Audi Q7 2014 Model Instrument cluster not powering up
anuragh
Australia
C?ID=219176 (NRRT)
Hi
I have got 2014 Model Audi Q7 - Australian Version. Couple of days ago i was checking some fuses on the left hand side of the dash - Passenger side in Australia.
I have taken some fuses out and put it back in the right spot after checking them.
Now I do not have power in the dash cluster. All my dials, fuel gauge and temp gauge are not working.
I can only see couple of little icons like ABS, Hand brake, Air bags etc. My reverse camera and parking sensors are also not working.
When i try to reverse i hear a 4-5 seconds beep from the rear side of the car.
I did a scan and saw a lot of errors which i believe is due to the dash cluster being without power.
Could you please advise what could be the problem.
My error codes are attached below
Sunday,15,September,2019,19:54:37:12214
VCDS Version: 19.6.1.0 (x64)
Chassis Type: 4L-AU56 (4F0)
04-Steering Angle -- Status: Sporadic communication error 1000
05-Acc/Start Auth. -- Status: Malfunction 1010
10-Park/Steer Assist -- Status: Malfunction 1010
28-HVAC, Rear -- Status: Malfunction 1010
4F-Centr. Electr. II -- Status: Malfunction 1010
6C-Back-up Cam. -- Status: Malfunction 1010
6F-Centr. Conv. II -- Status: Malfunction 0010
Address 01: Engine (J623-CRCA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L2 910 401 B    HW: 4L0 907 401 C
   Component: 3.0TDI EDC17  H41 0003
   Revision: 53H41---    Serial number:
   Coding: 2A2A4012A52701020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0114L2910401B 001003
   ROD: EV_ECM30TDI0114L1910401H.rod
   VCID: 2345F6B12AFA4E57A4-8076
7 Faults Found:
7249 - No Communications with Steering Angle Sender (G85)
          U0126 00 [032] - -
                    Engine speed: 769.50 /min
                    Normed load value: 12.9 %
                    Coolant temperature: 58 °C
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 11.760 V
                    Cruise Control System (CCS): status-Bits 0-7: 15
                    selected gear-Bits 0-7: 0
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [032] - -
                    Engine speed: 726.50 /min
                    Normed load value: 27.5 %
                    Voltage terminal 30: 12.740 V
                    Cruise Control System (CCS): status-Bits 0-7: 207
4713 - No Communication with ABS Brake Control Module
          U0121 00 [032] - -
                    Engine speed: 760.00 /min
                    Normed load value: 15.7 %
                    Coolant temperature: 59 °C
                    Intake air temperature: 39 °C
                    Voltage terminal 30: 11.820 V
                    Cruise Control System (CCS): status-Bits 0-7: 44
4714 - Steering Column Control Module
          U0212 00 [032] - No Communications
                    Engine speed: 747.50 /min
                    Normed load value: 22.0 %
                    Voltage terminal 30: 12.280 V
4715 - No Communication with Instrument Cluster
          U0155 00 [175] - -
                    Engine speed: 696.50 /min
                    Normed load value: 22.4 %
                    Coolant temperature: 68 °C
                    Intake air temperature: 48 °C
                    Voltage terminal 30: 13.980 V
                    Cruise Control System (CCS): status-Bits 0-7: 239
4719 - No Communication with Diagnostic Gateway
          U0146 00 [032] - -
4720 - Body Control Module (Central Electric 2)
          U0141 00 [032] - No Communications
Readiness: 1 1 0 0 0
   Part No SW: 0C8 927 750 AL    HW: 0C8 927 750 AL
   Component: AL1000 AISIN  002 2447
   Coding: 001578
   Shop #: WSC 47550 001 1048576
   ROD: EV_TCMAL991031_002.rod
   VCID: 76E3FFE5C9E88BFFB3-8022
12810 - No Communication with ABS Brake Control Module
          U0121 00 [008] - -
                    Reset counter: 195
                    Engine speed: 840.0 /min
                    Transmission input speed: 660 /min
                    Engine torque: 24 Nm
                    Transmission fluid temperature: 50 °C
                    Accelerator position: 0.0 %
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
                    Lock Up Clutch: Open
                    EOP failure status 2: Normalcy
                    EOP target revolution: 0 /min
                    EOP actual revolution: 65279 /min
                    Engine Speed signal Current: 65279 /min
                    EOP failure status with EOP without HV 1: Motor normal stop
                    EOP target current: 65278 mA
12812 - Steering Column Control Module
          U0212 00 [008] - No Communications
                    Reset counter: 195
                    Engine speed: 810.0 /min
                    Transmission input speed: 780 /min
                    Engine torque: -4 Nm
                    Transmission fluid temperature: 74 °C
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
12813 - No Communication with Diagnostic Gateway
          U0146 00 [008] - -
                    Reset counter: 195
                    Engine speed: 720.0 /min
                    Transmission input speed: 690 /min
                    Engine torque: 12 Nm
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
12814 - No Communication with Instrument Cluster
          U0155 00 [009] - -
                    Reset counter: 201
                    Engine speed: 690.0 /min
                    Engine torque: -12 Nm
                    Transmission fluid temperature: 66 °C
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 2196593
   VCID: 346705ED5714D9EF4D-8060
                    Reset counter: 81
                    Count: 192
                    Count: 2881
                    Count: 297
                    Count: 32512
                    Reset counter: 81
                    Count: 65
                    Count: 166
                    Count: 43008
                    Reset counter: 41
                    Count: 321
                    Count: 8208
                    Count: 43008
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H08 0200
   Revision: 00H08000    Serial number: 10603702127028
   Coding: 0000151
   VCID: 2541E8A9ECCEB067CA-8070
   Subsystem 1 - Part No: 4F0 910 132 C
   Component: FBSAUDIC6 EZS   H04 0020
   Component: FBSAUDIC6 KSG   H03 0020
00193 - Rear Right Door Handle Touch Sensor (G418)
            007 - Short to Ground
                    Fault Status: 01110111
                    Reset counter: 41
                    Reset counter: 81
02072 - Control Module for Energy Management (J644)
                    Reset counter: 81
00263 - Transmission
                    Reset counter: 81
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AN
   Revision: 00---031    Serial number: 00000030330508
   Coding: 01029456
   VCID: 2541E8A92CCEB067CA-8070
                    Reset counter: 41
                    Fault Status: 00101010
                    Reset counter: 81
                    Temperature: 30.0°C
   Part No SW: 4F0 910 279 AH    HW: 4F0 907 279 D
   Component: ILM Fahrer      H31 0400
   Coding: 0023121
   VCID: 6FEDCA817EB2BA3770-803A
   Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H13 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
                    Reset counter: 81
00456 - Control Module for Access and Start Control (J518)
                    Reset counter: 81
                    Reset counter: 81
00908 - Control Module for Wiper Motor
                    Reset counter: 81
Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
   Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
   Component: PARKHILFE 8K  H07 0011
   Revision: 11001001    Serial number: 55961408700599
   Coding: 28031F
   ASAM Dataset: EV_EPHVA18AU7160000 001001
   ROD: EV_EPHVA18AU7160000.rod
   VCID: 346705ED9F14D9EF4D-8060
12670224 - Databus
                    Reset counter: 41
12656936 - Databus
                    Reset counter: 81
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 70 AIRBAG AUDI8RH45 0230
   Revision: 06H45000    Serial number: 00399D605TYM
   Coding: 0014128
   VCID: 2E531785B938F33F3B-807A
   Subsystem 1 - Serial number: 6332QSME1E3F237EY
   Subsystem 2 - Serial number: 6342QSME204113580
   Subsystem 3 - Serial number: 6352QSME243F5244G
   Subsystem 4 - Serial number: 6362QSME273F165EV
   Subsystem 5 - Serial number: 63734SME3C4C11584
   Subsystem 6 - Serial number: 63834SME3C4C1B72B
            004 - No Signal/Communication - Intermittent - MIL ON
01312 - Powertrain Data Bus
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
   Component: J0527               0830
   Revision: 00H09000    Serial number: 90026140670295
   Coding: 0102142
   VCID: 285FE19D9BDCAD0FF1-807C
   Component: E0221           H03 0040
                    Reset counter: 41
                    Reset counter: 81
                    Date: 2063.15.31
                    Time: 31:63:02
                    Reset counter: 81
                    Date: 2063.15.31
                    Time: 31:63:02
                    Reset counter: 81
Address 17: Instruments
Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
   Part No SW: 4L0 910 105     HW: 4L0 815 071 H
   Component: Heizgeraet      H10 0140
   Revision: 0000000A    Serial number: 00000009024928
   Coding: 0000101
   VCID: 60CFB9BDB36C154FF9-8034
   Part No SW: 4F0 907 468 R    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0058
   Revision: LB700037    Serial number: 3700L143290454
   Coding: 00CF07
   VCID: 3E7327C5A95803BFAB-806A
   Component: J367-BDM  H07 0125
   Serial number: 31090219564121042614
   Serial number: 14092001342011200181
11 Faults Found:
                    Reset counter: 79
                    Mileage: 43919 km
                    Date: 2019.09.01
                    Time: 12:18:24
                    Bin. Bits:    10111
                    Voltage: 11.50 V
                    Count: 7
                    Fault Frequency: 48
                    Reset counter: 41
                    Mileage: 44099 km
                    Date: 2019.09.14
                    Time: 21:42:39
                    Bin. Bits:    10000
                    Voltage: 12.10 V
                    Count: 11
                    Bin. Bits:    10010
                    Reset counter: 81
                    Mileage: 44099 km
                    Date: 2019.09.14
                    Time: 21:42:39
                    Bin. Bits:    10000
                    Voltage: 12.10 V
                    Count: 11
                    Bin. Bits:    10010
                    Time: 13.50 s
                    Reset counter: 81
                    Mileage: 44099 km
                    Date: 2019.09.14
                    Time: 21:42:39
                    Bin. Bits:    10111
                    Voltage: 11.90 V
                    Count: 7
                    Bin. Bits:    10011
                    Time: 0.40 s
                    Reset counter: 81
                    Bin. Bits:    10111
                    Voltage: 12.00 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 4.90 s
01327 - Control Module for Parking Aid (J446)
                    Reset counter: 81
                    Bin. Bits:    10111
                    Voltage: 12.00 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 5.00 s
02103 - Control Module 2 for Vehicle Electrical System (J520)
                    Reset counter: 81
                    Bin. Bits:    10000
                    Voltage: 12.00 V
                    Count: 11
                    Bin. Bits:    10010
                    Time: 4.90 s
                    Reset counter: 81
                    Bin. Bits:    10000
                    Voltage: 11.90 V
                    Count: 12
                    Bin. Bits:    10010
                    Time: 25.40 s
00384 - Optical Databus
                    Fault Status: 00101011
                    Reset counter: 81
                    Bin. Bits:    00000
                    Voltage: 12.20 V
                    Count: 19
                    Bin. Bits:    10010
00565 - Rear A/C Control Head (Climatronic) (E265)
                    Reset counter: 81
                    Bin. Bits:    10000
                    Voltage: 12.00 V
                    Count: 12
                    Bin. Bits:    10011
                    Time: 25.40 s
                    Reset counter: 81
                    Bin. Bits:    11111
                    Voltage: 12.00 V
                    Count: 7
                    Bin. Bits:    10011
                    Time: 0.40 s
   Part No SW: 4L0 910 158     HW: 4L0 919 158 AD
   Revision: 00---011    Serial number: 00000030330555
   Coding: 0000006
   VCID: 68DFA19D5B5C6D0F31-803C
00003 - Control Module
                    Fault Status: 00100011
                    Fault Frequency: 15
                    Mileage: 34059 km
                    Date: 2018.08.28
                    Time: 15:12:12
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 41
                    Mileage: 44099 km
                    Date: 2019.09.14
                    Time: 21:39:19
                    Reset counter: 41
                    Mileage: 44099 km
                    Date: 2019.09.14
                    Time: 21:42:39
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000098720608
   Coding: 011E52200141440004
   Shop #: WSC 14644 002 104857
   VCID: 489F411DFB9C4D0F11-801C
02123 - Door Warning Light / Entry Light
                    Fault Status: 01101100
                    Fault Frequency: 19
                    Reset counter: 41
                    Reset counter: 81
                    Reset counter: 81
                    Reset counter: 81
   Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
   Component: Komfortgeraet   H12 0130
   Revision: 0130 ---    Serial number: 01945953440000
   Coding: 3539341
   VCID: 387F31DD4B7C3D8F61-806C
                    Reset counter: 81
                    Reset counter: 81
                    Reset counter: 81
                    Reset counter: 81
                    Reset counter: 81
   Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H04 0160
   Revision: CH004001    Serial number: 00000000038453
   Coding: 030000
   VCID: 2959E49940D69407EE-807C
   Part No SW: 4F0 910 280     HW: 4F0 907 280
   Component: ILM Beifahrer   H16 0100
   Revision:             Serial number: 00000000740665
   Coding: 0011001
   VCID: 5EB38745891823BFCB-800A
                    Reset counter: 81
                    Voltage: 12.100 V
                    Temperature: 35.0°C
                    Reset counter: 81
                    Voltage: 12.000 V
                    Temperature: 33.0°C
                    Fault Frequency: 84
                    Reset counter: 41
                    Mileage: 44096 km
                    Date: 2019.09.14
                    Time: 21:42:00
                    Voltage: 12.200 V
                    Temperature: 77.0°C
                    Reset counter: 81
                    Voltage: 9.700 V
                    Temperature: 77.0°C
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000097819635
   Coding: 011F52204C41440004
   VCID: 479D4221F682427718-8012
                    Fault Frequency: 12
                    Reset counter: 41
                    Reset counter: 81
                    Reset counter: 81
                    Reset counter: 81
   Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
   Serial number: 140407-0002-128
   Coding: 1147A71010000500
   ROD: EV_HeadlRegulBasic.rod
   VCID: 428B5335D5A0675FCF-8016
0074 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 81
0076 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 81
0078 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 81
0082 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 41
0084 - Function Restricted due to Missing Message(s)
          U1111 00 [137] - -
                    Reset counter: 41
0092 - Function Restricted due to Missing Message(s)
          U1111 00 [137] - -
                    Reset counter: 41
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227D90E7988906
   Coding: 040003010000000000
   VCID: 2643EFA551C8BB7FC3-8072
   Part No SW: 4L2 035 764 G    HW: 4L2 035 764 G
   Component: H-BNT-RW      H48 0793
   Revision: --------    Serial number: 222DQ0E7516151
   Coding: 180A01060004C3FF010007456F7720035C0000000000000000
   VCID: 326B03F56D00D7DF5F-8066
   Subsystem 1 - Part No: 8R0 060 884 BN
   Component: ROW 2014  0605
   Component: DU7 High  H42 0104
   Serial number: A130D%0E2999726
   Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
   Component: E0380 Bedient  H01 0060
   Serial number: 00000002176053
   Component: CD-Database  5571
                    Reset counter: 81
                    Voltage: 12.10 V
                    Reset counter: 41
                    Bin. Bits: 10000000 00000000
                    Bin. Bits: 00000000 00000100
                    Bin. Bits: 00000000 00000000
                    Reset counter: 41
                    Bin. Bits: 00000000 10000100
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000098742385
   Coding: 010850204041230004
   Shop #: WSC 14644 002 1048576
   VCID: 46834F25F1885B7FE3-8012
                    Reset counter: 81
   Part No SW: 4L0 907 428     HW: 7P6 907 441 D
   Component: TopView       H05 0293
   Revision: 11001001    Serial number: 82330JF0141287
   Coding: 020C010001000100000102000000
   ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
   ROD: EV_CamSysteCorneViewAUDI.rod
   VCID: 6ED3D785B1B8B33F7B-803A
13701381 - Databus
                    Reset counter: 81
                    Voltage terminal 30: 11.5 V
                    Terminal 15 status: Terminal 15 on
13701382 - Databus
                    Reset counter: 81
13701383 - Databus
                    Reset counter: 81
                    Voltage terminal 30: 12.3 V
                    Terminal 15 status: Terminal 15 off
13701385 - Databus
                    Reset counter: 81
13701386 - Databus
                    Reset counter: 81
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 4L0 910 945     HW: 4L0 827 851 F
   Component: ValeoHeckdeckel H58 0500
   Revision: --H58001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6CD7DD8D4FA4412F55-8038
   Subsystem 2 - Serial number: 5ó
   Subsystem 3 - Serial number: RD05.04.14--H58001002E0119ÿ
   Subsystem 4 - Serial number: 2E0119ÿ
   Component: ILM HINTEN 2    H08 0080
   Revision: AAH08080    Serial number: 0097987843----
   Coding: 0003587
   VCID: 2643EFA591C8BB7FC3-8072
   Component: J_245_EE16_SKB10H14 0220
   Component: J_394_EE16_SKB10H14 0220
   Component: J_392_EE16_SKB10H14 0220
                    Reset counter: 81
                    Reset counter: 81
                    Reset counter: 81
00927 - Terminal 30 (Right)
                    Fault Status: 00101100
                    Reset counter: 81
01516 - Terminal 30; Left
                    Reset counter: 81
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000098742384
                    Reset counter: 81
End-------------------------(Elapsed Time: 03:42)--------------------------
South Molton, UK
Many of those errors are intermittent, so try clearing all DTCs and see which ones come back, the post a new Auto-Scan showing those.
Are you 100% certain you put all the fuses back in the correct place?
anuragh
Australia
C?ID=219176 (NRRT)
Thanks PetrolDave
I actually cleared all DTCs before and i keep getting these errors back.
I may do it once again and get a full scan and post again in about an hour or less
I think i did put all the fuses back to where they were but i can be wrong now as i am questioning myself too :)
It would be handy if i can get a picture of the left hand side of the dash fuse pictures. Because the first fuse at the top bracket (out of 3) do not have power when i checked with voltage tester. I pulled that fuse out and checked - the fuse is ok.
anuragh
Australia
C?ID=219176 (NRRT)
Hi again
I cleared all DTC and rescanned
The errors still came up
Pls see the new errors below
Tuesday,17,September,2019,19:54:33:12214
VIN: WAUZZZ4L7ED035153   License Plate:
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 28 42 46 47 4F 52 55 56
          5F 62 6C 6D 6F 72
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
10-Park/Steer Assist -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
17-Instruments -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
6C-Back-up Cam. -- Status: Cannot be reached 1100
          U0155 00 [175] - -
                    Engine speed: 0.00 /min
                    Coolant temperature: 64 °C
                    Intake air temperature: 36 °C
                    Voltage terminal 30: 12.300 V
                    Cruise Control System (CCS): status-Bits 0-7: 236
   Coding: 001578
          U0155 00 [009] - -
                    Reset counter: 201
                    Engine speed: 0.0 /min
                    Transmission input speed: 0 /min
                    Engine torque: -52 Nm
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
   Revision: 00H02001
   Coding: 2196593
                    Reset counter: 41
                    Count: 128
                    Count: 321
                    Count: 8208
                    Count: 44288
   Coding: 0000151
   Coding: 01029456
                    Reset counter: 41
   Coding: 0023121
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 28031F
12670224 - Databus
                    Reset counter: 41
   Coding: 0014128
   Coding: 0102142
                    Reset counter: 41
   Coding: 0000101
   Coding: 00CF07
                    Reset counter: 41
                    Bin. Bits:    10000
                    Voltage: 12.70 V
                    Count: 12
                    Bin. Bits:    10011
   Coding: 0000006
                    Reset counter: 41
                    Reset counter: 41
   Coding: 3539341
   Coding: 030000
   Coding: 0011001
                    Reset counter: 41
                    Voltage: 12.800 V
                    Temperature: 20.0°C
          U1111 00 [009] - -
                    Reset counter: 41
          U1111 00 [137] - -
                    Reset counter: 41
          U1111 00 [137] - -
                    Reset counter: 41
                    Reset counter: 41
                    Reset counter: 41
   Coding: 0003587
End-------------------------(Elapsed Time: 03:33)--------------------------
morski
Cheshire UK
C?ID=90186
Recheck the fuses, check your manual for location and numbers. All the faults appear to be from no power to the modules
anuragh
Australia
C?ID=219176 (NRRT)
Thank You Morski
I checked all fuses
On the left hand side fuse block the A1 fuse - Supposed to be for Voltage stabiliser - J532 has no power. I thought it was a blown fuse but its not the fuse as i tried that fuse in other locations and also i tried a new fuse for this.
Now I am pretty sure my J532 module is gone. As i read that this provides constant 10V power to the dash clusters on these cars.
I could not find anywhere on internet the location of this Module. Does anyone know where this module is and how i can access it?
I am guessing behind the dash clusters , Battery under the seat or around the spare tyre at the back.
Thank you
morski
Cheshire UK
C?ID=90186
Check near the battery. Not 100% sure where it is on the Q7 but a5,a6,a4's etc are all near the battery. There are/should be some fuses by the battery terminal check them as well. Also have you used a voltage light stick where you can probe to check for power presence on each of the fuses whilst still physically in place? Could be a old fuse that looks ok but is broken inside.
Have you got the workshop manual for the car as it will the location of all fuse boxes and fuses
darkchina811
ITALY
C?ID=333184
free hint: before pulling out one entire row, or the whole fusebox, take pictures with your cell phone. been there :P
anuragh
Australia
C?ID=219176 (NRRT)
Thanks again Morski
I checked all the fuse locations except the one near battery as the battery in this car is located under the passengers seat - so i got to remove the seat or unless there is any easy access there.
Yes i used the voltage light to check the fuses and thus concluded that VOLTAGE STABILIZER FUSE port is dead and is not feeding power to the fuse. The fuse itself is good as i tried couple of new fuses too - just in case.
I do not have the workshop manual but i know the locations of all fuses. The only thing that's left for me to try is to test fuses near battery area under the seat and if fuses are good there start hunting for J532 Module which i don't know where its located - because in this case this module may need to be replaced.
please anyone help me show me an easy way to test fuses under the seat and tell me where J532 is located
Thank you
anuragh
Australia
C?ID=219176 (NRRT)
Anyone could please help me to locate the J532 module please/
And also if i remove the instrument cluster - do i need to unplug the battery?
Will it mess up the immobilizer if i do not disconnect battery?
anuragh
Australia
C?ID=219176 (NRRT)
Update. This port is actually for DC/DC converter. So could you please tell me why i am not getting power in this port. I think i have shorted something. Need to know what i shorted
anuragh
Australia
C?ID=219176 (NRRT)
Hi Guys Pls I still am looking for a clue. I don't want to take it to the dealer for this and local auto electricians are not really very sure of the wiring in this car. Is there any circuit breakers around the fuse block (left side of cockpit) which powers this fuse location (Voltage Stabilser).
Just to recap - i do not have power on this fuse location and so my dash cluster is not powering up.
