1J - VW Golf ABS CODING
mo_ferwana
Palestine Gaza
C?ID=11756
Hi
ABS has been burned for 1J - VW Golf . tried to read old coding , but No communications, have replaced other one but used one with the same number , have got :
01044 - Control Module Incorrectly Coded any help how to recode this unit please ?
thanks
Monday,16,September,2019,16:09:17:25282
VCDS Version: 19.6.1.0 (x64)
Dealer/Shop Name: Gaza Automotive Solutions WorkShop
Workshop Code: 012 14726 287716
VIN:    License Plate: ABS
Mileage: 145830km-90614mi   Repair Order:
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
          76
   Mileage: 145830km-90614miles
Address 01: Engine        Labels: 06A-906-019-AEH.lbl
   Part No: 06A 906 019 BC
   Component: 1.6l 2V/R4 SIMOS AT2523
   Coding: 04030
   Shop #: WSC 00046
   VCID: 65CBD5D6FF0304670A-4ACE
8 Faults Found:
00557 - Pressure Switch; Power Steering (F88)
            29-00 - Short to Ground
            79-00 - Please Check Fault Codes
00520 - Air Mass / Air Flow Sensor (G70)/(G19)
            31-10 - Open or Short to Ground - Intermittent
00523 - Intake Air Temp Sensor (G42)
            30-00 - Open or Short to Plus
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-10 -  - Intermittent
            36-10 - Open Circuit - Intermittent
Readiness: N/A
Address 02: Auto Trans        Labels: 01M-927-733.lbl
   Part No: 01M 927 733 EQ
   Component: AG4 Getriebe 01M    3960
   Coding: 00000
   VCID: 030FEB4E1177DA5784-0956
7 Faults Found:
00518 - Throttle Position Sensor (G69)
            16-10 - Signal Outside Specifications - Intermittent
00281 - Vehicle Speed Sensor (G68)
            03-00 - No Signal
00529 - Engine Speed Signal Missing
            35-10 - - - Intermittent
00545 - Engine-Transmission Electrical Connection
01312 - Powertrain Data Bus
Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
   Part No: 1J0 907 379 G
   Component: ABS     20 IE CAN  0001
   Coding: 03504
   Shop #: WSC 00046
   VCID: 356B45960F23B4E77A-4AB4
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
            35-00 - -
            35-00 - -
Address 15: Airbags        Labels: 1J0-909-60x-VW3.lbl
   Part No: 1J0 909 609
   Component:  A AIRBAG VW3 SG   0002
   Coding: 00065
   Shop #: WSC 00046
   VCID: 6CDDA0F21CE9352F55-4AE6
01284 - Side Airbag; Drivers Side; Disabled
            35-00 - -
Address 17: Instruments        Labels: 1J0-919-xxx-17.lbl
   Part No: 1J0 919 881 C
   Component: KOMBI+WEGFAHRS. MM0 V14
   Coding: 00142
   Shop #: WSC 00222
   VCID: 32617E8AFE4DA3DF5F-5102
   Subsystem 1 - Part No: Ident
   Component: Nr. WEGFAHRS.:VWZ6Z0W0541746
   Ident.-Nr. WEGFAHRS.:VWZ6Z0W0541746
01039 - Coolant Temperature Sensor (G2)
            64-10 - Not Currently Testable - Intermittent
01128 - Immobilizer Pickup Coil (D2)
01176 - Key
   Part No: 1J0 959 799 N
   Component: 4E Zentral-SG Komf. 0002
   Coding: 04097
   Shop #: WSC 00046
   VCID: 4993396673DBC0070E-4ACE
   Subsystem 1 - Part No: 1J1959801C
   Component: 4E Tõrsteuerger. FS0001r
   Subsystem 2 - Part No: 1J1959802D
   Component: 4E Tõrsteuerger. BF0001B
   Subsystem 3 - Part No: 1J4959811C
   Component: 4E Tõrsteuerger. HL0001r
   Subsystem 4 - Part No: 1J4959812C
   Component: 4E Tõrsteuerger. HR0001r
7 Faults Found:
01179 - Incorrect Key Programming
            35-00 - -
01030 - Central Locking Key Switch; Driver Side; Lock
            35-00 - -
00912 - Window Regulator Switch; Front Left (E40)
            35-00 - -
            27-00 - Implausible Signal
End-------------------------(Elapsed Time: 05:27)--------------------------
Are you sure you have installed the correct ABS for this car?
Please post the car's VIN.
Please clear all the spurious fault codes.
mo_ferwana
Palestine Gaza
C?ID=11756
Hi
here is the VIN :
WVWZZZ1JXB078165
and here are an autoscan after delete all dtc and also the DTC for ABS after delete all dtc then start engine without drive
AUTOSCAN AFTER DELETE ALL DTC :
Wednesday,18,September,2019,13:34:08:25282
VCDS Version: 17.1.3.0
VIN:    License Plate: GOLF 2001
Mileage: 121350km-75403mi   Repair Order:
          76
   Mileage: 121350km-75403miles
   Coding: 04000
   Shop #: WSC 01317
   VCID: 65CBD5D6FF0304697A-4ACE
7 Faults Found:
            P1570 - 35-00 -
01177 - Engine Control Unit
            37-10 - Faulty - Intermittent
            49-00 - No Communications
00282 - Throttle Position Actuator (V60)
            17-00 - Control Difference
Readiness: N/A
   Coding: 00000
   VCID: 030FEB4E1177DA59F4-0956
00811 - System Not Ready for Interrogation (Ross-Tech; Check Fault Codes Later)
            35-00 -  -
   Coding: 03504
   VCID: 356B45960F23B4E90A-4ACE
   Coding: 00065
   Shop #: WSC 00046
   VCID: 6CDDA0F21CE9352125-4AE6
            35-00 -  -
   Part No: 1J0 919 861 E
   Component: KOMBI+WEGFAHRS. MM0 V02
   Coding: 00142
   Shop #: WSC 07300
   VCID: 32617E8AFE4DA3D12F-5102
   Component: Nr. WEGFAHRS.:VWZ6Z0W0437044
   Ident.-Nr. WEGFAHRS.:VWZ6Z0W0437044
   Coding: 04097
   Shop #: WSC 00046
   VCID: 4993396673DBC0097E-4AB4
End-------------------------(Elapsed Time: 05:28)--------------------------
ABS READ AFTER START ENGINE :
Wednesday,18,September,2019,13:35:58:25282
VIN:    License Plate: ABSS
Control Module Part Number: 1J0 907 379 G
  Component and/or Version: ABS     20 IE CAN  0001
           Software Coding: 03504
            Work Shop Code: WSC 00000
                      VCID: 356B45960F23B4E90A-4AB4
            35-00 -  -
Address 03: DTCs cleared
only have just replaceD ABS , ABS FRONT RIGHT AND LEFT ARE IN VERY GOOD CONDITIONS AND HAVE NO ISSUES
ANY IDEA ?
THANKS
