Audi A4 2003 coding questions
Dp41n8w
Finland
C?ID=372411
Hello. I have few questions about 2003 A4
1) I it possible to remove brake bad alert from cluster?
2) Is it possible to remove oil level sensor from cluster?
3) There is big screen in cluster, but only one function. Can I code there all the info (range and so on..)? There is MF washer wiper.
Saturday,07,September,2019,18:00:58:19148
VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
VIN: WAUZZZ8E13A269637   License Plate: A4
Mileage: 334810km-208041mi   Repair Order:
          67 69 75 76 77
VIN: WAUZZZ8E13A269637   Mileage: 334810km-208041miles
Address 01: Engine        Labels: 06B-906-018-AVJ.lbl
   Part No SW: 8E0 909 518 AA    HW: 8E0 909 018 A
   Component: 1.8L R4/5VT     G   0004
   Coding: 0011501
   Shop #: WSC 00000 000 08192
   VCID: 6FBBD3AB5B89A0BF233-5160
16618 - Boost Pressure Regulation
            P0234 - 001 - Limit Exceeded (Overboost Condition)
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517
   Component: ABS/ESP front       1726
   Coding: 04475
   Shop #: WSC 00011
   VCID: 6597B1838C756AEF59F-51F2
   Part No: 8E0 820 043 J
   Component:   A4 Klimaautomat   1116
   Coding: 00000
   Shop #: WSC 63351
   VCID: 2809F8B7BBE7B787A29-513C
            41-10 - Blocked or No Voltage - Intermittent
01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
01810 - Actuating Motor for Temperature Flap; Right (V159)
01842 - Potentiometer/Actuator for Temperature Flap; Right (G221)
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
            30-00 - Open or Short to Plus
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 E
   Component: int. Lastmodul  NDL 0305
   Coding: 00002
   Shop #: WSC 63351
   VCID: 34311CC7772FC3671E1-4B00
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 B
   Component: Airbag 8.4EP        2000
   Coding: 0011602
   Shop #: WSC 06435 000 00000
   VCID: 363526CF6453D177205-5184
   Part No: 8E0 953 549 N
   Component: Lenksáulenmodul     0308
   Coding: 00041
   Shop #: WSC 50359
   VCID: 3E253EEF49631937F85-4B00
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8E0 920 900 L
   Component: KOMBI+WEGFAHRS. RB4 D36
   Coding: 00100
   Shop #: WSC 00006
   VCID: 2D0709A3940592AF51F-5160
   WAUZZZ8E13A269637     AUZ6Z0B0373513
Address 46: Central Conv.        Labels:. 8E0-959-433-MIN.clb
   Part No: 8E0 959 433 AR
   Component: Komfortgerát T85    1210
   Coding: 06720
   Shop #: WSC 63351
   VCID: 015F8513781DA6CFC57-4B00
   Subsystem 1 - Part No: 8E1959801B
   Component: Tõrsteuer.FS BRM 0002
   Subsystem 2 - Part No: 8E1959802B
   Component: Tõrsteuer.BF BRM 0002
01561 - Rear left door
            59-10 - Can't Unlock - Intermittent
            61-10 - Won't De-Safe - Intermittent
End----------(Elapsed Time: 05:49, VBatt start/end: 12.0V/12.0V)-----------
1) On that cluster, it would appear the answer is no. But it's trivially easy to jumper out the circuit.
2) Not that I am aware. And why would you want to?
3) I don't think so. I expect you would need a cluster with the appropriate software in it.
Dp41n8w
Finland
C?ID=372411
'cause someone had change oil pan and In the new oil pan there isn' t place for the oil lever sensor 🤔
Dp41n8w
Finland
C?ID=372411
I quess that the original oil pan was too expensive and thats why there is chinese copy oil pan.
Well, if it were mine, I would either get the correct/proper oil pan for it, or I would have a look at the the wiring diagrams and try to figure out what electrical components were needed to fool the car into believing the sensor is present and the oil level is OK.
darkchina811
ITALY
C?ID=333184
and make sure you check the actual oil level quite often :D
