Confused newb with some questions
samstar
Michigan, USA
C?ID=367987
Hi All,
Glad to be here finally after thinking about getting this software for a few years!
I have bought a Hex-V2 and have downloaded the newest VCDS software (19.6.1?) from the RT website. I have also updated the firmware and registered with RT. So hopefully, I'm good to start using VCDS and the Hex-V2.
My questions are:
1. Why are some boxes not available to me in the VCDS software. For example, there are 4 boxes for 'Engine' under 'drivetrain' but I can only click on 01-Engine - the others throw up a ' not found' message. Similarly, 'measuring blocks' using 01-engine is not available to me ???
2. The videos in the Wiki (e.g. for Throttle Body Alignment) show a much older software version of VCDS. As such, when I try and do the same steps using the current software, they look nothing alike. In the video, the very first step in the TB alignment shows 01-Engine / measuring blocks. I do not have the same pages . For example, there are no group boxes anywhere? So how do I check the battery voltage first - measuring value block group 004 ? Since measuring blocks are not available (as above), how and where do I enter values in group boxes ???
3. How can I find out my engine variant? My car is a 2018 Audi S5 coupe. UDS is displayed in the comm status box so therefore I presume my car uses the UDS protocol?
4. How do I code to release the rear electronic brake so I can change the rear rotors and pads?
5. Ditto for headlight adjustment - I need to raise them. Is there a page with coding on the forums or the wiki?
Thanks in advance. I hope this thread is in the right place.
samstar
Michigan, USA
C?ID=367987
here's my scan
Tuesday,10,September,2019,16:40:41:43858
Chassis Type: FR-AU48 (8R0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 22 36 42 44 46 47 52 53 56
          5F 6C A9
VIN: WAUCGAFR3DA018672   Mileage: 83300km-51760miles
Address 01: Engine (J623-CGXC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 E    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIX07 0002
   Revision: --X07---
   Coding: 1A250034052600060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551E 001002
   ROD: EV_ECM30TFS0218K5907551E.rod
   VCID: 3829297072D93EE7329-806C
6323 - MAP/MAF <-> Throttle Position Correlation
          P0068 00 [047] - -
                    Mileage: 83244 km
                    Date: 2019.09.06
                    Time: 20:09:16
                    Engine speed: 700.00 /min
                    Normed load value: 14.5 %
                    Coolant temperature: 93 °C
                    Intake air temperature: 52 °C
                    Voltage terminal 30: 12.898 V
                    Engine speed: actual: 704 /min
                    MAP_1_ENVD: 376.77148 hPa
                    MAP_2_ENVD: 382.07813 hPa
                    TPS_ENVD: 4.7 %
                    Ignition angle: actual: -0.375 °
                    RFP_AV_ENVD: 55.3937
6307 - MAP/MAF <-> Throttle Position Correlation
          P0068 00 [175] - -
                    Mileage: 83244 km
                    Date: 2019.09.06
                    Time: 20:09:16
                    Engine speed: 702.00 /min
                    MAP_2_ENVD: 376.77148 hPa
                    PDT_ENVD: 371.46484 hPa
                    AMP_ENVD: 981.7285 hPa
Readiness: 0000 0100
   Part No SW: 8K2 927 156 M    HW: 0B5 927 156 J
   Component: 0B5 30TFSINAR H01 0004
   Revision: --H01---
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501021 001010
   ROD: EV_TCMDL501021.rod
   VCID: 40D941902A0976278A9-8014
   Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
   Component: ESP8 quattro  H09 0100
   Coding: 291D1A
   VCID: 04518D807E11AA07EE1-8050
   Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM
   Component: BCM2 2.0      H11 0621
   Coding: 0D804000000000000000
   VCID: 015F84946103BF2FC57-8054
   Serial number: 2312000156798013
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
   Component: MEM-BFS       H10 0076
   Revision: AA000000    Serial number: 00000034056350
   Coding: 00037025002C00000000
   VCID: 45D7508435AB530FB9F-8010
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01190720120724
   Coding: 6602228000
   VCID: 392F2C74495327EFCD7-806C
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000451570602
   Coding: 2600C011873CAFE0210048C300003D0D0F9CD388A2090221000008004000030100000030000000
   Shop #: WSC 12345 123 61029
   VCID: 78A9E97032D9FEE7F29-802C
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 200712  H15 0080
   Serial number: SWF12070200161
   Coding: 00FD11
   Serial number: 20436550
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001207120115
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R2AZV02
   Serial number: 4EA88C36000000000001
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Serial number: 003KJD90GHU+
   Coding: 303343334830303030304A55304C38543053
   VCID: 4ACD63B81C35BC7754D-801E
   Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
   Component: BF-Gewichtss.  H02 0060
   Serial number: 5810000R1200009FX2
   Serial number: 6334MSME6F020565C
   Serial number: 6344MSME6E11001B8
   Serial number: 6352QSME211C1B62D
   Serial number: 6362QSME1B1C1D44P
   Serial number: 63732SME091A3F543
   Serial number: 63832SME601C2146W
   Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
   Component: Lenks.Modul   H07 0171
   Revision: 00000000    Serial number: 20120724000657
   Coding: 000036
   VCID: 51FF74D4F1E38FAF157-8004
   Component: E221 - MFL  H03 0003
   Part No SW: 8T0 920 983 P    HW: 8T0 920 983 P
   Component: KOMBIINSTR.   H35 0553
   Revision: 00000000    Serial number: RAU74PE7D
   Coding: 8BBF01008301D705020000
   VCID: 4BC366BC13CFA57F6FB-801E
   Part No SW: 8R0 907 468 H    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0051
   Revision: 1Y050025    Serial number: 2541Y12712035A
   Coding: 80C303FF00
   VCID: 44D14D803E916A07AE1-8010
   Serial number: 4215187801
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H13 0100
   Serial number: 000907120001016
   VCID: 2F3B122C8797F95F633-807A
   Component: MEM-FS        H10 0076
   Revision: AA000000    Serial number: 00000034153105
   Coding: 001B7B25002C00000000
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0304
   Coding: 011C13224E00120102
   VCID: 56F587C8D80DE897C05-8002
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0009710662
   Coding: 100000010001
   Shop #: WSC 06324 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 34311D406EB1DA871E1-8060
   Revision: 00002001    Serial number: 0180568859
   Coding: 0106069A00FA400582B0003200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000546624
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H03 0220
   Revision: 00005001    Serial number: 94813004795402
   VCID: 2D0708248D1B8B4F51F-8078
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0304
   VCID: 55F780C4C50BE38FC9F-8000
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 20000000118260
   ROD: EV_ParkiBrake_AU48.rod
   Part No SW: 4G0 035 082 D    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0112
   Revision: AB001007    Serial number: 156GY0C7616313
   Coding: 020007010000000001
   VCID: 211FE414C1C35F2FE57-8074
   Part No SW: 8R1 035 746 B    HW: 8R1 035 746 B
   Component: H-BNT-NA      H43 0552
   Revision: --------    Serial number: 204GW0C7513753
   Coding: 140200020206A1EF45028B4E00000403140000000000000000
   VCID: 36352748784DC897205-8062
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130GK0C2503128
   Subsystem 3 - Part No SW: 8T0 919 611 C    HW: 8T0 919 611 C
   Component: E0380 Bedient  H02 0020
   Serial number: 00000001222804
   Subsystem 4 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
   Revision: --H07---    Serial number: 525PA8-J2592MV
   Coding: 1000008
   VCID: 382929707E593EE7329-806C
Address A9: Struct. Borne Sound        Labels: 4H0-907-159.clb
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   ROD: EV_SoundActuaGen2AU64X_002.rod
   VCID: 72BDDB58542594B7CCD-8026
End----------(Elapsed Time: 02:21, VBatt start/end: 12.9V/14.1V)-----------
Bruce
Near Philadelphia, PA, USA
Welcome to the forum. Let's see if I can be of some help.
Boxes not available to you are items that are not installed in your car. Not much sense showing stuff that is not there. Will likely confuse the issues.
Right. Your car is using all UDS functionality. When you go to Basic Settings or to Adaptations, there are drop down boxes with the information and procedures. You did take a look at the online manual - right?
Correct. Your car uses UDS. The engine code is normally stamped on the engine itself. Someone posted a photo of that... hmm.. where is it... I can't find it at the moment... perhaps others will come along to help.
samstar
Michigan, USA
C?ID=367987
Thanks for the quick reply Bruce
Noted on the shaded out boxes - just wanted to make sure it wasn't a fault
UDS - got it. I didn't see the online manual - thanks that's helpful. I do have some PDFs from various audi forums with help on how to do things but this manual should help a great deal.
Thanks for the engine variant code also.
So do the drop down boxes in the new VCDS software take the place of the measuring block group numbers in the older version ?
Yes, pretty much.
On your engine, TBA should be this Basic Setting:
IDE00754 -- Test of throttle valve adaptation
However, I doubt this will cure the MAP/MAF <-> Throttle Position Correlation faults.
As for the EPB, have a look here:
http://wiki.ross-tech.com/wiki/index.php/Audi_A4_(8R/8K)_Parking_Brake_EPB-4
Headlight adjustment: Since your car doesn't have a separate headlight range module, I believe this page is applicable:
http://wiki.ross-tech.com/wiki/inde...ngs_in_BCM1/09-Cent._Elect._(J519)_controller
samstar
Michigan, USA
C?ID=367987
Yes, pretty much.
Thanks for the info.
I'm going to take the MAP sensors off and clean them. I'm also going to clean out the TB. I'm hoping that will do the job? If not, what else should I look at?
Thanks for the EPB and the Headlight links.
Excellent help and service on this forum guys, I must say
At that point, I would be looking at actual MAP and MAF values to see if they're reasonable. Something somewhere is slightly out of whack; not enough for the ECU to decide the sensor is bad, but enough to throw off a cross-check of readings.
samstar
Michigan, USA
C?ID=367987
Do you suggest just getting new sensors?
If not, how do I determine what the MAP values should be (there's no MAF in this car) - I don't have repair manual?
grant@gendan
With the engine off the MAP should read atmospheric pressure (you can look this value up online for where you are located). This is a good starting check.
When idling the pressure usually drops below atmospheric pressure.
samstar
Michigan, USA
C?ID=367987
Great - thanks. I'll try that first
