Door locking issue GTI mk7
ernesst
Texas
C?ID=373830
Hello, new to the forum and VCDS.
I tends to have lock and unlock door issue on the driver door, for the past days I was not able to unlock the door with the remote. Tonight playing with the central lock button on the internal trim helps, then I was able to unlock the door with the following sequence (Push unlock, then push lock, then push unlock) in a repeatable manner with the remote.
My autoscan result give me several errors :
Wednesday,11,September,2019,02:31:34:04572
VIN: 3VW4T7AUXFM008869   License Plate:
Mileage: 41250km-25632mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F 75 A9
VIN: 3VW4T7AUXFM008869   Mileage: 41250km-25631miles
Address 01: Engine (J623-CNTA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0004
   Revision: --H13---
   Coding: 091D00124424000F0000
   Shop #: WSC 00066 790 00224
   ASAM Dataset: EV_ECM20TFS0205G0906259A 001006
   ROD: EV_ECM20TFS0205G0906259A.rod
   VCID: 2C010484568A2AA7461-8078
Readiness: 1010 1101
   Part No SW: 0D9 300 040 S    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H52 4315
   Revision: 05852204    Serial number: TFK01403310368
   Shop #: WSC 00066 790 07031
   ROD: EV_TCMDQ250021.rod
   VCID: 270BFBA84F6C09FFAB3-8072
21153 - Gear 1
          P072C 00 [002] - Not Selectable
21159 - Gear R
          P072B 00 [002] - Not Selectable
10731 - Valve 3 in Transmission Part 1
          P174A 00 [002] - Electrical malfunction
10657 - RPM Signal from ECU
          P0726 00 [002] - Implausible Signal
10906 - Cooling Oil Valve
          P179D 00 [002] - Electrical Malfunction
          P1734 00 [002] - -
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 51344000000311
   Coding: 01FA6BA134200974007F020681CC2980D62C9000408194B400430050C009
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033_VW37.rod
   VCID: 44D14C24DE1AC2E7AE1-8010
   Part No SW: 5G0 907 426 N    HW: 5G0 907 426 N
   Component: AC Manuell    H01 0705
   Revision: 00001K06
   Coding: 00020004200100000000000000000000
   VCID: 363526EC98C66077205-8062
   Part No SW: 5Q0 937 087 K    HW: 5Q0 937 087 K
   Component: BCM PQ37BOSCH 026 0097
   Revision: --------    Serial number: 86580905141371
   Coding: 000018464041804969E44000001407201000000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
   ROD: EV_BCMBOSCH_012.rod
   VCID: 43D34F38DB14C5DF97B-8016
   Component: WWS    140330  043 0581
   Serial number:         140610073753
                    Fault Frequency: 8
                    Reset counter: 25
                    Mileage: 41219 km
                    Date: 2019.09.08
                    Time: 21:23:02
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM009W8R
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 51FF75701168274F157-8004
   Occupant Detection:
   Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
   Component: BF-Gewichtss.  H05 0016
   Serial number: IBH0000J140000UVEB0R
   Coding: 30325A
   Subsystem 2 - Part No SW: -----------    HW: 480 000 504 14
   Serial number: 35700000000E34BC9F0/
   Subsystem 3 - Part No SW: -----------    HW: 480 000 504 14
   Serial number: 35800000000FE62C9F03
   Subsystem 4 - Part No SW: -----------    HW: 480 401 504 14
   Serial number: 35100029D157E9D5C14I
   Subsystem 5 - Part No SW: -----------    HW: 480 401 704 14
   Serial number: 3520002C1157E9D302C5
   Subsystem 6 - Part No SW: -----------    HW: 480 402 104 14
   Serial number: 3550002AD157E99182DL
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 104 14
   Serial number: 3560002AD157E993A32G
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0155
   Revision: FF028028    Serial number: 20140426500283
   Coding: 0410
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FDB43C8B7FCA13FF33-806A
617752 - Selector Lever Park Position Lock Switch
          B1162 29 [008] - Signal Implausible
                    Reset counter: 25
                    Mileage: 41240 km
                    Date: 2019.09.10
                    Time: 18:10:00
                    Ubat 30 Voltage: 13.70 V
                    Ignition State: On
                    Terminal 15: 12.90 V
                    A/D #1: 0.00 %
                    A/D #2: 0.00 %
                    A/D #3: 0.00 %
   Part No SW: 5G6 920 970 C    HW: 5G6 920 970 C
   Component: KOMBI         316 2210
   Coding: 0BBD090A2180CF0502086A00000000
   Shop #: WSC 00066 790 00201
   VCID: 303910F47AA24E477A9-8064
   Part No SW: 5Q0 907 530 P    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2163
   Revision: --------    Serial number: 16021410001206
   Coding: 0101000820085900EF000028180F00000001000000000000000000000000
   ASAM Dataset: EV_GatewConti 010015
   ROD: EV_GatewConti_010.rod
   VCID: 3E253ECCB0F6A837F85-806A
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H06 0101
   Serial number: 29140000106890044145
   Coding: 29FFFF
   Serial number: 240514060501L3
   Coding: 003E03200000040000000000
   VCID: 40D94034CA02DEC78A9-8014
   Serial number: 00000000000002499248
   Coding: 011000
65593 - Switch for Central Locking
          B122D 29 [008] - Signal Implausible
                    Fault Frequency: 32
                    Reset counter: 25
                    Mileage: 41229 km
                    Date: 2019.09.09
                    Time: 18:26:15
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8102
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 353721E085C06B6F29F-8060
   Serial number: 1605140605037K
   Serial number: 00000000000002591878
   Coding: 191000
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     013 0645
   Serial number: V7B00305142805
   Coding: 02730000FF00000021220001001800001F0203040100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 6491ACA47EDAA2E74E1-8030
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9PS5005CU
          B11CF 53 [009] - Deactivated
                    Reset counter: 236
                    Mileage: 41219 km
                    Date: 2019.09.08
                    Time: 21:20:32
                    Voltage terminal 30: 13.5 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
   Part No SW: 5QE 035 285     HW: 5QE 035 285
   Component: OCULowMQBUS   006 0528
   Coding: 02730002C2821A017F1E06000000
   ROD: EV_OCULowMQB.rod
   VCID: 025D8A3C848E0CD7DCD-8056
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 240
   Component: SAS-GEN 2     H06 0013
   Serial number: 140329200598
   VCID: 6B83C7989304ED9F0FB-803E
End----------(Elapsed Time: 01:01, VBatt start/end: 13.8V/13.8V)-----------
They are minor error : Satellite radio, car seat, one maybe related to the recent recall regarding to the P switch position and the "Switch for Central Locking - Signal Implausible"
I found this topic : https://forums.ross-tech.com/showthread.php?14221-Golf-7-window-regulator with the same error but not much info.
I'm trying to figure out where is this Switch for Central Locking, from my understanding seems to be in the door latch system, is this statement correct ?
Tonight, i've checked / pushed back some of the electrical connections : Door latch, J386 box, door to car frame, seems better however I still do have this fault (even after a clear). This week-end i'll try to check better the wiring.
Any though ?
Ernesst.
^^ here's a cut-down version of how the driver side door module and the central locking unit are wired together. Of course you car may not have a SAFELOCK feature (extra motor) - but I suggest that you pay particular attention to the integrity of the wires, connectors for the switches.
PS: and in answer to your first question - the central locking system is integrated into the door lock
ernesst
Texas
C?ID=373830
Thanks DV52 for your answer and the diagram.
My car is US so i believe it's not equipped with a SAFELOCK system.
So far what i've done yesterday improved the situation but not the scan.
darkchina811
ITALY
C?ID=333184
as a side note, it looks like all Golfs come out of the factory with the SAFE option, wired and ready to go (they probably manufacture just one version of the door lock). it's not coded out if you didn't buy the car with the OEM alarm system. now, I don't know if the SAFE thing would work without retrofitting the whole alarm.
I really doubt that's true of NAR models. They've historically not had the mechanical bits necessary for the SAFE function because that function is not allowed by the USA's FMVSS (Federal Motor Vehicle Safety Standards). The way I understand it, doors must be able to be opened from the inside no matter what, even with a total electrical failure.
darkchina811
ITALY
C?ID=333184
oops, somehow I always forget this NAR / ROW separation. I was speaking for european cars.
Yep, and the OP is in Texas, so I think we must assume his car is NAR. :)
PS: Stuff like this is why I'm fairly insistent that participant here has a location in their profile.
Uwe: isn't it odd (well...... I think that's it's odd) that a facility in (almost?) every other place on this fragile blue planet where this feature is touted as enhancing passenger SAFEty - is viewed as quite the opposite in America. Clearly the sage folk @ FMVSS are streets ahead of their counterparts elsewhere - or maybe not :facepalm:
Well, it's an enhancement if it prevents car-jackings, which I believe was the original intent of this feature, but after an accident, if it prevents you from exiting the vehicle, not so much...
Westbury, UK
The crash signal from the airbag ECU is 'supposed' to unlock all the doors even if they are SAFE locked.
Yeah, I know it's supposed to do that. But whoever wrote the FMVSS regulations here apparently doesn't trust that this will happen. ;)
And I can sort of understand that. Personally, I don't care to have my doors locked at all while driving, unless I'm in a sketchy neighborhood.
Westbury, UK
Before I retired I used to drive through many sketchy neighbourhoods so I was very happy that my doors SAFE locked automatically when I reached around 5mph :cool:
ernesst
Texas
C?ID=373830
I'm not sure how i configured my profile but I didn't got any notifications.
Bit late on this topic, my wife delivered the last days :)
My issue is still back and forth...
I noticed that when I the driver door doesn't unlock electrically and unlock manually from inside then the electrical lock/unlock features works fine until the next stop. I'm thinking that error code tends to be the correct one and the microswitch got "stuck" sometime.
I'll still check with the ohm meter the cable, what do you think about the spray to clean electrical connections ?
The SAFE locked automatically when above 5 mph is different that the Rest of World SAFELOCK I believe ?
Yes my car is a North America.... BTW strange that my GTI is less equipped than the golf 1.2 tsi of my parents in France ...
