A6 C7/4G Lights humidity sensor ?
gabrjel
Luxembourg
C?ID=306473
Hi
For some time I see that my driving lights are on during normal sunny day.
Also on autoroute where there is limit during rain - sign recognition shows my a limit for a rain.
Navi don't go dark (night/tunnel)
Lights on speedometer are on.
I suspect humidity sensor - or something similar.
No errors are shown in any module.
What was done recently in a car ?
Update of MMI from 928 to 1425.
I scan is necessary I will provide one.
Could you tell me in which module (09, 46?) I can see actual humidity used for detection of rain ?
---------AUTOSCAN---------
Sunday,15,September,2019,20:18:36:45479
[URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL]
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 13 15 16 17 19 28 34 36 3B 3C 42 44 46 52
          53 55 5F 62 69 6C 6D 72 85 8B 8E 8F 90 A9 AC C0
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Component: BCM1 2.0      H20 0311
   Revision: 15020001    Serial number: -
   Coding: 0105001440349FE2C90140C380001800CF9C6708AE08022100000894E10117020040003D030000
   Shop #: WSC 21239 003 1048576
   VCID: 71BCDC6DD1A200FF357-8024
   Component: WWS57X 141122  H37 0080
   Coding: 0045F7
   Coding: 0B006D
   Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
   Component: E1 - LDS  H07 0044
   Serial number: 14 12 2014  00000285
   Subsystem 4 - Part No SW: 4G0 907 410     HW: 4H0 907 410
   Component: EHL2 V07.03  H30 0030
   Part No SW: 4G9 920 950 T    HW: 4G9 920 950 T
   Component: TDieRdwAccNv  H07 0043
   Revision: 03001036    Serial number: -
   Coding: 138622081F550008000600
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 41DC4CADA102D07F857-8014
   Part No SW: 4G8 907 468     HW: 4G8 907 468
   Revision: --------    Serial number: -
   Coding: C0CD078118
   Shop #: WSC 02391 785 00200
   VCID: 75B4E87DA54A2CDFE9F-8020
   Serial number: 4745765203
   Voltage stabilizer:
   Serial number: 1410070000000000026C
   Part No SW: 4H0 907 064 FP    HW: 4H0 907 064 EP
   Component: BCM2 2.0      H36 0560
   Revision: 00002001    Serial number: -
   Coding: 01000E3820B97095C32009042E010F470000000000000000000000000000
   VCID: 7CA2FD5986E07D97961-8028
   Component: GTO BF  H01 0081
   Serial number: -
   Subsystem 2 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J245 PS20.008  H02 0007
   Serial number:    -
   Coding: 901F00
   Subsystem 3 - Part No SW: 4G9 959 591     HW: 8V3 959 591
   Component: J394 PS20.008  H02 0007
   Serial number:     -
   Coding: 801F00
   Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0081
   Coding: 04FA02202A170200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
   VCID: 33301665EBBE72EF07B-8066
   Coding: E01F00
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Left:
   Subsystem 3 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo li.  H03 0031
   Coding: E01F00
   Matrix Headlamp Powermodule 1 Right:
   Subsystem 4 - Part No SW: 4H0 941 329 A    HW: 4H0 941 329 A  Labels: 3D0-941-329.CLB
   Component: MxB LeiMo re.  H03 0031
   Coding: E01F00
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 043 M    HW: 4G1 035 043 D
   Component: MU-H-N-EU     051 ????
   Serial number: -
   Coding: 01754201FF0A000033110001000E04232F000AE5F1700100BF
   VCID: 280AF10922780137A29-807C
   Subsystem 1 - Part No SW: V03 959 802 DF    HW: -----------
   Component: ECE 2019/2020  --- 0177
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Component: DU8 C7 SV  H63 0007
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 4G1 919 610 F    HW: 4G1 919 610 F
   Compact Disc Database:
   Component: Gracenote2  --- 1012
   Component: DPC-SG        H27 0081
   Coding: FA160000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 2C020D1936802D17461-8078
   Part No SW: 4H0 907 107 H    HW: 4H0 907 107
   Component: BV-SG         H33 0092
   Serial number: -
   Coding: 04C0BB1C1111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
gabrjel
Luxembourg
C?ID=306473
I removed not relevant modules.
