   Coding: 02730201FF00000021110001000800001F0100140100010045
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 270B062A0F62B05FAB3-8072
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H60 0030
   Serial number: VWZ8Z9PS4049LB
   Subsystem 2 - Part No SW: 5G0 919 866 Q    HW: -----------
   Component:  ECE 2015  --- 0045
0008 - Connection between Antenna Amp 2 for Radio and Antenna
          B1273 13 [009] - Open Circuit
                    Reset counter: 115
                    Mileage: 154987 km
                    Date: 2019.09.13
                    Time: 08:14:10
                    Voltage terminal 30: 11.4 V
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Electrical OK
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Open circuit
                    Status of antenna 2 for radio-Reception level antenna 2: 255 dBµV
End----------(Elapsed Time: 01:36, VBatt start/end: 11.9V/12.0V)-----------
There's a crazy amount of data regarding the clutches in the measuring values of that TCU, but I'm not sure exactly what it is you're looking for. Have you got an example of the data you like from an older, non-UDS DSG?
Teamox
h11-004764
I Would like to see the clutch adaptions like in MB 115-3 95-3 (new 11mm worn 17mm)
