HID Reps installed in 2015 GTI
3WheelingGTI
C?ID=378780
I've recently installed ed's replica GTI MK7.5 headlights with the Morimoto HID kit and keep getting bulb out errors, on either the left or right side. I'l restart the car, and sometime the lights will fire correctly.
"I saw some threads about modifying the leuchte6 and leuchte7 lasttyp codes. It says to set leuchte 6 and leuchte7 lasttyp to: "3 - xenon abblendlicht" That it should help mitigate low volt issues that might trigger beam out code. You can also do the same to the DRL settings (Leuchte 5 and leuchte4) and change them to LED (can't remember number off top of head)."
Just not sure how to make those changes with VCDS.
Thanks for any assistance.
Friday,13,September,2019,18:53:22:01934
VIN: 3VWTT7AU7FM062206   License Plate:
Mileage: 37764km-23465mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75 A9
VIN: 3VWTT7AU7FM062206   Mileage: 37764km-23465miles
Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0006
   Revision: --H13---
   Coding: 091D00124424002F1000
   Shop #: WSC 00066 790 00218
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001008
   ROD: EV_ECM20TFS0205G0906259A.rod
   VCID: 2C010412268B4F87461-8078
17178 - Databus
   Part No SW: 0D9 300 041 T    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4511
   Revision: 03253104    Serial number: TFK01411020763
   ROD: EV_TCMDQ250021.rod
   VCID: 290FFD0629795AAFBD7-807C
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Revision: 00000000    Serial number: 53244000002482
   Coding: 01FA6BA13426096E0079020081C92980D62C9000408194B400430050C009
   Shop #: WSC 01383 790 50316
   VCID: 47CB5BBE9F2D8CDF4B3-8012
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 134
                    Mileage: 30717 km
                    Date: 2018.04.13
                    Time: 00:13:29
   Revision: 00021000    Serial number: 0349842661
   Coding: 030C0C
   VCID: 3A2D324ADCDFE137C4D-806E
   Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 00020004200100000000000000000000
   VCID: 46D556BA982795D7B05-8012
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
   Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
   Revision: --------    Serial number: 86580812142208
   Coding: 001118464001826969644000001407201800000000000000000000000000
   Shop #: WSC 00066 790 00020
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4ACD628A8C3F71B754D-801E
   Component: WWS    141129  043 0581
   Serial number:         150106200549
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S2Y14M10D17H02M54S44
   Coding: 00A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H02 0003
   Serial number: 0000FST0000CMYW00000
   Coding: 181801
6666 - Bulb for Low Beam Headlamp Left
          B1217 15 [008] - Open or Short to Plus
                    Reset counter: 161
                    Mileage: 37589 km
                    Date: 2019.08.18
                    Time: 20:47:48
6922 - Bulb for Low Beam Headlamp Right
          B1218 15 [008] - Open or Short to Plus
                    Reset counter: 133
                    Mileage: 37574 km
                    Date: 2019.08.18
                    Time: 19:32:39
17674 - Bulb for Front Left Side Marker Lamp
          B12BA 15 [009] - Open or Short to Plus
                    Reset counter: 83
                    Mileage: 37574 km
                    Date: 2019.08.18
                    Time: 00:00:44
17930 - Bulb for Front Right Side Marker Lamp
          B12BB 15 [009] - Open or Short to Plus
                    Reset counter: 83
                    Mileage: 37574 km
                    Date: 2019.08.18
                    Time: 00:00:44
                    Reset counter: 165
                    Mileage: 35483 km
                    Date: 2018.12.20
                    Time: 19:31:15
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM01FWC
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 51FF75E66169426F157-8004
   Occupant Detection:
   Serial number: IBH0000J1400021SZW0$
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 002 410 14
   Serial number: 35700000000C3980511B
   Subsystem 3 - Part No SW: -----------    HW: 480 002 410 14
   Serial number: 358000000000D894711G
   Subsystem 4 - Part No SW: -----------    HW: 480 402 210 14
   Serial number: 3510002A718166A2512R
   Subsystem 5 - Part No SW: -----------    HW: 480 402 210 14
   Serial number: 3520002B11811BA3538W
   Subsystem 6 - Part No SW: -----------    HW: 480 402 010 14
   Serial number: 3550002B518166B220E$
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 010 14
   Serial number: 3560002B518166B5138$
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20141103500260
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 04518CB2EE9B67C7EE1-8050
   Part No SW: 5G1 920 856     HW: 5G1 920 856
   Component: KOMBI         342 4270
   Coding: 0BAD011A2180CF0502086A001000000000000000
   VCID: 6B83C70EE30588BF0FB-803E
9456681 - Key
          B104C 29 [008] - Implausible Signal
                    Mileage: 32840 km
                    Date: 2018.05.30
                    Time: 12:50:13
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 19111410000065
   Coding: 0101000820085900EF0000281C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07027
   ROD: EV_GatewConti_011.rod
   VCID: 71BFD566C129626F357-8024
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0101
   Serial number: 27140002606790094435
   Coding: 29FFFF
   Revision: 00000000    Serial number: 14000318567005
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311C72FEBB17471E1-8060
   Serial number: 261114060509RK
   Coding: 003E13200000040100000000
   VCID: 40D940A2BA03BBE78A9-8014
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5061
   Coding: 8102
   VCID: 372B2B7EEFCDFC5F3B3-8062
   Serial number: 281114060500GP
   VCID: 3FDB435EC7FDC41FF33-806A
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     014 0645
   Serial number: V7B02211142778
   Coding: 027300000000000021220002001800001F0203340100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 6491AC320EDBC7C74E1-8030
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9PS500XHE
          B11CF 53 [009] - Deactivated
                    Reset counter: 62
                    Mileage: 34370 km
                    Date: 2018.09.12
                    Time: 18:40:05
                    Voltage terminal 30: 12.1 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   Component: OCULowMQBUS   007 0564
   Coding: 02730002C28238017F1E06000000
   Shop #: WSC 00066 790 00123
   ROD: EV_OCULowMQB.rod
   VCID: 43D34FAEAB15A0FF97B-8016
7170 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Bordcomputer-Setup (0x0F) - BapErr_RetryNotSuccessful]
                    Reset counter: 144
                    Mileage: 37444 km
                    Date: 2019.07.29
                    Time: 08:02:55
   Component: SAS-GEN 2     H06 0014
   Serial number: 140924200478
End----------(Elapsed Time: 01:28, VBatt start/end: 13.4V/13.3V)-----------
m87a
Bosnia and Herzegovina
C?ID=156900
Left Low Beam:
(1)-Leuchte6ABL LC5-Lasttyp 6 --> 3 - Xenon Abblendlicht If your bcm doiesn't support xenon set it to LED Abblendlicht it will work...
(5)-Leuchte6ABL LC5-Lichtfunktion B 6 --> Lichthupe generell
(6)-Leuchte6ABL LC5-Dimmwert AB 6 --> 127
Right low beam:
(1)-Leuchte7ABL RB1-Lasttyp 7 --> LED Abblendlicht
(5)-Leuchte7ABL RB1-Lichtfunktion B 7 --> Lichthupe generell
(6)-Leuchte7ABL RB1-Dimmwert AB 7 --> 127
