2019 Audi RS3 output for fan circuit
forcefedjunkie
C?ID=683
Trying to manually turn my radiator fan on with key on engine off, which works on my Golf R and S5. However, on my RS3 nothing happens and I get a message "request denied by controller". In fact, this message occurs when trying to activate any system using the output function on the RS3. I have the HEX-NET dongle and latest software (19.6 I believe). TIA.
Todd
Bruce
Near Philadelphia, PA, USA
and where do we find a recent autoscan of the car?
We need help to help you.
hadez16
C?ID=289891
Did you have the hood opened?
forcefedjunkie
C?ID=683
Here is the Autoscan:
Monday,16,September,2019,12:00:55:30244
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WUABWGFF2KA905917   License Plate:
Mileage: 708km-439mi   Repair Order:
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 14 15 17 19 22 29 2B 39 3C 42 44 47 4B
          52 5F 65 6C BB BC CF D6 D7
VIN: WUABWGFF2KA905917   Mileage: 708km-439miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
Address 01: Engine (------DAZA)       Labels: None
   Part No SW: 8V0 907 404 J    HW: 07K 907 309 E
   Component: R5 2.5l TFSI  H22 0002
   Revision: 53H22000
   Coding: 0A250032242600053620
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM25TFS0118V0907404J 001003
   ROD: EV_ECM25TFS011_AU37.rod
   VCID: 40CC5445DBF5E74FD9-8014
   Part No SW: 0DL 300 013 E    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 3023
   Revision: 00H06V07
   VCID: 2C1410F5477D132F15-8078
10679 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [040] - -
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
                    Engine speed: 0.00 /min
                    Coolant temperature: 69 °C
                    Clutch: primary stat: New
                    selected gear: GANG_R
                    Driving position: P
                    Engine torque: 200 Nm
                    Control Module temperature: 49 °C
                    Accelerator position: 14.8 %
                    DTC memory status: 66
   Part No SW: 8V0 614 517 D    HW: 8V0 614 517 C
   Component: ESC           H25 0640
   Revision: 00000000    Serial number: 61299000000741
   Coding: 2EAA6B7DD4990BAE899A0B6540986974D62BD091D0029636024150840288420000000012121212B835351919323200
   Shop #: WSC 06335 790 00021
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037008
   ROD: EV_Brake1UDSContiMK100IPB_037_VW41.rod
   VCID: 3A3826ADBD29BD9F97-806E
7 Faults Found:
8246 - Databus
          [FCAN: Motor_Code_01 message is not received]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:17
8250 - Databus
          [FCAN: Motor_07 message is not received]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:17
8252 - Databus
          [FCAN: Motor_11 message is not received]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:12
8254 - Databus
          [FCAN: Motor_12 message is not received]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:12
8256 - Databus
          [FCAN: Motor_14 message is not received]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
8258 - Databus
          [FCAN: Motor_20 message is not received]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
8264 - Databus
          [FCAN: Tsk_06 message is not received]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0516734542
   Coding: 030C0C1720
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   VCID: 43C65B49CAE3FC57C4-8016
12716804 - Databus
          [Message Motor_14 missing]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
                    Terminal_15_Kessy_specified_value: On
                    Terminal_15_Kessy_actual_value: On
                    Terminal_15_central electric_actual_value: On
                    Terminal_15red_Kessy_specified_value: On
                    Terminal_15red_Kessy_actual_value: On
                    Terminal_S_Kessy_specified_value: On
                    Terminal_S_Kessy_actual_value: On
                    Terminal_S_central electric_actual_value: On
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 12.096 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 0.0 /min
                    Status of vehicle locking: Vehicle unlocked
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: Open
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID sensor 1 authentication: status: No response
                    ID sensor 2 authentication: status: No response
                    ID sensor 3 authentication: status: No response
                    ID sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12718343 - Databus
          [Message Motor_07 missing]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:17
                    ZAT_pressed: OFF
                    Control Module Voltage: 12.073 V
                    Driver door: Open
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12718344 - Databus
          [Message Motor_09 missing]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:17
                    ZAT_pressed: OFF
                    Driver door: Open
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12718345 - Databus
          [Message Motor_code_01 missing]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:17
                    ZAT_pressed: OFF
                    Control Module Voltage: 12.084 V
                    Driver door: Open
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Part No SW: 8V0 820 043 AF    HW: 8V0 820 043 AF
   Component: AC Automat    H03 0150
   Revision: 20003000    Serial number: 00000001832631
   Coding: 03000015010000000000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
   VCID: 76A0F29DC9B119FFB3-8022
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 72A1DBA900PAG0MUFU03
459023 - Databus
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:12
   Part No SW: 5Q0 937 085 BS    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H38 0273
   Serial number: 01001914900022
   Shop #: WSC 06324 790 00021
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 0B56B369A2337417FC-805E
   Component: WWS371 190424  043 0585
   Serial number:         190507143751
   Coding: 0A47F7
   Serial number: 21909266X81A955547A0
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
   Component: E1 - LDS MQB  H06 0032
   Serial number: 15 03 2019  20000703
   Serial number: 00000000000047165008
   Sun Roof:
   Component: J245 PS73.404  H04 0005
   Serial number: 0000FST002C7HUW00000
   Coding: 101F00
   Steering Column Switch:
   Subsystem 6 - Part No SW: 82A 953 521 CG    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0070
   Serial number: 00000024051904400530
541973 - Databus
          [Motor_04 Datenbus fehlende Botschaft]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:12
542229 - Databus
          [Motor_14 Datenbus fehlende Botschaft]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
542485 - Databus
          [Motor_18 Datenbus fehlende Botschaft]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
555541 - Databus
          [Motor_12_alt aktiv]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
559125 - Databus
          [Motor_07 Datenbus fehlende Botschaft]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418019135
   Coding: 0470155011
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CD47075E7BD332F35-8018
13637426 - Databus
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
12648468 - Databus
          [Motorsteuergerät - Motor_20 - kein Signal/keine Kommunikation]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 H    HW: 8V0 907 376 F
   Component: DAEMPFUNGS-SG H11 0083
   Serial number:       090519084
   ASAM Dataset: EV_AudiMagneRide 003007
   ROD: EV_AudiMagneRide_003.rod
   VCID: 46C0425DF9D1C97FE3-8012
10506241 - Databus
          [Motor_07_Timeout]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:17
                    COM: 0A FE 0A EF 00 0B 3A 14 00 00
                    Voltage terminal 30: 12.2 V
                    Terminal 15 status via CAN: Terminal 15 on
                    Engine run: Not available
                    Engine torque: Not available
                    AMR state: 6
                    Damping adjustment indicator lamp: OFF
                    ESP automatic engagement: not activated
                    Fall-back level: 01 B0 20 00
10510337 - Databus
          [Motor_11_Timeout]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
                    COM: 0A DF 0A D0 00 0B 29 02 00 00
                    Engine run: 0
                    Engine torque: -4 Nm
                    AMR state: 0
                    Fall-back level: 00 00 00 00
10514433 - Databus
          [Motor_14_TimeOut]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
                    COM: 0A EF 0A DF 00 0B 2A BA 00 00
                    AMR state: 6
                    Fall-back level: 00 30 00 00
10518529 - Databus
          [Motor_Code_01_Timeout]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:17
                    COM: 0A EF 0A EF 00 0B 37 BC 00 00
                    AMR state: 6
                    Fall-back level: 01 30 20 00
   Serial number: 003GCR0C1CA7
   Coding: 9DCCFCC0008000005000001AC248000000C5
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47DE4F59FEDBD07718-8012
   Belt Pretensioner left:
   Serial number: 34258931A22051930173
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34258932A17051920562
   Coding: 333135
   Occupant Detection:
   Serial number: 694000000000001WC0M0
   Coding: 303433
   Subsystem 4 - Part No SW: -----------    HW: 480 002 405 19
   Serial number: 35700000000CB6483C3V
   Subsystem 5 - Part No SW: -----------    HW: 480 002 405 19
   Serial number: 35800000000B5341CC3O
   Subsystem 6 - Part No SW: -----------    HW: 480 402 305 19
   Component: SideSensor_Dr  005 6149
   Serial number: 3510001A4F001356B74X
   Subsystem 7 - Part No SW: -----------    HW: 480 402 105 19
   Component: SideSensor_Pr  005 6149
   Serial number: 3520001C4F051DB61698
   Subsystem 8 - Part No SW: -----------    HW: 480 401 805 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001A4F001352B74X
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 401 805 19
   Component: FrontSensor_P  005 6149
   Serial number: 3560001A4F00135347C-
1053952 - Databus
          [NWD: 0x121 Motor_20 Timeout]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 890 B    HW: 8V0 920 890 B
   Component: FBenUSA       H19 0108
   Coding: 086F18D33A88CF050204EC041800001000000000
   ASAM Dataset: EV_DashBoardFPKAU37X 001032
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 3C3420B5B71D83AF85-8068
16776971 - Databus
          [Motor_04 communication error can_error_timeout]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
   Component: GW MQB High   442 4368
   Revision: --------    Serial number: 0009592959
   Coding: 0301000434085D005B00800EB80B00000001010000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 6E90DAFDB1E1213F7B-803A
   Component: 1-01-09-01-04
   Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Serial number: 20190517155441 31809
   Subsystem 3 - Part No SW: 8S0 915 181 C    HW: 8S0 915 181 C
   Serial number: 1271461305
131702 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [008] - -
          [Timeout Knoten 0x76 / 01 - Motorsteuergerät]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:15
                    Supply voltage: Terminal 30: 11.9 V
                    Terminal 15: On
   Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
   Component: Haldex4Motion H55 7762
   Serial number: HA1-00025.04.19
   Coding: 0601
   Shop #: WSC 06325 790 00021
   VCID: 4DD27D711CA73A2722-8018
17506 - Databus
          [Motorsteuergerät - TO -- Mot_07]
                    Fault Priority: 8
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:16
17473 - Databus
          [Motorsteuergerät - TO -- Mot_11]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:12
16657 - Databus
          [Motorsteuergerät - TO -- Mot_12]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:12
17474 - Databus
          [Motorsteuergerät - TO -- Mot_14]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:12
16727 - Databus
          [Motorsteuergerät - TO -- Mot_20]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:12
17475 - Databus
          [Motorsteuergerät - TO -- Mot_Code]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:16
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
   Component: LCM_MQB       H07 0022
   VCID: 42C85E4DD5F9F55FCF-8016
0279 - Databus
          [databus - message missing]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H08 0021
   Serial number: 19000152588009
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_AU37.rod
   VCID: 312A0181605F7EC726-8064
12666369 - Databus
          [Timeout Message Motor_14]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
                    Result lock conditions: invalid
                    ESCL locked: No
                    ESCL unlocked: Yes
                    Lock sensor: not activated
                    Unlock sensor: operated
                    Error mode 1: not active
                    Error mode 2: not active
                    Clamp S: On
                    Clamp 15: On
                    Clamp 15 Status: valid
                    Remote Start: not active
                    Driver door: Open
                    Central locking locked external: unlocked
                    Central locking safed external: Vehicle not secured
                    Clamp Request: No
                    Request highside lock: No
                    HW highside lock: OFF
                    Highside unlock: No
                    Motor break: not active
                    Activation lowside unlock: OFF
                    Activation lowside lock: OFF
                    I2C overflow: No
                    I2C error pathflags: No
                    I2C resetinfo: No
                    I2C error cpu: No
                    I2C error rom: No
                    I2C error ram: No
                    I2C length failure: No
                    I2C error sda: No
                    I2C communication failure: i2c no comm failure
                    I2C state esp 10: i2c cnd true
                    I2C cnd haco message: valid
                    Coco reset: No
                    Coco supply: On
                    Password IMS OK: Yes
                    Signature IMS OK: Yes
                    IMS responded: Yes
                    Positive authentification in current KL15 cycle: Yes
                    Lifestate: Immobilizer download obtained
                    Learn mode: Adapted
                    Authentication valid (T1): No
                    State of authentication state machine: WFS_AUTH_INIT_e
                    Vehicle speed: 0.00 km/h
                    UBat internal: 11.3 V
                    UMotorBridge: 6.2 V
                    Lock condition engine speed: Condition met
                    Lock condition clamp S: Condition not met
                    Lock condition clamp 15: Condition not met
                    Lock condition E2E clamp status: Condition not met
                    Lock condition timeout clamp status: Condition met
                    Lock condition vehicle speed: Condition met
                    Lock condition E2E vehicle speed: Condition met
                    Lock condition timeout vehicle speed: Condition met
                    Lock condition Mode1: Condition met
                    Lock condition drive readiness: Condition met
                    Lock condition selector lever position parking: Condition met
                    Clamp enable ESCL: not enabled
                    Lock condition timeout distance pulse: Condition met
                    Lock condition E2E distance pulse: Condition met
                    Lock condition difference distance pulse: Condition met
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
0279 - Databus
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
   Part No SW: 3Q0 907 566 H    HW: 3Q0 907 566
   Component: MRR1Rear      H25 0630
   Revision: --------
   Coding: 040002
   VCID: 3D322DB1AC078AA7B2-8068
1183750 - Databus
          [databus message missing - Motor]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
                    Control Module temperature: 46 °C
                    Voltage terminal 30: Measured value not available
                    Terminal 15 status: Measured value not available
                    Voltage terminal 15: 11.90 V
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS002 0287
   Serial number: YE007SEE23082
   Coding: 005E1B205000008000000002
   VCID: 44C45855CFEDFB6FFD-8010
524339 - Databus
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 811E0000
   ROD: EV_SteerAssisMQB_015.rod
7 Faults Found:
22272 - Databus
          [KFC_MOTOR_11 Botschaft - CAN-Timeout]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
                    Motor status: 00
                    Supply voltage: 12.00 V
                    Temperature: 40.0 °C
                    KFC: 57
                    KFA: 00 00
                    Environmental conditions: 20
                    uioUdNotFilt_xdu16: 12.03 V
                    uAdSensI_SwitchedKl30_xdu16: 12.04 V
                    RP_VALCNTSAV: not activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
22528 - Databus
          [MOTOR_12 Botschaft - CAN-Timeout]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
                    Motor status: 00
                    KFC: 58
                    KFA: 00 00
23040 - Databus
          [MOTOR_20 Botschaft - CAN-Timeout]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
                    Motor status: 00
                    KFC: 5A
                    KFA: 00 00
22784 - Databus
          [MOTOR_14-Botschaft - CAN-Timeout]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
                    Motor status: 03
                    System status: Driving mode
                    KFC: 59
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 12.19 V
                    uAdSensI_SwitchedKl30_xdu16: 12.21 V
19460 - Databus
          [ESP_05 Botschaft - SNA-Check]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:14
                    Motor status: 03
                    KFC: 4C
                    KFA: 00 04
                    Environmental conditions: 21
23296 - Databus
          [MOTOR_CODE_01 Botschaft - CAN-Timeout]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:17
                    Motor status: 03
                    KFC: 5B
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 12.16 V
                    uAdSensI_SwitchedKl30_xdu16: 12.16 V
28672 - Databus
          [MOTOR_07 Botschaft - CAN-Timeout]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:17
                    Motor status: 03
                    KFC: 70
                    KFA: 00 00
   Part No SW: 81A 035 466 B    HW: 81A 035 466
   Component: MIB2_amp_P_A3 H10 0440
   Revision: 00000001    Serial number: AUZ8ZAK5F02GR97
   Coding: 0173030000AAAA2AAA0000010000
   ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
   ROD: EV_AMPMst16C9Gen2ALPI.rod
   VCID: 2404F8D52FADDB6FDD-8070
   Component: FCM MQB Low   002 0345
   Serial number: 18051910521011
   Coding: 000000050900143206112300040000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW41.rod
   VCID: 35223591943752E77A-8060
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS002 0287
   Serial number: YE007SEF1530E
   Coding: 005E13205C00008000000002
524339 - Databus
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:13
   Part No SW: 8V1 035 880 C    HW: 8V1 035 880 C
   Component: MU-P-LNS-US   055 1363
   Serial number: A702E0KS017399
   Coding: 017361020000000011220002041A00332F0028E4017001047E
   Subsystem 1 - Part No SW: V03 959 802 DK    HW: -----------
   Component: NAR 2018/2019  --- 0066
   Component: DU High  H49 0014
   Serial number: AUZ8Z9K1Y0J216
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BT    HW: 8V0 919 614 BT
   Component: ControlUnit_H  H85 0858
   Serial number: ALJAL114121800050325
   Compact Disc Database:
   Component: Gracenote2  --- 3013
6708 - Databus
          [Engine: no communication]
                    Reset counter: 54
                    Mileage: 178 km
                    Date: 2019.08.12
                    Time: 16:16:17
                    Network diagnosis-Status: Enabled
Address 65: Tire Pressure (J502)       Labels: None
   Part No SW: 8S0 907 273     HW: 4M0 907 273 B
   Component: RDKHUFAU736   H05 0002
   Serial number: 30000000008637
   ROD: EV_RDKHUFAU736_AU37.rod
   VCID: 77BEFF99CEBB60F7A8-8022
   Coding: 0273010102002001400040
   VCID: 393A39A1B82FB6879E-806C
   Part No SW: 8W1 959 395 D    HW: 8W1 959 395 D
   Component: TSG HFS004 0189
   Serial number: YE007SE219375
   Coding: 000C13204000008000000002
   Component: TSG HBFS004 0189
   Serial number: YE007SE219372
   Part No SW: 3Q0 907 590 H    HW: 3Q0 907 590
   Revision: --------
   Coding: 040002
   VCID: 177EDF19EEFB80F748-8042
End----------(Elapsed Time: 01:47, VBatt start/end: 12.1V/12.1V)-----------
Based on the above fault codes, one might speculate the ECU in that car had been flashed and whoever flashed it didn't bother to clear out the fault codes that all the other modules set while the ECU was off-line.
As far as opening the hood, some of the latest cars, especially Audis do require that in order for anything that isn't strictly a "read data" kind of operation.
It's been discussed here off and on:
https://duckduckgo.com/?q=diagnostic+firewall+site:forums.ross-tech.com
hadez16
C?ID=289891
What?
Audi RS3 2019?
Why does the Scan say its a "FF-AU37" Chassis? Audi A3 should be 8V.
And you have the DAZA Engine in a MY19 car. That is strange! DAZA was the engine in MY18.
Here in Germany MY19 RS3 do have another engine.
Do you not have these Particulate Filters for Gasoline Engines over there since MY19???
What?
Audi RS3 2019?
US requirements for VINs apply:
https://en.wikipedia.org/wiki/Vehicle_identification_number#Model_year_encoding
"In order to identify the exact year in passenger cars and multipurpose passenger vehicles with a GVWR of 10,000 or less, one must read position 7 as well as position 10. For passenger cars, and for multipurpose passenger vehicles and trucks with a gross vehicle weight rating of 10,000 lb (4,500 kg) or less, if position seven is numeric, the model year in position 10 of the VIN refers to a year in the range 1980–2009. If position seven is alphabetic, the model year in position 10 of VIN refers to a year in the range 2010–2039."
Thus VAG uses different characters for the 7th and 8th digits in the NAR market than in RDW.
The NAR market does not (yet?) have a requirement for particulate filters on gasoline engines.
forcefedjunkie
C?ID=683
Should I take from this that I should go back to where it was flashed and get the fault code situation rectified?
I have not tried opening the hood but will today.
Todd
If it was mine, I would just clear the faults myself. I mean you have VCDS, right? ;)
