P02CB00 fault code, limp mode
H-bus guy
C?ID=275687
Transporter 2011, 2.0 biTdi 4motion CFCA engine. 171000 miles.
Had dpf light and coil light come on whilst driving to airport (150miles). Limp mode.
Had vw roadside assistance come out, ws blocked dpf filter ( and dpf pressure differential sensor pipe), turbo pressure too low. Fault codes p02cb00 and P246300.
He cleared pipe, tested G450 sensor, manual regen of dpf. Has new MAP sensor.
It cleared the dpf fault but the low boost still returns after about 1/2 a mile.
Full auto scan
Saturday,07,September,2019,07:53:24:16358
VCDS Version: 19.6.0.2
VIN: WV1ZZZ7HZBH070165   License Plate: ND60RJO
Mileage: 275630km-171268mi   Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 15 17 19 22 25 56 69 0B
VIN: WV1ZZZ7HZBH070165   Mileage: 275630km-171268miles
Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
   Part No SW: 03L 906 022 JE    HW: 03L 907 309 H
   Component: R4 2,0L EDC   H34 9970
   Revision: 22H34---    Serial number: 00000000000000
   Coding: 01254012231600080000
   Shop #: WSC 81903 210 00000
   ASAM Dataset: EV_ECM20BTD01103L906022JE 002009
   ROD: EV_ECM20BTD01103L906022JD_002.rod
   VCID: 71E9A2EDA096FCC76E-8024
11895 - Turbo / Supercharger B
          P02CB 00 [101] - Pressure too Low
                    Mileage: 275624 km
                    Date: 2019.09.06
                    Time: 13:40:49
                    Engine speed: 2638.00 /min
                    Normed load value: 89.4 %
                    Vehicle speed: 74 km/h
                    Coolant temperature: 98 C
                    Intake air temperature: 35 C
                    Voltage terminal 30: 13.780 V
                    Charge air pressure specified value: 2532 hPa
                    Charge air pressure: actual value: 2427.6 hPa
                    Air mass: actual value (mg/stroke): 1033.6 mg/stroke
                    Air cleaner degree of soiling: 18.27 %
                    Throttle valve adapter: actual value: 64.50 %
                    Bypass valve f high press turboch turbine inlet: actual value: 98.01 %
                    Mean injection quantity: 52.89 mg/stroke
   Part No SW: 0BT 300 011 Q    HW: 0BH 927 711 C
   Component: DSG DQ500-7A  H08 2258
   Revision: 00H08V01
   ROD: EV_TCMDQ500021_VW36.rod
   VCID: 3C7743D9B75441AF8D-8068
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 G    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0105
   Revision: 00H43001
   Coding: 508764AD99AB0A9526A39977A96316
   Shop #: WSC 02736 790 49152
   VCID: 366351F181789BFF7B-8062
   Part No SW: 7E5 907 047 AL    HW: 7E5 907 047 AL
   Component: Climatic-T5   H11 0203
   Revision: 00005001
   Coding: 0000000002
   Shop #: WSC 02737 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 79F99ACDF8E6B487D6-802C
   Part No SW: 7H0 937 087 F    HW: 7H0 937 087
   Component: BCM T5GP H+4  H47 0230
   Revision: BO047001    Serial number: 0396 321100593
   Coding: A0A0393A0E212013002008102C2B8C540000430F60044000300000000000
   Shop #: WSC 02734 790 00000
   VCID: 377D5CF5867262F760-8062
   Subsystem 1 - Part No SW: 7E0 959 801 C    HW: 7E0 959 801 C  Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  003 3311
   Coding: 050000
   Subsystem 2 - Part No SW: 7E0 959 802 C    HW: 7E0 959 802 C  Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  003 3311
   Coding: 040000
03303 - Response Closing Status of Rear Left Door
                    Reset counter: 27
                    Mileage: 275632 km
                    Date: 2014.01.27
                    Time: 21:28:05
   Component: VW10Airbag009 H06 0013
   Revision: --------    Serial number: 003HL002H9WF
   Shop #: WSC 02734 790 50316
   VCID: 356156FD947E90E772-8060
   Part No SW: 7E0 920 960 CX    HW: 7E0 920 960 CX
   Component: KOMBI         H04 0204
   Coding: 460300
   Shop #: WSC 51034 001 1048576
   VCID: 0109F22D9036EC479E-8054
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 0230
   Coding: 042300
   VCID: 70EFA7E9A39CF5CF61-8024
   Part No SW: 09N 907 554 B    HW: 09N 907 554 B
   Component: Haldex 4Motion      6008
   Coding: 0000002
   Shop #: WSC 02748 790 00000
   VCID: 377D5CF5467262F760-8062
   Component: IMMO          H04 0204
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADBB5818D400F1F2F-803E
   Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 01000000    Serial number: VWZ1Z2K8556967
   Coding: 0500020002
   VCID: 6BD5B0858ABA161754-803E
   Revision: 3A001001    Serial number: 00000137824167
   Coding: 410D000100000000
   Shop #: WSC 02736 790 00000
   VCID: 306F67E9631CB5CF21-8064
End-------------------------(Elapsed Time: 03:05)--------------------------
scan of fault code
Saturday,07,September,2019,12:45:54:16358
                Address 01: Engine       Labels: 03L-906-022-CFC.clb
Control Module Part Number: 03L 906 022 JE    HW: 03L 907 309 H
  Component and/or Version: R4 2,0L EDC   H34 9970
           Software Coding: 01254012231600080000
            Work Shop Code: WSC 81903 210 00000
              ASAM Dataset: EV_ECM20BTD01103L906022JE 002009 (VN75)
          P02CB 00 [167] - Pressure too Low
                    Mileage: 275633 km
                    Date: 2019.09.07
                    Time: 11:11:59
                    Engine speed: 2601.50 /min
                    Normed load value: 77.6 %
                    Vehicle speed: 67 km/h
                    Coolant temperature: 51 C
                    Intake air temperature: 31 C
                    Voltage terminal 30: 14.180 V
                    Charge air pressure specified value: 2625 hPa
                    Charge air pressure: actual value: 2363.2 hPa
                    Air mass: actual value (mg/stroke): 1044.7 mg/stroke
                    Air cleaner degree of soiling: 18.08 %
                    Throttle valve adapter: actual value: 99.62 %
                    Bypass valve f high press turboch turbine inlet: actual value: 99.08 %
                    Mean injection quantity: 44.33 mg/stroke
Readiness: N/A
Was thinking it could be clogged up wastegate with soot or issue with wastegate actuator?
Gonna try and get under van today and check both actuators move from end to end using
hand vacuum pump.
Whats your thinkings?
H-bus guy
C?ID=275687
Dont really wanna have to take biturbo off as absolute nightmare due to 4motion. Means taking out driveshaft, catalytic converter and bevel box....
What other tests can i do?
What else could it be?
Need van everyday so struggling....
South Molton, UK
Checked all the pipes around turbo to inlet for leaks?
H-bus guy
C?ID=275687
Nothing obvious, may have to try and rig up a smoke test.
H-bus guy
C?ID=275687
Any help anyone?
Mike@Gendan
Swansea, UK
C?ID=57030
[b]VCDS Version: 19.6.0.2[/b]
I can't help with your issue I'm afraid, but as a side-note you should update VCDS. There were some bugs in 19.6.0.x
19.6.1 has been out since late June / early July
H-bus guy
C?ID=275687
Yes i have updated to the latest version the day after that scan was taken.
Many thanks.
H-bus guy
C?ID=275687
Tested both actuators with vacuum pump today, both move freely.
Autopaja
Finland
C?ID=290404
Hello.
I had the same fault P02CB Pressure too low (Transporter T5 Bi turbo)
I took the lambda off form exhaust and 70% off the power came back.
Then i took DPF off whash it and fault has been fixed.
