2018 Audi A5 1.4tfsi virtual speedometer retrofitting
Flashdash
Sheffield, UK
C?ID=222374
Hi
This is my first post I've installed a used virtual cluster in a 2018 Audi A5 1.4 Tfsi automatic the speedometer was from a 2018 audi RS5. Everything seems to be working as it should but for some reason i cannot change the wheel circumference coding. it says request out of range. also the cluster displays gearbox malfunction. i atatch full vcds scan of the car. any help appreciated
Saturday,14,September,2019,11:58:40:06187
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZF5XJA087435 License Plate: YY18CXV
Mileage: 14048km-8729mi Repair Order:
Chassis Type: F5-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 19 29 2B 39 42 44 46 52 5F 6D 81 A5
BB BC D6 D7
VIN: WAUZZZF5XJA087435 Mileage: 14048km-8729miles
Address 01: Engine (J623-CVNA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 022 B HW: 04E 907 309 R
Component: R4 1.4l TFS H22 4032
Revision: 44H22000
Coding: 022500324324150834080000000000000000000000000000
Shop #: WSC 06314 790 00001
ASAM Dataset: EV_ECM14TFS01104E906022B 002002
ROD: EV_ECM14TFS01104E906022B.rod
VCID: 1E65224DC0365747D85-804A
23734 - Implausible Data Received from Instrument Panel Control Module
U0423 00 [038] - -
[Invalid Data Received FromInstrument Panel Cluster Control Module]
Mileage: 14048 km
Date: 2019.09.14
Time: 11:53:55
Engine speed: 0.00 /min
Coolant temperature: 80 °C
Intake air temperature: 24 °C
Voltage terminal 30: 12.380 V
Outside air temperature: 19 °C
Absolute intake pressure: 103 kPa abs
Engine torque: 0.0 Nm
Fuel level: 327.67 l
Oxygen sensor bank 1 sensor 1: specified value: 1.0000
Intake camshaft bank1 active operating mode-Bits 0-7: 0
Overrun cut-off-Bits 0-7: 0
4715 - No Communication with Instrument Cluster
U0155 00 [038] - -
[Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
Mileage: 14048 km
Date: 2019.09.14
Time: 11:53:05
Coolant temperature: 81 °C
Voltage terminal 30: 12.460 V
Fuel level: 34.00 l
Readiness: 0110 0001
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 8W2 927 155 AD HW: 0CJ 927 156
Component: 0CK 14TFSIRdW H05 0002
Revision: --H05--- Serial number: 0000002232
Shop #: WSC 05761 780 00200
ASAM Dataset: EV_TCMDL382021 002027
ROD: EV_TCMDL382021_AU49.rod
VCID: 035373394B949AAFD7B-8056
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041180040000142
20995 - Control Module in Instrument Cluster
U100E 00 [167] - Wheel Circumference Implausible
[Control module for instrument panel insert Wheel circumference implausible]
Mileage: 14047 km
Date: 2019.09.14
Time: 10:56:37
Engine speed: 0 /min
Driving position: P
Transmission fluid temperature: 21 °C
Voltage terminal 30: 11.7 V
Engine torque: -20 Nm
selected gear: 1
Ctrl. mod.: operating condition: regular operation
Auxiliary pump for transmission: requesting function: Preloading
Auxiliary hydraulic pump for transmission oil: current: 0 A
Oil pressure reservoir: pressure: 17.3 bar
Pressure of clutch 1: actual value: 0.0 bar
Pressure of clutch 2: actual value: 0.0 bar
Clutch status: Neutral
Occurrence_counter_over_length_of_life: 8
ESP_Wheel_circumference: 2068
Safety_interface_expected_wheel_circumference: 2012
21021 - No Communication with Instrument Cluster
U0155 00 [038] - -
Mileage: 14048 km
Date: 2019.09.14
Time: 11:53:05
Driving position: P
Transmission fluid temperature: 31 °C
Voltage terminal 30: 12.5 V
Engine torque: -12 Nm
selected gear: 1
Oil pressure reservoir: pressure: 18.2 bar
Occurrence_counter_over_length_of_life: 5
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PLU-V1.clb
Part No SW: 8W0 907 379 K HW: 8W0 907 379 J
Component: ESP9 Plus H10 0766
Coding: 04AA049A10AA0A9D11A2489400825292F4A5D2202008508812 004A492FA54B
Shop #: WSC 06334 790 00001
ROD: EV_ESP9BOSCHCMP_002.rod
VCID: 4DC79501DD509CDF71F-8018
496896 - Databus
U1121 00 [046] - Missing Message
[ComScl:_PDU_Kombi_01-_Timeout_error]
Mileage: 14048 km
Date: 2019.09.14
Time: 11:53:05
7D 00 80 00 C2 00 00 00 00 00
Unlearning counter according OBD-OBD unlearning counter: 28
Address 08: Auto HVAC (E87) Labels:* Redir Fail!
Part No SW: 8W0 820 043 T HW: 8W0 820 043 T
Component: Klima Zone 3 H60 0210
Coding: 140800095544040D0200010088000000000000000000000000 0000000000
Shop #: WSC 06335 790 00001
ROD: EV_AirCondiBHTCAU491.rod
VCID: 44D1B0250E1A5D97AE1-8010
Subsystem 1 - Part No SW: 4M2 820 021 B HW: 4M2 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000002134524
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: 4461501900PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 HW: 8W0 919 158
Component: E265 Kli Fond H40 0080
459013 - Databus
Reset counter: 45
Mileage: 14047 km
Date: 2019.09.14
Time: 10:49:38
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07501143E11800CD050551181BAC80F9110B31080000000000 00000020001A810A450122025601
VCID: 025D763D548E93A7DCD-8056
Subsystem 1 - Part No SW: 8W6 955 119 A HW: 8W6 955 119 A
Component: 494 RL 120118 036 0471
Serial number: 00000001801100300026
Coding: 5FC7F7
Serial number: 21160496X81A955555A0
Coding: 02005D
Subsystem 3 - Part No SW: 4M0 941 531 AG HW: 4M0 941 531 AG
Component: E1 - LDS H06 0008
Serial number: 15 01 2018 01262886
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE116121723811295
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 8W0 947 135 BQ HW: 8W0 947 135
Component: J528-Dachele H14 0130
Serial number: B00688754
Subsystem 6 - Part No SW: 8W0 925 301 BC HW: 8W0 925 301 BC
Component: SL-B9/Q5NF H17 0010
Serial number: 2817000305327004
Address 15: Airbags (J234) Labels:| 8W0-959-655.clb
Part No SW: 8W0 959 655 F HW: 8W0 959 655 F
Component: Airbag10.44 H03 0107
Serial number: 003UP00D26SL
Coding: AACCF0C00C800000585400F3D0CC00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 006016
ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
VCID: 4CC19805264A95D7661-8018
Subsystem 1 - Part No SW: ----------- HW: 442 061 002 18
Serial number: 3577Y00A52711E41E15Z
Subsystem 2 - Part No SW: ----------- HW: 442 061 002 18
Serial number: 3587Y00A32711E41E31W
Subsystem 3 - Part No SW: ----------- HW: 442 0B2 901 18
Serial number: 3517700A12943BE1E208
Subsystem 4 - Part No SW: ----------- HW: 442 0B2 901 18
Serial number: 3527700A12943BE222B9
Subsystem 5 - Part No SW: ----------- HW: 442 0C3 001 18
Component: FrontSensor_D 1C5 014A
Serial number: 35575009B29736A5C2AP
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 442 0C3 001 18
Component: FrontSensor_P 1C5 014A
Serial number: 35675009B29736A540CI
Pedestrian Protection Center:
Subsystem 7 - Part No SW: ----------- HW: 442 0C2 401 18
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500A7291FA138030
Subsystem 8 - Part No SW: ----------- HW: 442 432 201 18
Component: PedPSensor_D2 256 0887
Serial number: I0M9M00B726ADCD3603S
Subsystem 9 - Part No SW: ----------- HW: 442 432 201 18
Component: PedPSensor_P2 256 0887
Serial number: I0N9M009F26ADCD4E424
1051904 - Databus
[NWD: 0x30B Kombi_01Timeout]
Reset counter: 45
Mileage: 14047 km
Date: 2019.09.14
Time: 10:49:38
Part No SW: 4M0 907 129 HA HW: 4M0 907 129 HA
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 76B51AED0846BF07E05-8022
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 790 D HW: 8W5 920 790 D
Component: FBenRDW H18 0371
Coding: 25A440DE288006000120E9601000000000000000
VCID: 43D3B3390B145AAF97B-8016
U1014 00 [008] - -
[ECU incorrectly coded]
Reset counter: 45
Mileage: 14048 km
Date: 2019.09.14
Time: 11:51:56
13636609 - Control module
U110E 00 [008] - implausible coding
[ECU incorrectly coded (number of fuel level sender BCM2/Kombi implausible)]
Reset counter: 45
Mileage: 14048 km
Date: 2019.09.14
Time: 11:53:54
16776982 - Databus
[SWA_01 communication error can_error_timeout]
Reset counter: 45
Mileage: 14048 km
Date: 2019.09.14
Time: 11:53:56
16776985 - Databus
[QSP_03 communication error can_error_timeout]
Reset counter: 45
Mileage: 14048 km
Date: 2019.09.14
Time: 11:53:55
16777007 - Databus
[Fahrwerk_Anzeige_01 communication error can_error_timeout]
Reset counter: 45
Mileage: 14048 km
Date: 2019.09.14
Time: 11:53:55
Part No SW: 8W5 907 468 F HW: 8W5 907 468 E
Component: Gateway H43 0123
Revision: 7A000002 Serial number: 0287A777918221
Coding: 03010001000086402607000000590012C81800071000000001 75078E10000000
ASAM Dataset: EV_CGateCONTIAU491 003111
Subsystem 1 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0004
Serial number: 20180214131246 21599
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 0353566804
8913154 - Databus
[Signal_Error_Tank_Level_High_Resolution]
Reset counter: 45
Mileage: 14047 km
Date: 2019.09.14
Time: 10:49:05
8531970 - Quiescent Current
U1406 00 [008] - Too High
[Electric_current_Upper_Limit_Value_Exceeded]
Reset counter: 44
Mileage: 14047 km
Date: 2019.09.13
Time: 23:16:36
Total static current-current total quiescent current: 135 mA
Total static current-Total time quiescent current exceeded: 1.0 H
EM_vehicle_state: 00 00
Address 29: Left Light (J1018) Labels: 4M0-907-397.clb
Part No SW: 4M0 907 397 AB HW: 4M0 907 397 B
Component: LCM_MLBevoH05 0024
VCID: 77AB17E90F4CC60FFB3-8022
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 18000056471017
Coding: 8800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 323DE6FDA4AEE3270CD-8066
Address 39: Right Light (J1023) Labels: 4M0-907-397.clb
Part No SW: 8W0 959 593 H HW: 8W0 959 593 F
Component: TSG FS 005 0129
Serial number: 0000304943975
Coding: 001DCA624001000000001482
VCID: 4FFB8F09D75CAECF033-801A
Reset counter: 3
Mileage: 14047 km
Date: 2019.09.13
Time: 18:38:41
Part No SW: 8W0 909 144 H HW: 8W0 909 144 B
Component: EPS_MLBEVO_ZF H08 0410
Coding: 09000380008000
ASAM Dataset: EV_EPSZFAU49X 003023
ROD: EV_EPSZFAU49X_003.rod
VCID: 42DDB63D140E53A79CD-8016
Part No SW: 8W0 907 064 EB HW: 8W0 907 064 DB
Component: BCM2 MLBevo 025 0387
Coding: 013500002FB100406301A0000600080231020010804306502F 04000000040030001F0001000000
Shop #: WSC 00200 935 01530
ASAM Dataset: EV_BCM2HellaAU736 014014
ROD: EV_BCM2HellaAU736_014_AU49.rod
VCID: 00597C355A8281B7CA9-8054
Subsystem 1 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY1735539WN
Subsystem 2 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000099797282
65896 - Databus
[Climatronic control module: Klima_03: no signal/communication]
Reset counter: 44
Mileage: 14047 km
Date: 2019.09.13
Time: 21:09:49
Supply voltages-Supply voltage: Terminal 30: 12.120 V
Supply voltages-Supply voltage Terminal 30 - 2: 12.187 V
Supply voltages-Supply voltage Terminal 30 - 3: 12.093 V
general_additional_freeze_frame-terminal_control_intern_status: 40 04 0A 10 04 80
Part No SW: 8W0 959 592 H HW: 8W0 959 592 F
Component: TSG BFS 005 0129
Serial number: 0000304611841
Coding: 001DCA224001000000001480
VCID: 4EC5920DD056A7C7085-801A
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGS2.clb
Part No SW: 8W0 035 192 H HW: 8W0 035 192 A
Component: MU-HS-LND-EU 050 0213
Coding: 01940301FF0A000053111101000A00102F000DE601F00100CE
ROD: EV_MUHigScl6C3DELP.rod
VCID: 3B23CBD973E4226FDFB-806E
Subsystem 1 - Part No SW: 8W0 919 866 AB HW: -----------
Component: ECE 2018 --- 0032
Subsystem 2 - Part No SW: 8W8 919 604 HW: 8W8 919 604
Component: DU Std AU49x H32 0170
Serial number: TPO00107111700720292
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8W0 919 614 N HW: 8W0 919 614 N
Component: ControlUnit_B H22 0134
Serial number: APVAK110021800020257
11 Faults Found:
0513 - Rear Right Treble Speaker
B1068 13 [009] - Open Circuit
[Hochtonlautsprecher Kanal 1: Unterbrechung (AC-Diagnose)]
Reset counter: 4
Mileage: 14047 km
Date: 2019.09.13
Time: 20:13:20
Voltage terminal 30: 12.0 V
0528 - Rear Left Treble Speaker
B1066 13 [009] - Open Circuit
[Hochtonlautsprecher Kanal 4: Unterbrechung (AC-Diagnose)]
Reset counter: 4
Mileage: 14047 km
Date: 2019.09.13
Time: 20:13:20
0532 - Subwoofer
B106C 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 5: Unterbrechung (DC-Diagnose)]
Reset counter: 4
Mileage: 14047 km
Date: 2019.09.13
Time: 20:13:15
0005 - Antenna Amplifier 1 for Radio
B126D 13 [009] - Open Circuit
Reset counter: 4
Mileage: 14047 km
Date: 2019.09.13
Time: 20:13:09
Status of antenna 1 for radio-Antenna current: 0 mA
Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
0006 - Antenna Amplifier 2 for Radio
B126E 13 [009] - Open Circuit
Reset counter: 4
Mileage: 14047 km
Date: 2019.09.13
Time: 20:13:08
Status of antenna 2 for radio-Antenna current: 0 mA
Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 2 for radio-Reception level antenna 2: 12 dBµV
3073 - Cellular Antenna
B1053 13 [009] - Open Circuit
[GSM/UMTS aerial - open circuit]
Reset counter: 4
Mileage: 14047 km
Date: 2019.09.13
Time: 20:13:08
3084 - GSM antenna 2
B1533 13 [009] - Open Circuit
Reset counter: 4
Mileage: 14047 km
Date: 2019.09.13
Time: 20:13:09
6666 - Optical data bus
U1049 00 [008] - Open circuit
Reset counter: 44
Mileage: 14047 km
Date: 2019.09.13
Time: 20:14:15
Temperature of MOST transceiver-max.value: -50 °C
Temperature of MOST transceiver-min.value: -4 °C
Temperature of MOST transceiver-Current: 48 °C
6698 - Optical data bus
[Optical data bus: open circuit: wakeup]
Reset counter: 44
Mileage: 14047 km
Date: 2019.09.13
Time: 20:14:30
6667 - Optical Data Bus for Information Electronics 1
U10CA 00 [009] - Intermittent Disruption
[Optical data bus: sporadic open circuit in central processor]
Reset counter: 5
Mileage: 14047 km
Date: 2019.09.14
Time: 10:49:52
Voltage terminal 30: 11.8 V
Temperature of MOST transceiver-Current: 33 °C
6672 - Optical Data Bus for Display in Instruments
U10CF 00 [008] - Intermittent Disruption
[Optical data bus: sporadic open circuit in instrument cluster display]
Reset counter: 44
Mileage: 14047 km
Date: 2019.09.13
Time: 20:16:32
Temperature of MOST transceiver-Current: 49 °C
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0163
Revision: -------- Serial number: 31792481200000
Coding: 0610
ASAM Dataset: EV_DeckLidCONTIAU736 001015
VCID: 48C9A415323279F7429-801C
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 8W2 713 041 G HW: 8W2 713 041 J
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 18013045792093
ROD: EV_GSMWaehlZFAU736.rod
VCID: 3829D4D542D20977329-806C
Address A5: Frt Sens. Drv. Assist
Part No SW: 8W0 959 595 H HW: 8W0 959 595 F
Component: TSG HFS 005 0129
Serial number: 0000303432968
Coding: 000DC8220001000000001080
VCID: 51FF8971C168B83F157-8004
Address BC: Door Rear Pass
Address D6: Light Ctrl Left 2
Address D7: Light Ctrl Right 2
End----(Elapsed Time: 01:31, VBatt start/end: 12.4V/12.3V. VIgn 0.3V)------
South Molton, UK
Starting 2 threads on the same topic isn't a great idea as it splits replies - the Benevolent Dictator will be along soon to merge them I reckon...
