How to enable Auto-dimming Mirror on USA Arteon SE?
SDarteon
C?ID=53880
A few of us over at VW Vortex have been trying to enable the drivers side auto-dimming mirror, which is not standard on the SE model.
This is what we have discovered:
a. the actual dimming mirror IS fitted
b. The wiring to the mirror is in place and the colors correspond to the dimming function Y20 in the VW wiring diagram
c. One person has an SE model where the dimming function does work.
d. Comparing the long coding of address 42, byte 9 we found that:
00345B42800020000000000 is the long coding without auto-dimming enabled (my car)
00345B428000020000010000 is the long coding with the auto-dimming feature working.
This corresponds to byte 9 bit 0=1 "electro chromatic mirror active"
When I enable this bit on my car, it does not cause the mirror glass to darken.
When I use VCDS to run an output test IDE10164-automatic day/night exterior mirror - I get the status "not running", however, when I use VCDS to look at the advanced measuring values, I see
automatic day/night mirror-status - active
automatic day/night mirror- dimming 30%
I check the mirror glass and there is no sign of dimming. I block off the interior mirror sensor and the interior mirror goes black, but nothing on the drivers side.
So it appears that there is an additional step or steps needed?
Does anyone know what are the dependencies between modules? If the door mirrors are using sensor information from the interior mirror, what coding or adaption needs to be made/checked.
Here is a full scan of my vehicle with byte 9 bit 1 =1.
Any help would be most appreciated or clues for us to help solve this apparent mystery:o
Sunday,08,September,2019,14:47:52:42457
VIN: WVWBR7AN5KE000387   License Plate:
Mileage: 6010km-3734mi   Repair Order: mirrorautodim question
Chassis Type: AN-VW48 (3Q0)
Scan: 01 02 03 05 08 09 13 14 15 17 19 22 2B 3C 42 44 4B 52 5F 65
          6C 6D BB BC CF D6 D7
VIN: WVWBR7AN5KE000387   Mileage: 6010km-3734miles
Address 01: Engine (J623-DLRB)       Labels: None
   Part No SW: 3G0 906 259 G    HW: 06K 907 425 J
   Component: R4 2.0l TFSI  H13 0004
   Revision: --H13---
   Coding: 092A00122426010E3004
   Shop #: WSC 05311 115 00175
   ASAM Dataset: EV_ECM20TFS0203G0906259G 001006
   ROD: EV_ECM20TFS0203G0906259G.rod
   VCID: 303911285AA90E177A9-8064
Readiness: 1110 0101
   Part No SW: 09G 927 158 L    HW: 09G 927 158
   Component: AISIN AQ8     206 3504
   Coding: 0000000100000000000000000000000000000000
   Shop #: WSC 05311 000 00030
   ROD: EV_TCMAQ450031_VW48.rod
   VCID: 3C21351886E1FA77D61-8068
   Part No SW: 5Q0 614 517 DD    HW: 5Q0 614 517 AC
   Component: ESC           H25 0424
   Revision: 00000000    Serial number: 60338000000026
   Coding: 0DFA6B9A5420236CC57A0308A0CA69B0D62AC4A3C0059674104150884289420B00000012121212B835351919323200
   Shop #: WSC 00015 115 08193
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 76B5E730F84D6027E05-8022
   Part No SW: 3Q0 959 435 J    HW: 3Q0 959 435 J
   Component: VWKESSYMQB    037 1104
   Revision: 00037000    Serial number: 0477916684
   Coding: 132C0C0723
   Shop #: WSC 05311 115 00311
   ASAM Dataset: EV_KessyHellaMQBAB 004043
   ROD: EV_KessyHellaMQBAB_VW48.rod
   VCID: 41DF44ECE103979F857-8014
   Part No SW: 5G0 907 044 EG    HW: 5G0 907 044 EG
   Component: Climatronic   H04 2009
   Revision: 00001K10
   Coding: 1402000420011000101500009210180A
   ASAM Dataset: EV_ACClimaBHBVW37X 006148
   VCID: 70B9D1289A294E173A9-8024
   Air quality sensor:
   Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: 865827041801ME
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7BA3F604C36F3D4F9FB-802E
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    180510  042 0607
   Serial number:         180525161633
   Component: RLHS  052 0107
   Serial number: S2Y18M06D18H23M51S23
   Coding: 01E8DD
   Subsystem 3 - Part No SW: 3G0 941 633 N    HW: 3G0 941 633 N
   Serial number: 27 07 2018  10000644
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 521 AS    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0160
   Serial number: 0100150620180C100825
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 3204009111FFC728949C810400401600000000000000000004
   ROD: EV_ACCBOSCHVW416_002_VW48.rod
   VCID: 44D14DF8FE1182B7AE1-8010
   Part No SW: 5Q0 907 376 C    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0130
   Serial number: 30051841351007
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 392F2C0C89D3CF5FCD7-806C
   Part No SW: 3Q0 959 655 CK    HW: 3Q0 959 655 CK
   Component: Airbag VW21   006 0711
   Revision: --------    Serial number: 003WTP789TT%
   Coding: 9DCCFCC00C0000005000001AC20840000065
   Shop #: WSC 05311 000 08193
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 094F9CCC99B31FDF9D7-805C
   Occupant Detection:
   Component: Occ.Detection  H13 0022
   Serial number: IBH0000J180008ZPNZ0S
   Coding: 303030
   Subsystem 2 - Part No SW: -----------    HW: 454 000 406 18
   Serial number: 35700000000442848F2J
   Subsystem 3 - Part No SW: -----------    HW: 454 000 406 18
   Serial number: 3580000000059865303C
   Subsystem 4 - Part No SW: -----------    HW: 454 800 406 18
   Serial number: 351005BCDF914000000-
   Subsystem 5 - Part No SW: -----------    HW: 454 800 306 18
   Serial number: 352002B4805150000003
   Subsystem 6 - Part No SW: -----------    HW: 454 802 205 18
   Serial number: 355003179B1140000007
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 454 802 205 18
   Component: FrontSensor_P  304 0149
   Serial number: 356003887B914000000M
   Pedestrian Protection Driver:
   Subsystem 8 - Part No SW: -----------    HW: 454 801 704 18
   Component: PedP_Sensor_D  30D 014A
   Serial number: 2280036ED0714000000H
   Subsystem 9 - Part No SW: -----------    HW: 454 801 704 18
   Component: PedP_Sensor_P  30D 014A
   Serial number: 229007ECE0614000000S
   Pedestrian Protection Center:
   Subsystem 10 - Part No SW: -----------    HW: 454 801 704 18
   Component: PedP_Sensor_C  30D 014A
   Serial number: 23000A2EE0714000000E
   Subsystem 11 - Part No SW: -----------    HW: 454 002 605 18
   Component: PedP_Sens_D_2  008 0887
   Serial number: I0M00000000DD4797F2O
   Subsystem 12 - Part No SW: -----------    HW: 454 002 605 18
   Component: PedP_Sens_P_2  008 0887
   Serial number: I0N00000000621E8BF2E
   Part No SW: 3G5 920 850 A    HW: 3G5 920 850 A
   Component: KOMBI         311 2500
   Coding: 03B4109DBA88CF0502802B0D10000000A0000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009065
   VCID: 2809F948627946D7A29-807C
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   439 4344
   Revision: --------    Serial number: 0007954250
   Coding: 030300047F085900FB0002489C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF.rod
   VCID: 3D27381C9DFBF37FE1F-8068
   Subsystem 2 - Part No SW: 5G0 959 442 AA    HW: 5G0 959 442 AA  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0052
   Serial number: 39170002880120117526
   Coding: 28FFFF
   Serial number: 75886000001806160E79
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: HA1-00023.05.18
   Coding: 0301
   VCID: 4CC165D8D6414AF7661-8018
   Serial number: 18000196761016
   Coding: 0800000000000000
   Shop #: WSC 05311 115 00065
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 33331E24ABBF350F07B-8066
   Part No SW: 3Q0 907 566 G    HW: 3Q0 907 566
   Component: MRR1Rear      H23 0530
   Revision: --------
   Coding: 040000
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007QKG1825C
   Coding: 00345B428000020000010000
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 818028 00
   Coding: 0100001000C00110
   Shop #: WSC 00015 115 00311
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
   VCID: 2B030644738F6DCF4FB-807E
   Component: FCM MQB Low   002 0342
   Serial number: 24041810523638
   Coding: 000000070900045206210100030000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002004
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 3537203CA5CB2B3F29F-8060
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007RD525388
   Coding: 003453428000020000010000
   VCID: 43D34EE4FB1F858F97B-8016
   Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
   Component: MU-S-S-US     722 0870
   Coding: 02840300FF00000051220001001808001F0500C40120050002
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 2E050F50409D18E7685-807A
   Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
   Component: ABT_Std-2  H52 8130
   Serial number: VWZ6ZJV1601841
          B11CF 53 [009] - Deactivated
                    Reset counter: 213
                    Mileage: 6010 km
                    Date: 2019.09.06
                    Time: 14:47:29
                    Voltage terminal 30: 12.2 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Audio Signal: Not available
                    SDARS_tuner_status_2-Antenna current: 113 mA
                    SDARS_tuner_status_2-Reception quality: weak_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
   Serial number: 40000000167307
   ROD: EV_RDKBERU30_006_VW48.rod
   VCID: 34311D38AEB132371E1-8060
   Coding: 0184030160002017300040
   Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0261
   Revision: --------    Serial number: 31972635200000
   Coding: 0B28
   Shop #: WSC 17873 123 50804
   VCID: 42DD4BE0E4058C879CD-8016
   Part No SW: 8W1 959 595 D    HW: 8W1 959 595 D
   Component: TSG HFS002 0187
   Serial number: YE007RDD0365D
   Coding: 000051420100020000000000
   VCID: 4EC56FD0205D78E7085-801A
   Component: TSG HBFS002 0187
   Serial number: YE007RDD03967
   Part No SW: 3Q0 907 590 G    HW: 3Q0 907 590
   Revision: --------
   Coding: 040000
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   VCID: 7EA5FF10D07D2867B85-802A
End----------(Elapsed Time: 01:57, VBatt start/end: 12.3V/12.3V)-----------
FandaTDI
Czech Republic
C?ID=204559
As you almost suggested, I would check coding of RLS and maybe BCM and also filter adaptations(incl.42) for "mirror", etc. . If you are sure all is connected right (sound strange "block off interior mirros sensor and the interior mirror goes black" ...), it seems to be really the matter of "setting".
TBAx
DE
C?ID=287144
There are a few things to consider when working with exterior mirror dimming.
I hope everything applies to your Arteon as well, the statements come from my O3RS, which has losely the same hardware installed.
  • mirror dimming is normally controlled by the BCM (address 09)
  • the only sensor adjusting the dimming is the one on the interior mirror
  • the feature only seems to work when headlights are on...
  • ...and only when the rotary light switch is set to AUTO
Since the measurement values you posted (IDE10164-MAS01632 and IDE10164-MAS03691) look good I would not see a reason why it would not work. However I am not sure, how you tested it. Where all requirements stated above fulfilled? Did the other mirrors dim, while the driver mirror did not?
SDarteon
C?ID=53880
Thanks to both for the responses.
I think I understand the networking parts of it. The mirror sensor, and other "simple" sensors are on the low-speed LIN bus and are slaved to J519 Electronics control module. This module is likely responsible for multiplexing data from other sensors to form a CAN message for the things like the electronic door control module and changing the transmission rate to 500kbit/sec. The door module is on the Convenience/Comfort Higher speed CAN bus, which is reached via the CAN Gateway (J533).
So the next check is to see what sensor/mirror adaption values are in J519 to allow the CAN message to be generated (with dimming sensor data included) and then to check that the CAN gateway passes it also (it may be transparent to such a low level sensor). Not sure why the output test did not work, but it will depend upon where the message was created... I think.
So more homework on the J519 adaptions list. Any clues... always... will be appreciated. Let me know if my understanding is incorrect. I dug around various SSP and VW training materials.
