Fresh Air Blower
Gmickey
C?ID=354933
My fresh air blower does not turn on sometimes, especially when it is very hot outside. I can open up the shroud and give it a little help with a screwdriver and it always starts. I have read this is most likely due to poor connection on the internal motor components due to wear. I plan to replace it, but understand there is also a starter. Should I replace that as well while I have everything opened up or is it unlikely to need replacement? Thanks.
Sunday,25,August,2019,16:52:58:43616
VIN: WAULFAFR9AA0XXXXX   License Plate: 7PNXXXX
Mileage: 244650km-152018mi   Repair Order:
Chassis Type: FR-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56
          77
VIN: WAULFAFR9AA0XXXXX   Mileage: 244650km-152018miles
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H15 0001
   Revision: E1H15---
   Coding: 0114010A190F0160
   Shop #: WSC 09211 444 182470
   ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
   ROD: EV_ECM20TFS0118K2907115AL.rod
   VCID: 79AFEFA0A953F4CF8D7-802C
4106 - Bank 1; System too Rich at Idle
          P2188 00 [096] - -
                    Mileage: 243961 km
                    Date: 2019.08.01
                    Time: 16:26:22
                    Engine speed: 798.00 /min
                    Normed load value: 10.2 %
                    Coolant temperature: 93 °C
                    Intake air temperature: 46 °C
                    Voltage terminal 30: 14.041 V
                    Unlearning counter according OBD: 21
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 J    HW: 0B6 927 156
   Component: 0B6 20TFSIUSA H05 0008
   Revision: --H05---
   Coding: 001012
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMAL651 A01006
   ROD: EV_TCMAL651.rod
   VCID: 3D273BB0FDFB08EFE1F-8068
   Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
   Component: ESP8 quattro  H04 0010
   Coding: 150D18
   VCID: 7AADF0ACACD5FFD784D-802E
   Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
   Component: BCM2 1.1      H02 0324
   Coding: 090000
   VCID: 78A9EAA492D9EDC7F29-802C
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Serial number: 0509000049953018
   Serial number: 0209000063527007
Address 06: Seat Mem. Pass (J521)       Labels:. 8T0-959-760.clb
   Part No SW: 8T0 959 760 C    HW: 8T0 959 760 C
   Component: MEM-BFS       H10 0074
   Revision: AA000000    Serial number: 00001010004295
   Coding: 08017025002400001000
   VCID: 43D34D489B9F7E1F97B-8016
   Component: KLIMA 3 ZONEN H08 0171
   Revision: C1000000    Serial number: 01150920090294
   Coding: 64022000
   VCID: 00598244CA09A507CA9-8054
                    Reset counter: 64
                    Mileage: 241740 km
                    Date: 2019.07.01
                    Time: 18:06:35
                    Temperature: 35.0°C
                    Voltage: 13.60 V
                    Output: 0 W
                    Output: 0 W
                    Temperature: 34.0°C
01273 - Fresh Air Blower (V2)
                    Fault Status: 00101001
                    Fault Frequency: 21
                    Reset counter: 100
                    Mileage: 241740 km
                    Date: 2019.07.01
                    Time: 18:06:35
                    Temperature: 35.0°C
                    Voltage: 13.80 V
                    Current: 0.000 A
                    Voltage: 13.80 V
01844 - Control Module for Fresh Air Blower (J126)
                    Fault Status: 00101110
                    Reset counter: 98
                    Mileage: 241740 km
                    Date: 2019.07.01
                    Time: 18:08:58
                    Temperature: 34.0°C
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000340407
   Coding: 26001091063CAF010000080300003D3D0F1C528800010161000000
   VCID: 3C2136B4E66101E7D61-8068
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 120909  H14 0070
   Serial number: SWF09090125441
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10596177
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 AN    HW: 8K0 941 531 AN
   Component: E1 - LDS  H08 0090
   Serial number: 00000000002807091472
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
   Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
   Component: AirbagVW-AU10 H37 0520
   Serial number: 003EGD02CYY%
   Coding: 303333334330303030304A55304C38543053
   VCID: 42DD484C840577179CD-8016
   Subsystem 1 - Part No SW: 8K0 959 339     HW: 8K0 959 339
   Component: BF-Gewichtss.  H01 0050
   Serial number: 5810000R0900004E33
   Serial number: 6334MSME4B754319H
   Serial number: 6344MSME4B4101511
   Serial number: 6352QSME6A3A0D02L
   Serial number: 6362QSME153B1228B
   Serial number: 63732SME0D390C2E9
   Serial number: 63832SME0539240AX
   Revision: --------    Serial number: 90319II8000EE
   Coding: 000036
   VCID: 3D273BB0FD7B08EFE1F-8068
   Part No SW: 8T0 920 950 Q    HW: 8T0 920 950 Q
   Component: KOMBIINSTR.   H33 0255
   Revision: 00000000    Serial number: CHU22J299
   Coding: 8B1701000300D705020000
   VCID: 46D5545CA8AD4B37B05-8012
   Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0105
   Revision: GB600050    Serial number: 5000G0990383BB
   Coding: 00C303
   VCID: 50F972045AE995871A9-8004
   Component: J367-BDM  H06 0170
   Serial number: 1908C051250809
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0280
   Revision: 00000000
   Coding: 020302
   VCID: 392F2FA0E95334CFCD7-806C
   Component: MEM-FS        H10 0074
   Revision: AA000000    Serial number: 00001010004226
   Part No SW: 8T0 959 793 J    HW: 8T0 959 793 D
   Component: TSG FA        H07 1301
   Coding: 011C03224000120102
   Shop #: WSC 09211 444 175787
   Revision: 00002001    Serial number: 0121269251
   Coding: 0106029A007A440400B0000000000000
   Shop #: WSC 06342 000 00000
   Component: GTO BF  H06 0050
   Serial number: 00000000000000166955
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE19SKB12  H01 0220
00218 - Humidity Sensor (G355)
                    Reset counter: 229
                    Mileage: 241389 km
                    Date: 2019.06.24
                    Time: 17:32:42
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 96
                    Mileage: 244161 km
                    Date: 2019.08.13
                    Time: 07:30:34
Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
   Part No SW: 8T0 035 223 AR    HW: 8T0 035 223 AJ
   Component: DSP Prem      H17 0320
   Revision: 00017001    Serial number: 34834004493702
   Coding: 0203010302
   VCID: 7EA5FCBCB0FDD3F7B85-802A
   Part No SW: 8T0 959 792 J    HW: 8T0 959 792 D
   Component: TSG BF        H07 1301
   VCID: 4FFB717847D78A7F033-801A
   Revision: 00000003    Serial number: 10000000312954
   VCID: 34311E94CE31C9A71E1-8060
   Part No: 8K5 907 357
   Coding: 0000002
   Shop #: WSC 06324 000 00000
   VCID: 77ABE99893C7E2BFFB3-8022
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
   Component: Con3 Sirius   H04 0351
   Revision: 00000006    Serial number: AUZ5Z6I1267629
   Coding: 040300020104850043D9070800
   Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
   Component: Display
                    Reset counter: 229
                    Mileage: 241389 km
                    Date: 2019.06.24
                    Time: 17:31:51
                    Fault Frequency: 19
                    Reset counter: 101
                    Mileage: 241389 km
                    Date: 2019.06.24
                    Time: 17:43:02
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
   Part No SW: 8T0 862 336 D    HW: 8T0 862 336 D
   Component: FSE_256x BT     H37 0600
   Revision: 00000000    Serial number: 00000005051481
   Coding: 0010370
   VCID: 3C2136B4EA6101E7D61-8068
End----(Elapsed Time: 01:39, VBatt start/end: 11.7V/11.7V. VIgn 11.8V)-----
South Molton, UK
The blower motor always used to be a permanent magnet DC motor that uses brushes and a commutator, with this type of motor low starting torque is most often down to worn brushes.
Gmickey
C?ID=354933
So the starter likely does not need replacing? Does the motor lend itself to replacing the brushes or should I just replace the entire unit?
South Molton, UK
I can't recall anyone replacing the brushes, once you've got the motor out it's easier/simpler just to replace the whole motor.
