How can i adapt an steering gear from an audi s3 to tt8s ???
nafg
Peru
C?ID=305294
i have an audi tt 8s that i have replace the steering gear with one from an audi s3, how can i adapt this.
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 42 44 47 52 55 5F A9
VIN: TRUZZZFV1F1003700   Mileage: 8063km-5010miles
Address 01: Engine (J623-CHHC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8S0 906 259     HW: 06K 907 425 B
   Revision: --H13---
   Coding: 0A1D00324406010B3002
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208S0906259 001003
   ROD: EV_ECM20TFS0208S0906259.rod
   VCID: 7AAEFB7D5C532CF784D-802E
20277 - Terminal 15 Voltage
          P151B 00 [032] - Implausible
   Part No SW: 0D9 300 012 E    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4504
   Revision: 05853104    Serial number: TFK01408310100
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 186AC1F5421FDEE7129-804C
21222 - Steering Column Control Module
          U0212 00 [011] - No Communications
                    Mileage: 6630 km
                    Date: 2017.12.18
                    Time: 10:50:05
   Part No SW: 8S0 907 379 B    HW: 8S0 907 379 B
   Component: ESC           H31 0504
   Revision: 00000000    Serial number: 62654000000153
   Coding: 32AA608D0A9915AC4098006442918306444C0650A8020042C16022
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 052008
   ROD: EV_Brake1UDSContiMK100IPB_052.rod
   VCID: 40DA49957A0FB6278A9-8014
0295 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 244
                    Date: 2017.12.18
                    Time: 10:51:28
8277 - Databus
          [FCAN: EPS_DSR_Status signal is invalid]
                    Reset counter: 244
                    Date: 2017.12.18
                    Time: 10:51:28
          C1146 02 [137] - Signal Failure
                    Reset counter: 244
                    Mileage: 6630 km
                    Date: 2017.12.18
                    Time: 10:51:37
32951 - Control Module for Electronic Parking Brake
          C10E2 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 244
                    Date: 2017.12.18
                    Time: 10:51:28
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0522
   Revision: 00023000    Serial number: 0346499341
   Coding: 000F0F1720
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   VCID: 77A8E2496F41319FFB3-8022
   Part No SW: 8S0 820 043     HW: 8S0 820 043
   Component: AC Automat    H05 0020
   Revision: 20008000    Serial number: 89300000003403
   Coding: 400040140011141000
   ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
   ROD: EV_AirCondiVAPrehAU33x.rod
   VCID: 6C82CD2526078247061-8038
   Serial number: 19C84C47000000000001
   Operating and display unit 2 for air conditioning:
   Subsystem 2 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
   Component: E775 BuA_2  H06 0010
   Serial number: 00000000000000000683
   Operating and display unit 3 for air conditioning:
   Subsystem 3 - Part No SW: 8S0 820 359     HW: 8S0 820 359
   Component: E776 BuA_3  H06 0010
   Operating and display unit 4 for air conditioning:
   Subsystem 4 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
   Component: E777 BuA_4  H06 0010
   Part No SW: 5Q0 937 084 BR    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0136
   Serial number: 01011426700426
   Coding: 04055C42C20106FD03044004B31807A80080000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 094C94B109B5376F9D7-805C
   Subsystem 1 - Part No SW: 8S1 955 119 A    HW: 8K1 955 119 B  Labels: 5QX-955-119-V1.CLB
   Component: 43x LL 140605  032 0371
   Serial number: 00000001406030704791
   Coding: 1BC7F7
   Serial number: 23251043
   Coding: 00005D
   Serial number: 30 07 2014  00000638
   Subsystem 4 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY142170415
   Serial number: 00000000000060629435
197904 - Central Locking
          B140A 4B [008] - Over temperature
                    Reset counter: 167
                    Mileage: 7846 km
                    Date: 2019.08.17
                    Time: 08:11:03
267030 - Siren / Alarm Horn for Anti-Theft Alarm System
          U1137 00 [008] - Implausible Message
          [Sirene-DWA->unplausible Botschaft]
                    Reset counter: 174
787462 - Relay for Headlight Washer System
          B1262 15 [009] - Open or Short to Plus
                    Reset counter: 52
                    Mileage: 7128 km
                    Date: 2018.04.21
                    Time: 17:35:55
   Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0051
   Revision: --------    Serial number: 39331426803488
   Coding: 0070051051
   VCID: 42DE439D7403A4379CD-8016
13637426 - Databus
                    Reset counter: 242
                    Mileage: 6630 km
                    Date: 2017.12.17
                    Time: 16:26:00
   Part No SW: 5Q0 959 655 P    HW: 5Q0 959 655 P
   Component: AirbagVW20    009 0870
   Serial number: 003M7R002Z9J
   Coding: 88CCC000008000005C000000004800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4DC460A1BD5D6B4F71F-8018
   Subsystem 1 - Part No SW: -----------    HW: 480 002 909 14
   Serial number: 357000000006A7B8F01U
   Subsystem 2 - Part No SW: -----------    HW: 480 002 909 14
   Serial number: 35800000000FA7B8F01/
   Subsystem 3 - Part No SW: -----------    HW: 480 012 708 14
   Component: SideSensor_Dr  004 0108
   Serial number: 351001A01544A6C35E53
   Subsystem 4 - Part No SW: -----------    HW: -----------
   Component: FrontSensor_D  --- ----
   Serial number: -------------------$
   Front Sensor Passenger:
   Subsystem 5 - Part No SW: -----------    HW: -----------
   Component: FrontSensor_P  --- ----
20 Faults Found:
9437201 - Igniter for Driver's Airbag
          B1000 11 [136] - Short to Ground
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:34:00
9437713 - Igniter for Passenger's Airbag
          B1002 11 [137] - Short to Ground
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:45
9438481 - Igniter for Driver head airbag
          B1005 11 [136] - Short to Ground
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:45
9438225 - Igniter for Front passenger's Head Curtain Airbag
          B1004 11 [136] - Short to Ground
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:45
9439002 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 1A [137] - Resistance Too Low
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:45
          B1000 1B [137] - Resistance Too High
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:45
          B1006 1B [137] - Resistance Too High
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:45
9438491 - Igniter for Driver head airbag
          B1005 1B [137] - Resistance Too High
                    Fault Frequency: 13
                    Mileage: 6232 km
                    Date: 2015.07.31
                    Time: 00:01:12
9438235 - Igniter for Front passenger's Head Curtain Airbag
          B1004 1B [137] - Resistance Too High
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:59
9442587 - Igniter for battery interrupt
          B1015 1B [137] - Resistance Too High
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:45
9443093 - Driver's Side Airbag Crash Sensor
          B1017 15 [136] - Open or Short to Plus
                    Mileage: 6232 km
                    Date: 2015.08.22
                    Time: 00:00:34
9451029 - Crash sensor side airbag; passenger side
          B1036 15 [136] - Open or Short to Plus
                    Mileage: 6232 km
                    Date: 2015.08.22
                    Time: 00:00:34
9443857 - Driver's Front Airbag Crash Sensor
          B101A 11 [137] - Short to Ground
                    Mileage: 6232 km
                    Date: 2015.07.31
                    Time: 03:13:13
9443861 - Driver's Front Airbag Crash Sensor
          B101A 15 [137] - Open or Short to Plus
                    Mileage: 6232 km
                    Date: 2015.07.31
                    Time: 00:01:21
9444117 - Front Passenger's Front Airbag Crash Sensor
          B101B 15 [137] - Open or Short to Plus
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:46
          B13BC F2 [008] - No function
                    Mileage: 6232 km
                    Date: 2015.07.31
                    Time: 00:01:25
          U1101 00 [008] - Active
          [ATP Wrong IKA]
                    Mileage: 6232 km
                    Date: 2015.07.31
                    Time: 00:52:45
9466352 - Crash Data from Belt Tensioner Stored
          B1071 F0 [137] - Unknown Error Elaboration
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:38
9447424 - Front crash data stored
          B1028 00 [137] - -
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:38
16712515 - Internal Control Module Memory Check Sum Error
          B2000 00 [137] - -
          [Electronic Control Unit Malfunction]
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:40
   Part No SW: 8S0 907 129 R    HW: 8S0 907 129 R
   Component: Lenks. Modul  H06 0140
   Revision: --------    Serial number: 91335NJ300038
   Coding: 0018
   ASAM Dataset: EV_SMLSKLOMQB 019002
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 49CC54B14935776F5D7-801C
   Part No SW: 8S0 920 790     HW: 8S0 920 790
   Component: FBenRDW       H32 0221
   Coding: 04050050298000080520A8809000800000000000
   ASAM Dataset: EV_DashBoardBOSCHAU33X 001013
   ROD: EV_DashBoardBOSCHAU33X.rod
   VCID: 76B6EF4D684B4897E05-8022
   Part No SW: 8S0 907 468     HW: 8S0 907 468
   Component: GW MQB TT3    012 0184
   Revision: --------    Serial number: 06091410801350
   Coding: 030100042F025A004B0002683C0000000000000000000000000000000001
   ASAM Dataset: EV_GatewContiAU33X 011002
   ROD: EV_GatewContiAU33X_011.rod
   VCID: 7DA4F0614D7D1BCFA1F-8028
   Subsystem 2 - Part No SW: 8S0 951 523 C    HW: 8S0 951 523 C
   Component: J453 MFL  H06 0001
   Serial number: 20140821124851 RD001
   Subsystem 3 - Part No SW: 8S0 915 181 A    HW: 8S0 915 181 A
   Serial number: 0326444303
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7742
   Serial number: HA1-00010.08.14
   Coding: 0101
   VCID: 45D45881652D930FB9F-8010
   Serial number: 14000140131006
   Coding: 0900000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BCDC5101256FAF357-8024
   Serial number: 20091402090270
   Coding: 001F46225C00040100001402
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 0002
   Shop #: WSC 06314 790 00021
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3534284135CD038F29F-8060
15873 - Steering angle sensor
                    Reset counter: 244
                    Mileage: 6630 km
                    Date: 2017.12.18
                    Time: 10:37:42
                    Motor status: 00
                    Supply voltage: 12.50 V
                    Temperature: 37.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Environmental conditions: 5B
                    uioUdNotFilt_xdu16: 12.63 V
                    uAdSensI_SwitchedKl30_xdu16: 12.64 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
   Part No SW: 8S0 035 465     HW: 8S0 035 465
   Component: MIB2_amp_P_TT H06 0170
   Revision: 00000001    Serial number: AUZ8ZAEH7001BV.
   Coding: 0133040000AA2A2AAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2ALPI 001012
   ROD: EV_AMPMst16C1Gen2ALPI_AU37.rod
   VCID: 72BED35D042354B7CCD-8026
0605 - Double Bass Speaker 2; Front Right
          B1348 13 [008] - Open Circuit
                    Fault Frequency: 9
                    Reset counter: 188
                    Voltage terminal 30: 12.4 V
0600 - Double Bass Speaker 1; Front Right
          B1346 13 [008] - Open Circuit
                    Reset counter: 188
                    Mileage: 7061 km
                    Date: 2018.03.30
                    Time: 22:05:25
   Serial number: 21091406071734
   Coding: 001F46225E00040100001402
   VCID: 41DC4C917105BF2F857-8014
   Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0090
   Coding: 03EA001E2B200200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005008
   VCID: 333016593BB91DBF07B-8066
   Coding: E01800
   Coding: E01800
   Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 S002
   Coding: E01800
   Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 S002
   Coding: E01800
13705992 - Databus
          [Empfangener Fehlerwert im Signal LWI_Lenkradwinkel: CAN Message LWI_01]
                    Reset counter: 244
                    Mileage: 6630 km
                    Date: 2017.12.18
                    Time: 10:50:34
5276209 - Power Output Module for Right Headlamp
          C1082 31 [008] - No Signal
                    Reset counter: 154
                    Mileage: 7712 km
                    Date: 2019.07.30
                    Time: 11:50:41
   Part No SW: 8S0 035 028     HW: 8S0 035 028
   Component: MU-H-N-ER     H33 0117
   Serial number: A262I0E7507099
   Coding: 013304000000000011220002001800002F0000E0000000001A
   VCID: 6D84C0211D1D8B4F11F-8038
   Multimedia Operating Unit:
   Subsystem 1 - Part No SW: 8S0 919 614 A    HW: 8S0 919 614 A
   Component: ControlUnit_H  H21 0124
   Serial number: C1000015081400010077
   Compact Disc Database:
   Subsystem 2 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote  --- 1010
   Part No SW: 8S0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0002
   Serial number: 140904203546
End----(Elapsed Time: 01:38, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
South Molton, UK
Impossible to answer until you post a full unedited VCDS Auto-Scan :popcorn:
Moved to Retrofits.
nafg
Peru
C?ID=305294
any advice ?
morski
Cheshire UK
C?ID=90186
My question is: but why? Why not get the correct steering for your car in the first place?
nafg
Peru
C?ID=305294
here its the FULL Auto-Scan
Thursday,12,September,2019,10:00:10:51026
VIN: TRUZZZFV1F1003700   License Plate:
   Revision: --H13---
                    Mileage: 6630 km
                    Date: 2017.12.18
                    Time: 10:50:05
                    Reset counter: 244
                    Date: 2017.12.18
                    Time: 10:51:28
8277 - Databus
                    Reset counter: 244
                    Date: 2017.12.18
                    Time: 10:51:28
                    Reset counter: 244
                    Mileage: 6630 km
                    Date: 2017.12.18
                    Time: 10:51:37
                    Reset counter: 244
                    Date: 2017.12.18
                    Time: 10:51:28
   Coding: 000F0F1720
   Coding: 1BC7F7
   Coding: 00005D
                    Reset counter: 167
                    Mileage: 7846 km
                    Date: 2019.08.17
                    Time: 08:11:03
                    Reset counter: 174
                    Reset counter: 52
                    Mileage: 7128 km
                    Date: 2018.04.21
                    Time: 17:35:55
   Coding: 0070051051
13637426 - Databus
                    Reset counter: 242
                    Mileage: 6630 km
                    Date: 2017.12.17
                    Time: 16:26:00
20 Faults Found:
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:34:00
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:45
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:45
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:45
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:45
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:45
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:45
                    Fault Frequency: 13
                    Mileage: 6232 km
                    Date: 2015.07.31
                    Time: 00:01:12
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:59
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:45
                    Mileage: 6232 km
                    Date: 2015.08.22
                    Time: 00:00:34
                    Mileage: 6232 km
                    Date: 2015.08.22
                    Time: 00:00:34
                    Mileage: 6232 km
                    Date: 2015.07.31
                    Time: 03:13:13
                    Mileage: 6232 km
                    Date: 2015.07.31
                    Time: 00:01:21
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:46
                    Mileage: 6232 km
                    Date: 2015.07.31
                    Time: 00:01:25
          [ATP Wrong IKA]
                    Mileage: 6232 km
                    Date: 2015.07.31
                    Time: 00:52:45
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:38
          B1028 00 [137] - -
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:38
          B2000 00 [137] - -
                    Mileage: 6234 km
                    Date: 2015.07.19
                    Time: 04:32:40
   Coding: 0018
   Coding: 0101
   Coding: 0002
                    Reset counter: 244
                    Mileage: 6630 km
                    Date: 2017.12.18
                    Time: 10:37:42
                    Motor status: 00
                    KFC: 3E
                    KFA: 00 01
          B1348 13 [009] - Open Circuit
                    Reset counter: 149
          B1346 13 [009] - Open Circuit
                    Reset counter: 149
                    Mileage: 7061 km
                    Date: 2018.03.30
                    Time: 22:05:25
   Coding: E01800
   Coding: E01800
   Coding: E01800
   Coding: E01800
13705992 - Databus
                    Reset counter: 244
                    Mileage: 6630 km
                    Date: 2017.12.18
                    Time: 10:50:34
                    Reset counter: 154
                    Mileage: 7712 km
                    Date: 2019.07.30
                    Time: 11:50:41
in Select Chassis opción there is not my chassis 8S
morski
Cheshire UK
C?ID=90186
The car has obviously been in a collision so you need to get the other faults cleared as well; mainly the steering angle sensor. Get that calibrated. Easy enough to do!
What module are you in when looking for chassis 8S?
Was the original steering rack too damaged to remove its attached ecu?
