2006 A4 B7 3.0 TDI ASB not starting
Proffa
Finland
C?ID=165882 (NRRT)
Hi,
Suddenly my Audi refused to start anymore, worked like charm day before. Cranks just fine but no life in engine. Could use some help for diagnose.
Wednesday,11,September,2019,21:42:50:39136
VCDS Version: 19.6.1.0 (x64)
VIN: WAUZZZ8E77A087768   License Plate:
          67 69 75 76 77
VIN: WAUZZZ8E77A087768   Mileage: 363700km-225992miles
Address 01: Engine        Labels: 059-907-401-ASB.clb
   Part No SW: 8E0 910 401 N    HW: 8E0 907 401 AL
   Component: 3.0L V6TDI  G000AG  0050
   Revision: --H03---    Serial number:
   Coding: 0011171
   Shop #: WSC 06335 000 00000
   VCID: 2A5140078567C91FE7-807E
005491 - Left Engine Mount Solenoid Valve (N144)
               P1573 - 001 - Open Circuit
                    Fault Status: 01100001
                    Mileage: 362253 km
                    RPM: 798 /min
                    Torque: 85.8 Nm
                    Voltage: 13.76 V
                    Bin. Bits:        0
                    Bin. Bits:        0
                    Bin. Bits:        0
   Part No SW: 8E1 910 156 H    HW: 09L 927 156 B
   Component: AG6 09L 3,0 TDI 150 0070
   Revision: --H01---    Serial number:        4228310
   Coding: 0000001
   VCID: 2C5D461F8F93D72F15-8078
006273 - Powertrain Data Bus: Missing Message
               P1881 - 000 - Acceleration Request - Intermittent
                    Fault Frequency: 12
                    RPM: 224 /min
                    (no units): 30.0
                    (no units): 25.0
                    Temperature: 24.0°C
                    T.B. Angle: 60.0°
050177 - Implausible Data Received from Engine Control Module
               U0401 - 000 -  - Intermittent
                    Fault Frequency: 12
   Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
   Component: ESP8 quattro    H06 0140
   Coding: 0004426
   VCID: 2E594C17B98FA53F3B-807A
                    Hex Value: 0x0080
                    Hex Value: 0x0702
                    Hex Value: 0x0013
                    Hex Value: 0x8595
                    Hex Value: 0x0001
                    Hex Value: 0x0080
                    Hex Value: 0x0702
                    Hex Value: 0x0024
                    Hex Value: 0x0193
                    Hex Value: 0x0001
   Part No: 8E0 820 043 BK
   Component:   A4 Klimaautomat   2833
   Coding: 00000
   VCID: 6BDF8503191D10175C-5106
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
            30-00 - Open or Short to Plus
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
            09-00 - Adaptation Limit Surpassed
            27-00 - Implausible Signal
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  ECE 0907
   Coding: 11041
   VCID: 3D7B7B5B37E94EA7B2-4B1C
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H12 3730
   Revision: 91H12373    Serial number: 0036M0G3A6S8
   Coding: 0031612
   VCID: 3B7F75437AFD40978C-806E
   Subsystem 1 - Serial number: 6332DRB403CC0B98
   Subsystem 2 - Serial number: 6342DRB403CB5423O
   Subsystem 3 - Serial number: 6352ARB4018B9B8C%
   Subsystem 4 - Serial number: 6362ARB4017FF1BE4
   Subsystem 5 - Serial number: 63729RB401890C83O
   Subsystem 6 - Serial number: 63829RB401890C82O
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0701
   Coding: 02042
   Shop #: WSC 06335
   VCID: 418307AB4B112A47D6-4B04
   Part No SW: 8E0 920 931 P    HW: 8E0 920 931 P
   Component: KOMBI+WFS 4     H14 0110
   Revision: 0110        Serial number: 00000000000000
   Coding: 0007111
   Shop #: WSC 17300 205 61667
   VCID: 356B637B5FD996E77A-5140
   Coding: 0007111
   VCID: 356B637B5FD996E77A-515C
   Part No: 8E0 959 433 CE
   Component: Komfortgerát T23    4135
   Coding: 31584
   Shop #: WSC 06335
   VCID: 76E9A477525FDDFFB3-4B04
   Subsystem 1 - Part No: 8E1959801H
   Component: Tõrsteuer.FS BRM 0606
   Subsystem 2 - Part No: 8E1959802H
   Component: Tõrsteuer.BF BRM 0606
   Component: Tõrsteuer.HL BRM 0606
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 0606
00956 - Key 2
            35-10 - - - Intermittent
00957 - Key 3
   Part No: 8P0 907 357 F
   Coding: 0000005
   VCID: 3D7B7B5B64E94EA7B2-8068
                    Reset counter: 37
   Part No: 8E0 035 186 AA
   Component: concert II  GRO    0004
   Coding: 11005
   Shop #: WSC 06335
   VCID: 66C9F43702FF2D7F03-4B1C
Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
   Part No SW: 8E0 919 283 D    HW: 8E0 919 283 D
   Component: Parkhilfe 4-Kan H06 0010
   Revision: 00H06000    Serial number: 00067802030624
   Coding: 0011014
   Shop #: WSC 14500 205 61023
   VCID: 3163576BABB1BAC726-5140
01545 - Sensor for Parking Aid; Rear Left (G203)
            009 - Open or Short to Ground
End-------------------------(Elapsed Time: 06:00)--------------------------
HMC
C?ID=28246
Hi Proffa,
Have you checked fuses for the engine management? ECU does not seem to be awake.
Regards HMC
Proffa
Finland
C?ID=165882 (NRRT)
Hi Proffa,
Regards HMC
I only found 1 which is 15 amps, switched it with another of same value, no help.
Proffa
Finland
C?ID=165882 (NRRT)
Quite quiet in here too... Well, added question: Since ECU might be faulty how hard/easy it would be to fit this into my car? https://ibb.co/my16L8d
Proffa
Finland
C?ID=165882 (NRRT)
Ok, didn't have a clue that there were fuses also in ECU box... Those checked now too, no help. Seems I have to get those security screws off from both ECUs and try that other one.
