Centr. Electr. II faults. What's this stuff mean!
carboncow
Central Ohio
C?ID=266014
2011 JSW SE 2.5L
While chasing some HVAC gremlins (AC intermittent, solenoid fix installed, then it didn't work for a month...now it works even when switched off!). Did a scan an finally got the scan off the laptop. Mentions one fault in circuit intermittent and another about the module incorrectly coded. Now although I have a VCDS I have never tried custom codes on this ride. I noted the fault stamps were 1.10.2014 which is prior to my ownership too...so maybe another coded.
How does one identify these concerns (primarily the coding comment) and find the correct code? I'm assuming Cent Elect II is a who list of functionality from pano roof to wipers from what I can tell? Can someone educate me to Cent Elec II?
Monday,09,September,2019,19:24:57:39593
VCDS Version: 19.6.1.0  HEX-NET CB: 0.4508.4
[URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL]
VIN: 3VWPZ7AJ5BM612681   License Plate:
Mileage: 202720km-125964mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
VIN: 3VWPZ7AJ5BM612681   Mileage: 202720km-125964miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 BE    HW: 07K 906 055
   Component: 2,5l R5/4V      G01 9213
   Revision: T4H04---    Serial number:
   Coding: 0000075
   Shop #: WSC 08151 444 84507
   VCID: 72A8117A6D3588DF9F-8026
   Part No SW: 09G 927 750 LM    HW: 09G 927 750 LM
   Component: AQ 250 6F           1734
   Revision: 00H90000    Serial number:
   Coding: 0000840
   Shop #: WSC 00066 000 00000
   VCID: 075E50AE76B79D77D8-8052
   Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
   Component: ESP MK60EC1   H30 0106
   Revision: 00H30001
   Coding: 114B400C492300FC881102EC921A0041B70000
   VCID: 74A41762D72186EF8D-8020
02214 - Tire Pressure Warning
                    Reset counter: 239
                    Mileage: 201917 km
                    Date: 2014.01.18
                    Time: 21:08:34
                    Count: 32768
                    Count: 4608
                    Count: 16401
                    Count: 50946
                    Count: 511
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Revision: 00009001
   Coding: 0000001002
   Shop #: WSC 00066 000 00146
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 75A22A66D45B9FE7BA-8020
   Part No SW: 5K0 937 084 E    HW: 5K0 937 084 E
   Component: BCM PQ35 B    011 0035
   Revision: BG011001
   Coding: 2D380E1F902F3EC400080081600000C401000086435D8D60648020000040
   VCID: 3424D76297A1C6EF4D-8060
   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 29071  21  0512
   Coding: 009795
Address 15: Airbags
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90440JFE000BG
   Coding: 188A140000
   Shop #: WSC 00066 000 00186
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 76A02D6AC95D94FFB3-8022
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0002241
   Coding: 820000
   Part No SW: 5K0 920 971 B    HW: 5K0 920 971 B
   Component: KOMBI         H03 0406
   Coding: 270F01
   VCID: 2E10C50A718DEC3F3B-807A
   Part No SW: 7N0 907 530 A    HW: 1K0 907 951
   Component: J533  Gateway   H25 5603
   Revision:   H25       Serial number: 03081001200958
   Coding: ED807F0600160300002002
   Shop #: WSC 00066 123 12345
   VCID: 2E10C50AB98DEC3F3B-807A
   Part No SW: 5N0 919 879     HW: 5N0 919 879
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1225223R99HH06
   Coding: 0000002
   VCID: 7EB0354A296DDCBFEB-802A
   Component: IMMO          H03 0406
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A98091A8DE5401F27-803E
   Part No SW: 3C0 959 701 B    HW: 3C0 959 793
   Component: TUER-SG FT    002 0307
   Revision: 13101005    Serial number: 0001235618
   Coding: 0004B5
   Shop #: WSC 01383 790 50316
   ROD: EV_DCU42BroseDriveSide_VW36.rod
   VCID: 271E302E5E77BD77F8-8072
   Slave Driver:
   Subsystem 1 - Part No SW: 1K0 959 703 AH    HW: 1K0 959 795 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1401
   Serial number: 00000005011784
   Coding: 000490
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 312ADE76A8B3F3C726-8064
   Component: EZE_2         H25 5603
   Coding: 000B0500
   VCID: 6FAE180EBE07A53770-803A
02071 - Local Databus
                    Fault Status: 00101100
                    Reset counter: 244
                    Mileage: 201104 km
                    Date: 2014.01.10
                    Time: 20:20:02
                    Fault Frequency: 12
                    Reset counter: 210
                    Mileage: 201103 km
                    Date: 2014.01.10
                    Time: 07:40:59
   Part No SW: 3C0 959 702 B    HW: 3C0 959 792
   Component: TUER-SG BT    002 0307
   Revision: 15101005    Serial number: 0001230716
   Coding: 0004B4
   ROD: EV_DCU52BrosePasseSide_VW32.rod
   VCID: 281C33125369B20FF1-807C
   Slave Passenger:
   Subsystem 1 - Part No SW: 1K0 959 704 AH    HW: 1K0 959 794 T  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 1401
   Serial number: 00000005027190
   Coding: 000490
   Part No SW: 6RD 035 187 B    HW: 6RD 035 187 B
   Component: MIB2-S-R-CN   036 0317
   Revision: -----001    Serial number: VWZ6Z2Q7005543
   Coding: 1700040004000A
   Shop #: WSC 00081 790 00117
   VCID: 46C09DAAF13D447FE3-8012
                    Reset counter: 73
                    Mileage: 190529 km
                    Date: 2013.08.26
                    Time: 07:45:38
00856 - Radio Antenna
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 142
                    Mileage: 179714 km
                    Date: 2013.04.26
                    Time: 07:52:04
                    Reset counter: 18
                    Mileage: 151271 km
                    Date: 2012.08.04
                    Time: 21:11:44
                    Reset counter: 142
                    Mileage: 179714 km
                    Date: 2013.04.26
                    Time: 07:52:04
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668217051
   Coding: 0A00000000010100
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 3228D17A65B5C8DF5F-8066
          B104F 13 [009] - Short to GND
                    Reset counter: 210
                    Mileage: 170325 km
                    Date: 2018.09.09
                    Time: 18:03:06
          B104E 13 [009] - Short to GND
                    Reset counter: 15
                    Mileage: 170325 km
                    Date: 2018.09.09
                    Time: 18:03:06
End----------(Elapsed Time: 01:19, VBatt start/end: 12.2V/12.1V)-----------
DrPeter
16.4905° S, 151.7375° W
QA
It would appear that the [Address 4F: Centr. Electr. II (J520)] is not coded correctly for the equipment this vehicle has installed as per the VIN.
[P75] = "Panoramic sunroof & 17-inch alloy wheelspackage"
You should have a coding value of [050B0500] for the [4F], that is for the Panoramic sunroof/blind. Unless someone has sealed it up and preventing it from opening due to water leaks.
The J520-Vehicle Electrical System Control Module 2 is part of the J533-Vehicle Electrical System Control Module and is primarily responsible for the following:
J245-Power Sunroof Control Motor (with V1-Sunroof Motor)
J394 Roof Blind Control Module (with V260-Sunroof Blind Motor)
Please see the Volkswagen Self Study Program 892803-The 2009 Jetta SportWagen for more information about the J520 and a whole lot more.
Your Auto-Scan is missing the information in the Address 4F: Centr. Electr. II (J520)
Subsystem 1 - Part No SW: 8R0 959 591 A
and
Subsystem 2 - Part No SW: 8R0 959 591 A
Was there any work to the Panoramic sunroof or any of it's components?
Hope this helps,
drpeter
carboncow
Central Ohio
C?ID=266014
and
Hope this helps,
drpeter
Pano roof works fine and the sunshade did work til...
I think you might be onto something. The panoramic roof blind self ejected last month and I have it in the full open position now and cut out the train wreck that self destructed. You think one of the sensors tossed a code and may have extended past a stop?
It does mention wrong coding too...prob why you asked about previous work. The code will not reset.
I thought I've seen in other examples the error actually mention pano roof.
I'll do some reading on your link later and check the coding.
carboncow
Central Ohio
C?ID=266014
and
Hope this helps,
drpeter
Looks like that self study guide is for people more important than me...is a subscription service? I see no option to create an account to login?
DrPeter
You will need to Register and then subscribe(purchase) access to the repair information, then you can view and save that document.
Pro-tip!! I would dedicate the time to grab ALL the documents I could during the subscription period! You can save (or print) wiring diagrams, component location, workshop repair manuals as pdf files not only for this vehicle but for other Volkswagen vehicles up to current models.
erWin Online Registration
drpeter
DrPeter
I just wanted to add, you can can re-coded the [4F] controller and then clear ALL the fault codes and see what comes back.
By the way, the other control module's coding looks okay.
Also, if you could, post up a new Auto-Scan after the codes cleared, this would help others in the future.
Thanks,
drpeter
raf0468
C?ID=120244
address 15 airbags can not be reached..?
NostraJackAss
DrPeter
If you have a look at the Auto-Scan's Gateway installation List, you can see the Gateway does report the Airbag controller was [OK] at the time the information was gathered.
So it would appear for what ever reason VCDS did not establish communication with this controller during the actual Auto-Scan, another scan would be a good test, ;)
drpeter
NostraJackAss
I used to rely on this method of checking the installation list too, but found that is not always the truth & FOD can be lurking!
You are probably right here Peter & because the other modules's are not complaining of no 0x15.......
