2018 Audi A5 virtual cluster install
Flashdash
Sheffield, UK
C?ID=222374
Iver installed a virtual cluster ina 2018 Audi A5 everything works as it should but for some reason i cannot change the wheel circumference coding. it says request out of range. also the cluster displays gearbox malfunction. i atatch full vcds scan of the car. any help appreciated
Saturday,14,September,2019,11:58:40:06187
VIN: WAUZZZF5XJA087435   License Plate: YY18CXV
Mileage: 14048km-8729mi   Repair Order:
Chassis Type: F5-AU49 (8W5)
Scan: 01 02 03 08 09 15 16 17 19 29 2B 39 42 44 46 52 5F 6D 81 A5
          BB BC D6 D7
VIN: WAUZZZF5XJA087435   Mileage: 14048km-8729miles
Address 01: Engine (J623-CVNA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 022 B    HW: 04E 907 309 R
   Component: R4 1.4l TFS   H22 4032
   Revision: 44H22000
   Coding: 022500324324150834080000000000000000000000000000
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM14TFS01104E906022B 002002
   ROD: EV_ECM14TFS01104E906022B.rod
   VCID: 1E65224DC0365747D85-804A
23734 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [038] - -
          [Invalid Data Received FromInstrument Panel Cluster Control Module]
                    Mileage: 14048 km
                    Date: 2019.09.14
                    Time: 11:53:55
                    Engine speed: 0.00 /min
                    Coolant temperature: 80 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 12.380 V
                    Outside air temperature: 19 °C
                    Absolute intake pressure: 103 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel level: 327.67 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Intake camshaft bank1 active operating mode-Bits 0-7: 0
                    Overrun cut-off-Bits 0-7: 0
4715 - No Communication with Instrument Cluster
          U0155 00 [038] - -
          [Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
                    Mileage: 14048 km
                    Date: 2019.09.14
                    Time: 11:53:05
                    Coolant temperature: 81 °C
                    Voltage terminal 30: 12.460 V
                    Fuel level: 34.00 l
Readiness: 0110 0001
   Part No SW: 8W2 927 155 AD    HW: 0CJ 927 156
   Component: 0CK 14TFSIRdW H05 0002
   Revision: --H05---    Serial number: 0000002232
   Shop #: WSC 05761 780 00200
   ASAM Dataset: EV_TCMDL382021 002027
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 035373394B949AAFD7B-8056
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041180040000142
20995 - Control Module in Instrument Cluster
          U100E 00 [167] - Wheel Circumference Implausible
          [Control module for instrument panel insert Wheel circumference implausible]
                    Mileage: 14047 km
                    Date: 2019.09.14
                    Time: 10:56:37
                    Engine speed: 0 /min
                    Driving position: P
                    Transmission fluid temperature: 21 °C
                    Voltage terminal 30: 11.7 V
                    Engine torque: -20 Nm
                    selected gear: 1
                    Ctrl. mod.: operating condition: regular operation
                    Auxiliary pump for transmission: requesting function: Preloading
                    Auxiliary hydraulic pump for transmission oil: current: 0 A
                    Oil pressure reservoir: pressure: 17.3 bar
                    Pressure of clutch 1: actual value: 0.0 bar
                    Pressure of clutch 2: actual value: 0.0 bar
                    Clutch status: Neutral
                    Occurrence_counter_over_length_of_life: 8
                    ESP_Wheel_circumference: 2068
                    Safety_interface_expected_wheel_circumference: 2012
21021 - No Communication with Instrument Cluster
          U0155 00 [038] - -
                    Mileage: 14048 km
                    Date: 2019.09.14
                    Time: 11:53:05
                    Driving position: P
                    Transmission fluid temperature: 31 °C
                    Voltage terminal 30: 12.5 V
                    Engine torque: -12 Nm
                    selected gear: 1
                    Oil pressure reservoir: pressure: 18.2 bar
                    Occurrence_counter_over_length_of_life: 5
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
   Part No SW: 8W0 907 379 K    HW: 8W0 907 379 J
   Component: ESP9 Plus     H10 0766
   Coding: 04AA049A10AA0A9D11A2489400825292F4A5D2202008508812004A492FA54B
   Shop #: WSC 06334 790 00001
   ROD: EV_ESP9BOSCHCMP_002.rod
   VCID: 4DC79501DD509CDF71F-8018
496896 - Databus
          U1121 00 [046] - Missing Message
          [ComScl:_PDU_Kombi_01-_Timeout_error]
                    Mileage: 14048 km
                    Date: 2019.09.14
                    Time: 11:53:05
                    7D 00 80 00 C2 00 00 00 00 00
                    Unlearning counter according OBD-OBD unlearning counter: 28
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
   Component: Klima Zone 3  H60 0210
   Coding: 140800095544040D02000100880000000000000000000000000000000000
   Shop #: WSC 06335 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 44D1B0250E1A5D97AE1-8010
   Subsystem 1 - Part No SW: 4M2 820 021 B    HW: 4M2 820 021 B
   Component: J126 FLuftV  H09 0003
   Serial number: 00000000000002134524
   Serial number: 4461501900PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
459013 - Databus
                    Reset counter: 45
                    Mileage: 14047 km
                    Date: 2019.09.14
                    Time: 10:49:38
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Coding: 07501143E11800CD050551181BAC80F9110B3108000000000000000020001A810A450122025601
   VCID: 025D763D548E93A7DCD-8056
   Subsystem 1 - Part No SW: 8W6 955 119 A    HW: 8W6 955 119 A
   Component: 494 RL 120118  036 0471
   Serial number: 00000001801100300026
   Coding: 5FC7F7
   Serial number: 21160496X81A955555A0
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AG    HW: 4M0 941 531 AG
   Component: E1 - LDS  H06 0008
   Serial number: 15 01 2018  01262886
   Serial number: GX1CE116121723811295
   Coding: 210000
   Interior Light Module:
   Subsystem 5 - Part No SW: 8W0 947 135 BQ    HW: 8W0 947 135
   Component: J528-Dachele  H14 0130
   Serial number: B00688754
   Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2817000305327004
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 F    HW: 8W0 959 655 F
   Component: Airbag10.44   H03 0107
   Serial number: 003UP00D26SL
   Coding: AACCF0C00C800000585400F3D0CC00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006016
   ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
   VCID: 4CC19805264A95D7661-8018
   Subsystem 1 - Part No SW: -----------    HW: 442 061 002 18
   Serial number: 3577Y00A52711E41E15Z
   Subsystem 2 - Part No SW: -----------    HW: 442 061 002 18
   Serial number: 3587Y00A32711E41E31W
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 901 18
   Serial number: 3517700A12943BE1E208
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 901 18
   Serial number: 3527700A12943BE222B9
   Subsystem 5 - Part No SW: -----------    HW: 442 0C3 001 18
   Serial number: 35575009B29736A5C2AP
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 442 0C3 001 18
   Serial number: 35675009B29736A540CI
   Pedestrian Protection Center:
   Subsystem 7 - Part No SW: -----------    HW: 442 0C2 401 18
   Serial number: 2307500A7291FA138030
   Subsystem 8 - Part No SW: -----------    HW: 442 432 201 18
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M00B726ADCD3603S
   Subsystem 9 - Part No SW: -----------    HW: 442 432 201 18
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M009F26ADCD4E424
1051904 - Databus
          [NWD: 0x30B Kombi_01Timeout]
                    Reset counter: 45
                    Mileage: 14047 km
                    Date: 2019.09.14
                    Time: 10:49:38
   Part No SW: 4M0 907 129 HA    HW: 4M0 907 129 HA
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 76B51AED0846BF07E05-8022
   Part No SW: 8W5 920 790 D    HW: 8W5 920 790 D
   Component: FBenRDW       H18 0371
   Coding: 25A440DE288006000120E9601000000000000000
   VCID: 43D3B3390B145AAF97B-8016
          U1014 00 [008] - -
          [ECU incorrectly coded]
                    Reset counter: 45
                    Mileage: 14048 km
                    Date: 2019.09.14
                    Time: 11:51:56
13636609 - Control module
          U110E 00 [008] - implausible coding
          [ECU incorrectly coded (number of fuel level sender BCM2/Kombi implausible)]
                    Reset counter: 45
                    Mileage: 14048 km
                    Date: 2019.09.14
                    Time: 11:53:54
16776982 - Databus
          [SWA_01 communication error can_error_timeout]
                    Reset counter: 45
                    Mileage: 14048 km
                    Date: 2019.09.14
                    Time: 11:53:56
16776985 - Databus
          [QSP_03 communication error can_error_timeout]
                    Reset counter: 45
                    Mileage: 14048 km
                    Date: 2019.09.14
                    Time: 11:53:55
16777007 - Databus
          [Fahrwerk_Anzeige_01 communication error can_error_timeout]
                    Reset counter: 45
                    Mileage: 14048 km
                    Date: 2019.09.14
                    Time: 11:53:55
   Part No SW: 8W5 907 468 F    HW: 8W5 907 468 E
   Component: Gateway       H43 0123
   Revision: 7A000002    Serial number: 0287A777918221
   Coding: 03010001000086402607000000590012C8180007100000000175078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 003111
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Serial number: 20180214131246 21599
   Serial number: 0353566804
8913154 - Databus
          [Signal_Error_Tank_Level_High_Resolution]
                    Reset counter: 45
                    Mileage: 14047 km
                    Date: 2019.09.14
                    Time: 10:49:05
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Electric_current_Upper_Limit_Value_Exceeded]
                    Reset counter: 44
                    Mileage: 14047 km
                    Date: 2019.09.13
                    Time: 23:16:36
                    Total static current-current total quiescent current: 135 mA
                    Total static current-Total time quiescent current exceeded: 1.0 H
                    EM_vehicle_state: 00 00
   Part No SW: 4M0 907 397 AB    HW: 4M0 907 397 B
   Component: LCM_MLBevoH05 0024
   VCID: 77AB17E90F4CC60FFB3-8022
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 18000056471017
   Coding: 8800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 323DE6FDA4AEE3270CD-8066
   Part No SW: 8W0 959 593 H    HW: 8W0 959 593 F
   Component: TSG FS        005 0129
   Serial number: 0000304943975
   Coding: 001DCA624001000000001482
   VCID: 4FFB8F09D75CAECF033-801A
                    Reset counter: 3
                    Mileage: 14047 km
                    Date: 2019.09.13
                    Time: 18:38:41
   Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0410
   Coding: 09000380008000
   ASAM Dataset: EV_EPSZFAU49X 003023
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 42DDB63D140E53A79CD-8016
   Part No SW: 8W0 907 064 EB    HW: 8W0 907 064 DB
   Component: BCM2 MLBevo   025 0387
   Coding: 013500002FB100406301A0000600080231020010804306502F04000000040030001F0001000000
   Shop #: WSC 00200 935 01530
   ASAM Dataset: EV_BCM2HellaAU736 014014
   ROD: EV_BCM2HellaAU736_014_AU49.rod
   VCID: 00597C355A8281B7CA9-8054
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY1735539WN
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000099797282
65896 - Databus
          [Climatronic control module: Klima_03: no signal/communication]
                    Reset counter: 44
                    Mileage: 14047 km
                    Date: 2019.09.13
                    Time: 21:09:49
                    Supply voltages-Supply voltage: Terminal 30: 12.120 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.187 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.093 V
                    general_additional_freeze_frame-terminal_control_intern_status: 40 04 0A 10 04 80
   Part No SW: 8W0 959 592 H    HW: 8W0 959 592 F
   Component: TSG BFS       005 0129
   Serial number: 0000304611841
   Coding: 001DCA224001000000001480
   VCID: 4EC5920DD056A7C7085-801A
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGS2.clb
   Part No SW: 8W0 035 192 H    HW: 8W0 035 192 A
   Component: MU-HS-LND-EU  050 0213
   Coding: 01940301FF0A000053111101000A00102F000DE601F00100CE
   ROD: EV_MUHigScl6C3DELP.rod
   VCID: 3B23CBD973E4226FDFB-806E
   Subsystem 1 - Part No SW: 8W0 919 866 AB    HW: -----------
   Component: ECE 2018  --- 0032
   Subsystem 2 - Part No SW: 8W8 919 604     HW: 8W8 919 604
   Component: DU Std AU49x  H32 0170
   Serial number: TPO00107111700720292
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 N    HW: 8W0 919 614 N
   Component: ControlUnit_B  H22 0134
   Serial number: APVAK110021800020257
11 Faults Found:
0513 - Rear Right Treble Speaker
          B1068 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 1: Unterbrechung (AC-Diagnose)]
                    Reset counter: 4
                    Mileage: 14047 km
                    Date: 2019.09.13
                    Time: 20:13:20
                    Voltage terminal 30: 12.0 V
0528 - Rear Left Treble Speaker
          B1066 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 4: Unterbrechung (AC-Diagnose)]
                    Reset counter: 4
                    Mileage: 14047 km
                    Date: 2019.09.13
                    Time: 20:13:20
0532 - Subwoofer
          B106C 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 5: Unterbrechung (DC-Diagnose)]
                    Reset counter: 4
                    Mileage: 14047 km
                    Date: 2019.09.13
                    Time: 20:13:15
0005 - Antenna Amplifier 1 for Radio
          B126D 13 [009] - Open Circuit
                    Reset counter: 4
                    Mileage: 14047 km
                    Date: 2019.09.13
                    Time: 20:13:09
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
0006 - Antenna Amplifier 2 for Radio
          B126E 13 [009] - Open Circuit
                    Reset counter: 4
                    Mileage: 14047 km
                    Date: 2019.09.13
                    Time: 20:13:08
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 12 dBµV
3073 - Cellular Antenna
          B1053 13 [009] - Open Circuit
          [GSM/UMTS aerial - open circuit]
                    Reset counter: 4
                    Mileage: 14047 km
                    Date: 2019.09.13
                    Time: 20:13:08
3084 - GSM antenna 2
          B1533 13 [009] - Open Circuit
                    Reset counter: 4
                    Mileage: 14047 km
                    Date: 2019.09.13
                    Time: 20:13:09
6666 - Optical data bus
          U1049 00 [008] - Open circuit
                    Reset counter: 44
                    Mileage: 14047 km
                    Date: 2019.09.13
                    Time: 20:14:15
                    Temperature of MOST transceiver-max.value: -50 °C
                    Temperature of MOST transceiver-min.value: -4 °C
                    Temperature of MOST transceiver-Current: 48 °C
6698 - Optical data bus
          [Optical data bus: open circuit: wakeup]
                    Reset counter: 44
                    Mileage: 14047 km
                    Date: 2019.09.13
                    Time: 20:14:30
6667 - Optical Data Bus for Information Electronics 1
          U10CA 00 [009] - Intermittent Disruption
          [Optical data bus: sporadic open circuit in central processor]
                    Reset counter: 5
                    Mileage: 14047 km
                    Date: 2019.09.14
                    Time: 10:49:52
                    Voltage terminal 30: 11.8 V
                    Temperature of MOST transceiver-Current: 33 °C
6672 - Optical Data Bus for Display in Instruments
          U10CF 00 [008] - Intermittent Disruption
          [Optical data bus: sporadic open circuit in instrument cluster display]
                    Reset counter: 44
                    Mileage: 14047 km
                    Date: 2019.09.13
                    Time: 20:16:32
                    Temperature of MOST transceiver-Current: 49 °C
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0163
   Revision: --------    Serial number: 31792481200000
   Coding: 0610
   ASAM Dataset: EV_DeckLidCONTIAU736 001015
   VCID: 48C9A415323279F7429-801C
   Part No SW: 8W2 713 041 G    HW: 8W2 713 041 J
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 18013045792093
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 3829D4D542D20977329-806C
Address A5: Frt Sens. Drv. Assist
   Part No SW: 8W0 959 595 H    HW: 8W0 959 595 F
   Component: TSG HFS       005 0129
   Serial number: 0000303432968
   Coding: 000DC8220001000000001080
   VCID: 51FF8971C168B83F157-8004
Address BC: Door Rear Pass
Address D6: Light Ctrl Left 2
Address D7: Light Ctrl Right 2
End----(Elapsed Time: 01:31, VBatt start/end: 12.4V/12.3V. VIgn 0.3V)------
Flashdash
Sheffield, UK
C?ID=222374
The speedometer was out of a audi RS5
South Molton, UK
Starting 2 threads on the same topic isn't a great idea as it splits replies - the Benevolent Dictator will be along soon to merge them I reckon...
Edit - I saw 3 posts and (my bad) assumed 3 threads - sorry!
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Because of same post we have 3X, thread lock until further notice.
I only see two, but this is the right place for a retrofit, so I've closed the other one and re-opened this one.
Flashdash
Sheffield, UK
C?ID=222374
Sorry I'm new to this forum and after posting here read the section where it says newbie users post here. That's why I posted in two sections
Boki Ar
C?ID=57300
I temporarily closed the thread based on the email report.
Thank You Uwe, it's OK now, let's move on. :cool:
That would have been fine too. What we object to is opening two different threads with the same question(s). :)
