Golf 2018 Hybrid 26623 - Crash Shut-Down Activated P1609 00 [167]
Ashraf6119
C?ID=174194
Hi All,
Got this vehicle in as non start after been involved in an accident and its been now repaired but, the new owner doesn't know what was damaged as its been bought from the auction so can't explain more about the damage......
Scanned vehicle and had Crash Shut-Down Activated faults in few modules managed to clear them by using the basic settings but, the one in Address 8C: Hybrid Battery (J840) can't be cleared as there is no security access code in drop bar for basic settings I have tried 20103 which does accept but, when I select basic settings option it says (Not Running).
Can please any one help with the right security code or, any way to clear this fault code, please see the attached full scan below.....
Friday,13,September,2019,13:50:55:29912
VCDS Version: 19.6.1.0
VIN: WVWZZZAUZJW803777   License Plate: GOLG H/B SANKAR
Mileage: 31112km-19332mi   Repair Order:
Chassis Type  AU-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 23 42 44 4B 51 52 5F 75 8C
          A9 C6
VIN: WVWZZZAUZJW803777   Mileage: 31112km-19332miles
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
51-Electric Drive -- Status: Malfunction 0010
8C-Hybrid Battery -- Status: Malfunction 0010
Address 01: Engine (J623-CUKB)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023 BN    HW: 04E 907 309 F
   Component: 1.4l TFSI hy  H22 4518
   Revision: X3H22---
   Coding: 011D0012636405082008
   ASAM Dataset: EV_ECM14TFS01104E906023BN 008006
   ROD: EV_ECM14TFS01104E906023BN.rod
   VCID: 6DD78C75BCE5262742-8038
17158 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 23:29:23
                    Engine speed: 0.00 /min
                    Coolant temperature: 17 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 9.520 V
                    Acceleration: 0.000 m/s²
                    Cruise Control System (CCS): status-Bits 0-7: 1
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
8221 - System Voltage
          P0562 00 [038] - Too Low
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:49:52
                    Coolant temperature: 16 °C
                    Voltage terminal 30: 9.000 V
          U0428 00 [039] - -
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:46:08
                    Voltage terminal 30: 9.980 V
                    Outside air temperature: 19 °C
                    Absolute intake pressure: 102 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel level: 22.00 l
                    E-machine torque actual value: 0.0 Nm
                    Operating mode control expanded electrical driving: False result
                    Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE: 0
                    High-volt. battery: charge state: abs. value: 26.19 %
Readiness: 1110 0001
   Part No SW: 0DD 300 046     HW: 0DD 927 770 C
   Component: GSG DQ400E    H32 1601
   Revision: 00032056    Serial number: TFK01708250161
   ROD: EV_TCMDQ400021_VW37.rod
   VCID: 65C7F45564151E670A-8030
10821 - System Voltage
          P0562 00 [046] - Too Low
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:50:25
                    Engine speed: 6.25 /min
                    Engine torque: -100 Nm
                    Vehicle speed: 58 km/h
                    Control Module temperature: 52 °C
                    CURRENT pressure: -9.5 bar
                    Clutch: primary stat: Driving
                    selected gear: GANG_6
                    Driving position: N
                    Accelerator position: 0.0 %
                    DTC memory status: 40192
10779 - System Voltage
                    Fault Frequency: 9
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:49:54
                    Control Module temperature: 65 °C
                    Driving position: N
                    Accelerator position: 0.4 %
                    DTC memory status: 13824
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 BL    HW: 5Q0 614 517 AH
   Component: ESC           H62 0855
   Revision: 00000000    Serial number: 62497000000284
   Coding: 01FA80A13820216F477E060741CA2980011C84E26082947338B15078C20203
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
   ROD: EV_Brake1UDSContiMK100OMG_003_VW37.rod
   VCID: 7CF1B131F79FBFAFC5-8028
0128 - Function Restricted due to Insufficient Voltage
          U1400 00 [046] - -
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:51:07
0295 - Steering angle sensor
          B1168 54 [167] - Missing Calibration / Basic Setting
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:46:08
8277 - Databus
          U1122 00 [047] - Implausible Message
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:46:08
16412 - Display for Tire Pressure Monitoring
          C1146 02 [175] - Signal Failure
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:46:19
16413 - Display for Tire Pressure Monitoring
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:46:19
   Part No SW: 5GE 907 044 AM    HW: 5GE 907 044 AM
   Component: Climatronic   H04 1702
   Revision: 00001K01
   Coding: 0012100420011001040500000010102A
   VCID: 071BDEDDBE59EC77D8-8052
   Subsystem 3 - Part No SW: 3Q0 963 231 E    HW: 3Q0 963 231 E
   Serial number: -00103.7U.3A20340267
   Air quality sensor:
   Air Conditioning Compressor Sub:
H02
          B10CD 00 [009] - -
                    Reset counter: 75
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:45:32
                    Voltage terminal 30: 10.0 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 2
                    CAN input signal(s) status-Back-up light: OFF
1048839 - Function limitation due to crash signal
          B1397 00 [009] - -
                    Reset counter: 75
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:45:32
   Part No SW: 5Q0 937 084 CP    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H36 0253
   Serial number: 01001726301716
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0819DDE1B347E30FD1-805C
   Component: WWS    170819  042 0551
   Serial number:         170904064606
   Component: RLHS  047 0105
   Serial number: S4Y17M09D18H17M28S37
   Coding: 00A8DD
   Serial number: 000000000ZY172280YYE
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223972143389
131330 - Supply voltage
                    Reset counter: 115
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:52:24
          U1400 00 [008] - -
                    Reset counter: 115
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:51:29
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418617257
   Coding: 1471051811
   VCID: 4B9322EDE2B1C8173C-801E
          U1400 00 [008] - -
                    Reset counter: 115
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:50:44
13637426 - Databus
                    Reset counter: 75
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:44:22
   Part No SW: 5Q0 907 572 H    HW: 5Q0 907 572 H
   Coding: 5500678159FFC728949C810580400600000000000000000000
   VCID: 3C717131B71F7FAF85-8068
2055 - Databus
                    Reset counter: 75
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:45:49
                    Voltage terminal 15: 9.9 V
2101 - Databus
                    Reset counter: 75
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:45:49
0928 - Databus
                    Reset counter: 75
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:45:49
2068 - Databus
                    Reset counter: 75
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:45:49
1389 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 115
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:49:52
                    Control Module temperature: 35 °C
                    Voltage terminal 15: 8.9 V
   Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
   Component: AirbagVW20    010 0870
   Serial number: 003MFR03FV1V
   Coding: 98CCC000002000005C0000CF00C800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 50A935810B97EBCF49-8004
   Belt Pretensioner left:
   Serial number: 34169677E15091750937
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676E17091791453
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 609 17
   Serial number: 35700000000D1A51D72O
   Subsystem 4 - Part No SW: -----------    HW: 480 001 804 18
   Serial number: 35800000000F6B7C5E22
   Subsystem 5 - Part No SW: -----------    HW: 480 401 409 17
   Serial number: 35100019B269FFC5C1DY
   Subsystem 6 - Part No SW: -----------    HW: 480 401 109 17
   Serial number: 3520001A9269FFC2E2CX
   Subsystem 7 - Part No SW: -----------    HW: 480 402 009 17
   Serial number: 3550001A924A4334B27/
9634838 - Control Module for Front Left Belt Tensioner
          B1304 16 [008] - Voltage Too Low
                    Reset counter: 115
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:50:21
9635094 - Control Module for Front Right Belt Tensioner
          B1305 16 [008] - Voltage Too Low
                    Reset counter: 115
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:50:08
1050117 - Databus
                    Reset counter: 75
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:44:59
   Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 10091708491419
   Coding: 0410
   VCID: 020DCFC9957BC95F8F-8056
   Part No SW: 5G1 920 794 A    HW: 5G1 920 794 A
   Component: KOMBI         407 3194
   Coding: 27AC7B082FC0060001886B111601030000000000
   VCID: 2D574C757C65E62702-8078
13635840 - Supply voltage
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:51:52
   Part No SW: 3Q0 907 530 H    HW: 3Q0 907 530 D
   Component: GW MQB EV     618 6305
   Serial number: 22081710803300
   Coding: 020100176EF11000FB00527C5C1D00000001070100010000000300000000
   ROD: EV_GatewNF.rod
   VCID: 346159119F4FB7EF4D-8060
   Subsystem 1 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Serial number: 29170001921730027355
   Coding: 2DFFFF
   Subsystem 2 - Part No SW: 5QE 915 181 A    HW: 5QE 915 181 A
   Serial number: 9317815004
1282 - Supply voltage
                    Reset counter: 115
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:52:40
                    Supply voltage: Terminal 30: 8.4 V
                    Terminal 15: OFF
8526361 - LV Energy Management
          B1802 F1 [009] - Warning Triggered
                    Reset counter: 75
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:44:18
                    Supply voltage: Terminal 30: 10.0 V
                    Terminal 15: On
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 G    HW: 5QE 909 059 B
   Component: EBKV          H14 0211
   Serial number:   085460011686
   Coding: 02720100331900000002060500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004003
   ROD: EV_BrakeBoostBoschMQBOMG_004_VW37.rod
   VCID: 52AD3F89059B99DF7F-8006
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 5QE 909 057 D    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0155
   Serial number: 05802861010917213849
173568 - Voltage Supply 2
          C1205 00 [046] - Voltage too Low
                    Fault Frequency: 8
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:48:34
173312 - Voltage Supply 2
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:51:10
180736 - Implausible Data Received from Engine Control Module
          U0401 00 [175] - -
                    Mileage: 31112 km
                    Date: 2019.07.11
                    Time: 00:06:42
202752 - Supply Voltage for Brake Pressure Accumulator
          C120A 00 [038] - Implausible Signal
                    Mileage: 31112 km
                    Date: 2019.08.19
                    Time: 00:10:44
11008 - Supply Voltage for Brake Pressure Accumulator
          C120A 00 [046] - Implausible Signal
                    Mileage: 31112 km
                    Date: 2019.08.19
                    Time: 00:10:44
250112 - Implausible Data Received from Engine Control Module
          U0401 00 [047] - -
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:46:08
   Serial number: 170717EGH04731
   Coding: 003F0620D001048000001000
   VCID: 43830ACDCAE10057C4-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Serial number: 00000000000016413001
   Coding: 0D0000
65548 - Supply voltage
                    Reset counter: 115
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:53:54
65649 - Lamp for Ambient Illumination
          B1325 13 [008] - Open Circuit
                    Reset counter: 115
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 23:29:23
589829 - Window Regulator; Rear Driver side
          B131F F5 [008] - Supply Voltage too Low
                    Reset counter: 115
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:51:10
   Component: EPS_MQB_ZFLS  129 1072
   Coding: 0002
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 458714D5C4D53E67EA-8010
15873 - Steering angle sensor
                    Reset counter: 75
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:44:32
                    Motor status: 00
                    Supply voltage: 10.00 V
                    Temperature: 26.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Environmental conditions: 5F
                    uAdSensI_U1V2Filtered_gdu16: 1.19 V
                    uioUdNotFilt_xdu16: 9.92 V
                    uAdSensI_SwitchedKl30_xdu16: 9.92 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
11776 - Supply voltage
                    Reset counter: 115
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:51:23
                    Motor status: 00
                    Supply voltage: 8.50 V
                    Temperature: 27.0 °C
                    KFC: 2E
                    KFA: 00 00
                    Environmental conditions: 25
                    uioUdNotFilt_xdu16: 8.75 V
                    uAdSensI_SwitchedKl30_xdu16: 8.75 V
Address 4B: Multifunc. Module
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
   Part No SW: 5G0 907 080 E    HW: 5G0 907 080 E
   Component: LE Gen 3.3H11 1032
   Revision: 00H11000
   Coding: C0020000000000000000
   ASAM Dataset: EV_DMCM08530115G0907080E 001008
   ROD: EV_DMCM08530115G0907080E.rod
   VCID: 295FB865488DFA07EE-807C
31789 - System Voltage
                    Fault Frequency: 11
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:49:53
                    Voltage terminal 30: 8.794 V
                    Drive control condition: DisCharge
                    Drive control condition-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb Drv Ctrl UBYTE: 13
37308 - System Voltage
                    Fault Frequency: 30
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:51:31
                    Voltage terminal 30: 6.984 V
   Serial number: 250817EHP08107
   Coding: 003F0020DE01048000801000
   VCID: 428D0FC9D5FB095FCF-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Serial number: 00000000000016431479
   Coding: 150000
                    Reset counter: 115
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:53:54
                    Reset counter: 115
                    Mileage: 31112 km
                    Date: 2019.08.19
                    Time: 00:11:37
589845 - Window Regulator; Front Passenger side
          B1320 F5 [008] - Supply Voltage too Low
                    Reset counter: 115
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:51:10
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    851 0842
   Coding: 02731001FF0000005111010100880A001F0509E601200000CE
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 326D5F09655BB9DF5F-8066
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZHT2533257
          U1400 00 [008] - -
                    Reset counter: 115
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:51:38
                    Voltage terminal 30: 6.9 V
   Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
   Component: OCULowMQBLGE  H17 0718
   Revision: --------
   Coding: 02739001EA42980D3FFCBE000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004044
   ROD: EV_OCULowMQBLGE_004_VW37.rod
0041 - Databus
                    Reset counter: 115
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 03:25:11
                    Voltage terminal 30: 12.6 V
   Part No SW: 5Q0 915 182 D    HW: 5Q0 915 182 C
   Component: BECM          H05 0921
   Serial number: V4140073
   Coding: 00000000
   ASAM Dataset: EV_BECM09620115Q0915182 006041
   ROD: EV_BECM09620115Q0915182.rod
   Battery Junction Box:
   Subsystem 1 - Part No SW: 5Q0 915 250 E    HW: 5Q0 915 250 E
   Component: BJB  H28 0240
   Cell module: control module 1:
   Subsystem 2 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D1  H14 0481
   Serial number: V013C1751130382
   Cell module: control module 2:
   Subsystem 3 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D2  H14 0481
   Serial number: V013C1751130399
   Cell module: control module 3:
   Subsystem 4 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D3  H14 0481
   Serial number: V013C1751130381
   Cell module: control module 4:
   Subsystem 5 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D4  H14 0481
   Serial number: V013C1751130384
   Cell module: control module 5:
   Subsystem 6 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D5  H14 0481
   Serial number: V013C1751130400
   Cell module: control module 6:
   Subsystem 7 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D6  H14 0481
   Serial number: V013C1751130398
   Cell module: control module 7:
   Subsystem 8 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D7  H14 0481
   Serial number: V013C1751130405
   Cell module: control module 8:
   Subsystem 9 - Part No SW: 5QE 915 591 K    HW: 5QE 915 591 K
   Component: 6D8  H14 0481
   Serial number: V013C1751130408
          P1609 00 [167] - -
                    Mileage: 31112 km
                    Date: 2019.06.09
                    Time: 16:28:52
                    Pack Voltage: 346.6 V
                    Pack Current: -0.00 A
                    Isolation Resistance: 5080 kOhm
                    Maxumum charge current limit: 0 A
                    Maximum discharge current limit: 0.0 A
                    Contactor Voltage: 334 V
                    OBD unlearned counter: 40
                    Crash status: 01
                    Pilot Line Status: 00
                    Fuse Status: 00
                    (Minus) Contactor Status: 00
                    (Plus) Contactor Status: 00
                    Terminal 15 status: 01
                    Max Cell Temperature: 33 °C
                    Min Cell Temperature: 32 °C
                    Air inlet temperature: 30 °C
                    Air outlet temperature: 30 °C
                    LV Battery Voltage: 12.6 V
                    Min.cell voltage: 3.627 V
                    Max.cell Voltage: 3.654 V
                    Max.cell SOC: 27 %
                    Min.cell SOC: 26 %
                    Hybrid Battery Pack Remaining Life: 25.9 %
                    Max Charge Pack Current(10s duration): 67 A
                    Max Discharge Pack Current(10s duration): 277.5 A
                    Max Pack Voltage(10s duration): 352 V
                    Min Pack Voltage(10s duration): 314 V
                    Max.cell Voltage(10s duration): 3.672 V
                    Min.cell Voltage(10s duration): 3.285 V
                    Accelerator Pedal Position D: 14.5 %
                    Calculated LOAD Value: 11.0 %
                    Engine coolant temperature: 84 °C
                    Engine RPM: 3857.00 /min
                    Vehicle Speed Sensor: 95 km/h
                    Ambient Air Temperature: 215 °C
                    Hybrid Battery Pack Remaining Life: 25.88 %
                    control module system voltage: 12.629 V
                    absolute load: 21.6 %
                    Time After Engine Start: 3604 s
26633 - 14V Power System Voltage
          P0A8D 00 [038] - too Low
                    Fault Frequency: 14
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:51:14
                    Pack Voltage: 340.4 V
                    Contactor Voltage: 20 V
                    Crash status: 01
                    Fuse Status: 00
                    Max Cell Temperature: 17 °C
                    Min Cell Temperature: 16 °C
                    Air inlet temperature: 17 °C
                    Air outlet temperature: 17 °C
                    LV Battery Voltage: 8.4 V
                    Min.cell voltage: 3.537 V
                    Max.cell Voltage: 3.551 V
                    Max.cell SOC: 27 %
                    Min.cell SOC: 26 %
                    Max Charge Pack Current(10s duration): 0 A
                    Max Discharge Pack Current(10s duration): 0.0 A
                    Max Pack Voltage(10s duration): 340 V
                    Min Pack Voltage(10s duration): 340 V
                    Max.cell Voltage(10s duration): 3.551 V
                    Min.cell Voltage(10s duration): 3.536 V
                    Accelerator Pedal Position D: 14.9 %
                    Calculated LOAD Value: 0.0 %
                    Engine coolant temperature: 16 °C
                    Engine RPM: 0.00 /min
                    Vehicle Speed Sensor: 0 km/h
                    control module system voltage: 8.478 V
                    absolute load: 0.0 %
                    Time After Engine Start: 0 s
26624 - Crash Shut-Down Activated
          P1609 00 [167] - -
                    Mileage: 31112 km
                    Date: 2019.06.09
                    Time: 16:28:52
                    Pack Voltage: 351.1 V
                    Pack Current: 78.60 A
                    Isolation Resistance: 3220 kOhm
                    Maxumum charge current limit: 126 A
                    Maximum discharge current limit: 285.0 A
                    Contactor Voltage: 350 V
                    Crash status: 00
                    Fuse Status: 00
                    (Minus) Contactor Status: 01
                    (Plus) Contactor Status: 01
                    LV Battery Voltage: 13.0 V
                    Min.cell voltage: 3.651 V
                    Max.cell Voltage: 3.662 V
                    Max.cell SOC: 27 %
                    Min.cell SOC: 26 %
                    Calculated LOAD Value: 11.4 %
                    Engine RPM: 4331.50 /min
                    Vehicle Speed Sensor: 96 km/h
                    control module system voltage: 13.076 V
                    absolute load: 21.2 %
26644 - System Voltage
                    Fault Frequency: 12
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:51:01
                    Crash status: 01
                    Fuse Status: 00
                    LV Battery Voltage: 8.7 V
                    Max.cell SOC: 27 %
                    Min.cell SOC: 26 %
                    control module system voltage: 8.763 V
   Part No SW: 5G0 907 159 C    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0017
   Serial number: 170811200565
   VCID: 2E554B7971639D3F3B-807A
   Part No SW: 5QE 915 682 AF    HW: 5QE 915 682 AF
   Component: OBC KOSTAL    H40 4013
   Revision: --------    Serial number: 0409170I400098
   Coding: 115068222000
   ASAM Dataset: EV_OBCSinglPhaseKLOMQB12P 001001
   ROD: EV_OBCSinglPhaseKLOMQB12P.rod
   VCID: 112FF085C01DA2C706-8044
                    Reset counter: 115
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:53:17
          U1400 00 [008] - -
                    Reset counter: 115
                    Mileage: 31112 km
                    Date: 2019.08.18
                    Time: 22:50:57
End-------------------------(Elapsed Time: 05:46)--------------------------
morski
Cheshire UK
C?ID=90186
1st thing is you need to fully charge the battery! Everything is pointing to a very low voltage on the battery. Dont even bother running diagnostic scans when you have a low battery or at least use a battery maintainer.
Who repaired the car?
As its a hybrid, 99.9% chance is the HV system has been shut down by VW tech as its standard procedure for a HV car thats been in an accident. Safety procedures for anyone working on the car and usually its by someone who hasnt got a clue about HV systems and its dangers.
ODIS has shut down and reactivation procedure for the audi/VW hybrids, not sure if VCDS has it.
Ashraf6119
C?ID=174194
I am not sure who repaired it, VCDS could de active in all other modules only in this 8C Hybrid Module could not run the basic settings as I said the 20103 security code was accepted in all other module and also could run the basic settings and it did clear the fault codes but, only in 8C Hybrid module could not run the basic settings..
morski
Cheshire UK
C?ID=90186
No; basic settings is not the same as shutting down/reactivating the hybrid battery system. Its a strict procedure in ODIS that you have to follow in order to reactivate the battery system. Ive repaired a few of the them and always used ODIS to do it.
Been through that procedure with ODIS on a 2018 Audi A3 e-tron, which has essentially the same drivetrain. There was nothing wrong with the car, we just wanted to understand what ODIS was doing. Well ODIS runs you through an crazy number of checks and tests ("CYA"). In the end, what actually shuts down the hybrid battery is not some mysterious thing that the scan tool does, but rather pulling the little plug on the 12V control circuit to the battery's contractor. Guess what re-activates it? Yep, re-inserting that plug.
Oh, and without sufficient power from the 12V system, the contactor cant close even with the plug in place.
morski
Cheshire UK
C?ID=90186
Yes exactly but i didnt want to say that about the little connector plug as dealing with HV systems one never knows how a certain individual might approach these systems. Ive see them with the fuse pulled and the main HV connector to the battery removed as well.
Ashraf6119
C?ID=174194
Could you please tell me where about is this plug to look at...........?
morski
Cheshire UK
C?ID=90186
Back of the engine bay on the firewall; passenger side. Should have a tag attached to it.
golfi_vend
Tartu, Estonia
C?ID=195131
You'd really need to use odis to re-enable HV system.
Ashraf6119
C?ID=174194
Hi
I did not get you what are you trying to say could you please explain us bit more.....
South Molton, UK
See post #4 in this thread
