Need coding for blank ABS module (MK60EC1)
mak
C?ID=219607
I bought a 2010 Jetta and I believe the ABS module has been replaced as the coding for it is zeroed out. Can anyone provide the correct coding. Full scan below:
Thursday,12,September,2019,18:50:35:53825
VCDS Version: 18.9.0.2 (x64)
VIN: 3VWPL7AJ8AM620421   License Plate: HAR2
Mileage: 149400km-92832mi   Repair Order:
Chassis Type: AJ-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 65 72 77
VIN: 3VWPL7AJ8AM620421   Mileage: 149400km-92832miles
   Part No SW: 03L 906 019 CM    HW: 03L 906 022 TS
   Component: R4 2,0L EDC G000AG  9971
   Revision: 12H02---    Serial number:
   Coding: 0050078
   Shop #: WSC 05242 444 05201
   VCID: 78D106830B010A8AED-802C
009315 - Diesel Particle Filter
               P2463 - 000 - Excessive Soot Accumulation - MIL ON
                    Fault Status: 11100000
                    Mileage: 149402 km
                    Date: 2014.02.02
                    Time: 06:56:15
                    RPM: 828 /min
                    Mileage: 120 km
                        44.7
                        12.9
                    Pressure: 0 mbar
                    milliliters: 99 ml
Readiness: 1 1 0 0 1
   Part No SW: 02E 300 052     HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1920
   Revision: 04844002    Serial number: 00000908040650
   Shop #: WSC 00066 000 00000
   VCID: 51879B27C83B7BC20A-8004
   Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 000000000000000000000000000000000000
   VCID: 00216E6393D1424AD5-8054
                    Fault Status: 01100101
                    Reset counter: 163
                    Mileage: 149402 km
                    Date: 2014.02.02
                    Time: 06:28:48
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 279
                    Count: 49664
                    Reset counter: 163
                    Mileage: 149402 km
                    Date: 2014.02.02
                    Time: 06:28:48
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 270
                    Count: 49664
            000 -  -
                    Reset counter: 163
                    Mileage: 149402 km
                    Date: 2014.02.02
                    Time: 06:29:03
                    Count: 7
                    Count: 14
                    Count: 12800
                    Count: 195
                    Count: 49664
                    Reset counter: 163
                    Mileage: 149402 km
                    Date: 2014.02.02
                    Time: 06:28:48
                    Count: 3
                    Count: 14
                    Count: 12800
                    Count: 291
                    Count: 49664
   Part No SW: 3C8 907 336 N    HW: 3C8 907 336 N
   Component: Climatic      H13 0203
   Revision: 00006001
   Coding: 0000000000
   Shop #: WSC 00066 000 00187
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 3851C6838381CA8A2D-806C
Address 09: Cent. Elect.
   Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
   Component: AirbagVW10G   019 0706
   Serial number: 003C4D0796DO
   Coding: 00003044
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3957C387B88BD382D2-806C
   Subsystem 1 - Part No SW: 1KM 959 339     HW: 1KM 959 339
   Component: BF-Gewichtss.  007 0001
   Serial number: ---0000R--0004JQJP00
   Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3572MSME77375449ZZZ$
   Subsystem 3 - Part No SW: 1KM 955 557     HW: 1KM 955 557
   Serial number: 3582MSME40385149ZZZS
   Serial number: 3511HSME7628271DZZZR
   Serial number: 3521HSME495B231DZZZU
   Serial number: 35527SME09656D2BZZZS
   Serial number: 35627SME4E6D6E2BZZZ4
          B1006 1B [137] - Resistance Too High
                    Mileage: 149377 km
                    Date: 2019.09.10
                    Time: 01:36:20
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1B [137] - Resistance Too High
                    Mileage: 149377 km
                    Date: 2019.09.10
                    Time: 01:36:20
9442075 - Driver's Belt Force Limiter Igniter
          B1013 1B [137] - Resistance Too High
                    Mileage: 149377 km
                    Date: 2019.09.10
                    Time: 01:36:20
   Part No SW: 1K0 953 549 CD    HW: 1K0 953 549 CD
   Coding: 0001532
   VCID: 76CD08BB01157CFAFF-8022
   Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS   H05 0010
   Coding: 00000130
   Part No SW: 5K0 920 970 L    HW: 5K0 920 970 L
   Component: KOMBI         H08 0021
   Revision: V0008011    Serial number:
   Coding: 270F00
   Shop #: WSC 00066 000 00146
   ASAM Dataset: EV_KombiUDSMM9RM10 A04010
   ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
   VCID: 3753C5BF8E9FC5F224-8062
   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
   Component: J533  Gateway   H07 0081
   Revision:   H07 01    Serial number: 130809F2000078
   Coding: ED807F07001602002002
   VCID: 66ED58FB51B58C7A4F-8032
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223T5XVB04
   Coding: 0000002
   VCID: 7EDD109B292534BAA7-802A
   Component: IMMO          H08 0021
   ASAM Dataset: EV_ImmoUDSMM9RM10 A01010
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1519
   Revision: 72009005    Serial number: 00000626298908
   Coding: 0001205
   VCID: 6FC33DDF7E4F4D323C-803A
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 70     2901
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 2F43FDDFBECF0D327C-807A
                    Fault Status: 11100101
                    Mileage: 149377 km
                    Date: 2014.01.31
                    Time: 01:36:34
                    Battery Volts: 11.8 V
                        DD
                    Temperature: 9.0°C
                    Count: 3
                    Steering Angle: 0.00°
                        SteerAng n.Init
Address 46: Central Conv.
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1519
   Revision: 72009005    Serial number: 09062204244003
   Coding: 0001204
   VCID: 70C13EA3637152CA25-8024
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H15 0045
   Revision: -----27S    Serial number: VWZ4Z7L3146249
   Coding: 0500040004
   Shop #: WSC 57394 001 1048576
   VCID: 61E74BE7789BEB42BA-8034
            000 -  -
                    Reset counter: 163
                    Mileage: 149402 km
                    Date: 2014.02.02
                    Time: 07:01:43
   Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T
   Component: J388   TUER-SG HL   1401
   Revision: 12006001    Serial number: 00000004284430
   Coding: 0001168
Address 65: Tire Pressure (J502)       Labels:. 1K0-937-08x-65.clb
   Part No SW: 5K0 937 085 C    HW: 5K0 937 085 C
   Component: RDK           008 0817
   Coding: 018705
   VCID: 334BF1AF92E729D218-8066
   Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T
   Component: J389   TUER-SG HR   1401
   Revision: 12006001    Serial number: 00000004244874
   Coding: 0001168
   VCID: 77D305BF061F05F2E4-8022
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 035 730 C    HW: 1K8 035 730 C
   Component: Telefon       H08 6600
   Revision: 00008000    Serial number: 20389520184935
   Coding: 412100
   VCID: 297713C7402B6302A2-807C
End-------------------------(Elapsed Time: 01:55)--------------------------
Viking
C?ID=151455
Your VCDS is outdated, I'd suggest updating to the latest version would be a good starting point.
See here.
mak
C?ID=219607
See here.
I've already done the VCDS update, after I did this scan.
I was hoping to not have to re-do the scan, I would think that wouldn't be necessary to generate the coding... correct?
Viking
C?ID=151455
It's pretty much a stock request, if someone turns up with an old version the first thing asked is to update it. Those who do generally get their questions answered, while those who (for whatever reason) are unable to update their equipment are generally destined for a dark place.
Please Get Verified. It looks like you are in Category 2) of that post.
mak
C?ID=219607
Form submitted. Please let me know if I need to redo the scan with the 19.6.1 software or if the above is sufficient. Thanks All.
Verified. Moving this to Car Repair Support. I do not think a new scan is needed.
mak
C?ID=219607
Is anyone able to figure out the coding on my module? Or point me towards a way to find it?
Let me rattle some cages...
mak
C?ID=219607
Success! Thanks Jef.
No idea how you guys come up with that string.
Coded and all basic settings done. Now on to a Regen while driving...
