2012 VW Passat TDI need help
daisy
C?ID=290770
since April 2019, I have replaced water pump, timing belt, thermostat, radiator fan, transmission temperature sensor and it is still not fixed!
the latest problems with the vehicle is as soon as I turn on the AC the vehicle will start overheating, and by overheating I mean that the temp gauge will begin rising above the middle divider where it should be. There is no leak of antifreeze, the level is in the norm when vehicle is cold.
Also, the transmission would drive perfectly, but only when vehicle is cold. If I need to make a quick stop at the gas station to pump and turn off the vehicle as soon as I start it - it will go into Nutural and then if I turn off the vehicle and start it once more it will drive perfect again.
What the hell is wrong?! any recommendations would be appreciated.
Thursday,05,September,2019,17:54:23:42313
VCDS Version: 19.6.1.0 (x64)
VIN: 1VWCN7A35CC060811   License Plate: 7KQP428
Mileage: 389670km-242129mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 72 77
VIN: 1VWCN7A35CC060811   Mileage: 389670km-242129miles
   Component: R4 2.0l TDI   H21 9982
   Revision: 71H21---    Serial number:
   Coding: 001D0012042400008000
   Shop #: WSC 26061 444 00000
   ROD: EV_ECM20TDI01103L997009J.rod
   VCID: 3B74BECFB2C0E9978C-806E
8215 - Exhaust Gas Recirculation System
          P2457 00 [236] - Insufficient Cooling Performance
                    Fault Frequency: 8
                    Mileage: 389419 km
                    Date: 2019.08.31
                    Time: 10:19:36
                    Engine speed: 1411.50 /min
                    Normed load value: 97.3 %
                    Vehicle speed: 46 km/h
                    Coolant temperature: 104 °C
                    Intake air temperature: 42 °C
                    Voltage terminal 30: 14.000 V
                    Sensor for engine block temperature: raw value: 103.9 °C
                    Exh.gas temp.sen 4: 380.2 °C
                    Exhaust mass flow of low-pressure EGR: 23.6 kg/h
                    Temp sensor for low-pressure EGR after cooler: raw value: 217.8 °C
                    Low-pressure EGR cooling: model temperature: 172.2 °C
                    Low-pressure EGR cooling: request status-Bits 0-7: 1
                    Low-pressure EGR cooling: request status-Bits 0-7: 255
38303 - NOx Sensor 1 Bank 1
          P2201 00 [096] - Implausible Signal
                    Mileage: 388565 km
                    Date: 2019.08.23
                    Time: 16:58:29
                    Engine speed: 0.00 /min
                    Coolant temperature: 98 °C
                    Intake air temperature: 46 °C
                    Voltage terminal 30: 12.880 V
                    Unlearning counter according OBD: 35
                    Air mass: actual value (mg/stroke): 0.0 mg/stroke
                    Mean injection quantity: 0.00 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                    NOx Emission NOx-Sensor: 0 ppm
                    Air mass for release of NOx sensor 1 offset test: 0.0 g
                    Calculated efficiency of NOx conversion: 0.950
Readiness: 1 1 0 0 0
   Part No SW: 02E 300 057 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 9435
   Revision: 05551213    Serial number: 00001112090944
   Shop #: WSC 40321 001 1048576
   VCID: 26427FBB9142447FC3-8072
   Revision: 00H31001
   Coding: C54BC0F5492800FAA31303E5921A0042A71000
   Shop #: WSC 09003 957 00200
   VCID: 7DF070D7E45427A7F2-8028
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 085 0902
   Revision: 00085000    Serial number: 0161487923
   Coding: 130C0C
   VCID: 346695F39F9E26EF4D-8060
1057547 - Antenna for Keyless Entry System; Interior Antenna 1
          B1172 13 [008] - Open Circuit
                    Reset counter: 90
                    Mileage: 388714 km
                    Date: 2019.08.24
                    Time: 09:33:11
   Part No SW: 561 907 044 H    HW: 561 907 044 H
   Component: Climatronic   043 0202
   Revision: 00001001
   Coding: 0010001012
   VCID: 1C365D53170E8EAF65-8048
   Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
   Component: BCM PQ35 H+   121 0164
   Revision: BL121001
   Coding: 6F200E3B982B08D4088802013600814800710086458005F0648060009C70
   VCID: 74E655F3D71E66EF8D-8020
   Component: RLS 030212 05  54  0403
   Coding: 06300A
                    Fault Status: 00101010
                    Reset counter: 94
                    Mileage: 388558 km
                    Date: 2014.01.13
                    Time: 16:49:02
                    Voltage: 13.65 V
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003ENM01EMZ5
   Coding: 00003548
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FEC5A9FB638453770-803A
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H10 0045
   Serial number: 6940000Y120000AUAB0V
   Coding: 303047
   Serial number: 3572MSME326F3068ZZZ-
   Serial number: 3582MSME47507466ZZZX
   Serial number: 3516KSME574E1417ZZZW
   Serial number: 3526KSME23681F16ZZZW
   Serial number: 3556LSME3A201414ZZZJ
   Serial number: 3566LSME34051414ZZZH
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Revision: FF010040    Serial number: 20110729100513
   Coding: 000A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DF070D7EC5427A7F2-8028
   Component: E221__MFL-YVJ  H06 0022
   Coding: E20000
   Part No SW: 561 920 970 C    HW: 561 920 970 C
   Component: KOMBI         H07 0507
   Coding: 231E01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
   VCID: 1A3A5B4B1D3AF09F77-804E
   Part No SW: 7N0 907 530 P    HW: 1K0 907 951
   Component: J533  Gateway H40 1623
   Revision:   H40       Serial number: 07021201290602
   Coding: 461000
   VCID: 3D70B0D7A4D4E7A7B2-8068
   Component: IMMO          H07 0507
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADA4B8B8DDAA01F27-803E
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000274387004
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E52879B71B20C3F3B-807A
   Revision: A1001003    Serial number: 7661543498
   VCID: 29587487405C6B07EE-807C
   Part No SW: 561 959 760     HW: 561 959 760
   Component: MEM-FS        H04 0181
   Revision: AA000000    Serial number: 00000022806321
   Coding: 0000000000000000000000000000000000000000000000
   VCID: 60CE29A373E6EA4FF9-8034
   Part No SW: 3C8 035 684 E    HW: 3C8 035 684 E
   Component: RNS-MID       H61 3690
   Revision: AB001001    Serial number: VWZ6Z7M4047073
   Coding: 04090002010000A6000B
   VCID: 2D50809774B4772702-8078
                    Fault Frequency: 22
                    Reset counter: 94
                    Mileage: 388512 km
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Revision: 12110009    Serial number: 0003494557
   Coding: 0405FD
   ROD: EV_TSGFPQ25BRFVW46X.rod
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
          B11EC 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 92
                    Mileage: 388517 km
                    Date: 2019.08.21
                    Time: 19:14:28
131584 - Motor for Rear Window Regulator
          B11EE 54 [008] - Missing Calibration / Basic Setting
                    Reset counter: 95
                    Mileage: 388517 km
                    Date: 2019.08.21
                    Time: 19:14:28
   Part No: 1K0 909 144 N
   Component: EPS_ZFLS Kl. 290    3301
   Revision: 00H22000
   VCID: 3560A8F75CE43FE77A-8060
   Part No SW: 5C6 035 456     HW: 5C6 035 456
   Component: KonzernAmp10K H07 0468
   Revision: --------    Serial number: EAA083A0006189
   ROD: EV_AudioVerst10KanalSTT3.rod
   VCID: 65C038B764C48F670A-8030
   Component: EZE_2         H40 1623
   Coding: 01030108
   VCID: 6FEC5A9FBE38453770-803A
   Serial number: 53388786011134400591
   Coding: 181100
   Component: Analoguhr  008 0004
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Revision: 14110009    Serial number: 0003546138
   Coding: 0405FC
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1D3050570C1487A792-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
                    Fault Frequency: 22
                    Reset counter: 94
                    Mileage: 388512 km
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661523680
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 275C72BF5E485D77F8-8072
End-------------------------(Elapsed Time: 03:32)--------------------------
RyMar
South Africa
C?ID=133909
Try do read temperatues on engine & gearbox with vehicle idling and aircon off until the rad fan switches on/off? Then switch the aircon on and monitor the temps again? Is there any difference? Also monitor gearbox temperature at idle and after driving a distance?
Does turning on the AC produce the expected/appropriate behavior from the radiator fans?
As for the DSG: It has almost 1/4 million miles on it. What maintenance/ repairs have been done?
