- Jun 13, 2019
- 42
- 20
- Birmingham, UK
- C?ID=368132
hello all,
this vehicle was in a front end crash, now repaired the bodywork side.
the gears used to crank when i first tried to drive it, i then followed the procedure on ross tech wiki for basic settings etc and now selects gear smooth as should when driving it.
today i tried driving at full throttle kick down and the gear struggled to move from d2 unless i let go of the peddle.
clutch 1 clearence too small came back on scan after a drive.
im thinking would this problem with gear changing at full throttle have anything to do with the intake manifold fault?
any help please, thanks in advance
Tuesday,10,September,2019,20:52:14:58999
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8V5EA018154 License Plate: AA11
Mileage: 183339km-113921mi Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 55 5F BB BC
VIN: WAUZZZ8V5EA018154 Mileage: 183339km-113921miles
Address 01: Engine (J623-CJSA) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 B HW: 06K 907 425 A
Component: 1.8l R4 TFSI H09 0003
Revision: --H09---
Coding: 0A2500122404010B2000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM18TFS0218V0906264B 001003
ROD: EV_ECM18TFS0218V0906264B.rod
VCID: 3B23367733EBC7AFDFB-806E
15197 - Intake Manifold Flap Position Sensor (Bank 1)
P2014 00 [175] - Electrical Malfunction
Mileage: 183334 km
Date: 2019.03.31
Time: 07:05:37
Engine speed: 0.00 /min
Coolant temperature: 80 °C
Intake air temperature: 54 °C
Voltage terminal 30: 11.894 V
Engine: operating status: ES
STATE_LS_SAE[1]: INI
T_AST_SAE: 0 s
MAP_MES_SAE: 100 kPa
Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.070 V
FAC_TPS_1_SAE: 15.234375 %
FUP_H_SAE: 12780.0 kPa
14925 - Crankshaft Position Sensor (G28)
P0335 00 [237] - Malfunction
Mileage: 183334 km
Date: 2019.03.31
Time: 07:06:00
Engine speed: 335.00 /min
Voltage terminal 30: 10.566 V
N_TOOTH: 0 /min
STATE_CRK_STST: CRK_STST_PAS
T_AST_SAE: 0 s
TOIL: 86 °C
T_ES: 29 min
T_ES_DC: 4 min
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 045 P HW: 0AM 927 769 G
Component: GSG DQ200-MQB H43 5240
Revision: 00043014 Serial number: CU501306106143
Shop #: WSC 17734 418 534600
ROD: EV_TCMDQ200021_VW31.rod
VCID: 46D5578378298A47B05-8012
10817 - Clutch 1
P189A 00 [072] - Clearance too Small
Mileage: 183334 km
Date: 2019.03.31
Time: 07:07:33
Engine speed: 5125.75 /min
Engine torque: 32 Nm
Vehicle speed: 96 km/h
Control Module temperature: 88 °C
CURRENT pressure: -5.5 bar
Driving position: d
Accelerator position: 0.0 %
DTC memory status: 47616
Part No SW: 5Q0 907 379 AA HW: 5Q0 907 379 G
Component: ESC H31 0457
Revision: 00000000 Serial number: 616030000007A5
Coding: 12F18AA234212A740178060541C72948512C5480608294F4004100080508
VCID: 7BA3F677736B07AF9FB-802E
8296 - Databus
U1123 00 [136] - Received Error Message
[FCAN: MO_QBit_Drehzahl_01 signal is invalid]
Reset counter: 145
Mileage: 183334 km
Date: 2019.03.31
Time: 07:06:00
32865 - Databus
[IPB_BUS: Motor_12 / MO_Drehzahl_01]
Reset counter: 145
Date: 2019.03.22
Time: 05:17:11
32928 - Function Restricted due to Insufficient Voltage
U1400 00 [136] - -
[IPB: Supply Voltage below undervoltage threshold]
Reset counter: 145
Part No SW: 8V0 820 043 HW: 8V0 820 043
Component: AC Automat H13 0031
Revision: 20021000 Serial number: 00000000100271
Coding: 03100004000000011000000000001100
ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
VCID: 6FBBD22737136B0F233-803A
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 51C803B6000000000001
262658 - High Pressure Sensor
B10AE 31 [009] - No Signal
Reset counter: 105
Mileage: 183334 km
Date: 2019.03.31
Time: 07:03:56
Outside air temperature: 20 °C
Temperature after evaporator: 32.4 °C
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011316902014
Coding: 07001A42C24120DD03844004B31C07A80000000000000000000000000000
ROD: EV_BCMBOSCH_011.rod
VCID: 77ABEA474F4323CFFB3-8022
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 130604 041 0580
Serial number: 130606193909
Coding: 0A47F7
Subsystem 2 - Part No SW: 8V0 941 531 J HW: 8V0 941 531 J
Serial number: 17 04 2013 00001354
Subsystem 3 - Part No SW: 000 000 000 HW: 000 000 000
000 0000
Serial number: 000000000ZY131470KSR
Serial number: 00000000000057027438
Subsystem 5 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20405299
264462 - Sensor for anti-theft alarm system
B1330 01 [009] - Electrical Failure
Reset counter: 105
Mileage: 183334 km
Date: 2019.03.31
Time: 07:03:56
Part No SW: 5Q0 959 655 N HW: 5Q0 959 655 N
Component: AirbagVW20 011 0361
Serial number: 003M2R01Z2Y/
Coding: 98CCC0000C0000005C5400CA00C800000065
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 4BC366B7634B772F6FB-801E
Subsystem 1 - Part No SW: ----------- HW: 480 000 706 13
Serial number: 357670000005059C4D0X
Subsystem 2 - Part No SW: ----------- HW: 480 000 706 13
Serial number: 35867000000A6A6D5D06
Subsystem 3 - Part No SW: ----------- HW: 480 400 806 13
Serial number: 3516502C9105EDC3810E
Subsystem 4 - Part No SW: ----------- HW: 480 400 806 13
Serial number: 3526502AB10CBDF5108O
Subsystem 5 - Part No SW: ----------- HW: -----------
Component: FrontSensor_D --- ----
Serial number: -------------------$
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: -----------
Component: PedP_Sensor_D --- ----
Subsystem 7 - Part No SW: ----------- HW: -----------
Component: PedP_Sensor_P --- ----
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: -----------
Component: PedP_Sensor_C --- ----
8 Faults Found:
B1006 1B [137] - Resistance Too High
Mileage: 183334 km
Date: 2019.03.31
Time: 07:03:57
9439003 - Igniter for Seat Belt Tensioner; Passenger's Side
B1007 1B [137] - Resistance Too High
Mileage: 183334 km
Date: 2019.03.31
Time: 07:03:57
9451547 - Igniter 1 for pedestrian protection
B1038 1B [137] - Resistance Too High
Mileage: 183334 km
Date: 2019.03.31
Time: 07:03:57
9451803 - Igniter 2 for pedestrian protection
B1039 1B [137] - Resistance Too High
Mileage: 183334 km
Date: 2019.03.31
Time: 07:03:57
9443861 - Driver's Front Airbag Crash Sensor
B101A 15 [137] - Open or Short to Plus
Mileage: 183334 km
Date: 2019.03.31
Time: 07:04:00
9450005 - Pedestrian Protection Crash Sensor (driver's side)
B1032 15 [137] - Open or Short to Plus
Mileage: 183334 km
Date: 2019.03.31
Time: 07:04:00
9450261 - Pedestrian Protection Crash Sensor (passenger's side)
B1033 15 [137] - Open or Short to Plus
Mileage: 183334 km
Date: 2019.03.31
Time: 07:04:00
9496853 - Front Crash Sensor for Pedestrian Protection
B10E9 15 [137] - Open or Short to Plus
Mileage: 183334 km
Date: 2019.03.31
Time: 07:04:00
Part No SW: 8V0 953 521 HW: 5Q0 953 549 A
Revision: -------- Serial number: 13061308491672
Coding: 8418
Part No SW: 8V0 920 970 M HW: 8V0 920 970 M
Component: KOMBI H03 2210
Coding: 278409082A8046000100E800000000
Part No SW: 5Q0 907 530 M HW: 5Q0 907 530 F
Component: GW MQB High 125 1144
Revision: -------- Serial number: 0000681526
Coding: 030100042B085A005B0002481C0B00000001000000000000000000000000
ROD: EV_GatewLear_009.rod
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 10 06 2013 C0278982
Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
Component: J367-BDM H08 0192
Serial number: 00000000004051571089
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS 012 0006
Serial number: 07061301100140
Coding: 00108E204001040000001002
VCID: 3FDB426727F3DB8FF33-806A
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 81
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D27386F2DFFC99FE1F-8068
22532 - Databus
[MOTOR_12 Botschaft - SNA-Check]
Reset counter: 145
Mileage: 183334 km
Date: 2019.03.31
Time: 07:06:01
Motor status: 03
System status: Driving mode
Supply voltage: 11.50 V
Temperature: 44.0 °C
KFC: 58
KFA: 00 04
Environmental conditions: 25
uAdSensI_U5VFiltered_xdu16: 5.08308 V
uioUdNotFilt_xdu16: 11.75 V
uAdSensI_SwitchedKl30_xdu16: 11.74 V
ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS 012 0006
Serial number: 02061301100160
Coding: 001086204001040000001002
VCID: 3E253F6320F9D287F85-806A
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0070
Coding: 019C000001000000
VCID: 75B7E04F554F51DFE9F-8020
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-HGH1.clb
Part No SW: 8V0 035 020 B HW: 8V0 035 020
Component: MU-H-ND-EU H41 0171
Serial number: A305F0DB001162
Coding: 01730301FF00000021111101000A00002F00010701000100DE
ASAM Dataset: EV_MUHig4CHBAS 001040
ROD: EV_MUHig4CHBAS_AU37.rod
VCID: 2A0D0333CC714E27B4D-807E
Subsystem 1 - Part No SW: V03 959 800 PP HW: -----------
Component: ECE 2013/2014 --- 0062
Subsystem 2 - Part No SW: 8V0 919 604 A HW: 8V0 919 604 A
Component: DU High H48 0013
Serial number: AUZ8Z9DG50079B
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 H HW: 8V0 919 614 D
Component: ControlUnit_H H64 0764
Serial number: C1000028051300020121
Compact Disc Database:
Component: Gracenote --- 1008
0518 - Front Right Treble Speaker
B1064 13 [009] - Open Circuit
[Hochtonlautsprecher Kanal 2: Unterbrechung]
Reset counter: 105
Mileage: 183334 km
Date: 2019.03.31
Time: 07:04:00
Voltage terminal 30: 12.1 V
0523 - Front Left Treble Speaker
B1061 13 [009] - Open Circuit
[Hochtonlautsprecher Kanal 3: Unterbrechung]
Reset counter: 105
Mileage: 183334 km
Date: 2019.03.31
Time: 07:04:00
1024 - Interface for External Media Devices (MEDIA-IN)
B1288 13 [009] - Open Circuit
Reset counter: 105
Mileage: 183334 km
Date: 2019.03.31
Time: 07:03:58
Part No SW: 5Q0 959 595 A HW: 5Q0 959 595
Component: TSG HFS 010 0006
Serial number: 09061303110460
Coding: 000086204001040000001002
VCID: 41DF449F5107AD7F857-8014
Component: TSG HBFS 010 0006
Serial number: 09061302090471
End----------(Elapsed Time: 01:29, VBatt start/end: 12.5V/12.3V)-----------
