Audi Q5 2.0 Tdi, reductant pump 1, open circiut
RyMar
South Africa
C?ID=133909
Checked relavent wiring up to control unit and found to be OK. No Is it possible for this pump to fail at this kilometer reading?
Wednesday,11,September,2019,11:49:13:48706
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUZZZ8R4FA002533   License Plate: DBW 853 L
Mileage: 66930km-41588mi   Repair Order:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 62 69 6D 72
          77 AC
VIN: WAUZZZ8R4FA002533   Mileage: 66930km-41588miles
AC-Reductant Control -- Status: Malfunction 0010
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 JN    HW: 03L 906 018 JL
   Component: R4 2,0L EDC   H25 2929
   Revision: 45H25---
   Coding: 2A254012243601080000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM20TDI01103L906018JN 003003
   ROD: EV_ECM20TDI01103L906018JN.rod
   VCID: 7F4EE611E6433EB7E0-802A
16928 - Control Circuit for Reductant Pump 1
          P208A 00 [039] - Open Circuit
                    Mileage: 66934 km
                    Date: 2019.09.11
                    Time: 11:27:11
                    Engine speed: 0.00 /min
                    Coolant temperature: 67 °C
                    Intake air temperature: 38 °C
                    Ambient air pressure: 930 mbar
                    Voltage terminal 30: 12.000 V
                    Outside air temperature: 28.0 °C
                    Pressure sensor for reducing agent: measured pressure: -25 hPa
                    Sensor for reducing agent tank temperature: temperature: 20.8 °C
                    Reducing agent pump: activation: 0.00 %
                    Sensor for reducing agent fill level: voltage: 3105.0 mV
   Part No SW: 8R1 927 156 J    HW: 0B5 927 156 K
   Component: 0B5 20 TDIRdW H02 0003
   Revision: --H02---
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMDL501021 001015
   ROD: EV_TCMDL501021.rod
   VCID: 43C6AAE1CA2B9A57C4-8016
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AP    HW: 8R0 907 379 AP
   Component: ESP8 quattro  H09 0020
   Coding: 21D54C01
   VCID: 0E504BD5D9E9273F1B-805A
   Part No SW: 8K0 907 064 JG    HW: 8K0 907 064 JG
   Component: BCM2 2.0      H14 0650
   Coding: 01B54000000000000000
   VCID: 7EB01B15E94937BFEB-802A
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0514000070887007
   Part No SW: 8K2 820 043 BA    HW: 8K2 820 043 BA
   Revision: D0000000    Serial number: 01150520141293
   Coding: 342502E000
   VCID: 699A584980C7A0072E-803C
   Part No SW: 8K0 907 063 DG    HW: 8K0 907 063 DG
   Revision: 07016001    Serial number: 00000818433701
   Coding: 2600C0108034AFC00081400000001D0D0F1D670827090201000008004401030100000024000000
   VCID: 77BE0E31C67306F7A8-8022
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 140411  H12 0050
   Serial number: 90243015140402125050
   Coding: 01DD13
   Serial number: 22645649
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000605143838
   Serial number: B9088927000000000001
02988 - Left-Hand/Right-Hand Traffic Switchover Active
                    Reset counter: 137
                    Mileage: 66579 km
                    Date: 2019.07.05
                    Time: 15:11:51
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003JPDC0NH1R
   Coding: 30473431313030303030554A305238523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 48DCBDCDF30DB90F11-801C
   Serial number: 6334MSME447C445CP
   Serial number: 6344MSME447C4774N
   Serial number: 6352QSME10413C446
   Serial number: 6362QSME303F2172B
   Serial number: 63732SME2640046CX
   Serial number: 63832SME1A410340N
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NEH000FV
   Coding: 000037
   VCID: 48DCBDCDFB0DB90F11-801C
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 930 T    HW: 8R0 920 930 T
   Component: KOMBIINSTR.   H35 0564
   Revision: 00200000    Serial number: ZD433AH5F
   Coding: 3386220002010008010000
   VCID: 45C2B4F9CC1FA467EA-8010
   Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0060
   Revision: 1V090029    Serial number: 2941V144300740
   Coding: 80CF07FF00
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 5897323203
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 14134001326011200410
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000102500668
   Coding: 011D02205C01440004
   VCID: 4FEE96D11E636E3750-801A
   Part No SW: 8R0 909 144 G    HW: 8R0 909 144 B
   Component: RCEPS         H40 0508
   Revision: 00001000    Serial number: 0003547796
   Coding: 100000000001
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008015
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3C34D11DB7D5E5AF85-8068
   Revision: 00002001    Serial number: 0335538290
   Coding: 013A0622A0B930808420053680040047
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000102391535
   Coding: 011D02205E01440004
   VCID: 4ED08BD51969673F5B-801A
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 00000001481173
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A38D705BDE1DB9F97-806E
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8R2 035 186 N    HW: 8R2 035 186 N
   Component: Concert3      H05 0470
   Revision: 00000003    Serial number: AUZ5Z6N2041742
   Coding: 0500048204058D00035B071000
   VCID: 41CAA0E9D8378847D6-8014
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000103281719
   Coding: 010C02204001240004
   VCID: 46C0B3F5F119AF7FE3-8012
Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
   Part No SW: 8K0 907 383 D    HW: 8K0 907 383 D
   Revision: 1G001001    Serial number: 00008200328159
   Coding: 0109080000000000
   Shop #: WSC 25397 000 00000
   VCID: 3522C4399CFF34E77A-8060
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H53 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D32DC19A4CFECA7B2-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H53 0330
   Serial number: 8R0827852D
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000103281764
   Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005770060
   Coding: 0010390
   VCID: 3D32DC1964CFECA7B2-8068
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 141191565
   ROD: EV_RDCMA00100_008.rod
   VCID: 2D12EC597CAF7C2702-8078
196867 - Control Circuit for Reductant Pump 1
          P208A 00 [009] - Open Circuit
                    Reset counter: 140
                    Mileage: 66934 km
                    Date: 2019.09.11
                    Time: 11:27:07
                    Voltage terminal 30A: 12.0 V
                    Voltage terminal 30B: 12.0 V
                    Voltage terminal 87: 12.0 V
                    Reductant_pwm_duty_cycle: 0.0 %
                    Reductant_speed_pump_motor: 0 /min
                    Reductant_pump_output_stage_temperature: 29 °C
                    Reductant_heater_control_1_output_stage_temperature: 29 °C
                    Reductant_tank_temperature_sensor_actual_value: 21 °C
                    Reductant_temperature_ambient: 23 °C
                    Reductant_current_pump_motor_A: 0.0 A
                    Reductant_current_pump_motor_B: 0.0 A
                    Reductant_current_pump_motor_C: 0.0 A
                    Reductant_heater_control_1_actual_power_value: 0.0 A
                    Reductant_heater_control_2_actual_power_value: 0.0 A
                    Reductant_transfer_pump_current: 0.0 A
                    Reductant_pressure_sensor_actual_value: -50 mbar
                    Reductant_voltage_sensor_supply: 5.0 V
                    Reductant_voltage_sensor_gnd: 0.0 V
                    Reductant_level_sensor_actual_raw_voltage: 3.1 V
                    KL15 on: On
                    DIAG_Opt_H: On
                    Tank_L_SC: OFF
                    Lines_L_SC: OFF
                    DIAG_Lines_H: On
                    DIAG_Lines_L: On
                    DIAG_Tank_H: On
                    DIAG_Tank_L: On
                    MO_SCR_Dosierpumpe_Zustand: 00
                    MO_SCR_Tankheizung: OFF
                    MO_SCR_Leitungsheizung: OFF
                    MO_SCR_Transferpumpe: OFF
                    reserviert 1 0: On
                    Reserviert 2: OFF
                    Can signal MO_SCR_Dosierpumpe_Soll: 0.0 %
End----------(Elapsed Time: 01:40, VBatt start/end: 12.2V/12.2V)-----------
RyMar
South Africa
C?ID=133909
As per Elsa diagram wiring checked. Fault code cannot be erased, comes back after start up. Will connect battery charger and rerun scan and post.
Gone But Not Forgotten
Either pump is faulty, wiring or ECU, did you simulate sensors/pump with decade box to verify wiring & ECU will vacate the DTC & did you measure resistance of pump?
FUSES?
Ground connections?
RyMar
South Africa
C?ID=133909
Also think pump or ECU? Don’t have a decade box. Not allowed to buy any type of equipment from VW/Audi in South Africa. Will need to source equipment overseas and import. No function on VCDS to activate pump. The contr unit is part of the pump (pump) inside reductant tank! Will have to remove the contr unit/pump from the tank (draining tank), and then disconnect pump to check resistance.
A decade box is just a variable resistor/capacitance etc. and can be bought as a generic tool, it doesn't have to be bought from VAG.
Example.......not endorsed!
https://www.ebay.com/itm/323759943469
