Audi A4 radio fault
Radiosolutions
C?ID=178437
62 reg.audi multimedia not working at all. No screen or radio working. Checked all fuses and fibre optics seem to be working. Put in optical loop at different points but still will not power up.tryed loop in cd changer,multimedia unit, radio unit. in rear boot is the radio control unit. Only one 12 v feed ,is this correct.the mmi panel by gearstick does not light up,but 12 v feed is there. Can anyone help. Chassis is. Wauzzz8k7da077193. Can anyone help please.
Radiosolutions
C?ID=178437
here is scan from car. optical scan passed all tests.
Thursday,19,September,2019,15:35:56:42542
VCDS Version: 19.6.1.0
VIN: WAUZZZ8K7DA077193   License Plate: FY62LTX
Mileage: 166400km-103396mi   Repair Order: SATURN
Gateway Installation List:  8R0 907 468 H
0E-Media Player 1 -- Status: Cannot be reached 1100
5F-Information Electr. -- Status: Cannot be reached 1100
Address 19,8R0 907 468 H,recoded (Installation List),from,FF30742C20028100,to,FF30742C20828100,,
Address 19,8R0 907 468 H,recoded (Installation List),from,FF30742C20828100,to,FF30742C20028100,,
Control Module Part Number: 8R0 907 468 H
  Component and/or Version: GW-BEM 4CAN-M H11 0051
Optical Bus Diagnostic : Standard
Controller          	Electrical          	Optical
19-CAN Gateway      	OK                  	OK
5F-Information Electr.(High/D3)	OK                  	OK
0E-Media Player 1   	OK                  	OK
56-Radio            	OK                  	OK
56-Radio            	OK                  	OK
56-Radio            	OK                  	OK
56-Radio            	OK                  	OK
Optical Bus Diagnostic : 3dB Attenuation
I have tried a new mmi unit around gearstick, but still the same
What you posted above is not a "scan" but just the Gateway Installation List. Since the optical diagnostics are all OK, I would expect (hope?) to see some other clues as to why 0E and 5F cannot be reached in a full scan.
Radiosolutions
C?ID=178437
here is full scan of car. if someone can help. thanks
Monday,07,October,2019,13:23:42:42542
^^^ Still just the Gateway Installation List.
Radiosolutions
C?ID=178437
sorry here is full scan, thanks
Wednesday,09,October,2019,16:54:13:42542
VCDS Version: 19.6.2.0
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 0E 15 16 17 19 42 44 46 52 53 56 5F 62 72
VIN: WAUZZZ8K7DA077193   Mileage: 166400km-103396miles
Address 01: Engine (J623-CJCA)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 HT    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H25 9978
   Revision: 45H25---
   Coding: 0A034012242401080000
   Shop #: WSC 37301 001 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018HT 003009
   ROD: EV_ECM20TDI01103L906018HT.rod
   VCID: 03055EA98AB33657BA-8056
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K9 927 155 A    HW: 0AW 927 156 K
   Component: 0AW 20TDI RdW H04 0001
   Revision: --H04---    Serial number: 0000000946
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMVL381 A02432
   ROD: EV_TCMVL381.rod
   VCID: 3A7BE34DBDF9B79FA9-806E
   Part No SW: 8K0 907 379 CG    HW: 8K0 907 379 CG
   Component: ESP8 front    H09 0100
   Coding: 171544
   Shop #: WSC 06324 000 00000
   VCID: 000F51A593A52D4FA7-8054
   Part No SW: 8K0 907 064 GB    HW: 8K0 907 064 FB
   Component: BCM2 2.0      H11 0621
   Coding: 01B14040000000000000
   VCID: 76E3377DC16113FF8D-8022
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0812000097091015
   Serial number: 2312000106858009
   Part No SW: 8K2 820 043 AC    HW: 8K2 820 043 AC
   Revision: D0000000    Serial number: 01230520120354
   Coding: 342402E000
   VCID: 6ADB130D85D9C71F19-803E
   Part No SW: 8K0 907 063 DC    HW: 8K0 907 063 DC
   Revision: 03016001    Serial number: 00000427200902
   Coding: 290000308034A7C00081000000001F1F001D420827080201000008004000020000000024000000
   VCID: 73E50E69D21306D7AA-8026
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 240512  H06 0070
   Serial number: SWF12050240180
   Coding: 00FD11
   Serial number: 20299799
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001905120566
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 1F688D26000000000001
00910 - Indicator Lamp for Emergency Flashers (K6)
                    Fault Status: 01101100
                    Reset counter: 205
                    Mileage: 166409 km
                    Date: 2019.10.06
                    Time: 22:46:06
Address 0E: Media Player 1
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Serial number: 003KFD93A0YL
   Coding: 30534435363030303030554A3052384B3053
   Shop #: WSC 35353 001 1048576
   VCID: 489F8985F315D50F2F-801C
   Serial number: 6334MSME68125638C
   Serial number: 6344MSME6940692AK
   Serial number: 6352QSME3A150E42G
   Serial number: 6362QSME0B16296CP
   Serial number: 63732SME12150C6E/
   Serial number: 63832SME1215017CT
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [137] - Open or Short to Ground
                    Mileage: 166409 km
                    Date: 2019.10.06
                    Time: 22:48:25
9445397 - Key switch for deactivation of passenger-side airbag
          B1020 15 [137] - Open or Short to Plus
                    Mileage: 166409 km
                    Date: 2019.10.06
                    Time: 22:46:06
9446677 - Redundant signal path for airbag shut-off; passenger side
          B1025 15 [137] - Open or Short to Plus
                    Mileage: 166409 km
                    Date: 2019.10.06
                    Time: 22:46:06
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20120529001550
   Coding: 000016
   VCID: 4FADA2991E7B02376E-801A
   Component: E221 - MFL  H03 0003
   Part No SW: 8K0 920 982 E    HW: 8K0 920 982 E
   Component: KOMBIINSTR.   H35 0553
   Revision: 00000000    Serial number: RBK41GW5D
   Coding: 3386080002012600010000
   VCID: 3663F77D81E153FF4D-8062
   Part No SW: 8R0 907 468 H    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0051
   Revision: 1Y050025    Serial number: 2541Y12511805D
   Coding: 80CF07FF00
   VCID: 44879DB5C73DF16FC3-8010
   Serial number: 0412947401
   Serial number: 12143001998021200181
   Part No SW: 8T0 959 793 Q    HW: 8T0 959 793 F
   Component: TSG FA        H09 0304
   Coding: 011002204001410001
   VCID: 57BD5AF926AB4AF7B6-8002
   Component: RCEPS         H36 0507
   Revision: 00001000    Serial number: 0018589940
   Coding: 100000000001
   Shop #: WSC 05340 001 1048576
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3467CD759F9D41EF73-8060
   Revision: 00002001    Serial number: 0175540789
   Coding: 011B062200B90000802001368000000F
   Part No SW: 8T0 959 792 Q    HW: 8T0 959 792 H
   Component: TSG BF        H08 0304
   VCID: 56A357FD21A173FFAD-8002
   Part No SW: 8K0 907 801 K    HW: 8K0 907 801 J
   Component: EPB-4         H01 0002
   Revision: --------    Serial number: 10000000052868
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 377DFA798EEBAAF756-8062
Address 56: Radio
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0304
   Coding: 010002204001210001
   VCID: 59B95CC150BF5C8780-800C
   Component: TSG HR        H07 0304
End-------------------------(Elapsed Time: 03:49)--------------------------
Radiosolutions
C?ID=178437
can someone check the can network module coding to see if its correct,as I check everything now and now lost.the only thing I cannot see is in glovebox it has the multichanger and when running fibre diag it does not show this.
Radiosolutions
C?ID=178437
can anyone help
South Molton, UK
Have you tried putting an optical bypass in place of the multi changer?
