Issues with ACC, Pre sense after removing tow bar hitch
paul
C?ID=80508
After wasting a lot of time to try and resolve this I am now at a loss!
I had retrofitted this and as the car is being sold back to Audi they preferred it to be removed as they cant really warrant it despite it being genuine parts as it was not factory.
So I carefully removed all wiring and thought I had captured all coding but I must be missing something, sadly I don't have the reference scan from when car was sourced prior to install as old PC long since died.
Cant use lane assist, pre-sense keeps advising of a fault and stop start will not work.
Scan:
Sunday,15,September,2019,19:28:13:38198
VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4513.4
VIN: WAUZZZF40JA124225   License Plate:
Chassis Type: F4-AU49 (8W7)
Scan: 01 02 03 08 09 13 15 16 17 19 29 2B 39 42 44 46 52 5F 6C 6D
          81 82 8B A5 AC BB BC D6 D7
VIN: WAUZZZF40JA124225   Mileage: 15546km-9659miles
Address 01: Engine (J623-CRTC)       Labels: Redir Fail!
   Part No SW: 8W0 907 401 E    HW: 059 907 309 F
   Component: 3.0TDI MD1    H24 0004
   Revision: C7H24---
   Coding: 122A40320576050324080000000000000000000000000000
   ASAM Dataset: EV_ECM30TDI0118W0907401E 001004
   ROD: EV_ECM30TDI0118W0907401E.rod
   VCID: 392F2EF8E9D0C1AFCD7-806C
Address 02: Auto Trans (J217)       Labels:* Redir Fail!
   Part No SW: 8W0 927 158     HW: 0D5 927 156 H
   Component: 0D5  30TDIRdW H05 1010
   Revision: --H05---
   Coding: 100000
   ASAM Dataset: EV_TCMALX52011 002010
   ROD: EV_TCMALX52011.rod
   VCID: 7F5B00E0B7742F9FB33-802A
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PRE-V1.clb
   Part No SW: 8W0 907 379 M    HW: 8W0 907 379 D
   Component: ESP9 Premium  H13 0767
   Coding: 14AA309930A40A9A11A04893008252A2E4A5D2280C0C508812004A4527A54B
   Shop #: WSC 06324 790 00001
   ROD: EV_ESP9BOSCHCMP_002.rod
   VCID: 4FFB702047547F1F033-801A
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
   Component: Klima Zone 3  H60 0210
   Coding: 2618002D5544450D02000100880000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 44D14F0C9E128C47AE1-8010
   Subsystem 1 - Part No SW: 4M2 820 021 B    HW: 4M2 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000002043849
   Serial number: 1AB1190900PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Coding: 07501343E17900CD054D57195FAE80F9110B3104000000000000000020001A810A45012B025605
   VCID: 025D8914C4864277DCD-8056
   Subsystem 1 - Part No SW: 8W2 955 119     HW: 8V2 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 171122  043 0813
   Serial number: 89425300401732600688
   Coding: 5BC7F7
   Serial number: 21025295X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AH    HW: 4M0 941 531 AH
   Component: E1 - LDS  H06 0008
   Serial number: 22 08 2017  01102510
   Serial number: GX1CE115111723611409
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 8W0 947 135 BQ    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B00641630
   Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2617000195697005
66649 - Local Data Bus 3
          U10C8 00 [009] - No Communications
                    Reset counter: 170
                    Mileage: 15546 km
                    Date: 2019.09.15
                    Time: 19:20:04
                    average_Voltage_terminals: 12.90 V
                    Outside air temperature sensor-Outside air temperature on CAN: 19.50 °C
                    interior_temperature: 23.00 °C
                    Vehicle speed: 0.00 km/h
                    Terminal control-Terminal 75 status: On
                    Terminal control-Terminal 15 status signal: On
                    Terminal control-Terminal 15 via CAN: On
                    Terminal control-Term 75: qualification: OFF
   Part No SW: 8W0 907 561 C    HW: 8W0 907 561
   Component: LRR4          H10 0340
   Coding: 3473FFE258FFEC0A959A81A0
   ASAM Dataset: EV_ACCBOSCHAU49X 003022
   ROD: EV_ACCBOSCHAU49X.rod
   VCID: 3E253DE4F0FEE697F85-806A
2153 - Databus
          [FAULT_HC_STA_FAIL]
                    Fault Frequency: 9
                    Reset counter: 170
                    Mileage: 15541 km
                    Date: 2019.09.15
                    Time: 19:07:48
                    Control Module temperature: 37 °C
                    Voltage terminal 15: 12.7 V
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 170
                    Mileage: 15541 km
                    Date: 2019.09.15
                    Time: 19:07:48
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 F    HW: 8W0 959 655 F
   Component: Airbag10.44   H03 0107
   Serial number: 003UP00BT9G.
   Coding: AACCF0C00C800000985400F3D0CC00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006016
   ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
   VCID: 4CC1672CB6424407661-8018
   Subsystem 1 - Part No SW: -----------    HW: 442 062 811 17
   Serial number: 3577Y00C126D2BC2D304
   Subsystem 2 - Part No SW: -----------    HW: 442 062 911 17
   Serial number: 3587Y00C926068A152A%
   Subsystem 3 - Part No SW: -----------    HW: 442 0B1 511 17
   Serial number: 3517700B127DA976339I
   Subsystem 4 - Part No SW: -----------    HW: 442 0B0 712 17
   Serial number: 3527700B728B79E4613L
   Subsystem 5 - Part No SW: -----------    HW: 442 0C2 507 17
   Serial number: 3557500AF275CB2631BO
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 442 0C2 507 17
   Serial number: 3567500AF275CB2520CN
   Pedestrian Protection Center:
   Subsystem 7 - Part No SW: -----------    HW: 442 0C2 507 17
   Serial number: 23075009F2772296E27D
   Subsystem 8 - Part No SW: -----------    HW: 442 430 212 17
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M00B92532143E0B7
   Subsystem 9 - Part No SW: -----------    HW: 442 430 212 17
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M00B9253214341D1
   Part No SW: 4M0 907 129 ME    HW: 4M0 907 129 ME
   ROD: EV_SMLSKLOAU736_006.rod
   Part No SW: 8W5 920 790 D    HW: 8W5 920 790 D
   Component: FBenRDW       H18 0373
   Coding: 258669D06C82060001A3E9601000400000000000
   VCID: 43D34C109B1C8B7F97B-8016
   Part No SW: 8W7 907 468 F    HW: 8W7 907 468 E
   Component: Gateway       H42 0123
   Revision: 7C000001    Serial number: 0187C027718109
   Coding: 03010001000086407F07000000590012D8180007100000000175078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 003111
   VCID: 4EC56D24405E7617085-801A
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20180108184828 21851
   Serial number: 5191156004
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0024
   VCID: 78A9EBFC925A18A7F29-802C
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 17000379963004
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 323D19D434A632F70CD-8066
   Part No SW: 8W0 959 593 H    HW: 8W0 959 593 F
   Component: TSG FS        005 0129
   Serial number: 0000295268633
   Coding: 005D9A215001000000001082
   Shop #: WSC 06325 790 00001
   Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0410
   Coding: 0D008380008080
   ASAM Dataset: EV_EPSZFAU49X 003023
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 42DD4914840682779CD-8016
   Part No SW: 8W0 907 064 EC    HW: 8W0 907 064 DC
   Component: BCM2 MLBevo   025 0387
   Coding: 013500006FB100406309A0000E00080233024010804706502F0400000504803F001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 014014
   ROD: EV_BCM2HellaAU736_014_AU49.rod
   VCID: 015F8618C180596FC57-8054
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY173384HQP
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000099906688
   Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
   Component: GEB.F.Heckoef  H16 0905
   Serial number: >1194400
   Part No SW: 8W0 959 592 H    HW: 8W0 959 592 F
   Component: TSG BFS       005 0129
   Serial number: 0000278938534
   Coding: 005D9A215C01000000001080
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W5 035 035 B    HW: 8W5 035 035
   Component: MU-P-LND-EU   034 1177
   Serial number: A829A0JB050759
   Coding: 019402010000000053111102000A00332F0002E701700100BE
   VCID: 363525C4D8CE2ED7205-8062
   Subsystem 1 - Part No SW: V03 959 802 DD    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Subsystem 2 - Part No SW: 8W8 919 605     HW: 8W8 919 605
   Component: DU High AU49x  H32 0170
   Serial number: TPO00106091700820864
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Component: ControlUnit_H  H30 0206
   Serial number: APVAK129111700020827
   Compact Disc Database:
   Component: Gracenote2  --- 1016
3086 - Antenna for Telephone Mount
          B1564 01 [009] - Electrical Failure
                    Reset counter: 170
                    Mileage: 15533 km
                    Date: 2019.09.15
                    Time: 12:00:56
                    Voltage terminal 30: 11.6 V
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): not selected
                    Status of telephone-Handset holder (cradle): not connected
   Component: RVC Compact   H12 0250
   Coding: 0294020102002001400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   VCID: 33331CD0CBBC3BFF07B-8066
   Part No SW: 4M0 959 107 B    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0163
   Revision: --------    Serial number: 31709534400000
   Coding: 0570
   ASAM Dataset: EV_DeckLidCONTIAU736 001015
   Part No SW: 8W2 713 041 F    HW: 4M2 713 041 F
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 17121145195270
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 372B28C0DFC4D7DF3B3-8062
Address 82: Heads Up Display (J898)       Labels:* None
   Part No SW: 8W5 919 617 C    HW: 8W5 919 617 C
   Component: HeadUpDisplay H18 1640
   Coding: 4F01C0
   ASAM Dataset: EV_HudNSEIKAU736 001017
   ROD: EV_HudNSEIKAU736.rod
   VCID: 48C95B3CA23AA827429-801C
Address 8B: Adaptive Cruise 2 (J850)       Labels: None
   Part No SW: 8W0 907 541 C    HW: 8W0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU49X 003022
   ROD: EV_ACC2BOSCHAU49X.rod
   VCID: 3C2137ECE6E2F487D61-8068
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W0 907 217 C    HW: 8W0 907 217 C
   Component: BVS           H17 0050
   Coding: 0404090200000403024023A5A50000FCB0F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
1122565 - Databus
          [TIMEOUT_Anhaenger_01]
                    Fault Frequency: 8
                    Reset counter: 170
                    Mileage: 15541 km
                    Date: 2019.09.15
                    Time: 19:08:52
                    Control Module temperature: 29 °C
                    Voltage terminal 15: 12.80 V
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355 D    HW: 4M0 907 355 B
   Component: SCR-Stg-G3H04 0006
   ASAM Dataset: EV_RDCMINERGAU736 005012
   ROD: EV_RDCMINERGAU736_AU49.rod
   Part No SW: 8W0 959 595 H    HW: 8W0 959 595 F
   Component: TSG HFS       005 0129
   Serial number: 0000297723583
   Coding: 000D98200001000000001080
   VCID: 51FF7658516069EF157-8004
   Component: TSG HBFS      005 0129
   Serial number: 0000297723312
   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 1675C544B80ECED7005-8042
   Component: LED1R         H09 0003
End----------(Elapsed Time: 01:57, VBatt start/end: 13.0V/13.0V)-----------
NEtech
Denmark
C?ID=56995
Here you have your AutoScan, without trailer coding.
Coding without trailer:
[01] > 122A40320566050324080000000000000000000000000000
[09] > 07501143E17900CD054D51195BAE80F9110B3108000000000000000020001A810A45012B025605
[17] > 258469D06C80060001A3E9601000400000000000
[46] > 013500002FB100406309A0000E00080233024010804706502F0400000504803F001F0001000000
[A5] > 0404090200000403024023A4A50000FCB0F0C020C020
paul
C?ID=80508
Absolute legend, will be engine coding for starters! Sometimes the answer is right under our noses. Will scan through and adjust as required.
