NothernSky
- Sep 10, 2019
- 7
- 3
- Mexico
- HC402084 (2nd hand?)
So I retrofitted Direct TPMS to VW NAR Passat TDI 2016.
All is working fine, but somehow in the cluster the car icon is not showing up.
Parts:
3AA 907 275 F. Wheel Sensors: Quantity 4 (Should use 3AA 907 275 B but revision F worked for me)
3AA 907 273 D. Antenna: (Also 3AA 907 273 F works but has different tire parametrization not for NA Passat)
8E0 971 934 A. Antenna connector.
3AA 907 538. Antenna support.
000 979 009 E. Cables. Qty 2
3C0 972 741. Grommets.Qty 4
Antenna Connector------------> Gateway (with Extended Can Bus feature)
Pin 1 ---------------------------> Pin 7 Gateway CAN Extended +
Antenna Connector------------> Fuse Panel +
Pin 2 ---------------------------> 10A + Switched Power (I connected to FUSE# 10)
Pin 3 ---------------------------> Pin 17 Gateway CAN Extended -
Antenna Connector------------> Any good ground connection.
Pin 4 ---------------------------> Ground -
VCDS:
19 Address: Gateway add address on the installation list, tick 65.
17 Address: Instruments and tick TPMS Byte 2.
Not showing the car icon
Parts:
VCDS:
Monday,09,September,2019,21:04:38:32969
VCDS Version: 19.6.1.0 (x64)
VIN: 1VWCV7A3XGC005566 License Plate:
Mileage: 36560km-22717mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 25 2B 36 3C 42 44 46 47
4F 52 5F 62 65 72 75 A5
VIN: 1VWCV7A3XGC005566 Mileage: 36560km-22717miles
Address 01: Engine (J623-DEKA) Labels: None
Part No SW: 04L 906 016 NP HW: 04L 907 309 K
Component: R4 2.0l TDI H20 4790
Revision: 8AH20---
Coding: 011D0012034410089000
Shop #: WSC 20200 993 00000
ASAM Dataset: EV_ECM20TDI01104L906016NP 004003
ROD: EV_ECM20TDI01104L906016NP.rod
VCID: 840DADB70F9B566F3D-80D0
Part No SW: 02E 300 063 J HW: 02E 927 770 AL
Component: GSG DSG AG6 531 4915
Revision: 06253104 Serial number: 00001507050398
Shop #: WSC 09003 957 00200
VCID: 9D3BF8D3443187A712-80C8
Part No SW: 1K0 907 379 CC HW: 1K0 907 379 CC
Component: ESP MK60EC1 H46 0175
Revision: 00H46001
Coding: C54BC0F5492200FFA31003EA921F004201F1F01A
VCID: F5EBC0735C417FE73A-80A0
Part No SW: 5K0 959 434 F HW: 5K0 959 434
Component: VWKESSYPQ35GP 093 1202
Revision: 00093000 Serial number: 0376496207
Coding: 130C0C
VCID: B875094703D3C28FE1-80EC
Part No SW: 561 907 044 AM HW: 561 907 044 AM
Component: Climatronic H07 0910
Revision: 00001K04
Coding: 0050019012
VCID: E2C18B2FF5CFF85F6F-80B6
Part No SW: 5K0 937 087 AL HW: 5K0 937 087 AL
Component: BCM PQ35 H++ 122 0183
Revision: BN122001
Coding: EF200E3BD82B08D4098806093400854806F1000645B005B0E4806000BC70
Shop #: WSC 13385 003 104857
VCID: FF07225B6E7D35B760-80AA
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 150915 03 37 0059
Coding: 0038DD
Part No SW: 1K8 919 475 B HW: 5Q0 919 298
Component: PARKHILFE PLA H12 0479
Revision: -------- Serial number: 39411433601309
Coding: 0031165011
ASAM Dataset: EV_EPHVA2CVW364GP00 001010
ROD: EV_EPHVA2CVW364GP00_VW36.rod
VCID: B9730C4338D9DB871E-80EC
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 B HW: 7N0 907 572
Component: ACC Bosch PQx H03 0120
Serial number: 13081577031458
Coding: 01001002FE0739
ASAM Dataset: EV_ACCBEGVW361 001005
ROD: EV_ACCBEGVW361_VW32.rod
VCID: B56B007314C13FE7FA-80E0
Address 15: Airbags (J234) Labels:* 561-959-655.clb
Part No SW: 561 959 655 HW: 561 959 655
Component: AirbagVW11 001 0207
Serial number: 003RXM00ZVBX
Coding: 8CCCCC00000000005000001A020800000065
ASAM Dataset: EV_AirbaVW11SMEVW411 001002
ROD: EV_AirbaVW11SMEVW411_VW41.rod
VCID: E3CF8E2BEAD5F15764-80B6
Component: BF-Gewichtss. H11 0021
Serial number: IBH000000000003GT6O
Coding: 30324A
Subsystem 2 - Part No SW: ----------- HW: 480 000 708 15
Serial number: 35700000000EC109E51S
Subsystem 3 - Part No SW: ----------- HW: 480 000 708 15
Serial number: 3580000000075664F51M
Subsystem 4 - Part No SW: ----------- HW: 480 022 108 15
Component: SideSensor_Dr 000 0148
Serial number: 3510001B91BE60638665
Subsystem 5 - Part No SW: ----------- HW: 480 022 408 15
Component: SideSensor_Pr 000 0148
Serial number: 3520001C31BE606337A1
Subsystem 6 - Part No SW: ----------- HW: 480 022 807 15
Component: FrontSensor_D 000 0189
Serial number: 3550001B11B2C525773
Subsystem 7 - Part No SW: ----------- HW: 480 020 508 15
Component: FrontSensor_P 000 0189
Serial number: 3560001B719BDF23375G
Part No SW: 1K5 953 521 CS HW: 5K0 953 569 BF
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20150727300040
Coding: 2012C40008
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 8005A1A71B834A4F19-80D4
Subsystem 1 - Part No SW: 6C0 959 442 B HW: 6C0 959 442 B Labels: 3C8-959-537.CLB
Serial number: 3461501192300065AE2B
Coding: 2D0000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 981 A HW: 561 920 981 A
Component: KOMBI H04 1008
Coding: 231E090000
VCID: 9A31F3CF9D1FF09FF7-80CE
Part No SW: 7N0 907 530 BC HW: 7N0 907 530 AN
Component: J533 Gateway H56 1663
Revision: H56 Serial number: 09091503000428
Coding: 461010
VCID: F2E1FB6F2D2F68DF1F-80A6
Component: IMMO H04 1008
Coding: 000007
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: EAD1E30F0DFFA01FA7-80BE
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 15000178363007
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: B0653167EBA31ACFA9-80E4
Part No SW: 561 959 760 B HW: 561 959 760 B
Component: MEM-FS H04 0183
Revision: AA000000 Serial number: 00000159150901
Coding: 00581B0000000000000021010100202020202120202020
VCID: A241CB2FBD4FB85F2F-80F6
Address 3C: Lane Change (J1086) Labels:. 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H11 0071
Serial number: 0377246863
Coding: 02011102
ROD: EV_HREntryHella_VW27.rod
VCID: BC7D155737EBEEAF05-80E8
No ASAM data for: "EV_HREntryHella" (VW41)
Part No SW: 561 959 701 C HW: 3C0 959 793 J
Component: TUER-SG FT 002 0637
Revision: 12100010 Serial number: 0009951391
Coding: 3415FD
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04004
ROD: EV_TSGFPQ25BRFVW46X.rod
VCID: 9E39FFDF81379CBF0B-80CA
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 B HW: 561 959 811 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 006 5470
Serial number: 14202630150928214210
Coding: 800000
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 313 3501
Revision: 00H22000
VCID: B9730C43F0D9DB871E-80EC
Part No SW: 5C6 035 456 C HW: 5C6 035 456 C
Component: KonzernAmp10K H08 6831
Revision: -------- Serial number: EAA098C0069297
ROD: EV_AudioVerst10KanalSTT3.rod
VCID: A855D907D373520F71-80FC
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1663
Coding: 01030108
VCID: EFE7F21B3E1D4537F0-80BA
Subsystem 1 - Part No SW: 561 959 591 A HW: 561 959 591 A
Component: J245 P05 9BA3 H08 0005
Serial number: 53388786011501401389
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 C HW: 561 919 204 C
Component: Analoguhr 001 0002
Part No SW: 561 959 702 C HW: 3C0 959 792 J
Component: TUER-SG BT 002 0637
Revision: 14100010 Serial number: 0009956559
Coding: 3415FC
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04004
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 9F47C2DB863D95B700-80CA
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 B HW: 561 959 812 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 006 5470
Serial number: 14202631150928144824
Coding: 800000
Part No SW: 5C0 035 684 HW: 5C0 035 684
Component: MU-S-NS-US H21 0245
Serial number: VWZAZ2R0379323
Coding: 02140102AA00000051220003001808001F0100D400200105C6
Shop #: WSC 13385 003 1048576
ROD: EV_MUStd4CTSAT_VW41.rod
Subsystem 1 - Part No SW: 3G0 919 866 B HW: -----------
Component: NAR 2015/16 --- 0220
Part No SW: 3AA 907 273 D HW: 3AA 907 273 D
Component: RDKBERU30 H09 0010
Serial number: 30000000014146
ASAM Dataset: EV_RDKBERU30 003012
ROD: EV_RDKBERU30_003.rod
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 561 035 285 A HW: 561 035 285 A
Component: OCULowUSA 020 0156
Serial number: 000003554140542
Coding: 02140102C24232007F1606000000
ASAM Dataset: EV_OCULow 002009
ROD: EV_OCULow_002.rod
VCID: 942D9DF77FFBC6EFAD-80C0
Address A5: Frt Sens. Drv. Assist (R242) Labels:. 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 C HW: 3Q0 980 654
Component: MQB_B_MFK H04 0023
Serial number: 070715null0565
Coding: 000401010001020100201346C0804000D0000E230020
ROD: EV_MFKBoschMQBB_001_VW27.rod
VCID: B7770A7B0ECDCDF7E8-80E2
No ASAM data for: "EV_MFKBoschMQBB" (VW41)
End-------------------------(Elapsed Time: 04:03)--------------------------
