VW Scirocco 1.4L 7speed gearbox slipping
dpasquazzo
Bahrain
C?ID=324791
Dear,
I would like your help in the troubleshooting of the following code for that gearbox:
Address 02: Auto Trans Labels: 0AM-927-769.clb
Part No SW: 0AM 300 048 N
HW: 0AM927769D
Component: GSG DSG AG7 403 9056
Revision: 00040034
Serial Number: TFK01101200561
Shop #: WSC 33962 001 1048576
VCID: 3B39A4EF0097B091264015-806E
  1. 006300 - Function Restriction due to Insufficient Pressure Build-Up P189C - 000 - -
  2. 006079 - Hydraulic Pump P17BF - 000 - Play Protection
  3. 006079 - Hydraulic Pump P17BF - 001 - Play Protection
Address 01:
Engine Labels: 03C-906-027-CAV.clb
Part No SW: 03C 906 027 BB
HW: 03C907309B
WSC 71500 819 100930
  1. 049409 - No Communication with Transmission Control Module U0101 - 000 - - - Intermittent
  2. 001092 - EVAP Purge Control Valve (N80) P0444 - 000 - Circuit Open - MIL ON
Regards,
South Molton, UK
Please post a full unedited Auto-Scan not just two tiny sections :thanks:
dpasquazzo
Bahrain
C?ID=324791
VIN: WVWAC2135AV431700 Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 4F 52 55 56 77 VIN: WVWAC2135AV431700 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Communication Error 1010 03-ABS Brakes -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: Malfunction 0010 17-Instruments -- Status: Malfunction 0010 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Xenon Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 77-Telephone -- Status: OK 0000 ----------------------------------------------------------------- Address 01: Engine Labels: 03C-906-027-CAV.clb Part No SW: 03C 906 027 BB HW: 03C907309B Component: MED17.5.5 G 9703 Revision: LAH08--- Serial Number: Coding: 0000077 Shop #: WSC 71500 819 100930 VCID: 6287398BC7BDA15945C6A0-8037 2 Faults Found: 049409 - No Communication with Transmission Control Module U0101 - 000 - - - Intermittent 001092 - EVAP Purge Control Valve (N80) P0444 - 000 - Circuit Open - MIL ON ----------------------------------------------------------------- Address 02: Auto Trans Labels: 0AM-927-769.clb Part No SW: 0AM 300 048 N HW: 0AM927769D Component: GSG DSG AG7 403 9056 Revision: 00040034 Serial Number: TFK01101200561 Coding: 0000020 Shop #: WSC 33962 001 1048576 VCID: 3B39A4EF0097B091264015-806E 3 Faults Found: 006300 - Function Restriction due to Insufficient Pressure Build-Up P189C - 000 - - 006079 - Hydraulic Pump P17BF - 000 - Play Protection 006079 - Hydraulic Pump P17BF - 001 - Play Protection ----------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ Component: ESP MK60EC1 H30 0107 Revision: 00H30001 Coding: 743B60F5612500FB2E1206E486190040310000 Shop #: WSC 00020 790 00000 VCID: 7AB761EB4F2DC9997DD6D8-802F 1 Fault Found: 01315 - Transmission Control Module 004 - No Signal/Communication - Intermittent ----------------------------------------------------------------- Address 08: Failed to respond ----------------------------------------------------------------- Address 09: Failed to respond
dpasquazzo
Bahrain
C?ID=324791
sure
Monday,16,September,2019,16:56:05:57315
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4505.4
VIN: WVWAC2135AV431700   License Plate:
Chassis Type: 13-VW36 (1K0)
02-Auto Trans -- Status: Malfunction 1010
Address 01: Engine (CAV)       Labels: 03C-906-027-CAV.clb
   Part No SW: 03C 906 027 BB    HW: 03C 907 309 B
   Revision: LAH08---    Serial number:
   Coding: 0000077
   VCID: 628844B9BD90525FEF-8036
               U0101 - 000 -  - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Temperature: 25.0°C
                    Temperature: 25.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 12.065 V
                    Fault Status: 11100000
                    Date: 2047.15.31
                    Time: 31:63:63
                    RPM: 244 /min
                    Load: 50.6 %
                    Temperature: 26.0°C
                    Temperature: 25.0°C
                    Voltage: 10.922 V
Readiness: 0110 0101
   Part No SW: 0AM 300 048 N    HW: 0AM 927 769 D
   Revision: 00040034    Serial number: TFK01101200561
   VCID: 3B36D9DD7ABA43978C-806E
               P189C - 000 -
                    Fault Frequency: 8
                    Reset counter: 10
                    Mileage: 118867 km
                    Date: 2046.14.00
                    Time: 00:16:54
               P17BF - 000 - Play Protection - Intermittent
                    Reset counter: 10
                    Mileage: 118867 km
                    Date: 2046.14.00
                    Time: 08:04:45
   Revision: 00H30001
   VCID: 7AB81CD9F500BA9FD7-802E
                    Reset counter: 18
                    Mileage: 118867 km
                    Date: 2045.14.31
                    Time: 00:29:02
                    Count: 16386
                    Count: 14
                    Count: 28672
                    Count: 8195
                    Count: 43776
                    Count: 10081
Address 08: Auto HVAC (J255)       Labels:. 5K0-907-044.clb
   Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
   Component: Climatronic   H15 1012
   Revision: 00003001
   Coding: 0000001002
   Shop #: WSC 35435 001 1048576
   ROD: N/A
   VCID: 7EB010C9E12896BFEB-802A
No ASAM data for: "EV_Climatronic" (VW36 *)
   Part No SW: 5K0 937 087 D    HW: 5K0 937 087 D
   Component: BCM PQ35 H    011 0028
   Revision: BE011001
   Coding: 40100A3B98250A0040080080340049E643550A88736D8D60648000000000
   Shop #: WSC 99900 715 86054
   VCID: 3620C8E981989EFF73-8062
   Subsystem 1 - Part No: 1K8 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 14110  22  0614
   Coding: 009795
   Component: RLS 221209 05  54  0402
   Coding: 0330ED
                    Reset counter: 58
                    Mileage: 118867 km
                    Date: 2045.14.31
                    Time: 00:29:04
                    Voltage: 12.20 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 18
                    Mileage: 118867 km
                    Date: 2045.14.31
                    Time: 00:29:03
                    Voltage: 12.20 V
Address 10: Park/Steer Assist (J446)       Labels:. 1K0-919-475.clb
   Part No SW: 1K0 919 475 K    HW: 1K0 919 475 K
   Component: PARKHILFE     005 1706
   Revision: 00005000    Serial number: 0 263 004 388
   Coding: 100101
   VCID: 3A38DCD9B5807A9F97-806E
                    Reset counter: 18
                    Mileage: 118867 km
                    Date: 2045.14.31
                    Time: 00:29:01
   Part No SW: 1K0 909 605 AE    HW: 1K0 909 605 AE
   Component: 0G AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 003D1D01YHMI
   Coding: 0012359
   VCID: 6FAE3D8D7E42EF3770-803A
   Subsystem 1 - Serial number: 6332MSME4C657509J
   Subsystem 2 - Serial number: 6342MSME4C660F48R
   Subsystem 3 - Serial number: 6352QSME1A4A2724H
   Subsystem 4 - Serial number: 6362QSME264A3D06M
Address 16: Steering wheel (J527)       Labels:. 5K0-953-569.clb
   Part No SW: 5K0 953 521 F    HW: 5K0 953 569 B
   Component: LENKS.MODUL   009 0122
   Revision: FF010035    Serial number: 20100104100117
   Coding: 189A140000
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_SMLSNGVOLWS A01002
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 2F2EFD8D76C2AF3730-807A
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H05 0010
   Coding: 830000
No ASAM data for: "EV_SMLSNGVOLWS" (VW36)
Unable to open the following:
IV_EV_SMLSNGVOLWS_A3,IV_EV_SMLSNGVOLWS_D2,IV_EV_SMLSNGVOLWS_M23,IV_EV_SMLSNGVOLWS_X4
Internal ROD error:
EV_SMLSNGVOLWS.rod:FFMUX
0516 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 58
                    Mileage: 118867 km
                    Date: 2109.14.31
                    Time: 00:29:02
Address 17: Instruments (J285)       Labels:. 5K0-920-xxx-17.clb
   Part No SW: 1K8 920 871 B    HW: 1K8 920 871 B
   Component: KOMBI         H05 0305
   Coding: 670E00
   ROD: N/A
   VCID: 312AFBF560F6B9C726-8064
No ASAM data for: "EV_Kombi_UDS_VDD_RM09" (VW36 *)
12648704 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 58
                    Mileage: 118867 km
                    Date: 2109.14.31
                    Time: 00:29:02
   Part No SW: 1K0 907 530 AE    HW: 1K0 907 951
   Component: J533  Gateway   H06 0112
   Revision:   H06 01    Serial number: 181209F1000967
   Coding: EDA11F06000603004000
   VCID: 6A982C9945A00A1F27-803E
                    Fault Status: 00110100
                    Reset counter: 58
                    Mileage: 118867 km
                    Date: 2046.14.00
                    Time: 05:12:42
   Component: IMMO          H05 0305
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A982C998DA00A1F27-803E
Internal ROD error:
EV_Immo_UDS_VDD_RM09.rod:FFMUX,EV_Immo_UDS_VDD_RM09.rod:MWB,EV_Immo_UDS_VDD_RM09.rod:XPL
   Part No SW: 1Q0 959 701 H    HW: 1Q0 959 701 H
   Component: Tuer-SG         009 2123
   Coding: 0020535
   VCID: 393AC3D5708671879E-806C
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 69     3001
   Revision: 00H17000
   VCID: 312AFBF5A8F6B9C726-8064
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Component: EZE_2         H06 0112
   Coding: 01030100
   VCID: 668058A991B82E7F03-8032
   Subsystem 1 - Part No SW: 6R0 959 591     HW: 6R0 959 591
   Component: J245/J878  H04 0054
   Serial number: 947200093561
   Coding: 000005
   Part No SW: 1Q0 959 702 H    HW: 1Q0 959 702 H
   Coding: 0020790
   VCID: 3A38DCD975807A9F97-806E
   Part No: 8P0 907 357 K
   Coding: 0000015
   VCID: 42C8A4391D50325FCF-8016
                    Fault Status: 11101010
                    Reset counter: 18
                    Mileage: 118872 km
                    Date: 2045.14.30
                    Time: 21:09:18
                    Reset counter: 18
                    Mileage: 118872 km
                    Date: 2045.14.30
                    Time: 21:09:18
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190     HW: 5K0 035 190
   Component: Radio RCD510  040 0167
   Revision: 00000001    Serial number: VWZ1Z3I7312823
   Coding: 0500040004
   VCID: 628844B97D90525FEF-8036
Address 77: Telephone        Labels: 3C0-035-730.lbl
   Part No SW: 5N0 035 730 B    HW: 5N0 035 730 B
   Component: J412                8502
   Revision: 00015000    Serial number: 0000B7A138941
   Coding: 0020145
   VCID: 271E15AD9632F777F8-8072
End----------(Elapsed Time: 01:20, VBatt start/end: 13.5V/13.5V)-----------
dpasquazzo
Bahrain
C?ID=324791
The dealership recommend to change the mechatronic...and 2 litters of gearbox oil. I am thinking maybe it is a harness fault.
What is the part i need to search for ? ebay..second hand what will be the coding to replace that part ?
Regards
Jef
HQ
OK, first questions:
Did you do something to cause the TCM to go offline? Unplug something or pull fuse(s)? If you go and clear out all the codes, do the ones for dead TCM come back?
siLc
Tallinn, Estonia
C?ID=330192
The fault codes in the transmission pretty much tell the tale of the common mechatronic fault of the DQ200 DSG. The pressure accumulator valve housing inside the mechatronic develops cracks and hydraulic pressure needed for correct operation is not attained.
Either replace or repair the mechatronic unit.
Golftwincharged
Guyana
C?ID=320847
Another Failed DSG7 mech unit, valve accumulator plate issues, replacing plate will fix this, but can this cause gearbox slipping?? in cases like this you get no gears..
dpasquazzo
Bahrain
C?ID=324791
Yes dear, it comes back as soon as s reset all codes. I didn't remove anything but maybe dealership did as I got it out of the dealership, second hand fresh purchased..
