Unable to perform SRI
Gremling
Norway, Nordland
C?ID=319714
Hi, Gremling here,
Last evening I tried to help out a friend with his VW Jetta, 2011 1,6 tdi, it had just been to service at a Toyota dealer/workshop ( we do not have a VAG dealer within a few hundre km). Anyway, the Toyota workshop, and also I was unable to reset the Service Reminder Indicator. Using my HexNet-V2 (VCDS) I got the message in my vag that the control module (for SRI system?) was not initialized. Tried to use the default values, to no avail. Tried according to a wici ross link, that also to no avail. Owner have had the car in for software update, regarding the environmental issue, at VAG workshop, prior to this service. He said last time the mentioned Toyota workshop also did the service, and that time they did not get problems resetting SRI. Any advices or tips?
Will post scan later today, tomorrow or monday, unable to do so now
Regards
Gremling
Posted from i-phone
AndySwede
Stockholm Sweden
C?ID=172802
If you are still using VagCom I suggest uppdating to VCDS release 19.6 for a start... and the SRI performance may be different to a Jetta I 161 (launched 1979 in europe) or a Jetta 1K3 (launched 2010) or other models in between...
Gremling
Norway, Nordland
C?ID=319714
Its a 2011 1,6 tdi (although VIN has the C as 10th digit -> 2012.
Have tried to, in the following order, and with test run in between:
Reset SRI with Hexnet-V2 (VCDS), software version 19.6.0.6 (Have just gotten the 19.6.1 and installing it now, but scan has been done.
Have tried to reset with a Delphi box / PC (but of course I prefer the VAGCom,
Have tried the 0,0 Button followed by sign on, then the square Button and ignition of checked oil Says 1500km 731 days.
Have tried to do it via MFD panel, service reset
The symbol (looks like a spanner, if you have a good imagination) keeps coming back after a few km of driving.
Auto scan here>
Thursday,05,September,2019,03:09:00:27784
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VirtualBox)
VCDS Version 19.6.0.6  HEX-V2 CB: 0.4508.4
VIN: WVWZZZ16ZCM011561   License Plate: YE90921
Mileage: 140990km-87607mi   Repair Order:
Chassis Type: 16-VW32 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 20 25 2E 42 44 46 4F 52 56 61
          62 69 72 77
VIN: WVWZZZ16ZCM011561   Mileage: 140990km-87607miles
   Part No SW: 03L 906 023 MQ    HW: 03L 907 425 C
   Component: R4 1.6l TDI   H43 9977
   Revision: --H43---    Serial number: 00000000000000
   Coding: 10254036032401080000
   Shop #: WSC 00066 000 00187
   ASAM Dataset: EV_ECM16TDI02103L906023MQ 003012
   ROD: EV_ECM16TDI02103L997557T.rod
   VCID: 015F7BB0618FC28FC5B-8055
   Part No SW: 0AM 300 051 T    HW: 0AM 927 769 D
   Component: GSG DSG AG7     421 2710
   Revision: 00042014    Serial number: TFK01105260709
   Shop #: WSC 00066 000 00000
   VCID: 3B23C9584F63685FDF7-806F
006079 - Hydraulic Pump
               P17BF - 000 - Play Protection - Intermittent
                    Fault Frequency: 13
                    Reset counter: 10
                    Mileage: 140786 km
                    Date: 2014.01.13
                    Time: 08:23:50
               P17BF - 001 - Play Protection - Intermittent
                    Fault Frequency: 13
                    Reset counter: 10
                    Mileage: 140786 km
                    Date: 2014.01.13
                    Time: 08:23:50
006300 - Function Restriction due to Insufficient Pressure Build-Up
               P189C - 000 -  - Intermittent
                    Reset counter: 8
                    Mileage: 140940 km
                    Date: 2014.01.24
                    Time: 10:12:37
               P17BF - 002 - Play Protection - Intermittent
                    Fault Frequency: 13
                    Reset counter: 10
                    Mileage: 140786 km
                    Date: 2014.01.13
                    Time: 08:23:50
002113 - Transmission Fluid Pressure Sensor/Switch 1
               P0841 - 000 - Implausible Signal - Intermittent
                    Reset counter: 9
                    Mileage: 140978 km
                    Date: 2014.01.25
                    Time: 13:13:50
   Revision: 00H31001
   Coding: A13B20F8092300FB851004EA901A0051210000
   VCID: 7BA3095803E3A85F9F7-802F
   Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Component: Climatronic   H18 1112
   Revision: 00001003
   Coding: 0000004003
   Shop #: WSC 00066 000 00119
   ROD: EV_ClimaAutoBasis_VW32.rod
   VCID: 00597EB46A85CB87CA5-8055
   Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
   Component: BCM PQ35 M    011 0046
   Revision: BC011001
   Coding: 00000A3A982D02C040080088140081E40371008860A085625CC087000041
   VCID: 3B23C9584363685FDF7-806F
   Component: RLS 300611 05  54  0403
   Coding: 02300A
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 5C6 919 475     HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H10 0005
   Revision: --------    Serial number: 84091115400251
   Coding: 118101
   Shop #: WSC 00185 218 94865
   ASAM Dataset: EV_EPHVA18VW3610000 001003
   ROD: EV_EPHVA18VW3610000.rod
   VCID: 71BF2B70512FD20F35B-8025
   Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
   Component: AirbagVW10    013 0613
   Serial number: 003G6D059V74
   Coding: 00003242
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 323DE47C94A9A9170C1-8067
   Serial number: 3572MSME45310060ZZZC
   Serial number: 3582MSME6E04565FZZZ6
   Serial number: 3516KSME3B137410ZZZJ
   Serial number: 3526KSME43517B10ZZZM
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Revision: FF010040    Serial number: 20110603201004
   Coding: 0892140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 76B5186C3841F537E09-8023
   Subsystem 1 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H08 0010
   Coding: 830000
   Part No SW: 5C6 920 871 A    HW: 5C6 920 871 A
   Component: KOMBI         H04 0617
   Coding: 171E00
   VCID: 2A0DFC1CBC79E1D7B41-807F
   Part No SW: 7N0 907 530 K    HW: 1K0 907 951
   Component: J533  Gateway H40 1620
   Revision:   H40       Serial number: 11071101290183
   Coding: 351002
   VCID: 3829D65472554347325-806D
   Part No SW: 5K0 857 511 B    HW: 8P0 857 511 C
   Component: FLA           H04 0006
   Revision: AA001002
   Coding: 0101006B74745D545420363E00
   VCID: 2D07F7008D17F6EF513-8079
   Component: IMMO          H04 0617
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6A8D3C1C7CF921D7741-803F
   Revision: A1001003    Serial number: 7660166335
   VCID: 290F0310B9FFEACFBDB-807D
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0515
   Revision: 12110009    Serial number: 0002924440
   Coding: 0210B7
   Shop #: WSC 01383 790 50316
   VCID: 1C612AC4E62D0F6736D-8049
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1508
   Serial number: 00000005872643
   Coding: 000090
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 70     3201
   Revision: 00H20000
   Shop #: WSC 02069 000 90108
   VCID: 3431E264623DA7271ED-8061
   Component: EZE_2         H40 1620
   Coding: 01030100
   VCID: 6FBB2D08479BC4FF23F-803B
   Subsystem 1 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.019  H08 0006
   Serial number:     WRH0002GG9D
   Coding: 180000
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0515
   Revision: 14110009    Serial number: 0002864234
   Coding: 0210B6
   VCID: 1D6727C0FD37066FC13-8049
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  006 1508
   Serial number: 00000005871449
   Coding: 000090
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195 G    HW: 3C8 035 195 G
   Component: Radio RCD510  050 0207
   Revision: 00000001    Serial number: VWZ1Z3L1549163
   Coding: 01000400040006
   VCID: 2C01FA04B60DFFE746D-8079
   Component: Batt.regelung H40 1620
   Coding: 030B185A
   VCID: 71BF2B7051AFD20F35B-8025
   Subsystem 1 - Part No SW: 5C0 915 181     HW: 5C0 915 181
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370755755
   Revision: 3A001001    Serial number: 00000148599580
   Coding: 410D000100000000
   VCID: 3039EE749A259B077A5-8065
            011 - Open Circuit - MIL ON
                    Fault Status: 11101011
                    Reset counter: 74
                    Mileage: 139847 km
                    Date: 2013.12.08
                    Time: 12:45:40
   Part No SW: 7P6 035 730 E    HW: 7P6 035 730 E
   Component: TELEFON       H09 2730
   Revision: 1B001001    Serial number: 00007660119543
   Coding: 0A01000000010101
   ASAM Dataset: EV_UHVNA A01015
   ROD: UHVNA.rod
   VCID: 3431E2646EBDA7271ED-8061
End----------(Elapsed Time: 01:32, VBatt start/end: 11.9V/11.8V)-----------
Fault code for Trailer has now been cleared, and was caused by worn replaced battery. Auto GB has been changed or overhauled previously, and i have now deleted fault code
Regards
Gremling
OK, so that's a UDS cluster.
Current versions of VCDS should allow you to use the SRI Reset button on that. It will give you some options for "NAR only" (or something like that) but they actually do work world-wide.
Worst case, post a Adaptation Channel Map.
Gremling
Norway, Nordland
C?ID=319714
Have tried all above tip for SRI reset, no difference, car is driven for a few km, and maintenance spanner comes up again (alternating spanner and gear indicated).
S this has been tested, but no difference:
Reset SRI with Hexnet-V2 (VCDS), software version 19.6.1, with Reset SRI
Have tried to reset with a Delphi box / PC (but of course I prefer the VAGCom)
Reset SRI with Hexnet-V2 (VCDS), software version 19.6.1, controller 17, and thereafter as shown 1/2 out in above video.
Since this type of problem with his car started after the environmental upgrade, I have told my friend to take car back to the VAG workshop, where upgrade was done. I do not believe they will be much helpful there, as they are known for being both greedy and arrogant, but one never knows, they have just gotten a few new in management.
Regards
Gremling
Jef
HQ
Just laying this down here...
Start VCDS, click on [SRI Reset], VCDS goes in and gathers data... user selects what action they want to perform from the drop down menu at the top of the screen. For a UDS like OP's case, it is always safe to select the "Reset FIX & ESI" option as shown below:
All UDS clusters have the ESI option, but not all early UDS clusters have the FIX option, so VCDS will try and get a report back from the cluster along the lines of vales could not be saved since it doesn't know what FIX means.
Once a selection is made from the drop down menu, click on [Perform SRI] at the bottom to have the request carried out.
If one wants to go in an manually reset the service on a UDS cluster, you can follow the example shown on our wiki site for the 7P Touareg (it is all the same):
[url]http://wiki.ross-tech.com/wiki/index.php/VW_Touareg_(7P)_Instrument_Cluster#Adaptation[/URL]
Gremling
Norway, Nordland
C?ID=319714
Tried, all the above, no luck, drives car a few km and spanner shows up again.
Seems like a module will not take/handle commands properly. When using VCDS and
In control module 17 i see:
Oil quality good
Oil service done 1050km ago
Max dist to next service 14050
Service/inspection performed 44 days ago
Time to service 371 days
Regards
Gremling
Please post an Adaptation Channel Map from the instrument cluster in this car.
HMC
C?ID=28246
Hi Gremling,
Have you actually tried resetting the SRI via Instrument (17) and adaptions? I do not have problems doing, Reset warning to not active, make sure the mileage and distance for oil change is zero, change the mileage and distance since inspection to zero.
Regards HMC
Gremling
Norway, Nordland
C?ID=319714
Just went offshore, will do so when back home (14-15days or so). Want it even if the module has been initialized?
Regards
Gremling
Gremling
Norway, Nordland
C?ID=319714
WillCo, can do this when I get back home again (just went offshore, back in 14-15days). Do you want this done, even if my friend gets this initialized from VAG dealer?
Regards
Gremling
That would probably not be particularly helpful. We need to see the state it's in where you "Can't Reset" it.
Gremling
Norway, Nordland
C?ID=319714
Yes HMC, have tried it, I filled in km and time from last service to actual km and days, filled oil quality to good etc. It is only in this specific car this has been a problem. As stated earlier, have used several methods and different types of computer systems to reset SRI. All indications we get is issues with module for SRI is not initialized, which again. started to act up after the environmental software upgrade performed on car at VAG dealer workshop.
Prior to the software upgrade, there has never been issues resetting SRI on this car.
Regards
Gremling
Mike@Gendan
Swansea, UK
C?ID=57030
I don't suppose someone has fiddled with the interval values rather than the distance / time since service values have they?
Kinda hard to tell without seen a channel map. ;)
