Seat Exeo abs coding
AurimasFr
Lithuania
C?ID=360401
I need recode Seat Exeo abs from auto transmission to manual. Engine i have recode. Can some on help with abs?
Monday,16,September,2019,17:53:51:06635
VIN: VSSZZZ3RZDR002320   License Plate: SEAT EXEO
Mileage: 208970km-129847mi   Repair Order:
Chassis Type: 3R-SE41 (3R - Seat Exeo (2010 >))
Scan: 01 02 03 08 09 10 15 16 17 25 37 36 45 46 4C 55 56 77
VIN: VSSZZZ3RZDR002320   Mileage: 208970km-129847miles
Address 01: Engine (J623-CJCA)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 ME    HW: 03L 906 018 LD
   Component: R4 2.0l TDI   H24 9978
   Revision: 46H24---    Serial number:
   Coding: 13194012233400080000
   ASAM Dataset: EV_ECM20TDI01103L906018ME 003007
   ROD: EV_ECM20TDI01103L906018LD.rod
   VCID: 79AFEF3CF958CC7F8D7-802C
Address 03: ABS Brakes        Labels: None
   Part No SW: 3R0 907 379     HW: 3R0 614 517
   Component: ESP8 FRONT      H06 0050
   Coding: 0004402
   Shop #: WSC 06441 785 00200
   VCID: 78A9EA38CED2D577F29-802C
                    Hex Value: 0x0000
                    Hex Value: 0x0702
                    Hex Value: 0x0013
                    Hex Value: 0x44B1
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0702
                    Hex Value: 0x0014
                    Hex Value: 0x21B1
                    Hex Value: 0x0000
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 000 -
                    Hex Value: 0x0000
                    Hex Value: 0x0702
                    Hex Value: 0x0014
                    Hex Value: 0x10B1
                    Hex Value: 0x0000
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   3233
   Coding: 00000
   Shop #: WSC 06441
   VCID: 6D87CB6CB48060DF11F-5160
            30-00 - Open or Short to Plus
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  ECE 1107
   Coding: 11101
   Shop #: WSC 06441
   VCID: 3D273B2CA460305FE1F-4B1E
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 3R0 919 475     HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H08 0005
   Revision: --------    Serial number: 36861216901672
   Coding: 010002
   Shop #: WSC 04941 000 00000
   VCID: 78A9EA38C2D2D577F29-802C
Address 15: Airbags        Labels: 3R0-959-655.clb
   Part No SW: 3R0 959 655     HW: 3R0 959 655
   Component: 02 Airbag 9.41  H15 0010
   Revision: 91H15001    Serial number: 003E90026VT8
   Coding: 0012338
   VCID: 7CA1F628FAEAF957961-8028
   Subsystem 1 - Serial number: 6332DRB40EB3531FZ
   Subsystem 2 - Serial number: 6342DRB40EB21420I
   Subsystem 3 - Serial number: 6352ARB406BB8CA30
   Subsystem 4 - Serial number: 6362ARB406BB36A0U
   Subsystem 5 - Serial number: 63747RB406B53BAA$
   Subsystem 6 - Serial number: 63847RB406B51CE7/
   Part No: 8E0 953 549 Q
   Component: Lenksįulenmodul     0902
   Coding: 02042
   Shop #: WSC 11111
   VCID: 41DF47DCD89854BF857-4B1E
Address 17: Instruments        Labels: 3R0-920-xxx-17.clb
   Part No SW: 3R0 920 830 L    HW: 3R0 920 830 L
   Component: KOMBI+WFS 4     H06 0040
   Revision: 0040        Serial number: 00000000000000
   Coding: 0006018
   Shop #: WSC 12345 111 45725
   VCID: 372B2904835C1A0F3B3-5184
   Coding: 0006018
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 3R0 035 192     HW: 3R0 035 192
   Component: RNS-E PU EU     H07 0220
   Revision: 0000013S    Serial number: SEZBZ7M6903464
   Coding: 0318157
   VCID: 698FBF7C85687CFF7D7-5118
   Part No: 8E0 959 433 CL
   Component: Komfortgerįt T01    4336
   Coding: 07024
   Shop #: WSC 06441
   VCID: 7DA7FB2CE4E0F05FA1F-4B1E
   Subsystem 1 - Part No: 8E1959801G
   Component: Tõrsteuer.FS BRM 0706
   Subsystem 2 - Part No: 8E1959802G
   Component: Tõrsteuer.BF BRM 0706
   Component: Tõrsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 0606
00955 - Key 1
            35-00 - -
Address 4C: Tire Pressure II        Labels: 3R0-907-274.clb
   Part No SW: 3R0 907 274     HW: 3R0 907 274
   Component: J793  RKA+      H04 0002
   Revision: 00000528    Serial number: 00005280169166
   Coding: 0000577
   VCID: 72BDD810A8AEBF27CCD-8026
                    Fault Status: 11101101
                    Fault Frequency: 34
                    Reset counter: 108
                    Mileage: 208976 km
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0001
                    Voltage: 11.10 V
                    Temperature: 15.0°C
                    (no units): 0.0
                    Reset counter: 144
                    Mileage: 208976 km
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0001
                    Voltage: 14.50 V
                    Temperature: 20.0°C
                    (no units): 0.0
                    Fault Status: 00101101
                    Reset counter: 141
                    Mileage: 208976 km
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0001
                    Voltage: 12.00 V
                    Temperature: 22.0°C
                    (no units): 0.0
                    Fault Status: 11100100
                    Reset counter: 75
                    Mileage: 208976 km
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0001
                    Voltage: 12.00 V
                    Temperature: 22.0°C
                    (no units): 0.0
End----------(Elapsed Time: 03:07, VBatt start/end: 14.4V/14.4V)-----------
AurimasFr
Lithuania
C?ID=360401
I found. Its 0004401
