Admittedly, I'm a unique case, with a 2015 Mk7 GSW TDI, retrofitted with MIB2 unit from APG last year, then an Active Info Display / Virtual Cockpit earlier this year. Car came with factory "Front Assist", which is the flat bumper radar that only warns of near-imminent impact.
Car does NOT have the "lane assist" camera in the windshield.
Everything worked, but ever since getting the MIB2 unit installed, I've had a Component Protection error in 19-CAN GATEWAY. (But again, everything worked).
Taking inspiration from a few folks here, as well as mqb.pl explanation, i bought a round radar (5Q0 907 567 G). Did most of the coding ahead of time while the 13-AutoDistReg module was locked in component protection, according to the instructions laid out in the Xagico's Spanish-language .pdf.
After I took it to dealer (1.5 hours to get CP removed), everything seemed to work (ACC icons showed up properly, buttons did what they're ostensibly supposed to do; centre button of ACC controls moved the follow distance; +/- changed the ACC speed).
The problem: When I'm driving, and turn "on" ACC...nothing happens. Take foot off the pedal and...I just keep slowing down to a stop. SET and RES buttons change the icon view a bit, but don't SET the speed, nor "resume" (given that it never actually gets into a "set" speed).
Autoscan below; I've spent at least six hours myself so far trying to troubleshoot this; and have gotten a lot of info from darkchina811 (much thanks!) on some steps, but still....nothing.
Help (?). Any ideas, thoughts, suggestions, welcomed.
Friday,13,September,2019,13:22:43:51218
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 19.6.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: 3VWCA7AUXFM500299 License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 2B 42 44 52 55 5F
VIN: 3VWCA7AUXFM500299 Mileage: 72827km-45252miles
Address 01: Engine (J623-CRUA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 997 022 N HW: 04L 907 309
Component: R4 2.0l TDI X23 9459
Revision: 85X23---
Coding: 011D0012834410081000
Shop #: WSC 91489 999 12345
ASAM Dataset: EV_ECM20TDI01104L997022N 004002
ROD: EV_ECM20TDI01104L997022N.rod
VCID: 3B36FBF0B2ADB2978C-806F
Part No SW: 0D9 300 041 N HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4512
Revision: 03253104 Serial number: TFK01410290291
Shop #: WSC 00066 790 00221
ROD: EV_TCMDQ250021.rod
VCID: 230623902A1DEA57A4-8077
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 P HW: 3Q0 907 379 C
Component: ESC H32 0385
Revision: 00000000 Serial number: 53184000002387
Coding: 04FA6AA12420096C0079020981CC2520562490004081A4B214635050C002
Shop #: WSC 05065 002 104857
VCID: 47DE9700FE65E67718-8013
Revision: 00021000 Serial number: 0349846601
Coding: 030C0C
Shop #: WSC 01383 790 50316
VCID: 3A38FEF4BD978B9F97-806F
Part No SW: 5GM 907 044 A HW: 5GM 907 044 A
Component: Climatronic H03 1001
Revision: 00001K01
Coding: 02020124200100010005000000101400
VCID: 42C88614D547C35FCF-8017
Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
Air quality sensor:
Part No SW: 5Q0 937 087 R HW: 5Q0 937 087 R
Revision: -------- Serial number: 86580412141206
Coding: 00511B464041A2E949E44000091407001800000000000000000000000000
Shop #: WSC 00066 790 07031
ROD: EV_BCMBOSCH_014.rod
VCID: 4AD8AE34ED771B1F07-801F
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 140824 043 0581
Serial number: 141224033541
Component: RLHS 037 0059
Serial number: S5Y14M12D09H11M16S22
Coding: 06A8DD
Sun Roof:
Subsystem 3 - Part No SW: 5G0 959 591 HW: 7P0 959 591 C
Component: J245 PS22.018 H01 0008
Serial number: WOO33584535
Coding: 191800
Roof Blind:
Subsystem 4 - Part No SW: 5G0 959 591 HW: 7P0 959 591 C
Component: J394 PS22.018 H01 0008
Serial number: WOO33583141
Coding: 191800
U1400 00 [008] - -
Reset counter: 167
Mileage: 72826 km
Date: 2019.09.13
Time: 11:28:29
Reset counter: 167
Mileage: 72826 km
Date: 2019.09.12
Time: 22:09:46
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-567.clb
Part No SW: 5Q0 907 567 G HW: 5Q0 907 567 G
Component: ACC3 H08 0390
Serial number: 14021376110493
Coding: 00001000FE030B
Shop #: WSC 00028 028 00024
ASAM Dataset: EV_ACCBoschMQB 001021
ROD: EV_ACCBoschMQB_VW37.rod
VCID: 3FCE8FE0A6B5AEB7A0-806B
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 009 0825
Serial number: 003MHM01GHAM
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 51EAB958002128C746-8005
Occupant Detection:
Component: BF-Gewichtss. H10 0021
Serial number: IBH0000J14000233FP0W
Coding: 303136
Subsystem 2 - Part No SW: ----------- HW: 480 000 511 14
Serial number: 3570000000049398811F
Subsystem 3 - Part No SW: ----------- HW: 480 000 511 14
Serial number: 35800000000831388116
Subsystem 4 - Part No SW: ----------- HW: 480 402 210 14
Serial number: 3510002A91811BA1809.
Subsystem 5 - Part No SW: ----------- HW: 480 402 210 14
Serial number: 3520002B31811BA4D24
Subsystem 6 - Part No SW: ----------- HW: 480 401 810 14
Serial number: 35500029D175A8E2E2DR
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 401 810 14
Component: FrontSensor_P 001 6149
Serial number: 35600029D175A8E4236C
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20141031400890
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 0444400C8FD30D6FBD-8051
B1149 13 [008] - Open Circuit
Reset counter: 167
Mileage: 72826 km
Date: 2019.09.12
Time: 22:09:02
Ubat 30 Voltage: 11.10 V
Ignition State: On
Terminal 15: 10.30 V
A/D #1: 96.86 %
A/D #2: 50.20 %
A/D #3: 0.00 %
Part No SW: 5G1 920 791 A HW: 5G1 920 791 A
Component: KOMBI 409 3197
Coding: 03A551082D80880A02807B201C00000000000000
Shop #: WSC 58161 001 104857
VCID: 2A18CEB44D373B1FE7-807F
U1014 00 [009] - -
Reset counter: 127
Mileage: 72826 km
Date: 2019.09.13
Time: 11:30:01
16776996 - Databus
[FCW_01 keine Kommunikation]
Reset counter: 127
Mileage: 72826 km
Date: 2019.09.13
Time: 11:30:01
16777034 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_DoorLocking_0x0D keine Kommunikation]
Reset counter: 167
Mileage: 72826 km
Date: 2019.09.13
Time: 11:30:04
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 12111410001103
Coding: 0901000800087300FF00020A1C0F00000001050000000000000000000000
Shop #: WSC 00066 790 07026
ROD: EV_GatewConti_011.rod
VCID: 72A816D4A56733DF9F-8027
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H16 0040
Serial number: 29150001901890095392
Coding: 2DFFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0000431
U1101 00 [009] - Active
Reset counter: 127
Mileage: 72826 km
Date: 2019.09.12
Time: 22:03:18
Supply voltage: Terminal 30: 10.5 V
Terminal 15: On
Address 20: High Beam Assist. (J844) Labels:| 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511
Component: FLA H04 0002
Revision: AA001001
Coding: 02018864727264565625393E01
ASAM Dataset: EV_HighBeamAssisAU37X 001009
ROD: EV_HighBeamAssisAU37X.rod
VCID: 2B16CBB042CD22171C-807F
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 14000317831004
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3424D0CC9FF37DEF4D-8061
U1400 00 [008] - -
[Under voltage (temporary)]
Reset counter: 167
Mileage: 72826 km
Date: 2019.09.13
Time: 11:28:26
ELV State: 04
Information Clamps: 77 64
CoCo State: A0 01
WFS State: 17 0E
Vehicle speed: 0.00 km/h
Voltage: 3D
AD-Value H-bridge: 1B
Clamp15 flip flop: SSTx: button contacts: 06
CAN signals: 00
13637389 - Function Restriction due to Implausible Message(s)
U1112 00 [008] - -
[Invalid SMLS_P_verriegelt]
Reset counter: 166
Mileage: 72823 km
Date: 2019.09.12
Time: 20:26:03
ELV State: 04
Information Clamps: 77 60
CoCo State: A0 01
WFS State: 17 06
Voltage: 6B
AD-Value H-bridge: 34
CAN signals: 00
Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B
Component: TSG FS 020 0025
Serial number: 2611140605045J
Coding: 007F1320D000040000000000
VCID: 40CC8C1CDB4BD14FD9-8015
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000000332757
Coding: 011000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 126 1061
Coding: 0102
VCID: 43C68310CA5DCA57C4-8017
Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B
Component: TSG BFS 020 0025
Serial number: 021214060508AH
Coding: 007F1320DC00040000000000
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000000390612
Coding: 091000
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 060A00000B000400
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
5275926 - Power Output Module for Left Headlamp
C1081 16 [008] - Voltage Too Low
Reset counter: 167
Mileage: 72826 km
Date: 2019.09.12
Time: 22:05:37
5276182 - Power Output Module for Right Headlamp
C1082 16 [008] - Voltage Too Low
Reset counter: 167
Mileage: 72826 km
Date: 2019.09.12
Time: 22:05:45
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 047 B HW: 3G0 035 047
Component: MU-H-LND-EU 043 0703
Serial number: A578C0GB003368
Coding: 027302020000000001220002001B00102F0100F571700000DE
Shop #: WSC 00046 123 12345
VCID: 1F0E2F600675CEB780-804B
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZHT3233336
Subsystem 2 - Part No SW: V03 959 806 CD HW: -----------
Component: NAR 2018/2019 --- 0066
Compact Disc Database:
Component: Gracenote2--- --- 1011
9 Faults Found:
U1014 00 [009] - -
Reset counter: 61
Mileage: 66866 km
Date: 2019.04.01
Time: 20:54:43
Voltage terminal 30: 12.1 V
B201A 00 [009] - -
Reset counter: 121
Mileage: 66866 km
Date: 2019.04.01
Time: 20:54:48
Voltage terminal 30: 12.0 V
Status_Software_Version_Management-module_name: MDUV612/Main
B2000 87 [009] - Missing message
Reset counter: 61
Mileage: 66866 km
Date: 2019.04.01
Time: 20:54:59
Software module: status-SW_Status_Consistency: 00 40 00
Software module: status-SW_Status_Device:
13697024 - Component Protection
U1100 00 [009] - No Basic Setting
[Anti-theft protection - component protection: no basic setting or basic setting incorrect]
Reset counter: 61
Mileage: 66866 km
Date: 2019.04.01
Time: 20:54:43
15361024 - Component Protection
[Anti-theft protection - component protection active (0xEA6400)]
Reset counter: 61
Mileage: 66866 km
Date: 2019.04.01
Time: 20:54:43
7173 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[ACC (0x05) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 164
Mileage: 72807 km
Date: 2019.09.10
Time: 15:31:41
BAP-BAP_Function_ID: 02
7178 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 61
Mileage: 66866 km
Date: 2019.04.01
Time: 20:54:45
7219 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Emergency call module (0x33) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 61
Mileage: 66866 km
Date: 2019.04.01
Time: 20:54:45
7223 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[ENI (0x37) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 61
Mileage: 66866 km
Date: 2019.04.01
Time: 20:54:45
End----------(Elapsed Time: 01:39, VBatt start/end: 12.4V/12.3V)-----------
