Skoda Octavia lost its coding after pump and module change
hussain.ali15
C?ID=373132
Hi guys,
So my friend's car now has a similar problem to mine. His brake pedal kept sinking to the floor so after some diagnostics, we changed his abs pump and module. Problem is, I didn't take any coding before doing so *duh* and now the car's lost its coding for the ABS module and the dashboard has lit up like a Christmas tree.
Can anyone help me with the coding? I attached the autoscan below:
Thanks in advance.
Tuesday,10,September,2019,22:04:19:61881
VIN: TMBBJ7NE0F0039103   License Plate: FL64 ZFC
Mileage: 351649km-218504mi   Repair Order:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: TMBBJ7NE0F0039103   Mileage: 351649km-218504miles
Address 01: Engine (J623-CKFC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 7544
   Revision: 83H22---
   Coding: 11190012030501090000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM20TDI01104L906021DS 002012
   ROD: EV_ECM20TDI01104L906021DS_002.rod
   VCID: 79AFEDF9D956495F8D7-802C
18111 - Oxygen (Lambda) Sensor B1 S1
          P2237 00 [237] - Pump Current Open Circuit
                    Mileage: 351649 km
                    Date: 2019.09.02
                    Time: 04:23:25
                    Engine speed: 889.50 /min
                    Normed load value: 44.7 %
                    Vehicle speed: 16 km/h
                    Coolant temperature: 81 °C
                    Intake air temperature: 72 °C
                    Voltage terminal 30: 14.120 V
                    Oxyg.sens.bank 1 before oxi cat: sign. qual. pump curr.regul.: 14
                    Oxyg.sensor bank 1 before oxi cat: signal quality temp regulat.: 6
                    O2 sen. bank 1 upstrm oxi cat: elec. correct. pump current: 0.0000000 A
                    Oxygen sensor bank 1 before oxi cat: heater activation: 0.000 %
                    O2 sen. bank 1 upstrm oxi cat: elec. corrected Urie sen. value: 0.3754 V
                    Oxygen sensor bank 1 before oxi cat: adjustable resistor: 85.3 Ohm
                    Oxyg.sensor bank 1 before oxi cat: curr.pump curr.adaptation: 1.0000
13865 - Coolant Pump for Intercooler
          P023A 00 [175] - Open Circuit
                    Mileage: 351648 km
                    Date: 2019.09.02
                    Time: 04:19:39
                    Engine speed: 769.50 /min
                    Coolant temperature: 78 °C
                    Intake air temperature: 65 °C
                    Air mass at air mass meter 1: 25.5 kg/h
                    Extern.temp.sens.1 bank 1: raw value: 21.5 °C
                    Intake air temperature before throttle valve: calculated: 0.0 K
                    Heater supp.pump 1 bank 1 charg.air cool.circuit: activat.: 95.00 %
          U0428 00 [032] - -
                    Mileage: 351648 km
                    Date: 2019.09.02
                    Time: 00:19:48
                    Engine speed: 891.00 /min
                    Normed load value: 24.3 %
                    Coolant temperature: 46 °C
                    Intake air temperature: 42 °C
                    Voltage terminal 30: 12.220 V
Readiness: 1 2 0 0 0
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 61854000002397
   Shop #: WSC 00049 770 00107
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
   VCID: 44D14C0DEE14C4B7AE1-8010
10 Faults Found:
0195 - Control module not coded
          U1013 00 [137] - -
          [ECU marked as Not Configured because vehicle ID is invalid]
                    Reset counter: 50
                    Date: 2019.09.11
                    Time: 09:31:46
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 50
                    Date: 2019.09.11
                    Time: 09:31:46
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 50
                    Date: 2019.09.11
                    Time: 09:31:46
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 50
                    Date: 2019.09.11
                    Time: 09:31:46
0295 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 50
                    Date: 2019.09.11
                    Time: 09:31:46
4161 - Coding invalid
          U10DA 00 [008] - -
          [mismatch between VIN on CAN and VIN in coding word]
                    Reset counter: 50
                    Mileage: 351649 km
                    Date: 2019.09.11
                    Time: 09:45:15
8278 - Control Module Incorrectly Coded
          U1014 00 [137] - -
          [FCAN: Mismatch between bytecoding and Lenkerposition signal]
                    Reset counter: 50
                    Date: 2019.09.11
                    Time: 09:31:46
8290 - Coding Not Possible
          U10BC 00 [137] - -
          [FCAN: Unplausible VIN number]
                    Reset counter: 50
                    Mileage: 351648 km
                    Date: 2019.09.11
                    Time: 09:31:51
8306 - Databus
          U1122 00 [137] - Implausible Message
                    Reset counter: 50
                    Mileage: 351648 km
                    Date: 2019.09.11
                    Time: 09:31:51
8308 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
                    Reset counter: 50
                    Date: 2019.09.11
                    Time: 09:31:46
   Part No SW: 5E0 907 044 K    HW: 5E0 907 044 K
   Component: Climatronic   H03 0907
   Revision: 00001K06
   Coding: 01110104000100011005000000101000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   VCID: 2D0709A95D9E25FF51F-8078
   Air quality sensor:
263425 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Reset counter: 88
                    Mileage: 283658 km
                    Date: 2018.09.29
                    Time: 10:20:06
                    Voltage terminal 30: 12.2 V
                    Outside air temperature: 12.5 °C
                    System run time-Engine running time: 24 s
                    System run time-Terminal 15 on: 25 s
   Part No SW: 5Q0 937 084 AG    HW: 5Q0 937 084 AG
   Component: BCM MQBAB M   H18 0134
   Serial number: 01011416100610
   Coding: 0F000842424700DB07A04082B10407280000000000000000000000000000
   Shop #: WSC 73430 790 00000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7DA7F9E9CD7E757FA1F-8028
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 140603  041 0570
   Serial number:         140606170247
   Coding: 065DDD
   Subsystem 2 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY1409701W7
   Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Serial number: 00000000000029588947
   Subsystem 4 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Component: G355_FeuchteS  H07 0002
   Serial number: 20775739
204290 - Remote key 1
          B1479 18 [008] - Current Too Low
                    Fault Frequency: 21
                    Reset counter: 76
                    Mileage: 320999 km
                    Date: 2019.04.06
                    Time: 09:15:57
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 D    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0048
   Revision: --------    Serial number: 39231417801925
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14AU3700000 002022
   VCID: 3A2D32F59CD08247C4D-806E
13637426 - Databus
                    Reset counter: 50
                    Mileage: 350800 km
                    Date: 2019.08.09
                    Time: 00:35:57
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0189
   Revision: --------    Serial number: 003P4PBPZ83A
   Coding: 98CCC000000000005C5400CC008800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F5B03E1C772676FB33-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 001 306 14
   Serial number: 3576U0000004186C3F0E
   Subsystem 2 - Part No SW: -----------    HW: 454 001 306 14
   Serial number: 3586U000000FFA010018
   Subsystem 3 - Part No SW: -----------    HW: 454 802 406 14
   Serial number: 3516R2576F303000000/
   Subsystem 4 - Part No SW: -----------    HW: 454 802 506 14
   Serial number: 3526R380EF0030000000
   Subsystem 5 - Part No SW: -----------    HW: 454 801 905 14
   Serial number: 3556VF4CF9C03000000Y
          B13BC F2 [137] - No function
                    Mileage: 351644 km
                    Date: 2019.09.02
                    Time: 00:04:37
   Part No SW: 5Q0 953 507 AB    HW: 5Q0 953 549
   Revision: --------    Serial number: 25061404221019
   Coding: 0600
   VCID: 76B5E6C5E8482627E05-8022
   Part No SW: 5E0 920 941     HW: 5E0 920 941
   Component: KOMBI         204 4290
   Coding: 27A402002180A60001082A001000000000000000
   VCID: 6393AF914BDAA38FB7B-8036
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 50
                    Mileage: 351644 km
                    Date: 2019.09.02
                    Time: 00:04:27
   Part No SW: 5Q0 907 530 R    HW: 5Q0 907 530 D
   Component: GW MQB Low    126 1188
   Revision: --------    Serial number: 0002184428
   Coding: 030000040F087300EF000248080F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011016
   ROD: EV_GatewLear_011.rod
   VCID: 40D9401DFA0CD8978A9-8014
   Subsystem 2 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Serial number: 4804203703
131602 - Power Steering Control Module
          U101D 00 [008] - No Communication
          [Timeout Knoten 0x12 / 44 - Steuergerät für Lenkhilfe]
                    Reset counter: 83
                    Mileage: 341366 km
                    Date: 2019.06.28
                    Time: 12:06:02
                    Supply voltage: Terminal 30: 12.8 V
                    Terminal 15: OFF
   Part No SW: 5Q4 959 393 B    HW: 5Q4 959 393 B
   Component: TSG FS        009 0014
   Serial number: 0000108584197
   Coding: 001000208001040000001100
   VCID: 42DD4A15F400CA879CD-8016
   Serial number: 00000000000003056276
   Coding: 1D0200
   Component: EPS_MQB_ZFLS  122 1043
   Coding: 8102
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DF4519F106D19F857-8014
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Reset counter: 90
                    Mileage: 351644 km
                    Date: 2019.09.02
                    Time: 00:06:15
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 11.75 V
                    Temperature: 22.0 °C
                    KFC: 4B
                    KFA: 00 04
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 11.88 V
                    uAdSensI_SwitchedKl30_xdu16: 11.89 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
   Part No SW: 5Q4 959 392 B    HW: 5Q4 959 392 B
   Component: TSG BFS       009 0014
   Serial number: 0000108550810
   Serial number: 00000000000003057237
   Coding: 050200
Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-STD1.clb
   Part No SW: 5E0 035 842 A    HW: 5E0 035 842 A
   Component: MU-S-D-ER     041 0435
   Serial number: S7E02806141408
   Coding: 03730100FF0000001111120100A800002F0000860100010002
   Shop #: WSC 73430 790 00063
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 211FE5991146F19FE57-8074
   Subsystem 1 - Part No SW: 5E0 919 605 B    HW: 5E0 919 605 B
   Component: ABT_Std_Plus  H50 0022
   Serial number: SKZ8Z9PK601974
0528 - Rear Left Treble Speaker
          B1066 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 4: Unterbrechung]
                    Reset counter: 224
                    Mileage: 280847 km
                    Date: 2018.09.16
                    Time: 13:24:13
                    Voltage terminal 30: 12.6 V
          U1111 00 [009] - -
          [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 50
                    Mileage: 351644 km
                    Date: 2019.09.02
                    Time: 00:04:28
                    Voltage terminal 30: 12.1 V
                    BAP-BAP_Function_ID: 02
7206 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 50
                    Mileage: 351644 km
                    Date: 2019.09.02
                    Time: 00:04:28
End----------(Elapsed Time: 01:25, VBatt start/end: 12.4V/12.3V)-----------
hussain.ali15
C?ID=373132
Unfortunately not. He got his diagnostics done using a different diagnostic scanner. I got asked to take a look after the coding was lost.
hussain.ali15
C?ID=373132
Yep. He said he tried plugging the old parts back in but it made no difference.
hussain.ali15
C?ID=373132
Decided to try plugging the old module back in once more and what do you know, coding was present. Copied and pasted into the module and everything spot on now. Thank you.
morski
Cheshire UK
C?ID=90186
Lesson learnt.. And always do an autoscan and save save save!!
hussain.ali15
C?ID=373132
No longer have the car with me but the correct coding was:
1A078A91242309750078060041C6245851249000608224F000630070C002
in case that helps.
