Audi 4F AllroadTrailer Hitch Retrofitting - Westfaila Electronic Module Coding
AKL R36
Australia
C?ID=152211
Hi All,
Hopes everyone had have a great & wonderful New Year celebrations.
I've justing finished retrofitting a westfaila trailer hitch & made several attemptes to configure module as per retrofitting configuration list.
I don't seem to be able to config module with correct codes, Can anyone help please?
Steps I taken below
Register the newly added Trailer Control Module (J345/#69) to Gateway module (J533/#19)
[69] Trailer Module (J345/#69) config to 0300000000000000
[01] Engine Control Module (J623/#01) No coding required as it uses 7 digits coding - Please correct me if i missed understood
[03] ABS Brake Electronics (J104/#03) Subtract 0016384 from 0016776? New code 0000392
[34] Level Control (J197/#34) 0000210 - What would be the correct code?
[76] Parking Aid (J446/#76) 0221416 - What would be the correct code?
[6C] Rear View Camera (J772/#6C) 1020305 - What would be the correct code?
Saturday,03,January,2015,15:57:46:50635
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: WAUZZZ4FX8N0xxxxx   License Plate:
Mileage: 72110km-44807mi   Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 34 37 42 46 47 4F 52
          53 55 56 61 62 67 69 6C 72 76 77
   Mileage: 72110km-44807miles
67-Voice Control -- Status: Cannot be reached 1100
   Part No SW: 4F9 910 401 L    HW: 4F0 907 401 C
   Component: 3.0L V6TDI  G000AG  0020
   Revision: --H05---    Serial number:
   Coding: 0011372
   Shop #: WSC 02334 758 00200
   VCID: 2E5920EEB9D28E51CD7-807B
               P1653 - 002 -
                    Fault Status: 01100010
                    Fault Frequency: 14
                    Mileage: 72110 km
                    Date: 2007.05.16
                    Time: 12:18:38
                    Duty Cycle: 1.0 %
                    Voltage: 11.78 V
                    Bin. Bits: 00101000
                    Torque: 109.2 Nm
                    Bin. Bits: 00000100
   Part No SW: 4F5 910 156 C    HW: 09L 927 156 C
   Component: AG6 09L 3,0 TDI RdW 0020
   Revision: --H04---    Serial number:        4378581
   Coding: 0000001
   Shop #: WSC 02325 758 00200
   VCID: 2855D6F69B36D06107B-807D
Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
   Part No SW: 4F0 910 517 AB    HW: 4F0 614 517 R
   Component: ESP 8.0 quattro H05 0040
   Coding: 0016776
   VCID: 64CD82C6A79E7401EB3-8031
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 000 -
                    Reset counter: 100
                    Mileage: 72110 km
                    Date: 2007.05.16
                    Time: 12:41:12
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x0014
                    Hex Value: 0x07A8
                    Hex Value: 0x00FF
01517 - Control Module for Trailer/Towing Sensor (J345)
            000 -  -
                    Reset counter: 100
                    Mileage: 72110 km
                    Date: 2007.05.16
                    Time: 12:41:12
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x0014
                    Hex Value: 0x08A8
                    Hex Value: 0x00FF
            000 -  -
                    Reset counter: 100
                    Mileage: 72110 km
                    Date: 2007.05.16
                    Time: 12:41:43
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x0024
                    Hex Value: 0x01A8
                    Hex Value: 0x00FF
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0230
   Revision: 09010701    Serial number: 10601500899793
   Coding: 0000147
   Shop #: WSC 02323 758 00200
   VCID: 63CF81DAA2907339129-8036
   Subsystem 1 - Part No: 4F0 910 131 A
   Component: FBSAUDIC6 EZS   H45 0080
   Subsystem 2 - Part No: 4F0 910 220
   Component: FBSAUDIC6 IDG   H01 0040
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
   Part No SW: 4F0 910 732 B    HW: 4E0 035 729 A
   Component: Interfacebox    H43 4220
   Revision: 00000000    Serial number: 351J$077552688
   Coding: 0003002
   Shop #: WSC 02335 785 00200
   VCID: 2241C4DEFD0A3A3159F-8077
   Component: Bedienteil MMIC6H01 0060
   Subsystem 2 - Serial number: 00000001438112
   Subsystem 3 - Serial number: 0105.11.090000000100010101ˇ
   Subsystem 4 - Serial number: 010101ˇ
Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
   Part No SW: 4F0 910 043 A    HW: 4F2 820 043 Q
   Component: KLIMABETAETIGUNGH30 0020
   Revision: 00000052    Serial number: 00000030290851
   Coding: 0001366
   VCID: 1C3DFA26DF6E0CC1933-8049
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H18 0250
   Coding: 0003121
   VCID: 31633B92A8EC91A9D05-8064
   Subsystem 1 - Part No: 4F2 910 113 B  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H04 0190
   Coding: 00064784
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0100
   Coding: 00146221
   Shop #: WSC 02335
Address 0E: Media Player 1 (R192)       Labels: 4E0-035-785.lbl
   Part No SW: 4E0 035 785 B    HW: 4E0 035 785 B
   Component: SG ext.Player H15 0700
   Revision: 00000000
   VCID: 2757D5CA5628DF190E1-8072
Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
   Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
   Component: 4F AIRBAG AUDI8RH30 0280
   Revision: 09H30000    Serial number: 0037LD0UADBM
   Coding: 0013382
   VCID: 2953D3F2803CE969185-807C
   Subsystem 1 - Serial number: 6332CSME2823047F2
   Subsystem 2 - Serial number: 6342CSME2973601D3
   Subsystem 3 - Serial number: 6352QSME3D2E4C2F%
   Subsystem 4 - Serial number: 6362QSME3C530D63N
   Subsystem 5 - Serial number: 63734SME41682C191
   Subsystem 6 - Serial number: 63834SME3D314001R
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0410
   Revision: 00H03000    Serial number: 90025072630567
   Coding: 0102142
   VCID: 2757D5CA9628DF190E1-8072
   Component: E0221           H02 0030
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4F0 920 933 J
   Component: KOMBIINSTR. M73 H21 0240
   Revision: 00700000    Serial number: 6XX13Y0A7
   Coding: 7273758
   Shop #: WSC 31250 822 00001
   VCID: 234FC1DAE2103339529-8076
Address 19: CAN Gateway        Labels: 4L0-910-468.lbl
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1100B0792584EC
   Coding: F751DE7F70720600
   VCID: 2D5B27E2B4D4F549F4D-8078
01301 - Control Module for Voice Recognition (J507)
                    Reset counter: 100
                    Mileage: 72110 km
                    Date: 2007.05.16
                    Time: 12:43:56
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 C    HW: 4E0 035 110 A
   Component: MP3-Changer     H46 0350
   Revision: 00046006    Serial number: AUZ5ZBG3488469
   VCID: 1835E6362B5660E1B7B-804D
Address 34: Level Control        Labels: None
   Part No SW: 4F0 910 553 A    HW: 4F0 907 553 A
   Component: J197 LUFTFEDER  H17 0060
   Serial number: 00619003920500
   Coding: 0000210
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Reset counter: 100
                    Mileage: 72110 km
                    Date: 2007.05.16
                    Time: 13:35:57
                    Fault Status: 11101101
                    Reset counter: 100
                    Mileage: 72110 km
                    Date: 2007.05.16
                    Time: 13:35:57
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 M
   Component: MNS ECE         H50 1060
   Revision: 00000000    Serial number: 364J.077721666
   Shop #: WSC 03002 959 06940
   VCID: 3B7F19BA7AA06BF97A9-806E
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 F    HW: 4F0 959 793 F
   Component: TSG FA          H21 0210
   Coding: 0001562
   Shop #: WSC 02327 758 00200
Address 46: Central Conv.        Labels: 4F0-910-289.lbl
   Part No SW: 4F0 910 289 J    HW: 4F0 907 289 J
   Component: Komfortgeraet   H26 0210
   Revision: 02100026    Serial number: 01070434870000
   Coding: 0394121
01699 - Motor for Central Locking; Hatch/Trunk (V53)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 99
                    Mileage: 63685 km
                    Date: 2014.09.01
                    Time: 16:55:05
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F0 910 223 J    HW: 4F0 035 223 G
   Component: DSP-High C6     H10 0240
   Revision: PROD_01     Serial number: 00000000065830
   Coding: 0000123
   Shop #: WSC 50620 822 999999
   VCID: 254BDFC2EC24CD093CD-8070
   Part No SW: 4F0 910 280     HW: 4F0 907 280 C
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000076857
   Coding: 0001013
   VCID: 5EB9B02E89F25ED13D7-800B
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 792 F    HW: 4F0 959 792 F
   Component: TSG BF          H21 0210
   Coding: 0001562
   VCID: 2C5D2AE68FCEFC41E33-8079
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
   Component: EPB  CDEC0080   H04 0080
   Revision: --H04---
   Coding: 0000321
   Shop #: WSC 02324 758 00200
   VCID: 2045CED6F30628214FB-8075
   Part No SW: 4F0 910 357 F    HW: 4F0 907 357 F
   Coding: 0000017
   Subsystem 1 - Part No: 4F0 941 329 D
   Component: AFS-Modul links H01 0010
   Subsystem 2 - Part No: 4F0 941 329 D
   Component: AFS-Modul rechtsH01 0010
   Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
   Component: TUNER EU/US/RDW H42 0620
   Revision: 00000000    Serial number: 304AA037512408
   Coding: 0000001
   Shop #: WSC 02312 785 00200
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 F    HW: 4F0 915 181 B
   Component: J0644 BEM       H12 0760
   Revision: 00000000    Serial number: 00000000021398
   VCID: 244DC2C6E71E34012B3-8071
   Subsystem 1 - Part No: 4F0 915 105 D
   Component: von VA0  320410A08B
   Coding: 344630393135313035442056413033323034313041303842
   Shop #: WSC 55163 000 1048576
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 F    HW: 4F0 959 795 F
   Component: TSG HL          H21 0210
   Coding: 0001026
   VCID: 2F673DEABED88759C61-807A
Address 67: Voice Control
Address 69: Trailer (J345)       Labels: 4F0-907-383.clb
   Part No SW: 4F0 907 383 D    HW: 4F0 907 383 D
   Component: Anhaenger     H10 0080
   Revision: 2B001001    Serial number: 00000325428571
   Coding: 0300000000000000
   VCID: 2C5D2AE64FCEFC41E33-8079
   Part No SW: 4F0 910 441 A    HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J7930AA
   Coding: 1020305
   Shop #: WSC 02335 758 00200
   VCID: 1E39F02EC9721ED17D7-804B
03006 - Back-up Camera System not calibrated
            000 -  -
                    Reset counter: 100
                        Invalid
                        Invalid
                        Invalid
                    Fault Status: 01101101
                    Reset counter: 100
                    Mileage: 72110 km
                    Date: 2007.05.16
                    Time: 14:22:25
                        Reverse OFF
                    Count: 3
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795 F    HW: 4F0 959 794 F
   Component: TSG HR          H21 0210
   Coding: 0001026
   Part No SW: 4F0 910 283 H    HW: 4F0 919 283 H
   Component: Parkhilfe 8-Kan H12 0080
   Revision: 00H12000    Serial number: 06340726801378
   Coding: 0221416
   Shop #: WSC 131071 102 209715
   Part No SW: 4E0 910 336 K    HW: 4E0 862 335
   Component: Handyvorb2      H18 0950
   Revision: 00000000    Serial number: 00000005035159
   Coding: 0010900
   VCID: 2A512CFE853AE27111F-807F
End-------------------------(Elapsed Time: 04:06)--------------------------
NEtech
Denmark
C?ID=56995
Hi All,
Steps I taken below
Should be right
Correct
Correct
0000220
0231416
1030305
AKL R36
Australia
C?ID=152211
Hi NEtech, many many thanks for your codes, it config all module & cleared all faults, except Rear View Camera (J772/#6C) with code 03006 - Back-up Camera System not calibrated, somehow it lost it calibration, can we calibrate with VCDS?
