Skoda Kodiaq MY17 electric child lock retrofit
Mika_M
Finland
C?ID=183725
I started to investigate how hard would it be to retrofit electronically operated rear door child safety locks to Kodiaq. Car has almost every other option installed from factory, but these are missing. Car has PR code 4H3 "Manual child safety lock". 4H5 would be the electrically operated version.
But after investigating wiring diagrams for 4H3 and 4H5, it seems that they are quite different. 4H3 shows no control module in rear door, locking module is wired straight to J519. Option 4H5 contains rear door control module, to which the locking module and window operations are wired.
What puzzles me now, is my auto-scan. It shows a slave module for rear door under each front doors. What is this module then, if my car should not have a control module in rear door?
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0032
Serial number: 0000255786274
Coding: 00150920DE00040000001100
Shop #: WSC 33361 790 00063
VCID: 47CBA6DE7F2B87EF4BB-8012
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000014679392
Coding: 010200
Can anyone clarify this for me, does it seem that my car already has rear door control modules or not? If it has, then the retrofit would be quite an easy task to do. But if not, then the amount of work may be too much for me...
Below is full auto-scan of my car.
Tuesday,20,August,2019,20:08:15:26429
VCDS Version: 19.6.0.2  HEX-V2 CB: 0.4505.4
VIN: TMBLK7NS9H8028838   License Plate:
Mileage: 96380km-59887mi   Repair Order:
Chassis Type: NS-SK37 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 18 19 22 29 2B 36 39
          3C 42 44 47 52 55 5F 69 6C 6D 75 A5 CA D6 D7
VIN: TMBLK7NS9H8028838   Mileage: 96380km-59887miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 EJ    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 3916
   Revision: B4H25---
   Coding: 0125003A04761D083000
   ASAM Dataset: EV_ECM20TDI01104L906026EJ 004004
   ROD: EV_ECM20TDI01104L906026EJ_004.rod
   VCID: 76B51B1A48414E67E0D-8022
   Part No SW: 0DL 300 011 N    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2014
   Revision: 00H06V07
   VCID: 3333E20E1BB31B4F073-8066
   Revision: 00000000    Serial number: 61297000001199
   Coding: 60076A9F54220B74477F070362CB4906562AD0E2E046927D386150F8E2AA4200002F641A1B13111435351919323200
   VCID: 77AB161E4F4B376FFBB-8022
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0441013672
   Coding: 032C0C0F03
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   ROD: EV_KessyHellaMQBAB_VW48.rod
   VCID: 3C21C93236EDD437D69-8068
   Subsystem 1 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
   Component: GEB.F.Heckoef  H17 0904
   Serial number: 58066189
   Part No SW: 5Q0 959 760 B    HW: 5Q0 959 760 B
   Component: Sitzmemory    H08 0021
   Serial number: Y0006QDK24573
   Coding: 0010000000000500018281818181000000008181000000D400
   ASAM Dataset: EV_SeatMemorPasseSide 002021
   ROD: EV_SeatMemorPasseSide.rod
   Part No SW: 565 907 044 AE    HW: 565 907 044 AE
   Revision: 00001K00
   Coding: 16010104004411011105100D0000110A
   Shop #: WSC 73430 790 00063
   VCID: 5EE563BAC0B1E62798D-800A
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
   Air quality sensor:
   Subsystem 3 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Component: G238 _AQS  H30 0119
   Serial number: 60603206
263425 - Air Quality Sensor
          B10AF 04 [009] - Internal System Fault
                    Fault Frequency: 98
                    Reset counter: 166
                    Mileage: 95140 km
                    Date: 2019.08.02
                    Time: 20:30:07
                    Voltage terminal 30: 12.4 V
                    Outside air temperature: 16.5 ∞C
                    System run time-Terminal 15 on: 255 s
   Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 032 0223
   Revision: --------    Serial number: 8658060517000J
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 015F78C6118F79DFC5F-8054
   Subsystem 1 - Part No SW: 566 955 119     HW: 566 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS326 170328  051 0907
   Serial number: 887353F0401708700512
   Coding: 164DDD
   Component: RLHS  042 0105
   Serial number: S9Y17M05D08H16M46S45
   Coding: 0088DF
   Seat Backrest Fan 1 Front Left:
   Seat Cushion Fan 1 Front Left:
   Seat Backrest Fan 1 Front Right:
   Seat Cushion Fan 1 Front Right:
   Part No SW: 3Q0 919 298 A    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H09 0021
   Serial number: 000405177478022
   Coding: 0231267A51
   ASAM Dataset: EV_EPHBO2CVW3260000 010016
   ROD: EV_EPHBO2CVW3260000.rod
   VCID: 3B23CA2E33E3D30FDF3-806E
   Part No SW: 2Q0 907 572 J    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0156
   Coding: 320147CB50FF8728749C8065304085
   ASAM Dataset: EV_ACCMRRCONTIVW376 001011
   ROD: EV_ACCMRRCONTIVW376_001.rod
   Serial number: 18041741350653
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 3829D52202D5F817321-806C
   Part No SW: 3Q0 959 655 AK    HW: 3Q0 959 655 AK
   Component: Airbag VW21   004 0306
   Revision: --------    Serial number: 003R6P84LE5R
   Coding: 98CCC0C0000000005C5400CF004800000065
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 074B66DE3FAB47EF8BB-8052
   Subsystem 1 - Part No SW: -----------    HW: 454 000 205 17
   Serial number: 3570000000018120A420
   Subsystem 2 - Part No SW: -----------    HW: 454 000 205 17
   Serial number: 35800000000C2C30A42I
   Subsystem 3 - Part No SW: -----------    HW: 454 800 205 17
   Serial number: 3510089F28310000000C
   Subsystem 4 - Part No SW: -----------    HW: 454 800 205 17
   Serial number: 35200735787100000005
   Subsystem 5 - Part No SW: -----------    HW: 454 801 504 17
   Serial number: 35500796DE50F000000$
   Part No SW: 5Q0 953 521 LA    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0245
   Revision: FF036036    Serial number: 20170515500850
   Coding: 6414
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001007
   ROD: EV_SMLSVALEOMQBLRH.rod
   VCID: 7CA10932766D1437969-8028
291104 - Temperature Sensor for Heated Steering Wheel
          B1455 01 [008] - Electrical Failure
                    Fault Frequency: 137
                    Reset counter: 206
                    Ubat 30 Voltage: 12.60 V
                    Internal error state: 0
                    LIN_Temp: 0
                    Isense: 0
                    Max.Leistung: 110
                    PWM: 0
                    Offset: 16
                    Slope: 134
                    kp: 18
                    OUT: 50
                    Temperatur Statisch: 30
                    p_t_soll_0: 34.00 ∞C
                    p_t_soll_1: 39.00 ∞C
                    p_t_soll_2: 44.00 ∞C
   Part No SW: 565 920 751     HW: 565 920 751
   Component: KOMBI         311 8311
   Coding: 03A5081CFF84000801886B0B5001000800000000
   Shop #: WSC 73430 031 00063
   VCID: 58E975A2A2951817D21-800C
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 G    HW: 5Q0 963 272 G
   Component: STH-MQB       008 0075
   Coding: 9309
   VCID: 3A2DCF2A3CD9EA07C45-806E
   Subsystem 1 - Part No SW: 3Q0 963 513     HW: 3Q0 963 513
   Component: R64 D208L  004 0401
   Serial number: 00000000000000241622
   Component: GW MQB High   518 5286
   Serial number: 07051710800030
   Coding: 0B0100344F087300EB03225A9E0F00010001070000000000000000000000
   Shop #: WSC 33361 790 00114
   ROD: EV_GatewNF.rod
   VCID: 2F3BEE7EF79B3FAF63B-807A
   Subsystem 2 - Part No SW: 3V0 919 719 C    HW: 3V0 919 719 C
   Serial number: 000000000A1815190417
   Subsystem 3 - Part No SW: 5QA 915 181 C    HW: 5QA 915 181 C
   Serial number: 75886100001705040B22
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 H    HW: 5Q0 907 155 H
   Component: U13DCAC  H25 0780
   Serial number: 0013773
   Serial number: HA1-00026.03.17
   Coding: 0101
   VCID: 4ACD9FEA6C397A87545-801E
Address 29: Left Light (J1018)       Labels: None
   Part No SW: 8V0 907 397 AD    HW: 8V0 907 397 D
   Component: LCM_MLBevoH05 0024
   VCID: 06556BDA38A15EE7F0D-8052
   Serial number: 17000116788015
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BF2806212F695F35F-8024
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Serial number: Y0006QDK14886
   ASAM Dataset: EV_SeatMemorDriveSide 002021
Address 39: Right Light (J1023)       Labels: None
   Serial number: 0438592042
   Coding: 02012103
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Serial number: 0440829488
   Coding: 020121
   Coding: 010200
   Revision: 00000000    Serial number: 0001644929
   Coding: 01010011004001
   ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
   VCID: 40D9BDC25A05B0D78A1-8014
   Part No SW: 81A 035 223     HW: 81A 035 223
   Component: MIB2_amp_P_SK H10 0410
   Revision: 00000001    Serial number: SKZ8Z1HJE01QNAM
   Coding: 0323160000AA002AAA0000000000
   ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001003
   ROD: EV_AMPMst16C4Gen2ALPI.rod
   VCID: 59EF70A6D99F011FEDF-800C
   Component: TSG BFS       010 0032
   Serial number: 0000257250262
   Coding: 00150120DE00040000001100
   VCID: 46D5ABDA78219EE7B0D-8012
   Serial number: 00000000000014613733
   Coding: 190200
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0070
   Coding: 03E202003D210901
   ROD: EV_HeadlRegulAFSMQBMAX_SK37.rod
   VCID: 41DFB8C6510FB9DF85F-8014
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
   Part No SW: 3V0 035 043 D    HW: 3V0 035 043
   Component: MU-H-N-EU     H50 0942
   Serial number: A677D0HS009230
   Coding: 032316010000000051110002000808232F0300E4012081009E
   ROD: EV_MUHig4CGen2HBAS_SK37.rod
   VCID: 2C01F972C68D44B7469-8078
   Subsystem 1 - Part No SW: 565 919 605 B    HW: 565 919 605 B
   Component: ABT_Std-2_Nav  H35 8077
   Serial number: SKZ6ZHT1360105
   Subsystem 2 - Part No SW: V03 959 801 JM    HW: -----------
   Component: ECE 2017  --- 0157
   Compact Disc Database:
   Component: Gracenote2---  --- 1013
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anhaenger     H21 0204
   Revision: 8A001003    Serial number: 0441297010
   Coding: 0100000202000000
   Part No SW: 5Q0 907 556 B    HW: 5Q0 907 556
   Component: Areaview 2    H13 0607
   Serial number: C854707JG014238
   Coding: 04231601A70FA00000604014
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
   Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: 31351429200000
   Coding: 1B88
   Part No SW: 5NA 035 284 A    HW: 5NA 035 284 A
   Component: OCULowMQBLGE  H13 0614
   Coding: 03231601EA423A0D3B1C9E020045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 003042
   ROD: EV_OCULowMQBLGE_003_VW25.rod
1078036 - Crash Signal
          B1073 15 [008] - Open or Short to Plus
                    Mileage: 67400 km
                    Date: 2018.11.21
                    Time: 14:04:22
   Serial number: 15091712P22800
   Coding: 020307060000040100262355C050A90098000E200020
   Shop #: WSC 39697 001 1048576
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Coding: 008040648202
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3D27C4362DF7DD3FE17-8068
   Part No SW: 7PP 941 571 AE    HW: 7PP 941 571 A
   Component: LED1L         H09 0007
   VCID: 186935A26215D817121-804C
   Component: LED1R         H09 0007
   ROD: EV_LEDModLeftMELCOAU736_VW48.rod
End------(Elapsed Time: 04:26, VBatt start/end: 12.1V/12.0V, udsna)--------
Mika_M
Finland
C?ID=183725
Ah, that slave module is rear door window motor... Rear door control modules should appear in installation list at address BB and BC. Too bad. :cry:
