05.5 Jetta Immobilizer Active
Burgas
NC, USA
C?ID=376620
Hey Everyone,
My girlfriend's car (not her primary transportation) has been having issues with the immobilizer for the past few months. In fact this issue is why I bought a VCDS cable in the first place.
It all started after we moved, her car has been fine as far as the immobilizer was concerned, never had any issues. At the new place it had sat for a few weeks and when I went to start it the battery was dead, no big deal I've had batteries die before (especially in my project car), so I pulled the battery out, booked up the Battery Tender and let it get fully charged. After the battery was charged and reinstalled when I tried to start it I got "Immobilizer Active" on the instrument cluster and the flashing car-key symbol on the dash.
Since getting the initial issue, I've been able to get the car started and driving on occasion. The first time I was able to get past the immobilizer I left the key in the ignition in the "on" position for 3 or so hours with the car hooked up to the Battery Tender. After I went back out I was able to start it and the error on the cluster went away. However the issue came back after cycling the key.
I disassembled the steering wheel column enough to disconnect the plug going into the D2 Reading Coil and to wiggle that around to see if the wires had any corrosion or issue, there were none I could find. I've also removed the instrument cluster and made sure the cable going from it's connection to the D2 Reading Coil wasn't pinched or frayed.
Another thing I tried was to take key apart (sadly there's only one key for this car, so no idea if this key is dying), and then try and start the car with the physical key for the car, but with my Jetta's key right next to the reading coil. The only change from doing that was an additional fault in the immobilizer in VCDS
01176 - Key
I have swapped batteries, and taken the battery for the car in for a scan at Advance Auto Parts, it passed.
The weird part to me is how it is intermittent, most of the time I get the error, but occasionally the error will go away and I can start and drive the car. When that's happened the immobilizer and engine have zero faults in them and the battery voltage is around 14.2 V. When the fault is there, the scans are done with the car off and voltage is around 12.5 V. I do have hooked up to the Battery Tender currently. Below is the latest scan from the car, which the car hasn't driven since I put the original battery back in, so some errors exist in the scan that will go away when the car is driven.
 Saturday,07,September,2019,19:29:54:26167
VIN: 3VWSF71K25M6xxxxx   License Plate:
Mileage: 192680km-119725mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 47 52 56 62 72
VIN: 3VWSF71K25M6xxxxx   Mileage: 192680km-119725miles
Address 01: Engine        Labels: 06A-906-032-BGP.lbl
   Part No SW: 06A 906 032 QE    HW: Hardware No
   Component: 2.5l R5/4V      G   6607
   Revision: 00000000    Serial number: VWZ7Z0D1108898
   Coding: 0000003
   Shop #: WSC 66565 257 00032
   VCID: 71BFD5B4DDAF79FF357-8024
17978 - Engine Start Blocked by Immobilizer
            P1570 - 008 -
Readiness: 0010 0000
   Part No: 09G 927 750 AS
   Component: AQ 250 6F           0649
   Coding: 0000008
   Shop #: WSC 00066 000 00000
   VCID: 025D8A78E8097267DCD-8056
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0021122
   VCID: 3A2D3298C059FAA7C4D-806E
   Part No: 1K0 907 044 AC
   Component: ClimatronicPQ35 066 0404
   VCID: 6889B8D0EE75B837629-803C
00576 - Terminal 15
00716 - Air recirculation Flap Positioning Motor (V113)
00926 - Terminal 30
   Part No SW: 1K0 937 049 C    HW: 1K0 937 049 C*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000000005590
   Coding: F4058E02400418000014000000140000002077035C
   VCID: 2F3B13CC0B1B2F0F633-807A
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
   Component: 1S AIRBAG VW8R  024 6300
   Revision: 03024000    Serial number: 0037KD005CZ9
   Coding: 0012627
   VCID: 2E050EC80C112607685-807A
   Subsystem 1 - Part No: 1K0 959 339 B
   Component: BF-Gewichtsens. 006 0003
   Subsystem 2 - Serial number: 6332MSME070F3B23C
   Subsystem 3 - Serial number: 6342MSME07264E47G
   Subsystem 4 - Serial number: 6351HSME042D083DA
   Subsystem 5 - Serial number: 6361HSME0419011F%
   Subsystem 6 - Serial number: 63727SME050D0341T
   Subsystem 7 - Serial number: 63827SME050D0E15%
   Part No SW: 1K0 953 549 AB    HW: 1K0 953 549 AB
   Component: J0527           010 0045
   Coding: 0010041
   VCID: 72BDDAB8D8A942E7CCD-8026
   Part No: 1K0 920 971 C
   Component: KOMBIINSTRUMENT 3HL 2120
   Coding: 0023203
   Shop #: WSC 07020 993 55679
   VCID: 2B0307DC3F03532F4FB-807E
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104B020164
   Coding: 3F3F03420F1002
   VCID: 290FFDD435FF413FBD7-807C
   Part No SW: 1K5 919 965     HW: 1K5 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 0371356TMSQH03
   VCID: 78A9E890BED528B7F29-802C
   Component: IMMO            3HL 2120
   Shop #: WSC 09430 444 85658
01176 - Key
01176 - Key
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2339
   Coding: 0001271
   VCID: 363526A8F4411EC7205-8062
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.3       1502
   VCID: 303910B0162530F77A9-8064
   Part No SW: 1K0 959 433 AT    HW: 1K0 959 433 AT
   Component:    KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 12100F880106083F2D06050FA0080F0490A540
   Component: LIN BACKUP HORN H02 1301
                    Reset counter: 44
                    Mileage: 192683 km
                    Time: 01:12:19
                    Fault Status: 01101100
                    Reset counter: 44
                    Mileage: 192683 km
                    Time: 01:14:04
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 44
                    Mileage: 192683 km
                    Time: 01:27:00
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No: 1K6 035 456
   Component: 08K Audioverst.     0003
   Revision: 00002000    Serial number: 00000000002530
   VCID: 698FBDD4F57F813F7D7-803C
00419 - Left Front DSP Midrange Speaker (R103)
00420 - Front Right DSP Midrange Speaker (R104)
   Part No: 1K0 959 702 K
   Coding: 0001271
   VCID: 372B2BACF34BE7CF3B3-8062
   Part No SW: 1K0 035 180 A    HW: 1K0 035 180 A
   Component: Radio DE2       008 0011
   Revision: 00008000    Serial number: VWZ4Z7D2013771
   Coding: 0010010
   VCID: 1E65DE087CB1B687D85-804A
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2416
   Coding: 0000144
   VCID: 313F15B41D2F39FF757-8064
   Part No: 1K0 959 704 D
   Coding: 0000144
   VCID: 323D1AB8182902E70CD-8066
End----(Elapsed Time: 01:10, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
NostraJackAss
Hey Everyone,
Please clear all fault codes turn key OFF wait 30 seconds than ON and post a fresh new auto-scan immediately after doing so & the OBD2 data MODE 01-01, 03, 07 & 9
Please provide your actual full VIN NUMBER?
Are you sure this is the entire story?
Thank you
[QUOTE]
   Component: 2.5l R5/4V      G  [COLOR=#ff0000][B] 6607 [/B][/COLOR]
   Coding: 0000003
   Shop #: [COLOR=#045504][B]WSC[/B][/COLOR] 66565 257 00032
            P1570 - 008 -
   Component: AQ 250 6F          [COLOR=#ff0000][B] 0649  [/B][/COLOR]
   Coding: 0000008
   Shop #: [COLOR=#045504][B]WSC[/B][/COLOR] 00066 000 00000
   Shop #: [COLOR=#045504][B]WSC[/B][/COLOR] 00000 000 00000
00576 - Terminal 15
00926 - Terminal 30
   Shop #: [COLOR=#045504][B]WSC[/B][/COLOR] 09430 444 85658
01176 - Key
01176 - Key
[/QUOTE]
MY BET IS ON FOD!
Burgas
NC, USA
C?ID=376620
Sure, here it is.
I'm not sure what you're implying about there being more to the story? We bought the car through private party a couple of years ago, what the car had done to it before then is information I don't have. Since we bought it the vacuum pump broke and we opted for the "Spulen Ultimate Brake Vacuum Pump Delete Kit For 2.5L" since it was a more cost effective option, replaced tires, and changed filters and fluids as needed. I did notice a spacer on the post cat O2 sensor when I was under the car a while back, but I haven't investigated if there's an issue with the catalytic converter or anything since I don't see any CELs about it, and it passes inspection. Also I'm pretty certain the previous owner had a different stereo in it at some point, it certainly sounds different than the stereo in my Jetta.
Saturday,07,September,2019,19:55:35:26167
VIN: 3VWSF71K25M602142   License Plate:
VIN: 3VWSF71K25M602142   Mileage: 192680km-119725miles
   Coding: 0000003
            P1570 - 008 -
   Coding: 0000008
   Coding: 0021122
00576 - Terminal 15
00926 - Terminal 30
   Coding: 00065493
   Coding: 00217125
   Coding: 0012627
   Coding: 0010041
   Coding: 0023203
01176 - Key
01176 - Key
   Coding: 0001271
                    Reset counter: 44
                    Mileage: 192683 km
                    Time: 02:32:31
   Coding: 0001271
   Coding: 0010010
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:09, VBatt start/end: 12.0V/12.0V)-----------
Saturday,07,September,2019,19:56:41:26167
Mode 01 - PID 01 : Readiness  --  Address 10
Number of DTCs stored: 0  --  MIL Status: MIL OFF
Misfire monitoring:  Passed
Fuel System: Not installed.
Comprehensive Components:  Passed
Catalyst monitoring:  Passed
Heated catalyst monitoring: Not installed.
Evaporative system monitoring: Not installed.
Secondary air system monitoring: Not installed.
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring:  Failed or Incomplete
Oxygen sensor heater monitoring: Not installed.
Exhaust Gas Recirculation: Not installed.
Mode 03: Emission related fault codes
Address 10 (Engine): No fault code found.
Address 1A (Auto Trans): No fault code found.
Type 02 - VIN : 3VWSF71K25M602142 (Address 10)
Type 04 - Calibration ID : 06A906032QE 6607 (Address 10)
Type 04 - Calibration ID : 09G927750AS_0649 (Address 1A)
Type 06 - Calibration Verification Number : A8683904 (Address 10)
Type 06 - Calibration Verification Number : 452C22AD (Address 1A)
NostraJackAss
Sure, here it is.
Car is indeed FOD Modified, not implying anything, I'm telling you it is............ ;)
Just like the other dirty car you posted that shouldn't pass inspection & when it as you aforementioned "passes inspection"?
Looks like I lost the side bet, but it was good odds! :p
Correct all FOD or get the immobilizer deleted too, pretty much everything else is already, no?
Vehicle Identification No.3VWSF71K25M602142
ModelJetta
JEM
Date of production11.01.2005
Model year2005
Sales type1K27N3
Engine CodeBGP
Transmission CodeHFU
Emission standard7GBEmission standard ULEV 2
Thank you for full disclosure though...........
Burgas
NC, USA
C?ID=376620
I'm curious what your side bet was?
My Jetta I have knowingly modified, mostly for performance and fun. I'm not certain what all has been done to this car, the risks of buying used of course. I am curious, why the highlights on the component revisions for the engine and transmission? I searched for another 2.5L autoscan and see the same component revisions for that car, so I am confused a tad on how that lead you to FOD.
I assume from the OBD 01-01 where it says "Oxygen sensor monitoring: Failed or Incomplete" that you're thinking the catalytic converter under efficiency flags have been removed from the ECU? Tricky tricky.
Well here's a question, how would I go about removing all FOD? I don't know what has been altered in the ECU, or how to reset it to pristine factory conditions. Any suggestions there? Is that something either an independent shop or the dealer would need to do?
I have looked into the Immobilizer Delete from Kerma TDI, which I'm not 100% opposed to, but the downside from what I've read is that the error would still exist in the cluster display and that's not ideal.
Immediately after clearing fault codes, there should be a number of Readiness bits reading "Fail", not just one..
NostraJackAss
Majestic clearance only!
Is it not self evident & are you sure?
Did you JPPSG yet and the entire thread?
Replacement ECU or flashed by dealer or authorized agent for EPA CARB pass-thru, no?
Was it SVM 348F?
Only for the people that do it half ass, no?
Have no fear, DOJ is going after CARB to shut it down and the EPA along with now suing VAG & for trying to make things in the verse, being cleaner, I just can't wrap my head around it myself, how about you?
https://www.cnet.com/roadshow/news/bmw-ford-honda-volkswagen-doj-investigation-california/
Burgas
NC, USA
C?ID=376620
JPPSG:
Step 1:
Step 2:
Stock save for:
Modifications to ECU around emissions it would seem
Step 3:
   Coding: 0000003
            P1570 - 008 -
   Coding: 0000008
   Coding: 0021122
00576 - Terminal 15
00926 - Terminal 30
   Coding: 00065493
   Coding: 00217125
   Coding: 0012627
   Coding: 0010041
   Coding: 0023203
01176 - Key
01176 - Key
   Coding: 0001271
                    Reset counter: 44
                    Mileage: 192683 km
                    Time: 02:32:31
   Coding: 0001271
   Coding: 0010010
   Coding: 0000144
   Coding: 0000144
Step 4:
Step 5:
As far as I'm aware everything is OEM minus above modifications
Step 6:
Concern is immobilizer
01176 - Key
01176 - Key
Step 7:
I have checked fuses related to instrument cluster. I have cleaned the battery terminals and connections as well as charged the battery with a Battery Tender.
Was it SVM 348F?
Not sure
Personally I cannot stand the current administration and I don't see how cars being more efficient than they legally need to be would be a problem in the slightest.
NostraJackAss
Using RTFB & WD did you try a bifurcated twisted pair to D2 from cluster or wound your own coil to isolate and see if key responds in VCDS blocks in 0x25 advanced measuring blocks?
Have you checked for a corroded connection or used stabilant 22A on all connections to enhance?
Thank you for attempting to JPPSG!
Did you read TSB's & SSP?
NostraJackAss
Sunday night factual follow UP for homework you may wish to entertain yourself with, NO?
Is it me or does your car look like it was a pre production vehicle/module, so couldn't you argue compensation of an ECU that comports as certified as a post useful life required free repair or maybe something else?
Test Group 5VWXV02.5253
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=9611&flag=1
Is it page 73 for your pleasure, right?
NostraJackAss
It is most likely cluster problem. Very common on early Mk5 , I Replaced so many of them.
So how many were with less than useful life replaced Marin & at 10-120K or 15/150K depending on how certified & since the MIL resides there?
Isn't this just an unfair competition device & used as an alleged security mechanism, further abusing the CFR to create a unjust enrichment scheme, wouldn't you just delete it OP, I mean you are apparently okay with all aforementioned AECD's deleted, why not this? :p
