2015 Passat tdi Coolant Temp Fault
C?ID=292050
2015 Passat with MIL on checked Group 1 Fault Codes found this:
4238 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 00 [175] - Signal too High
Checked advanced measuring codes for coolant sensors found this:
IDE00025   Coolant temperature 59 °C
  IDE00194   Coolant temperature at radiator output: specified value 90.0 °C
  IDE01266-ENG57549   Coolant shut-off valve-Bits 0-7 3
  IDE07724   Coolant temperature at engine outlet: calculated 59.7 °C
  IDE07725   Coolant temp.sens.1 bank 1 at cylinder head: raw value 59.5 °C
  IDE07726   Coolant temp.sens.1 bank 1 at cylinder head: uncnd. voltage 1906.0 mV
  IDE07727   Coolant temp. sensor 1 bank 1 at cylinder head: raw value -40.0 °C
  IDE07728   Coolant temp. sensor 1 bank 1 at cylinder head: uncnd. voltage 4999.8 mV
Replaced coolant temp. sensor at radiator outlet and it appears that fixed the issue. So far.
I am was confused by the similar labeling of the IDE measuring codes. Is this correct?
It appears by the actual temperature/voltage readings that IDE07727 and IDE07728 are for the sensor at the radiator outlet.
Complete Autoscan:
Chassis Type: A3-VW41 (7N0)
          75 77
VIN: 1VWBV7A32FC095600   Mileage: 187170km-116302miles
Address 01: Engine (J623-CVCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 016 D    HW: 04L 907 309 K
   Component: R4 2.0l TDI   H20 9466
   Revision: 8AH20---
   Coding: 011D0012032410080000
   Shop #: WSC 03340 444 00000
   ASAM Dataset: EV_ECM20TDI01104L997016D 004002
   ROD: EV_ECM20TDI01104L997016D.rod
   VCID: 346694E39F0DD1EF4D-8060
                    Mileage: 186517 km
                    Date: 2019.08.29
                    Time: 12:03:52
                    Engine speed: 1006.00 /min
                    Normed load value: 16.1 %
                    Coolant temperature: 51 °C
                    Intake air temperature: 48 °C
                    Voltage terminal 30: 12.280 V
                    Accelerator pedal travel: raw value: 0.00 %
                    Coolant temp. sensor 1 bank 1 at cylinder head: raw value: -40.0 °C
                    Heat delivery temperature in cooling system: -273.1 °C
                    Extern.temp.sens.1 bank 1: raw value: 26.0 °C
                    Fuel consumption: 0.63 l/h
                    Fuel temp. sensor 1 bank 1: raw value: 48.0 °C
                    Engine oil temperature: 47.7 °C
25147 - Control Circuit for Reductant Pump 1
          P208B 00 [096] - Implausible Signal
Readiness: 1 1 0 0 0
   Part No SW: 02E 300 061 T    HW: 02E 927 770 AL
   Component: GSG DSG AG6     531 4518
   Revision: 05653104    Serial number: 00001501250253
   Shop #: WSC 09003 957 00200
   VCID: 254079A7ECD7B867CA-8070
28907 - No Communications with Cruise Control (Front) Distance Sensor
            U0235 - 000 -  - Intermittent
                    Fault Frequency: 103
                    Reset counter: 37
                    Mileage: 168898 km
                    Date: 2019.04.16
                    Time: 12:18:08
   Part No SW: 1K0 907 379 BS    HW: 1K0 907 379 BS
   Component: ESP MK60EC1   H46 0166
   Revision: 00H46001
   Coding: C54BC0F5492B00FFA31103E492190042A1100012
   VCID: 04060423872DA16FBD-8050
02214 - Tire Pressure Warning
                    Reset counter: 149
                    Mileage: 177406 km
                    Date: 2019.06.06
                    Time: 08:49:31
                    Count: 32768
                    Count: 4608
                    Count: 16401
                    Count: 51325
                    Count: 65277
   Part No SW: 561 907 426 J    HW: 561 907 426 J
   Component: AC Manuell    H02 0404
   Revision: 00001K01
   Coding: 0010001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 224A62BB35F94F5FAF-8076
   Part No SW: 5K0 937 085 AB    HW: 5K0 937 085 AB
   Component: BCM PQ35 B+   122 0174
   Revision: BH122001
   Coding: EF200E1B802B2AD4098800010600044800F1A08640801520648060000C70
   Shop #: WSC 05512 002 1048576
   VCID: 73E457FFD28396D794-8026
   Part No SW: 5C0 959 655 AB    HW: 5C0 959 655 AB
   Component: AirbagVW10    500 0975
   Serial number: 003LZD06G7W4
   Coding: 00004D53
   Shop #: WSC 34130 003 1048576
   ASAM Dataset: EV_AirbaVW10SMEVW360 001030
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 72EA52FBA5999FDF9F-8026
   Serial number: 6940000Y150001BX2L0+
   Coding: 303044
   Serial number: 3572MSME68326A4EZZZ3
   Serial number: 3582MSME38035C4EZZZ0
   Serial number: 3516KSME03506635ZZZH
   Serial number: 3526KSME2D056635ZZZU
   Serial number: 3556LSME5F1E6634ZZZ5
   Serial number: 3566LSME7D0A6634ZZZ1
   Part No SW: 1K5 953 521 BM    HW: 5K0 953 569 AE
   Component: LENKS.MODUL   016 0162
   Revision: FF010042    Serial number: 20150304101167
   Coding: 088A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79F865D7F8EFEC87DE-802C
   Component: E221__MFL-8LP  H07 0023
   Serial number: 00000000000001044861
   Coding: E20000
   Part No SW: 561 920 970 G    HW: 561 920 970 G
   Component: KOMBI         H05 0813
   Coding: 231E01
   VCID: 1E32564B01816BBF8B-804A
   Part No SW: 7N0 907 530 AR    HW: 7N0 907 530 AM
   Component: J533  Gateway H55 1653
   Revision:   H55       Serial number: 30031503000942
   Coding: 461000
   VCID: 000E08339335BD4F99-8054
Address 1C: Position Sensing
   Component: IMMO          H05 0813
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADA4A9B8D49571F27-803E
Address 2E: Media Player 3
   Revision: 13110009    Serial number: 0009492876
   Coding: 0404B5
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 5BB41F5F52133E97AC-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14202630150417191230
   Coding: 800000
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 215    3501
   Revision: 00H22000
   VCID: 3978A5D7706F2C879E-806C
   Component: EZE_2         H55 1653
   Coding: 01030108
   VCID: 6FEC5B8FBEABB23770-803A
   Subsystem 1 - Part No SW: 561 959 591 A    HW: 561 959 591 A
   Component: J245 P05 9BA3  H08 0005
   Serial number: 53388786011433300690
   Coding: 181100
   Component: Analoguhr  009 0005
   Revision: 15110009    Serial number: 0009434365
   Coding: 0404B4
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 5CB61C43571D39AFA5-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14102631150417110200
   Coding: 800000
   Part No SW: 1K0 035 188 F    HW: 1K0 035 188 F
   Component: Radio Prem-8  H08 0009
   Revision: -----13S    Serial number: VWZ4Z7R3697294
   Coding: 0100044004000B
   VCID: 2B548F9F4A338E171C-807E
                    Reset counter: 169
                    Mileage: 167927 km
                    Date: 2019.04.10
                    Time: 16:03:45
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0156
   Serial number: 000003554140536
   Coding: 02140102C21632007F1606C00000
   ASAM Dataset: EV_OCULow 002009
   ROD: EV_OCULow_002.rod
   VCID: 14263463FF4D31EF2D-8040
   Part No SW: 5N0 035 729 E    HW: 5N0 035 729 E
   Component: TELEFON       H07 0593
   Revision: 1B001001    Serial number: 00007670129560
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: 326A92FB6519DFDF5F-8066
Thank you!
Wouldn't be the first time we've seen bugs that produce misleading results in a VW ECU. How long have you had TDIs? Remember how they used to number glow plugs improperly?
C?ID=292050
Thank you for your reply!
I have owned a tdi since 2004 - a 2001 jetta (which I still drive daily). I recently bought a 2013 Passat tdi and my daughter bought a 2015 Passat tdi. Also have a '97 Geo Tracker that I have a '98 Beetle tdi engine for, but that's been a long term project.
